Mobile GTX 1070: HDMI monitor not detected with 580xx drivers
EDIT: I run into this problem with a mobile GTX 1070 and an external MSI monitor (hdmi): The monitor is detected without issues under the 570 drivers but not detected with the 580s.
I have found this arch thread that might point to a solution:
https://bbs.archlinux.org/viewtopic.php?id=311143
When I install the 580 drivers with sudo mhwd -i pci video-hybrid-intel-nvidia-580xx-prime it shows missing dkms modules during the install process:
ERROR: module not found: 'nvidia' ==> ERROR: module not found: 'nvidia_drm' ==> ERROR: module not found: 'nvidia_uvm' ==> ERROR: module not found: 'nvidia_modeset'
Any possibility to fix this with bringing dkms-driver version to the manjaro repo? I use KDE Plasma and Wayland.
The general rule is:- One topic per user, per issue.
Your post has been moved to a dedicated topic.
Please provide your system and any other supporting information presented as pre-formatted text in accordance with forum guidelines. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
As far as I’m aware, the Nvidia 580xx drivers should support your GTX 1070 (Nvidia dropped that support with the 590xx series).
With any luck, someone may have a suggestion or two.
FYI, I have set back the system to the former, working state.
inxi -zv8 output:
  Kernel: 6.18.36-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=0b0199d0-0533-4c8b-b2d6-debc77944bf0 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Laptop System: Micro-Star product: GE73 Raider RGB 8RF v: REV:1.0
  Mobo: Micro-Star model: MS-17C5 v: REV:1.0 serial: <superuser required>
    part-nu: 17C5.1 uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: E17C5IMS.10F date: 05/20/2019
  ID-1: BAT1 charge: 32.2 Wh (91%) condition: 35.4/53.2 Wh (66.4%)
    volts: 11.81 min: 10.86 model: MSI BIF0_9 type: Li-ion serial: N/A charging:
    status: not charging cycles: N/A
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 16 GiB available: 15.45 GiB used: 4.56 GiB (29.5%)
  Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43CB1-CTD
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: no module installed
  Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52799
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
    driver: nvidia v: 570.211.01 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: legacy-active (EOL~2028-09-xx) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1ba1
    class-ID: 0300
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:9 chip-ID: 5986:1140
  Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: HDMI-A-1 model: MSI MAG322UPF serial: <filter> built: 2023 res:
    mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 139 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.310 green: x: 0.259 y: 0.655 blue: x: 0.141 y: 0.059 white:
    x: 0.314 y: 0.329 size: 708x399mm (27.87x15.71") diag: 801mm (31.5")
    ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x960, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 97 4: parse_edid:
    unhandled CEA mode 118
  Monitor-2: eDP-1 model: ChiMei InnoLux 0x1747 built: 2016 res: 1920x1080
    dpi: 128 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.263 y: 0.678
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
    modes: 1920x1080
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 26.1.2-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 15.09 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.350 layers: 8 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 630 (CFL GT2) driver: mesa intel v: 26.1.2-arch1.2
    device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1070 driver: nvidia v: 570.211.01
    device-ID: 10de:1ba1 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact, nvidia-settings, nvidia-smi
  Device-1: Intel 300/C240 Series Family HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10f0 class-ID: 0403
  API: ALSA v: k6.18.36-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
  Device-1: Intel 300/C240 Series Family CNVi Wi-Fi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.2.3:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u4u2u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:10
  Local Storage: total: 2.05 TiB used: 1.51 TiB (73.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
    model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: E8FK11.C temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-1: / raw-size: 228.71 GiB size: 228.71 GiB (100.00%)
    used: 107.37 GiB (46.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 0b0199d0-0533-4c8b-b2d6-debc77944bf0
  ID-2: /boot/efi raw-size: 9.77 GiB size: 9.76 GiB (99.90%)
    used: 696 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A5E1-B436
  ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.4 TiB (77.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 95fdb573-393f-48a1-bc85-ec914d509881
  ID-4: /var/cache raw-size: 228.71 GiB size: 228.71 GiB (100.00%)
  ID-5: /var/log raw-size: 228.71 GiB size: 228.71 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.73 GiB used: 1.42 GiB (18.4%)
    priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842
    dev: /dev/zram0
  Device-1: 1-1:2 info: Gudsen HGP Shifter
    type: abstract (modem),CDC-data,HID driver: cdc_acm,hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 346e:001e class-ID: 0300 serial: <filter>
  Hub-2: 1-4:3 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Device-1: 1-4.1:6 info: Keychron Link type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3434:d031 class-ID: 0300
  Hub-3: 1-4.2:8 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Hub-4: 1-4.2.2:12 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-4.2.4:13 info: Logitech USB Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c53f class-ID: 0300
  Device-2: 1-4.2.5:14 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 2109:8817 class-ID: 1100 serial: <filter>
  Device-3: 1-4.5:11 info: VIA Labs USB Billboard Device type: billboard
    mode: 2.0 chip-ID: 2109:8822 class-ID: 1100
  Device-4: 1-6:4 info: SteelSeries ApS ALC type: HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1124 class-ID: 0300
  Device-5: 1-7:5 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-6: 1-9:7 info: SteelSeries ApS KLC type: HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
  Device-7: 1-13:9 info: Bison HD Webcam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:1140 class-ID: 0e02 serial: <filter>
  Device-8: 1-14:10 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-5: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-6: 2-4:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 2109:0822
  Hub-7: 2-4.2:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  Device-1: 2-4.2.3:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
  System Temperatures: cpu: 48.0 C pch: 49.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2271 pm: dpkg pkgs: 0 pm: pacman pkgs: 2223 libs: 464
    tools: octopi,paru,yay pm: flatpak pkgs: 48
    1: https://mirror.23m.com/manjaro/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 386
  1: cpu: 16.5% command: kwin_wayland pid: 1129 mem: 164.9 MiB (1.0%)
  2: cpu: 11.6% command: konsole pid: 42268 mem: 305.6 MiB (1.9%)
  3: cpu: 9.4% command: brave pid: 40979 mem: 302.0 MiB (1.9%)
  4: cpu: 7.4% command: steamwebhelper pid: 35599 mem: 373.9 MiB (2.3%)
  5: cpu: 7.0% command: brave pid: 40681 mem: 670.9 MiB (4.2%)
  Memory top: 5 of 386
  1: mem: 670.9 MiB (4.2%) command: brave pid: 40681 cpu: 7.0%
  2: mem: 373.9 MiB (2.3%) command: steamwebhelper pid: 35599 cpu: 7.4%
  3: mem: 338.2 MiB (2.1%) command: brave pid: 40735 cpu: 3.5%
  4: mem: 326.5 MiB (2.0%) command: steamwebhelper pid: 35512 cpu: 5.1%
  5: mem: 320.3 MiB (2.0%) command: plasmashell pid: 1301 cpu: 0.5%
  Processes: 386 Power: uptime: 3h 33m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.02 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1 default: Bash
    v: 5.3.15 running-in: konsole inxi: 3.3.41
That might be for the best, all things considered.
Without meaning to create any false hope; especially as I have no idea if this would be a working option for your system; but, have you tried the 575xx driver series?
I seem to recall it being suggested for laptop configurations around the same time that the Nvidia driver issues were generally topical.
Same issue with 575 drivers.
So I had set some hope in 580, especially because Manjaro officially dropped 570 and 575 from the repos.
While I have no concrete suggestion to workaround the issue, I have consolidated the following information in case it may be useful for others wishing to help:
Under Notable Package Updates in the Stable Update 2026-07-11 announcement topic, it was stated that:
When packages are from the main repositories they are sometimes dropped to the AUR. However, all I can find is nvidia-575xx-dkms, in this instance:
It’s important to note that this is by no means a recommendation to use these drivers – only informing that they are available.
I have not found 570xx drivers available via the AUR, at this time. Perhaps @philm or @Yochanan might shed some light on this.
Additionally, under Known issues and solutions (on 2026-05-02) in Issues with updating Kernels due to Nvidia drivers:
Also noted was:
So, regardless, users of Nvidia 570xx, 575xx or 580xx series drivers, appear to be limited to kernel 6.18 (LTS) as it is the last kernel series to support those drivers.
Well, I am on kernel version 6.18 and my only issue is the detection of the attached monitor.
The laptop’s internal screen works flawless with 575 and 580 drivers, but the laptop stands on the side of my desk and the attached HDMI screen is usually the only monitor I use. The laptop screen is disabled after booting.
Notice there were some HDMI related issues in 580, cf. NVIDIA Releases Linux Driver 580.105 With HDMI and Game Crash Fixes
Now 580.173.02 is the latest version and should be fixed. However, you’re using an older kernel, so I’m not sure whether the fixes would work in that case. I would try out kernel 7.1 together with linux71-nvidia-580xx.
I updated the kernel to 7.1 and afterwards HDMI detection did not work either. So I just updated the whole system, because I was so annoyed by the situation and then installed the nvidia 580 drivers. Same issue.
Afterwards I re-googled the problem and tried modifying GRUB by adding nvidia-drm.modeset=1 and updating GRUB afterwards.
Before anyone complains now, that this should be a default GRUB entry for a hybrid system => in the past it never worked for me and lead to blackscreens during the boot process.
After updating GRUB and rebooting this time it seems to have fixed my problem. HDMI screen is now detected and my setup is working again.
Thanks to all for the above comments to my problem.
That’s been set by default since the 560xx series and was patched to set it for quite some time before that, by the way:
To verify that DRM is actually enabled, execute the following:
# cat /sys/module/nvidia_drm/parameters/modeset
Which should now return Y, and not N.
That’s probably what actually resolved the issue. :wink:
Well, I am not convinced by that, because I did updating and rebooting - more than once - before and the monitor was not detected then. That is what led to the whole hassle and this thread.
As far as I can tell, the GRUB edit did the trick. Maybe some of my config-files were screwed up before…
This (nvidia-drm.modeset=1) worked for me as well.
  • Up-to-date desktop system with 6.18 kernel
  • GTX 1060 (Pascal)
  • Dell Monitor / Display Port
After updating to driver 580.173.02 the system did boot (into Gnome DM), but only with a low resolution. The Dell display was not recognized and no other resolution could be selected in Manjaro Display Settings. Also, when turning the display ‘off’ and ‘on’, it would not return with any output and fall into display powersave mode.
I did the following:
Modify
/etc/default/grub:
GRUB_CMDLINE_LINUX=“nvidia-drm.modeset=1”
Run
$ sudo grub-mkconfig -o /boot/grub/grub.cfg
…and reboot.
$ sudo cat /sys/module/nvidia_drm/parameters/modeset now returns ‘Y’ instead of ‘N’.
Turns out the 580 series still needs the patch… :face_with_peeking_eye:
Fixed with 580.178.04 packages coming along later on in the Manjaro Unstable branch.
