Hello everyone. updated as normal did not even think about it just system restarted on request as normal. until i went to play on our modded minecraft server. minecraft forge reports the following:
Failed to initialize graphics window with current settings.
Failure details:
Failed to find a valid GLFW profile.
We tried 4.6, 4.5, 4.4, 4.3, 4.2, 4.1, 4.0, 3.3, 3.2 but none of them worked.
Trying 4.6: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.5: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.4: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.3: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.2: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.1: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 4.0: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 3.3: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
Trying 3.2: GLFW error: [0x10009]GLX: Failed to find a suitable GLXFBConfig
I’ve tried to do my own research to fix the issue as you know how fun that can be but I feel like I’m missing something fundamental. if i run glxinfo | grep OpenGL i get the following output:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce GTX 1080/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 550.54.14
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 550.54.14
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 550.54.14
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
so OpenGL 4.6 is supported but it can not use it for some reason. though my research i also found mhwd -l is useful and here is that output.
0000:01:00.0 (0300:10de:1b80) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia-390xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
I don’t know much about what I’m looking at here other than the free/not free column. Is it normal to have both 470xx and 390xx at the same time ?
along the same vein as mhwd inxi -gazy is useful. Looking through this I find it interesting that my webcam is listed in the same list as my monitors. Is this a video in/out list more or less?
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: eVga driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1b80 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10.3:10
chip-ID: 046d:082d class-ID: 0102 serial:
Device-3: Microdia Dual Mode Camera (8006 VGA) driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10.4:9
chip-ID: 0c45:8006 class-ID: 0301
Display: x11 server: X v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 81 s-size: 1806x343mm (71.10x13.50")
s-diag: 1838mm (72.37")
Monitor-1: DP-1 pos: right res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: DVI-D-0 pos: left res: 1920x1080 hz: 60 dpi: 82
Monitor-3: HDMI-0 pos: primary,center res: 1920x1080 hz: 60 dpi: 82
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 550.54.14
device-ID: 10de:1b80 surfaces: xcb,xlib
i’ve tried a couple of level 1 stuff restart etc with no joy i know i’m in over my head so any help would be greatly appreciated. thank you for your time.
