After receiving the following error my system video freezes, audio keeps working:
set 21 17:11:10 rohan kernel: NVRM: Xid (PCI:0000:01:00): 31, pid=5273, name=Renderer, Ch 00000040, intr 00000000. MMU Fault: ENGINE HOST0 HUBCLIENT_ESC faulted @ 0x0_00000000. Fault is of type FAULT_PDE ACCESS_TYPE_VIRT_READ
Relevant info:
inxi -Fxzi
Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.25.5 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.D0
date: 01/19/2021
Info: 6-core model: Intel Core i5-9600K bits: 64 type: MCP
arch: Coffee Lake rev: C cache: L1: 384 KiB L2: 1.5 MiB L3: 9 MiB
Speed (MHz): avg: 1283 high: 3700 min/max: 800/4700 cores: 1: 800 2: 800
3: 800 4: 800 5: 3700 6: 800 bogomips: 44412
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com.
driver: nvidia v: 515.65.01 arch: Ampere bus-ID: 01:00.0
Device-3: Logitech Logitech Webcam C925e type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-9.4:9
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: nvidia gpu: i915,nvidia resolution: 2560x1440
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-9.3:7 bus-ID: 00:1f.3
Device-2: NVIDIA GA106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: Bose PC Desktop Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech Logitech Webcam C925e type: USB
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-13:5
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 2.67 TiB used: 313.57 GiB (11.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
temp: 32.9 C
ID-2: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
temp: 25 C
ID-3: /dev/sdb vendor: A-Data model: SU630 size: 447.13 GiB temp: 29 C
ID-4: /dev/sdc vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB
ID-5: /dev/sdd vendor: Kingston model: SA400S37480G size: 447.13 GiB
temp: 30 C
ID-1: / size: 439.04 GiB used: 276.47 GiB (63.0%) fs: ext4 dev: /dev/sdd1
ID-2: /boot/efi size: 96 MiB used: 37.4 MiB (38.9%) fs: vfat
dev: /dev/sdc2
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 32.0 C pch: 39.0 C mobo: N/A gpu: nvidia
temp: 49 C
Processes: 249 Uptime: 23m Memory: 31.27 GiB used: 5.44 GiB (17.4%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2039
Shell: Bash v: 5.1.16 inxi: 3.3.21
This is not happening on all systems, but was discussed in the past on Nvidia developer forum
I’m not even sure that Nvidia is aware about this, but there has been a big community behind Valve’s new Proton software that allows to play Windows games on Linux. Sadly, the Nvidia driver on Linux is still not stable enough for many of those...
Reading time: 3 mins đź•‘
Likes: 4 ❤
Somebody else mentioned the second part of the error you got
opened 09:27AM - 04 Mar 22 UTC
We have 6 RTX 3060ti GPU rig for Ethereum mining on hiveos. GPUs are randomly cr… ashing with Trex latest miner. Errors are "FAULT_PDE ACCESS_TYPE_VIRT_READ", "NVRM XID PCIE (Number) MMU Fault: ENGINE GRAPHICS GPCCLIENT FAULTED", "GRAPHICS SM WARP EXCEPTION ILLEGAL INSTRUCTION ENCODING". GPUs goes into sleep mode. Only after restarting miner, its functional. We tried updating of Hiveos to latest, power off and On cycle. But no luck. It happens every 8-10 hrs on different gpus. We changed to latest Gminer and rig stable for almost 3 days now.
Since you are on a desktop PC, and from what i see you have the Monitor connected to the Nvidia GPU, why don’t you disable the iGPU from BIOS?
and make sure you don’t use the hybrid driver but video-nvidia
vfbsilva:
audio keeps working
but on what server?
right now are both running it seems.
Care to share the content of /etc/X11/mhwd.d/nvidia.conf ?
Xorg files
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 455.45.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
I have the iGPU. I tough I had disable it on the bios but since i updated the bios to use resizable bar seems I can no longer find how to disable it. Its a gigabyte z390. If anyone can give me some pointers of how to disable it I would be grateful.
What i would do, is enable early KMS. Edit the /etc/mkinitcpio.conf and make the MODULES line like this:
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
Then edit /etc/default/grub and make the GRUB_CMDLINE_LINUX line like
GRUB_CMDLINE_LINUX="nvidia-drm.modeset=1"
From terminal run:
sudo mkinitcpio -P
sudo update-grub
You could also make the Section “Device” look like this in your /etc/X11/mhwd.d/nvidia.conf
Section "Device"
Driver "nvidia"
Option "ConnectToAcpid" "Off"
Option "metamodes" "nvidia-auto-select +0+0 {ForceFullCompositionPipeline=On}"
EndSection
Reboot and see if this helps.
In some cases can be used also
Option "TripleBuffer" "On"
right under VendorName line and then create a file /etc/profile.d/kwin.sh with this content:
export KWIN_TRIPLE_BUFFER=1
Or you can use:
export __GL_YIELD=USLEEP
export __GL_MaxFramesAllowed=1
I just made the modifications. When I rebuild the modules I get the following error:
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.19-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> ERROR: '/lib/modules/5.7.19-2-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
Can I just remove that file? This kernel is not even listed in the available kernels.
Of course that kernel is EOL for quite some time. Best to remove it via this command
sudo mhwd-kernel -r linux57
Error: Kernel not installed.
Currently running: 5.19.7-1-MANJARO (linux519)
* linux515
* linux519
vfbsilva@rohan ~
well … then manual cleanup, but to be honest, not sure how that rogue /lib/modules/5.7 could have happen.
I don´t have a 5.7 folder it had a .old that I just removed.
For some reason I had a dangling:
I just removed it and the error is gone.
system
Closed
6 October 2022 20:18
10
