I’d like to use mmv but it seems that the package isn’t available for manjaro.
*sudo pacman -S mmv > error: can’t find the target
Hi @bilem,
mmvv
is an AUR package:
$ pamac search mmv
mmv 1.01b.orig-4 AUR
multiple move files (version with debian patches)
… and pacman cannot install AUR packages. So I think you meant:
pamac build mmv
More information:
Thank you Mirdarthos for your answer. I am not esperimented in manjaro.
If I type in pamac search mmv I do not see the mmv package.
Nevertheless, I tried sudo pamac build mmv but at a point, I have an error:
==> lauching prepare()…
/var/cache/private/pamac/mmv/PKGBUILD: line 32: patch : command not found
==> ERROR: An error occured in prepare().
Abandon…
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 5.898s
CPU time consumed: 4.320s
What does that mean?
I might be wrong, but I suspect you need the base-devel package as well as the kernel headers:
pamac install base-devel
This will install base-devel.
This will install headers for the currently installed kernels:
pamac install $(pamac list --installed --quiet | grep "^linux" | grep "^linux[0-9]*[-rt]*$" | awk '{print $1"-headers"}' ORS=' ')
And after a reboot, which I don’t know if it’s strictly necessary (I doubt it), you can try installing mmv again:
pamac build mmv
Wonderful! After having applied these two command lines, I was able to get mmv. Thanks a lot, Mirdarthos, for your input.
Best regards. Bilem
Just a reminder, do not use sudo pamac
Pamac will ask you for the password when it needs it.
Thank you for the advice ydar!
