"mmc0: timeout waiting for hardware interrupt" error loop during shutdown or restart
Hello,
I am encountering an issue where during shutdown or restart, the error “mmc0: timeout waiting for hardware interrupt” loops during the shutdown process, it does not end and I have to manually power off. The issue is present on both 610 and 66. I understand the issue relates to the micro sd card reader, but the computer reads and uses the micro sd card just fine during normal computer use. Its only a problem during shutdown. Is there a way to prevent the error loop or at least let the computer know to ignore the issue and shutdown instead of loop endlessly?
Not a arm computer, inxi results:
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
    root=UUID=715001f0-ad91-42ab-a8d2-08bf1db8716e rw rootflags=subvol=@ quiet
    splash udev.log_priority=3 pci=nommconf
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Laptop System: GPD product: WIN2 v: N/A serial: <superuser required>
  Mobo: GPD model: WIN2 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: 2.13 date: 12/16/2019
  ID-1: BAT0 charge: 31.2 Wh (84.1%) condition: 37.1/37.2 Wh (99.7%)
    power: 4.7 W volts: 8.1 min: 7.6 model: Intel SR 1 SR Real Battery
    type: Unknown serial: <filter> status: discharging
  Info: model: Intel Core m3-8100Y bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check level: v3 note: check built: 2017 process: Intel 14nm family: 6
    model-id: 0x8E (142) stepping: 9 microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 800 min/max: 400/3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 12805
    vulnerable
  Device-1: Intel UHD Graphics 615 driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:591c
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
    s-diag: 388mm (15.27")
  Monitor-1: eDP-1 res: 1280x720 hz: 60 size: N/A modes: 720x1280
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 615 (AML-KBL)
    device-ID: 8086:591c memory: 3.75 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 615 (AML-KBL) driver: mesa intel v: 24.1.6-arch1.1
    device-ID: 8086:591c surfaces: xcb,xlib
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Realtek
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2a
    class-ID: e001
  Local Storage: total: 1.4 TiB used: 1.12 TiB (80.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS512GMTS430S
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: TBD1 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Generic model: SD MMC size: 953.55 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00
    scheme: MBR
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 396.72 GiB (83.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
    used: 576 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 511.8 MiB (100.0%) priority: -2
    file: /swap/swapfile
  System Temperatures: cpu: 46.0 C pch: 44.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.68 GiB used: 2.76 GiB (35.9%)
  Processes: 213 Power: uptime: 22m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 1465 pm: pacman pkgs: 1459 libs: 452 tools: pamac pm: flatpak
    pkgs: 6 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: konsole inxi: 3.3.36
Not sure how to get the text from the error, here is a picture of the error:
That looks a bit suspicious. In my case:
sudo du -h /var/log/
[sudo] password for brian:
4.0K    /var/log/private
4.0K    /var/log/passim
4.0K    /var/log/gssproxy
4.0K    /var/log/old
116M    /var/log/atop
4.0K    /var/log/samba/cores/smbd
4.0K    /var/log/samba/cores/samba-dcerpcd
4.0K    /var/log/samba/cores/nmbd
4.0K    /var/log/samba/cores/rpcd_lsad
4.0K    /var/log/samba/cores/samba-bgqd
24K     /var/log/samba/cores
1.5M    /var/log/samba
4.0K    /var/log/audit
4.0K    /var/log/journal/remote
971M    /var/log/journal/d86a9b1dc6ed4d73a4dce801826c9e63
100K    /var/log/cups
1.1G    /var/log/
What is in those huge logs? … look at the last few dozen entries or so, might be a clue in there.
I don’t have a separate partition for /var … by the way.
Also, worth noting I am not using btrfs so can not offer any advice with that aspect.
He uses btrfs, and all volumes use the same shared space by default.
dmesg is the command you want for kernel output.
There might be more useful information in your regular logs.
Can you unmount and mount this device yourself? (While watching logs: journalctl -f)
You can also use journalctl -b -1 -p3 to see the previous boot for errors. (-p4 for warnings and up, etc…)
dmesg
[    0.106875] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.106876] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.106877] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.106883] MDS: Mitigation: Clear CPU buffers
[    0.106884] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.106887] SRBDS: Mitigation: Microcode
[    0.106892] GDS: Mitigation: Microcode
[    0.106897] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.106898] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.106899] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.106900] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.106902] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.106903] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.106905] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.106906] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.106907] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.110118] Freeing SMP alternatives memory: 40K
[    0.110118] pid_max: default: 32768 minimum: 301
[    0.110118] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[    0.110118] landlock: Up and running.
[    0.110118] Yama: becoming mindful.
[    0.110118] LSM support for eBPF active
[    0.110118] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.110118] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.110118] smpboot: CPU0: Intel(R) Core(TM) m3-8100Y CPU @ 1.10GHz (family: 0x6, model: 0x8e, stepping: 0x9)
[    0.110118] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.110118] ... version:                4
[    0.110118] ... bit width:              48
[    0.110118] ... generic registers:      4
[    0.110118] ... value mask:             0000ffffffffffff
[    0.110118] ... max period:             00007fffffffffff
[    0.110118] ... fixed-purpose events:   3
[    0.110118] ... event mask:             000000070000000f
[    0.110118] signal: max sigframe size: 2032
[    0.110118] Estimated ratio of average max frequency by base frequency (times 1024): 1728
[    0.110118] rcu: Hierarchical SRCU implementation.
[    0.110118] rcu:     Max phase no-delay instances is 1000.
[    0.110118] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.110118] smp: Bringing up secondary CPUs ...
[    0.110118] smpboot: x86: Booting SMP configuration:
[    0.110118] .... node  #0, CPUs:      #1 #2 #3
[    0.114097] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.114097] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.114097] smp: Brought up 1 node, 4 CPUs
[    0.114097] smpboot: Total of 4 processors activated (12804.00 BogoMIPS)
[    0.117188] devtmpfs: initialized
[    0.117188] x86/mm: Memory block size: 128MB
[    0.117696] ACPI: PM: Registering ACPI NVS region [mem 0x86600000-0x86600fff] (4096 bytes)
[    0.117696] ACPI: PM: Registering ACPI NVS region [mem 0x8ca60000-0x8cabffff] (393216 bytes)
[    0.117696] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.117696] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.117696] pinctrl core: initialized pinctrl subsystem
[    0.117696] PM: RTC time: 16:02:36, date: 2024-09-16
[    0.117696] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.117917] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.117989] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.118060] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.118071] audit: initializing netlink subsys (disabled)
[    0.118079] audit: type=2000 audit(1726502556.009:1): state=initialized audit_enabled=0 res=1
[    0.118079] thermal_sys: Registered thermal governor 'fair_share'
[    0.118079] thermal_sys: Registered thermal governor 'bang_bang'
[    0.118079] thermal_sys: Registered thermal governor 'step_wise'
[    0.118079] thermal_sys: Registered thermal governor 'user_space'
[    0.118079] thermal_sys: Registered thermal governor 'power_allocator'
[    0.118163] cpuidle: using governor ladder
[    0.118163] cpuidle: using governor menu
[    0.118163] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.118163] PCI: Using configuration type 1 for base access
[    0.118163] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.123485] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.123485] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.123485] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.123485] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.123501] Demotion targets for Node 0: null
[    0.123574] ACPI: Added _OSI(Module Device)
[    0.123576] ACPI: Added _OSI(Processor Device)
[    0.123578] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.123579] ACPI: Added _OSI(Processor Aggregator Device)
[    0.175768] ACPI: 13 ACPI AML tables successfully acquired and loaded
[    0.184323] ACPI: Dynamic OEM Table Load:
[    0.184332] ACPI: SSDT 0xFFFF9CD3C1333C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.186037] ACPI: Dynamic OEM Table Load:
[    0.186043] ACPI: SSDT 0xFFFF9CD3C137E800 000507 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.188840] ACPI: Dynamic OEM Table Load:
[    0.188847] ACPI: SSDT 0xFFFF9CD3C0EE8000 000D14 (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.191497] ACPI: Dynamic OEM Table Load:
[    0.191502] ACPI: SSDT 0xFFFF9CD3C1330800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.193203] ACPI: Dynamic OEM Table Load:
[    0.193209] ACPI: SSDT 0xFFFF9CD3C1333800 00030A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.197313] ACPI: _OSC evaluated successfully for all CPUs
[    0.197529] ACPI: EC: EC started
[    0.197530] ACPI: EC: interrupt blocked
[    0.203707] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.203710] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transactions
[    0.203712] ACPI: Interpreter enabled
[    0.203756] ACPI: PM: (supports S0 S3 S4 S5)
[    0.203758] ACPI: Using IOAPIC for interrupt routing
[    0.205826] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.205828] PCI: Using E820 reservations for host bridge windows
[    0.207198] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.214313] ACPI: \_SB_.PCI0.RP09.PXSX.WRST: New power resource
[    0.244782] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.244791] acpi PNP0A08:00: _OSC: OS supports [ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.244794] acpi PNP0A08:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
[    0.244935] acpi PNP0A08:00: MMCONFIG is disabled, can't access extended configuration space under this bridge
[    0.246185] PCI host bridge to bus 0000:00
[    0.246188] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.246191] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.246194] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000fffff window]
[    0.246196] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[    0.246198] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.246200] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.246302] pci 0000:00:00.0: [8086:590c] type 00 class 0x060000 conventional PCI endpoint
[    0.246401] pci 0000:00:02.0: [8086:591c] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[    0.246411] pci 0000:00:02.0: BAR 0 [mem 0xde000000-0xdeffffff 64bit]
[    0.246419] pci 0000:00:02.0: BAR 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.246424] pci 0000:00:02.0: BAR 4 [io  0xf000-0xf03f]
[    0.246443] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.246668] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000 conventional PCI endpoint
[    0.246679] pci 0000:00:04.0: BAR 0 [mem 0xdf120000-0xdf127fff 64bit]
[    0.247075] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330 conventional PCI endpoint
[    0.247101] pci 0000:00:14.0: BAR 0 [mem 0xdf110000-0xdf11ffff 64bit]
[    0.247179] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.248055] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000 conventional PCI endpoint
[    0.248075] pci 0000:00:14.2: BAR 0 [mem 0xdf13c000-0xdf13cfff 64bit]
[    0.248362] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000 conventional PCI endpoint
[    0.248571] pci 0000:00:15.0: BAR 0 [mem 0xdf13b000-0xdf13bfff 64bit]
[    0.249853] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000 conventional PCI endpoint
[    0.250062] pci 0000:00:15.1: BAR 0 [mem 0xdf13a000-0xdf13afff 64bit]
[    0.251327] pci 0000:00:15.2: [8086:9d62] type 00 class 0x118000 conventional PCI endpoint
[    0.251535] pci 0000:00:15.2: BAR 0 [mem 0xdf139000-0xdf139fff 64bit]
[    0.252694] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000 conventional PCI endpoint
[    0.252717] pci 0000:00:16.0: BAR 0 [mem 0xdf138000-0xdf138fff 64bit]
[    0.252800] pci 0000:00:16.0: PME# supported from D3hot
[    0.253257] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601 conventional PCI endpoint
[    0.253273] pci 0000:00:17.0: BAR 0 [mem 0xdf130000-0xdf131fff]
[    0.253282] pci 0000:00:17.0: BAR 1 [mem 0xdf137000-0xdf1370ff]
[    0.253290] pci 0000:00:17.0: BAR 2 [io  0xf090-0xf097]
[    0.253299] pci 0000:00:17.0: BAR 3 [io  0xf080-0xf083]
[    0.253307] pci 0000:00:17.0: BAR 4 [io  0xf060-0xf07f]
[    0.253316] pci 0000:00:17.0: BAR 5 [mem 0xdf136000-0xdf1367ff]
[    0.253366] pci 0000:00:17.0: PME# supported from D3hot
[    0.253743] pci 0000:00:1d.0: [8086:9d18] type 01 class 0x060400 PCIe Root Port
[    0.253770] pci 0000:00:1d.0: PCI bridge to [bus 01]
[    0.253777] pci 0000:00:1d.0:   bridge window [mem 0xdf000000-0xdf0fffff]
[    0.253838] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.254656] pci 0000:00:1e.0: [8086:9d27] type 00 class 0x118000 conventional PCI endpoint
[    0.254870] pci 0000:00:1e.0: BAR 0 [mem 0xdf135000-0xdf135fff 64bit]
[    0.256025] pci 0000:00:1e.4: [8086:9d2b] type 00 class 0x080501 conventional PCI endpoint
[    0.256047] pci 0000:00:1e.4: BAR 0 [mem 0xdf134000-0xdf134fff 64bit]
[    0.256875] pci 0000:00:1e.6: [8086:9d2d] type 00 class 0x080501 conventional PCI endpoint
[    0.256896] pci 0000:00:1e.6: BAR 0 [mem 0xdf133000-0xdf133fff 64bit]
[    0.257324] pci 0000:00:1f.0: [8086:9d4b] type 00 class 0x060100 conventional PCI endpoint
[    0.257773] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000 conventional PCI endpoint
[    0.257788] pci 0000:00:1f.2: BAR 0 [mem 0xdf12c000-0xdf12ffff]
[    0.258132] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040300 conventional PCI endpoint
[    0.258154] pci 0000:00:1f.3: BAR 0 [mem 0xdf128000-0xdf12bfff 64bit]
[    0.258182] pci 0000:00:1f.3: BAR 4 [mem 0xdf100000-0xdf10ffff 64bit]
[    0.258237] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.259127] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500 conventional PCI endpoint
[    0.259186] pci 0000:00:1f.4: BAR 0 [mem 0xdf132000-0xdf1320ff 64bit]
[    0.259258] pci 0000:00:1f.4: BAR 4 [io  0xf040-0xf05f]
[    0.259966] pci 0000:01:00.0: [8086:095a] type 00 class 0x028000 PCIe Endpoint
[    0.260051] pci 0000:01:00.0: BAR 0 [mem 0xdf000000-0xdf001fff 64bit]
[    0.260350] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.261241] pci 0000:00:1d.0: PCI bridge to [bus 01]
[    0.264372] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[    0.264462] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.264551] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    0.264639] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[    0.264727] ACPI: PCI: Interrupt link LNKE configured for IRQ 11
[    0.264815] ACPI: PCI: Interrupt link LNKF configured for IRQ 11
[    0.264903] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.264991] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[    0.269226] ACPI: EC: interrupt unblocked
[    0.269228] ACPI: EC: event unblocked
[    0.270119] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.270119] ACPI: EC: GPE=0x50
[    0.270119] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC initialization complete
[    0.270119] ACPI: \_SB_.PCI0.LPCB.H_EC: EC: Used to handle transactions and events
[    0.270148] iommu: Default domain type: Translated
[    0.270148] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.270290] SCSI subsystem initialized
[    0.270296] libata version 3.00 loaded.
[    0.270296] ACPI: bus type USB registered
[    0.270296] usbcore: registered new interface driver usbfs
[    0.270296] usbcore: registered new interface driver hub
[    0.270296] usbcore: registered new device driver usb
[    0.270296] EDAC MC: Ver: 3.0.0
[    0.270540] efivars: Registered efivars operations
[    0.270540] NetLabel: Initializing
[    0.270540] NetLabel:  domain hash size = 128
[    0.270540] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.270540] NetLabel:  unlabeled traffic allowed by default
[    0.270540] mctp: management component transport protocol core
[    0.270540] NET: Registered PF_MCTP protocol family
[    0.270540] PCI: Using ACPI for IRQ routing
[    0.270540] PCI: pci_cache_line_size set to 64 bytes
[    0.270879] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.270882] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.270883] e820: reserve RAM buffer [mem 0x86600000-0x87ffffff]
[    0.270884] e820: reserve RAM buffer [mem 0x88c3d000-0x8bffffff]
[    0.270886] e820: reserve RAM buffer [mem 0x8aa1a000-0x8bffffff]
[    0.270887] e820: reserve RAM buffer [mem 0x8be11000-0x8bffffff]
[    0.270889] e820: reserve RAM buffer [mem 0x8cfff000-0x8fffffff]
[    0.270890] e820: reserve RAM buffer [mem 0x26f000000-0x26fffffff]
[    0.270931] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.270931] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.270931] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.270931] vgaarb: loaded
[    0.270931] clocksource: Switched to clocksource tsc-early
[    0.270985] VFS: Disk quotas dquot_6.6.0
[    0.270994] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.271080] pnp: PnP ACPI init
[    0.271325] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.271325] system 00:00: [io  0xffff] has been reserved
[    0.271325] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.271325] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.271461] system 00:02: [io  0x1854-0x1857] has been reserved
[    0.272586] system 00:03: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.272589] system 00:03: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.272592] system 00:03: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.272595] system 00:03: [mem 0xe0000000-0xefffffff] has been reserved
[    0.272597] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.272599] system 00:03: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.272601] system 00:03: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.272603] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[    0.272605] system 00:03: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.272607] system 00:03: [mem 0xdffe0000-0xdfffffff] has been reserved
[    0.272656] system 00:04: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.272659] system 00:04: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.272661] system 00:04: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.272663] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.272665] system 00:04: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.272667] system 00:04: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.272669] system 00:04: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.273028] system 00:05: [io  0xff00-0xfffe] has been reserved
[    0.274475] system 00:06: [mem 0xfe029000-0xfe029fff] has been reserved
[    0.274478] system 00:06: [mem 0xfe028000-0xfe028fff] has been reserved
[    0.275315] pnp: PnP ACPI: found 7 devices
[    0.281720] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.281788] NET: Registered PF_INET protocol family
[    0.281872] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.298813] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.298842] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.298871] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.299060] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.299315] TCP: Hash tables configured (established 65536 bind 65536)
[    0.299389] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    0.299425] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.299449] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.299514] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.299523] NET: Registered PF_XDP protocol family
[    0.299541] pci 0000:00:1d.0: PCI bridge to [bus 01]
[    0.299557] pci 0000:00:1d.0:   bridge window [mem 0xdf000000-0xdf0fffff]
[    0.299565] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.299568] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.299569] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000fffff window]
[    0.299571] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[    0.299573] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.299575] pci_bus 0000:01: resource 1 [mem 0xdf000000-0xdf0fffff]
[    0.300420] PCI: CLS 64 bytes, default 64
[    0.300485] pci 0000:00:1f.1: [8086:9d20] type 00 class 0x058000 conventional PCI endpoint
[    0.300550] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    0.300829] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.300830] software IO TLB: mapped [mem 0x0000000080dcb000-0x0000000084dcb000] (64MB)
[    0.300875] Trying to unpack rootfs image as initramfs...
[    0.310175] Initialise system trusted keyrings
[    0.310186] Key type blacklist registered
[    0.310240] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    0.310251] zbud: loaded
[    0.310351] fuse: init (API version 7.40)
[    0.310437] integrity: Platform Keyring initialized
[    0.310439] integrity: Machine keyring initialized
[    0.324766] Key type asymmetric registered
[    0.324771] Asymmetric key parser 'x509' registered
[    0.324811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.324883] io scheduler mq-deadline registered
[    0.324886] io scheduler kyber registered
[    0.324900] io scheduler bfq registered
[    0.325411] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.326632] ACPI: AC: AC Adapter [ADP1] (off-line)
[    0.326697] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C09:00/PNP0C0D:00/input/input0
[    0.329542] ACPI: button: Lid Switch [LID0]
[    0.329613] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[    0.329637] ACPI: button: Sleep Button [SLPB]
[    0.329664] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    0.329681] ACPI: button: Power Button [PWRB]
[    0.329713] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.329765] ACPI: button: Power Button [PWRF]
[    0.330094] ACPI: thermal: [Firmware Bug]: No valid trip points!
[    0.330136] thermal LNXTHERM:00: registered as thermal_zone0
[    0.330138] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    0.330173] ACPI: thermal: [Firmware Bug]: No valid trip points!
[    0.330198] thermal LNXTHERM:01: registered as thermal_zone1
[    0.330200] ACPI: thermal: Thermal Zone [TZ01] (28 C)
[    0.330472] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.335137] hpet_acpi_add: no address or irqs in _CRS
[    0.335220] Non-volatile memory driver v1.3
[    0.335223] Linux agpgart interface v0.103
[    0.402349] Freeing initrd memory: 28764K
[    0.408901] ACPI: bus type drm_connector registered
[    0.423140] ahci 0000:00:17.0: version 3.0
[    0.423432] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    0.423436] ahci 0000:00:17.0: 2/2 ports implemented (port mask 0x3)
[    0.423438] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    0.423782] scsi host0: ahci
[    0.423902] scsi host1: ahci
[    0.423955] ata1: SATA max UDMA/133 abar m2048@0xdf136000 port 0xdf136100 irq 121 lpm-pol 3
[    0.423959] ata2: SATA max UDMA/133 abar m2048@0xdf136000 port 0xdf136180 irq 121 lpm-pol 3
[    0.424075] usbcore: registered new interface driver usbserial_generic
[    0.424082] usbserial: USB Serial support registered for generic
[    0.424198] rtc_cmos 00:01: RTC can wake from S4
[    0.424923] rtc_cmos 00:01: registered as rtc0
[    0.425061] rtc_cmos 00:01: setting system clock to 2024-09-16T16:02:36 UTC (1726502556)
[    0.425099] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[    0.426291] intel_pstate: Intel P-state driver initializing
[    0.426426] intel_pstate: HWP enabled
[    0.431713] ledtrig-cpu: registered to indicate activity on CPUs
[    0.432162] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.432557] fbcon: Deferring console take-over
[    0.432561] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.432619] hid: raw HID events driver (C) Jiri Kosina
[    0.432702] drop_monitor: Initializing network drop monitor service
[    0.432813] NET: Registered PF_INET6 protocol family
[    0.439919] Segment Routing with IPv6
[    0.439923] RPL Segment Routing with IPv6
[    0.439937] In-situ OAM (IOAM) with IPv6
[    0.439967] NET: Registered PF_PACKET protocol family
[    0.440314] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.440424] microcode: Current revision: 0x000000f6
[    0.440427] microcode: Updated early from: 0x00000098
[    0.440613] IPI shorthand broadcast: enabled
[    0.442426] sched_clock: Marking stable (434421716, 6168260)->(475558807, -34968831)
[    0.442603] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.442642] registered taskstats version 1
[    0.442841] Loading compiled-in X.509 certificates
[    0.446190] Loaded X.509 cert 'Build time autogenerated kernel key: 4cb8e78aea5d64cff207f605a8f08f587704ad17'
[    0.449822] zswap: loaded using pool zstd/zsmalloc
[    0.449892] Demotion targets for Node 0: null
[    0.450201] Key type .fscrypt registered
[    0.450203] Key type fscrypt-provisioning registered
[    0.452026] PM:   Magic number: 8:878:34
[    0.452103] workqueue blkcg_punt_bio: hash matches
[    0.452110] memory memory70: hash matches
[    0.456411] RAS: Correctable Errors collector initialized.
[    0.470032] clk: Disabling unused clocks
[    0.470037] PM: genpd: Disabling unused power domains
[    0.493580] ACPI: battery: Slot [BAT0] (battery present)
[    0.733262] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.733307] ata1: SATA link down (SStatus 4 SControl 300)
[    0.773930] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20240322/psargs-330)
[    0.773959] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[    0.774045] ata2.00: ATA-9: TS512GMTS430S, 02J0TBD1, max UDMA/133
[    0.774171] ata2.00: 1000215216 sectors, multi 2: LBA48 NCQ (depth 32), AA
[    0.775023] ata2.00: Features: Dev-Sleep
[    0.775449] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20240322/psargs-330)
[    0.775475] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
[    0.776090] ata2.00: configured for UDMA/133
[    0.786653] scsi 1:0:0:0: Direct-Access     ATA      TS512GMTS430S    TBD1 PQ: 0 ANSI: 5
[    0.787473] sd 1:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
[    0.787501] sd 1:0:0:0: [sda] Write Protect is off
[    0.787509] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.787538] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.787589] sd 1:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[    1.307795]  sda: sda1 sda2
[    1.308139] sd 1:0:0:0: [sda] Attached SCSI disk
[    1.309559] tsc: Refined TSC clocksource calibration: 1608.003 MHz
[    1.309579] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x172dacfb38b, max_idle_ns: 440795204692 ns
[    1.309628] clocksource: Switched to clocksource tsc
[    1.311357] Freeing unused decrypted memory: 2028K
[    1.312489] Freeing unused kernel image (initmem) memory: 3444K
[    1.312665] Write protecting the kernel read-only data: 32768k
[    1.313760] Freeing unused kernel image (rodata/data gap) memory: 816K
[    1.358241] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.358246] rodata_test: all tests were successful
[    1.358247] x86/mm: Checking user space page tables
[    1.400721] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.400726] Run /init as init process
[    1.400727]   with arguments:
[    1.400729]     /init
[    1.400730]     splash
[    1.400731]   with environment:
[    1.400732]     HOME=/
[    1.400732]     TERM=linux
[    1.400733]     BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
[    1.834154] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.834168] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.835306] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    1.836077] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.836083] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.836088] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.839608] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    1.839615] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.839618] usb usb1: Product: xHCI Host Controller
[    1.839621] usb usb1: Manufacturer: Linux 6.10.6-10-MANJARO xhci-hcd
[    1.839623] usb usb1: SerialNumber: 0000:00:14.0
[    1.839960] hub 1-0:1.0: USB hub found
[    1.839989] hub 1-0:1.0: 12 ports detected
[    1.850220] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    1.850228] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.850231] usb usb2: Product: xHCI Host Controller
[    1.850234] usb usb2: Manufacturer: Linux 6.10.6-10-MANJARO xhci-hcd
[    1.850237] usb usb2: SerialNumber: 0000:00:14.0
[    1.851025] hub 2-0:1.0: USB hub found
[    1.851050] hub 2-0:1.0: 6 ports detected
[    1.862802] sdhci: Secure Digital Host Controller Interface driver
[    1.862807] sdhci: Copyright(c) Pierre Ossman
[    1.878706] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    1.878705] sdhci-pci 0000:00:1e.4: SDHCI controller found [8086:9d2b] (rev 21)
[    1.880621] mmc1: SDHCI controller on PCI [0000:00:1e.4] using ADMA 64-bit
[    1.880682] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.060913] mmc1: Failed to initialize a non-removable card
[    2.099545] usb 1-2: new low-speed USB device number 2 using xhci_hcd
[    2.249028] usb 1-2: New USB device found, idVendor=258a, idProduct=6a99, bcdDevice= 1.00
[    2.249032] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.249035] usb 1-2: Product: USB KEYBOARD
[    2.249037] usb 1-2: Manufacturer: HK-ZYYK-US-A1-02-00
[    2.250417] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.363077] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[    2.388253] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.391467] usb 2-1: New USB device found, idVendor=0bda, idProduct=0316, bcdDevice= 2.04
[    2.391471] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.391473] usb 2-1: Product: USB3.0-CRW
[    2.391474] usb 2-1: Manufacturer: Generic
[    2.391475] usb 2-1: SerialNumber: 20120501030900000
[    2.397017] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.399401] usbcore: registered new interface driver usbhid
[    2.399406] usbhid: USB HID core driver
[    2.399419] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.404695] usb-storage 2-1:1.0: USB Mass Storage device detected
[    2.404858] scsi host2: usb-storage 2-1:1.0
[    2.404950] usbcore: registered new interface driver usb-storage
[    2.405071] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.405671] input: HK-ZYYK-US-A1-02-00 USB KEYBOARD as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:258A:6A99.0001/input/input4
[    2.409707] usbcore: registered new interface driver uas
[    2.430087] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.432664] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.434043] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    2.460057] hid-generic 0003:258A:6A99.0001: input,hidraw0: USB HID v1.10 Keyboard [HK-ZYYK-US-A1-02-00 USB KEYBOARD] on usb-0000:00:14.0-2/input0
[    2.460175] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.460510] input: HK-ZYYK-US-A1-02-00 USB KEYBOARD Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:258A:6A99.0002/input/input5
[    2.460673] input: HK-ZYYK-US-A1-02-00 USB KEYBOARD System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:258A:6A99.0002/input/input6
[    2.506213] usb 1-3: new full-speed USB device number 3 using xhci_hcd
[    2.516565] input: HK-ZYYK-US-A1-02-00 USB KEYBOARD Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:258A:6A99.0002/input/input7
[    2.516802] input: HK-ZYYK-US-A1-02-00 USB KEYBOARD Wireless Radio Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:258A:6A99.0002/input/input8
[    2.517359] hid-generic 0003:258A:6A99.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HK-ZYYK-US-A1-02-00 USB KEYBOARD] on usb-0000:00:14.0-2/input1
[    2.517480] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.565867] raid6: skipped pq benchmark and selected avx2x4
[    2.565872] raid6: using avx2x2 recovery algorithm
[    2.571897] xor: automatically using best checksumming function   avx
[    2.650810] usb 1-3: New USB device found, idVendor=0079, idProduct=18d6, bcdDevice= 1.00
[    2.650819] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.650822] usb 1-3: Product: Mouse for Windows
[    2.650825] usb 1-3: Manufacturer:
[    2.652658] input:   Mouse for Windows as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0079:18D6.0003/input/input9
[    2.652737] hid-generic 0003:0079:18D6.0003: input,hidraw2: USB HID v1.10 Mouse [  Mouse for Windows] on usb-0000:00:14.0-3/input0
[    2.652808] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.653910] input:   Mouse for Windows as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:0079:18D6.0004/input/input10
[    2.709769] hid-generic 0003:0079:18D6.0004: input,hidraw3: USB HID v1.10 Keyboard [  Mouse for Windows] on usb-0000:00:14.0-3/input1
[    2.709811] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.711477] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.761750] Btrfs loaded, zoned=yes, fsverity=yes
[    2.811891] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
[    2.814589] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.814781] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11
[    2.814958] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.832928] usb 1-7: new full-speed USB device number 4 using xhci_hcd
[    2.962402] fbcon: i915drmfb (fb0) is primary device
[    2.962413] fbcon: Deferring console take-over
[    2.962423] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    2.975076] usb 1-7: New USB device found, idVendor=8087, idProduct=0a2a, bcdDevice= 0.03
[    2.975094] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.978672] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    2.986556] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    3.422330] scsi 2:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 6
[    4.446694] BTRFS: device fsid 715001f0-ad91-42ab-a8d2-08bf1db8716e devid 1 transid 17478 /dev/sda2 (8:2) scanned by mount (214)
[    4.447344] BTRFS info (device sda2): first mount of filesystem 715001f0-ad91-42ab-a8d2-08bf1db8716e
[    4.447366] BTRFS info (device sda2): using crc32c (crc32c-intel) checksum algorithm
[    4.447377] BTRFS info (device sda2): using free-space-tree
[    4.451610] sd 2:0:0:0: [sdb] 1999749120 512-byte logical blocks: (1.02 TB/954 GiB)
[    4.451853] sd 2:0:0:0: [sdb] Write Protect is off
[    4.451858] sd 2:0:0:0: [sdb] Mode Sense: 2f 00 00 00
[    4.452185] sd 2:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    4.454998]  sdb: sdb1
[    4.455134] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[    4.455234] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    4.908265] systemd[1]: systemd 256.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    4.908277] systemd[1]: Detected architecture x86-64.
[    4.909461] systemd[1]: Hostname set to <jacob-defaultstring>.
[    5.224998] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    5.715754] systemd[1]: Queued start job for default target Graphical Interface.
[    5.758267] systemd[1]: Created slice Slice /system/dirmngr.
[    5.758715] systemd[1]: Created slice Slice /system/getty.
[    5.759081] systemd[1]: Created slice Slice /system/gpg-agent.
[    5.759455] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    5.759886] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    5.760300] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    5.760712] systemd[1]: Created slice Slice /system/keyboxd.
[    5.761126] systemd[1]: Created slice Slice /system/modprobe.
[    5.761535] systemd[1]: Created slice Slice /system/systemd-fsck.
[    5.761855] systemd[1]: Created slice User and Session Slice.
[    5.761946] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.762188] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.762217] systemd[1]: Expecting device /dev/disk/by-uuid/715001f0-ad91-42ab-a8d2-08bf1db8716e...
[    5.762228] systemd[1]: Expecting device /dev/disk/by-uuid/ECA0-3F04...
[    5.762237] systemd[1]: Expecting device /dev/sdb1...
[    5.762258] systemd[1]: Reached target Login Prompts.
[    5.762278] systemd[1]: Reached target Local Integrity Protected Volumes.
[    5.762304] systemd[1]: Reached target Remote File Systems.
[    5.762320] systemd[1]: Reached target Slice Units.
[    5.762352] systemd[1]: Reached target Local Verity Protected Volumes.
[    5.762445] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    5.762567] systemd[1]: Listening on LVM2 poll daemon socket.
[    5.764006] systemd[1]: Listening on Process Core Dump Socket.
[    5.764793] systemd[1]: Listening on Credential Encryption/Decryption.
[    5.764939] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.765074] systemd[1]: Listening on Journal Sockets.
[    5.765129] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    5.765152] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    5.765278] systemd[1]: Listening on udev Control Socket.
[    5.765380] systemd[1]: Listening on udev Kernel Socket.
[    5.767727] systemd[1]: Mounting Huge Pages File System...
[    5.769032] systemd[1]: Mounting POSIX Message Queue File System...
[    5.770685] systemd[1]: Mounting Kernel Debug File System...
[    5.775872] systemd[1]: Mounting Kernel Trace File System...
[    5.777988] systemd[1]: Starting Create List of Static Device Nodes...
[    5.782798] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    5.784737] systemd[1]: Starting Load Kernel Module configfs...
[    5.788988] systemd[1]: Starting Load Kernel Module dm_mod...
[    5.791042] systemd[1]: Starting Load Kernel Module drm...
[    5.796097] systemd[1]: Starting Load Kernel Module fuse...
[    5.799292] systemd[1]: Starting Load Kernel Module loop...
[    5.799450] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    5.802045] systemd[1]: Starting Load Kernel Modules...
[    5.802083] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    5.806378] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.806490] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    5.807811] systemd[1]: Starting Load udev Rules from Credentials...
[    5.815213] systemd[1]: Starting Coldplug All udev Devices...
[    5.818974] systemd[1]: Starting Virtual Console Setup...
[    5.823608] systemd[1]: Mounted Huge Pages File System.
[    5.823956] systemd[1]: Mounted POSIX Message Queue File System.
[    5.824116] systemd[1]: Mounted Kernel Debug File System.
[    5.824271] systemd[1]: Mounted Kernel Trace File System.
[    5.826923] device-mapper: uevent: version 1.0.3
[    5.827045] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    5.829328] systemd[1]: Finished Create List of Static Device Nodes.
[    5.830577] loop: module loaded
[    5.830647] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    5.830944] systemd[1]: Finished Load Kernel Module configfs.
[    5.831457] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    5.831714] systemd[1]: Finished Load Kernel Module dm_mod.
[    5.832130] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    5.832379] systemd[1]: Finished Load Kernel Module drm.
[    5.832784] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    5.833082] systemd[1]: Finished Load Kernel Module fuse.
[    5.833491] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    5.833738] systemd[1]: Finished Load Kernel Module loop.
[    5.867004] systemd[1]: Mounting FUSE Control File System...
[    5.868696] systemd[1]: Mounting Kernel Configuration File System...
[    5.868775] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    5.882189] i2c_dev: i2c /dev entries driver
[    5.882813] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    5.885171] systemd[1]: Finished Load udev Rules from Credentials.
[    5.885568] systemd[1]: Finished Virtual Console Setup.
[    5.885748] systemd[1]: Mounted FUSE Control File System.
[    5.887796] systemd[1]: Mounted Kernel Configuration File System.
[    5.894591] systemd[1]: Finished Load Kernel Modules.
[    5.896023] systemd[1]: Starting Apply Kernel Variables...
[    5.913015] systemd[1]: Finished Apply Kernel Variables.
[    5.924285] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    5.933990] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[    5.987125] systemd[1]: Finished Remount Root and Kernel File Systems.
[    5.988149] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[    5.989490] systemd[1]: Starting Load/Save OS Random Seed...
[    5.990916] systemd[1]: Starting Create System Users...
[    5.990956] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.029742] systemd[1]: Finished Load/Save OS Random Seed.
[    6.043322] systemd[1]: Finished Create System Users.
[    6.044383] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.106018] systemd[1]: Finished Create Static Device Nodes in /dev.
[    6.106176] systemd[1]: Reached target Preparation for Local File Systems.
[    6.106247] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[    6.108170] systemd[1]: Starting Journal Service...
[    6.109490] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    6.149999] systemd-journald[299]: Collecting audit messages is disabled.
[    6.201894] systemd[1]: Started Journal Service.
[    6.428402] mousedev: PS/2 mouse device common for all mice
[    6.518640] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    6.536605] Consider using thermal netlink events interface
[    6.537403] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    6.600896] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    6.657615] mmc0: SDHCI controller on PCI [0000:00:1e.6] using ADMA 64-bit
[    6.709726] intel_pmc_core INT33A1:00:  initialized
[    6.742438] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[    6.742807] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    6.745770] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[    6.810318] input: Intel HID events as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/INT33D5:00/input/input12
[    6.810775] intel-hid INT33D5:00: platform supports 5 button array
[    6.815890] input: Intel HID 5 button array as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/INT33D5:00/input/input13
[    6.877749] Bluetooth: Core ver 2.22
[    6.877772] NET: Registered PF_BLUETOOTH protocol family
[    6.877775] Bluetooth: HCI device and connection manager initialized
[    6.877780] Bluetooth: HCI socket layer initialized
[    6.877783] Bluetooth: L2CAP socket layer initialized
[    6.877788] Bluetooth: SCO socket layer initialized
[    6.879101] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[    6.890067] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    6.892039] input: PC Speaker as /devices/platform/pcspkr/input/input14
[    6.933747] intel-lpss 0000:00:15.2: enabling device (0000 -> 0002)
[    6.934286] idma64 idma64.2: Found Intel integrated DMA 64-bit
[    6.982350] Adding 524284k swap on /swap/swapfile.  Priority:-2 extents:2 across:648884k
[    6.991157] Goodix-TS i2c-GDIX1002:00: supply AVDD28 not found, using dummy regulator
[    6.991208] Goodix-TS i2c-GDIX1002:00: supply VDDIO not found, using dummy regulator
[    6.991987] systemd-journald[299]: Received client request to flush runtime journal.
[    6.992511] Goodix-TS i2c-GDIX1002:00: ID 911, version: 1062
[    6.998907] input: Goodix Capacitive TouchScreen as /devices/pci0000:00/0000:00:15.2/i2c_designware.2/i2c-7/i2c-GDIX1002:00/input/input15
[    7.003933] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.017288] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    7.020840] idma64 idma64.3: Found Intel integrated DMA 64-bit
[    7.023315] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.025259] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.036233] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    7.036264] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    7.075404] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    7.075410] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    7.075412] RAPL PMU: hw unit of domain package 2^-14 Joules
[    7.075414] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    7.075415] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    7.075417] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    7.146741] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[    7.158974] Intel(R) Wireless WiFi driver for Linux
[    7.160894] cryptd: max_cpu_qlen set to 1000
[    7.180305] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[    7.194667] iwlwifi 0000:01:00.0: Detected crf-id 0x0, cnv-id 0x0 wfpm id 0x0
[    7.194823] iwlwifi 0000:01:00.0: PCI dev 095a/9010, rev=0x210, rfid=0xd55555d5
[    7.195558] AVX2 version of gcm_enc/dec engaged.
[    7.195609] AES CTR mode by8 optimization enabled
[    7.205998] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[    7.206024] iwlwifi 0000:01:00.0: Found debug configuration: 0
[    7.206339] iwlwifi 0000:01:00.0: loaded firmware version 29.4063824552.0 7265D-29.ucode op_mode iwlmvm
[    7.209572] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[    7.212158] intel_rapl_common: Found RAPL domain package
[    7.212162] intel_rapl_common: Found RAPL domain dram
[    7.232057] pps_core: LinuxPPS API ver. 1 registered
[    7.232063] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    7.255942] PTP clock support registered
[    7.256365] dw-apb-uart.3: ttyS4 at MMIO 0xdf135000 (irq = 20, base_baud = 115200) is a 16550A
[    7.262036] intel_rapl_common: Found RAPL domain package
[    7.262041] intel_rapl_common: Found RAPL domain core
[    7.262043] intel_rapl_common: Found RAPL domain uncore
[    7.262045] intel_rapl_common: Found RAPL domain dram
[    7.262047] intel_rapl_common: Found RAPL domain psys
[    7.271311] iTCO_vendor_support: vendor-support=0
[    7.288874] EXT4-fs (sdb1): mounted filesystem 53182bef-4a37-4e7f-9757-ce87fb6d786f r/w with ordered data mode. Quota mode: none.
[    7.306699] usbcore: registered new interface driver btusb
[    7.318649] Bluetooth: hci0: Legacy ROM 2.x revision 5.0 build 25 week 20 2015
[    7.326823] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[    7.367232] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    7.368581] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    7.452038] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    7.452758] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    7.487426] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x1a/0x0/0x0/0x0/0x0) type:speaker
[    7.487435] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.487439] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[    7.487443] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    7.487445] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    7.487447] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x18
[    7.487450] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[    7.577875] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[    7.592055] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[    7.592762] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[    7.601430] iwlwifi 0000:01:00.0: base HW address: b8:9a:2a:43:69:94, OTP minor version: 0x0
[    7.605325] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[    7.605389] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    7.605446] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[    7.605500] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    7.605561] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    7.623616] Bluetooth: hci0: Intel BT fw patch 0x43 completed & activated
[    7.702155] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    7.738203] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
[    7.783131] intel_tcc_cooling: Programmable TCC Offset detected
[   13.725082] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.725088] Bluetooth: BNEP filters: protocol multicast
[   13.725095] Bluetooth: BNEP socket layer initialized
[   13.726641] Bluetooth: MGMT ver 1.22
[   13.741749] NET: Registered PF_ALG protocol family
[   13.877122] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[   13.881047] NET: Registered PF_QIPCRTR protocol family
[   13.958078] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[   13.960434] iwlwifi 0000:01:00.0: FW already configured (0) - re-configuring
[   13.978705] iwlwifi 0000:01:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
[   14.037685] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[   14.121839] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[   14.124757] iwlwifi 0000:01:00.0: FW already configured (0) - re-configuring
[   16.806212] mmc0: Timeout waiting for hardware cmd interrupt.
[   16.806226] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   16.806240] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
[   16.806254] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   16.806265] mmc0: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
[   16.806277] mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
[   16.806289] mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
[   16.806301] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
[   16.806312] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   16.806318] mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
[   16.806330] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   16.806335] mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
[   16.806347] mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
[   16.806359] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   16.806364] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   16.806368] mmc0: sdhci: Host ctl2: 0x00000000
[   16.806375] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
[   16.806379] mmc0: sdhci: ============================================
[   17.730753] wlp1s0: authenticate with fc:34:97:d0:11:b8 (local address=b8:9a:2a:43:69:94)
[   17.731286] wlp1s0: send auth to fc:34:97:d0:11:b8 (try 1/3)
[   17.734207] wlp1s0: authenticated
[   17.739540] wlp1s0: associate with fc:34:97:d0:11:b8 (try 1/3)
[   17.743904] wlp1s0: RX AssocResp from fc:34:97:d0:11:b8 (capab=0x1411 status=0 aid=36)
[   17.745809] wlp1s0: associated
[   17.833502] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by fc:34:97:d0:11:b8
[   20.764922] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   20.946496] Bluetooth: RFCOMM TTY layer initialized
[   20.946510] Bluetooth: RFCOMM socket layer initialized
[   20.946515] Bluetooth: RFCOMM ver 1.11
[   25.787038] wlp1s0: disconnect from AP fc:34:97:d0:11:b8 for new auth to fc:34:97:d0:11:bc
[   25.865594] wlp1s0: authenticate with fc:34:97:d0:11:bc (local address=b8:9a:2a:43:69:94)
[   25.866571] wlp1s0: send auth to fc:34:97:d0:11:bc (try 1/3)
[   25.868789] wlp1s0: authenticated
[   25.869517] wlp1s0: associate with fc:34:97:d0:11:bc (try 1/3)
[   25.870821] wlp1s0: RX ReassocResp from fc:34:97:d0:11:bc (capab=0x1011 status=0 aid=30)
[   25.888418] wlp1s0: associated
[   25.912157] wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by fc:34:97:d0:11:bc
[   26.829518] mmc0: Timeout waiting for hardware cmd interrupt.
[   26.829525] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   26.829528] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
[   26.829533] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   26.829537] mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
[   26.829540] mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
[   26.829543] mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
[   26.829547] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
[   26.829550] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   26.829553] mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
[   26.829556] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   26.829559] mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
[   26.829563] mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
[   26.829566] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   26.829569] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   26.829571] mmc0: sdhci: Host ctl2: 0x00000000
[   26.829587] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
[   26.829589] mmc0: sdhci: ============================================
[   36.856195] mmc0: Timeout waiting for hardware cmd interrupt.
[   36.856201] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   36.856212] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
[   36.856216] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   36.856219] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[   36.856223] mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
[   36.856227] mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
[   36.856230] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
[   36.856233] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   36.856237] mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
[   36.856240] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   36.856243] mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
[   36.856247] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
[   36.856250] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   36.856253] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   36.856255] mmc0: sdhci: Host ctl2: 0x00000000
[   36.856259] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
[   36.856261] mmc0: sdhci: ============================================
[   47.002675] mmc0: Timeout waiting for hardware cmd interrupt.
[   47.002680] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[   47.002683] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
[   47.002687] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   47.002690] mmc0: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
[   47.002693] mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
[   47.002696] mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
[   47.002699] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
[   47.002702] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   47.002705] mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
[   47.002708] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   47.002711] mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
[   47.002714] mmc0: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
[   47.002730] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   47.002740] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   47.002741] mmc0: sdhci: Host ctl2: 0x00000000
[   47.002745] mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
[   47.002746] mmc0: sdhci: ============================================
    ~                                                        ✔  10s 
    ~  journalctl -b -1 -p3                                          ✔
Sep 16 11:53:33 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Sep 16 11:53:33 jacob-defaultstring kernel: ACPI BIOS Error (bug): Could not>
Sep 16 11:53:33 jacob-defaultstring kernel: ACPI Error: Aborting method \_SB>
Sep 16 11:53:35 jacob-defaultstring bluetoothd[464]: Failed to set mode: Fai>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: Timeout waiting for hardwa>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI >
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x000000>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x000000>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000c>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a00>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x000000>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x000000>
Sep 16 11:53:39 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x000000>
...skipping...
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff00>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c8>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x000001>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x000000>
Sep 16 11:55:39 jacob-defaultstring kernel: mmc1: sdhci: ===================>
Sep 16 11:55:46 jacob-defaultstring pulseaudio[929]: org.bluez.BatteryProvid>
Sep 16 11:55:47 jacob-defaultstring dbus-broker-launch[459]: Activation requ>
Sep 16 11:55:47 jacob-defaultstring (sd-pam)[579]: pam_systemd(systemd-user:>
lines 232-246/246 (END)
Sometimes the error shows mmc0 or mmc1. Not sure why it changes, computer only has 1 sd card slot.
My bad. Not sure this will help, but could you do that command again with the --no-pager option? The lines get truncated in the default view.
But before you do that… Even WARNINGs, and INFO messages, may help (-p4, or removing -p# entirely for all logs.)
Only because, I assume, you can just sudo umount ... , then spawn a page or two of logs related to this.
    ~  journalctl -b -1 -p4 --no-pager                               ✔
Sep 16 15:14:53 jacob-defaultstring kernel: x86/cpu: SGX disabled by BIOS.
Sep 16 15:14:53 jacob-defaultstring kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Sep 16 15:14:53 jacob-defaultstring kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Sep 16 15:14:53 jacob-defaultstring kernel: acpi PNP0A08:00: MMCONFIG is disabled, can't access extended configuration space under this bridge
Sep 16 15:14:53 jacob-defaultstring kernel: ACPI: thermal: [Firmware Bug]: No valid trip points!
Sep 16 15:14:53 jacob-defaultstring kernel: hpet_acpi_add: no address or irqs in _CRS
Sep 16 15:14:53 jacob-defaultstring kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Sep 16 15:14:53 jacob-defaultstring kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT1._GTF.DSSP], AE_NOT_FOUND (20240322/psargs-330)
Sep 16 15:14:53 jacob-defaultstring kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT1._GTF due to previous error (AE_NOT_FOUND) (20240322/psparse-529)
Sep 16 15:14:54 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: supply AVDD28 not found, using dummy regulator
Sep 16 15:14:54 jacob-defaultstring kernel: Goodix-TS i2c-GDIX1002:00: supply VDDIO not found, using dummy regulator
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support bap plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support bass plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support mcp plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support vcp plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support micp plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support ccp plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support csip plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: src/plugin.c:init_plugin() System does not support asha plugin
Sep 16 15:14:55 jacob-defaultstring bluetoothd[482]: Failed to set mode: Failed (0x03)
Sep 16 15:15:02 jacob-defaultstring dbus-broker-launch[478]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Sep 16 15:15:02 jacob-defaultstring dbus-broker-launch[478]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Sep 16 15:15:02 jacob-defaultstring dbus-broker-launch[615]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Sep 16 15:15:02 jacob-defaultstring dbus-broker-launch[615]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Sep 16 15:15:02 jacob-defaultstring dbus-broker-launch[615]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Sep 16 15:15:04 jacob-defaultstring ksplashqml[619]: Texture 0x738a7020aa00 () used with different accesses within the same pass, this is not allowed.
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 16 15:15:04 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 16 15:15:04 jacob-defaultstring baloo_file[643]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Sep 16 15:15:04 jacob-defaultstring baloo_file[643]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.23'
Sep 16 15:15:04 jacob-defaultstring kded6[689]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Sep 16 15:15:05 jacob-defaultstring plasmashell[720]: kde.plasmashell: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 16 15:15:05 jacob-defaultstring plasmashell[720]: kde.plasmashell: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 16 15:15:05 jacob-defaultstring kded6[689]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Sep 16 15:15:05 jacob-defaultstring kded6[689]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kconf_update[784]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Sep 16 15:15:05 jacob-defaultstring kded6[689]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Sep 16 15:15:05 jacob-defaultstring xdg-desktop-por[646]: Choosing kwallet.portal for org.freedesktop.impl.portal.Secret via the deprecated UseIn key
Sep 16 15:15:05 jacob-defaultstring xdg-desktop-por[646]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Sep 16 15:15:05 jacob-defaultstring wireplumber[821]: pw.resource: can't create node: No such file or directory
Sep 16 15:15:05 jacob-defaultstring wireplumber[821]: wp-node: failed to create node from factory 'spa-node-factory'
Sep 16 15:15:05 jacob-defaultstring kded6[689]: kscreen.kded: PowerDevil SuspendSession action not available!
Sep 16 15:15:05 jacob-defaultstring plasmashell[720]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:196:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Sep 16 15:15:05 jacob-defaultstring org_kde_powerdevil[762]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 16 15:15:06 jacob-defaultstring org_kde_powerdevil[762]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 16 15:15:06 jacob-defaultstring org_kde_powerdevil[762]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 16 15:15:06 jacob-defaultstring bluetoothd[482]: Failed to set mode: Failed (0x03)
Sep 16 15:15:06 jacob-defaultstring kded6[689]: kf.bluezqt: PendingCall Error: "Failed"
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "applications:firefox.desktop" 0x5ceed727b010
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" 0x5ceed727b010
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" 0x5ceed727b010
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "applications:firefox.desktop" 0x5ceed72be590
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" 0x5ceed72bf640
Sep 16 15:15:06 jacob-defaultstring plasmashell[720]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" 0x5ceed72bf640
Sep 16 15:15:07 jacob-defaultstring plasmashell[720]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:162:21: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Sep 16 15:15:07 jacob-defaultstring plasmashell[720]: qml: SystemTray ItemLoader: Invalid state, cannot determine source!
Sep 16 15:15:07 jacob-defaultstring plasmashell[720]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1726514107768: Unsupported image format
Sep 16 15:15:08 jacob-defaultstring plasmashell[720]: file:///usr/lib/qt6/qml/org/kde/plasma/workspace/calendar/MonthViewHeader.qml:50:26: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Sep 16 15:15:08 jacob-defaultstring plasmashell[720]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 16 15:15:10 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/common/Azure Striker Gunvolt/save/steam_autocloud.vdf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:11 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/common/Azure Striker Gunvolt/exe/gv_win.dxvk-cache" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:11 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/appmanifest_388800.acf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 16 15:15:14 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/tracked_files" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Installer/862c.msi" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v1.1.4322/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v2.0.50727/csc.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v2.0.50727/installutil.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v4.0.30319/csc.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v4.0.30319/installutil.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v1.1.4322/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v2.0.50727/csc.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v2.0.50727/installutil.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v4.0.30319/csc.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v4.0.30319/installutil.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/globalization/sorting/sortdefault.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/input.inf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/input.pnf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/winebus.inf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/winebus.pnf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/winehid.inf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/winehid.pnf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/wineusb.inf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/wineusb.pnf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/inf/winexinput.inf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_037.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_10000.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_10001.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_10002.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_10003.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:14 jacob-defaultstring baloo_file_extractor[1061]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/c_10004.nls" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 16 15:15:22 jacob-defaultstring plasmashell[720]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Sep 16 15:15:22 jacob-defaultstring systemd[593]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Sep 16 15:15:22 jacob-defaultstring plasmashell[720]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Sep 16 15:15:22 jacob-defaultstring systemd[593]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Sep 16 15:15:22 jacob-defaultstring sddm-helper[587]: Signal received: SIGTERM
Sep 16 15:15:22 jacob-defaultstring sddm[561]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 16 15:15:22 jacob-defaultstring sddm[561]: Auth: sddm-helper (--socket /tmp/sddm-auth-85494c2f-7bc8-47e2-b769-2332024acebd --id 1 --start /usr/bin/startplasma-x11 --user jacob --autologin) crashed (exit code 1)
Sep 16 15:15:22 jacob-defaultstring sddm[561]: Auth: sddm-helper exited with 1
Sep 16 15:15:22 jacob-defaultstring sddm[561]: Signal received: SIGTERM
Sep 16 15:15:22 jacob-defaultstring pulseaudio[943]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
Sep 16 15:15:22 jacob-defaultstring pulseaudio[943]: Lost I/O connection in module "module-gsettings"
Sep 16 15:15:23 jacob-defaultstring dbus-broker-launch[478]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Sep 16 15:15:23 jacob-defaultstring NetworkManager[480]: <warn>  [1726514123.1910] dispatcher: (10) failed (after 0.006 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
I was hoping to recreate the event for what happens during shutdown to cause that. We can can get better logs when we can initiate it.
Does the reader work completely fine until shutdown/suspend?
I’m not sure myself otherwise. At least there’s a little more info for others now.
A grasping at straws thing to try, if you’re using the sdhci module for the reader. (It’s hard to tell what laptop you have from your inxi.)
sudo rmmod sdhci-pci sdhci
sudo modprobe sdhci debug_quirks2=4
sudo modprobe sdhci-pci
The sd card works fine during boot and during computer use, no issues until shutdown.
I already tried that rmmod/ modprobe and it did not work.
I forgot to mention sometimes the computer restarts/shuts down fine (Im unable to determine the reason why). Here is a journal example of a clean restart:
Sep 17 10:58:51 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:58:51 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:58:51 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:01 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:11 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:21 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:31 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:41 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 10:59:51 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:01 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:11 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:21 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:31 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:31 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:31 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:31 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:32 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:42 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:00:52 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:02 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:12 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:22 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:32 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:42 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:01:52 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:02 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:12 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:22 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:32 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:42 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:02:52 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:03:02 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:03:12 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: Timeout waiting for hardware cmd interrupt.
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: Host ctl2: 0x00000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:03:22 jacob-defaultstring kernel: mmc1: sdhci: ============================================
Sep 17 11:05:17 jacob-defaultstring systemd[576]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Sep 17 11:05:17 jacob-defaultstring plasmashell[714]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Sep 17 11:05:17 jacob-defaultstring plasmashell[714]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Sep 17 11:05:17 jacob-defaultstring sddm[558]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 17 11:05:17 jacob-defaultstring sddm[558]: Auth: sddm-helper (--socket /tmp/sddm-auth-d64596bb-ad49-4ba5-9a3b-053286aae882 --id 1 --start /usr/bin/startplasma-x11 --user jacob --autologin) crashed (exit code 1)
Sep 17 11:05:17 jacob-defaultstring sddm[558]: Auth: sddm-helper exited with 1
Sep 17 11:05:17 jacob-defaultstring pulseaudio[945]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
Sep 17 11:05:17 jacob-defaultstring sddm[558]: Signal received: SIGTERM
Sep 17 11:05:17 jacob-defaultstring ksmserver[682]: The X11 connection broke (error 1). Did the X11 server die?
Sep 17 11:05:17 jacob-defaultstring kded6[684]: The X11 connection broke: I/O error (code 1)
Sep 17 11:05:17 jacob-defaultstring systemd[576]: dbus-:1.50-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Sep 17 11:05:17 jacob-defaultstring systemd[576]: plasma-ksmserver.service: Failed with result 'exit-code'.
Sep 17 11:05:18 jacob-defaultstring systemd[576]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Sep 17 11:05:18 jacob-defaultstring systemd[576]: plasma-kded6.service: Failed with result 'exit-code'.
Sep 17 11:05:18 jacob-defaultstring dbus-broker-launch[477]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Sep 17 11:05:18 jacob-defaultstring NetworkManager[479]: <warn>  [1726585518.3839] dispatcher: (10) failed (after 0.007 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
Here is another example of a clean shutdown:
journalctl -b -1 -p4 --no-pager
6510/pfx/drive_c/windows/syswow64/dxgi.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:16 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/d3d12.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:16 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/syswow64/d3d12.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:16 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/system32/d3d12core.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:16 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/windows/syswow64/d3d12core.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:16 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/common/Hand of Fate/Hand of Fate_Data/output_log.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/system.reg" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/userdef.reg" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/drive_c/users/steamuser/AppData/LocalLow/Defiant Development/Hand of Fate/player.profile.52959.backup" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/266510/pfx/user.reg" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/appmanifest_266510.acf" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/winhelp.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/twain.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/rundll.exe" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system/ddeml.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system/mmsystem.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/wineopenxr.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/ntdll.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/d3dcompiler_47.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/concrt140.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/msvcp140_1.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/vcomp140.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/vcruntime140.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/d3dx10_37.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/vcruntime140_1.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/msvcr120_app.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/vulkan-1.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/msvcp140.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/msvcp120_app.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/xaudio2_9.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/d3dxof.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/d3dcompiler_46.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/d3dx11_42.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:17 jacob-defaultstring baloo_file_extractor[1043]: kf.baloo: "/home/jacob/Documents/Steam/Steam Proton/steamapps/compatdata/366240/pfx/drive_c/windows/system32/xinput1_4.dll" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:24:22 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:24:32 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:24:42 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:24:52 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:02 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:12 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:22 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:32 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:42 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:25:52 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:02 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000fa07
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:12 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:22 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:32 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:42 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:26:52 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:02 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:12 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:22 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:32 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:42 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:27:52 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:02 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:12 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004e47
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:22 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:33 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:43 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:28:53 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:28:58 jacob-defaultstring xdg-desktop-portal-kde[762]: xdp-kde-settings: Namespace  "org.gnome.desktop.interface"  is not supported
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:03 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:29:06 jacob-defaultstring kernel: warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Sep 17 11:29:06 jacob-defaultstring xdg-desktop-portal-kde[762]: xdp-kde-settings: Namespace  "org.gnome.desktop.interface"  is not supported
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:13 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:23 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:33 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:43 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:29:53 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:03 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:13 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:23 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000f447
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:33 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000c00 | Trn mode: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:43 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x80000c08 | Trn mode: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000341a | Max curr: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:30:53 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:03 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x000001aa | Trn mode: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000081a | Max curr: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:13 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:23 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:33 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:43 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000502 | Max curr: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:31:53 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:32:03 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:32:13 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:32:23 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x0000371a | Max curr: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:32:33 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: Timeout waiting for hardware cmd interrupt.
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x00001002
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Present:   0x000a0001 | Host ctl: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Power:     0x0000000e | Blk gap:  0x00000080
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x0000e8c7
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Int enab:  0x00ff0003 | Sig enab: 0x00ff0003
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Caps:      0x7568c881 | Caps_1:   0x00000807
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Cmd:       0x00000102 | Max curr: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: Host ctl2: 0x00000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x0000000000000000
Sep 17 11:32:43 jacob-defaultstring kernel: mmc0: sdhci: ============================================
Sep 17 11:44:42 jacob-defaultstring systemd[593]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Sep 17 11:44:42 jacob-defaultstring plasmashell[718]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Sep 17 11:44:42 jacob-defaultstring plasmashell[718]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Sep 17 11:44:42 jacob-defaultstring systemd[593]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Sep 17 11:44:42 jacob-defaultstring sddm-helper[587]: Signal received: SIGTERM
Sep 17 11:44:42 jacob-defaultstring sddm[562]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Sep 17 11:44:42 jacob-defaultstring sddm[562]: Auth: sddm-helper (--socket /tmp/sddm-auth-a8e90ea4-0297-449e-a808-86db2a117d59 --id 1 --start /usr/bin/startplasma-x11 --user jacob --autologin) crashed (exit code 1)
Sep 17 11:44:42 jacob-defaultstring sddm[562]: Auth: sddm-helper exited with 1
Sep 17 11:44:42 jacob-defaultstring sddm[562]: Signal received: SIGTERM
Sep 17 11:44:42 jacob-defaultstring pulseaudio[940]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NoReply:Remote peer disconnected
Sep 17 11:44:43 jacob-defaultstring dbus-broker-launch[479]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Sep 17 11:44:43 jacob-defaultstring NetworkManager[481]: <warn>  [1726587883.3366] dispatcher: (10) failed (after 0.006 sec): Could not activate remote peer 'org.freedesktop.nm_dispatcher': activation request failed: unit is invalid
What about just blacklisting that module?
I always have fancy USB SD readers, or tiny ones to carry one. (If you really need it.)
Id rather find a fix if possible. This is a handheld gaming PC called a GPD Win 2. The built in sd card slot is important for the additional game storage. Having an external sd card slot hampers the form factor of the device.
Would you know a way I could suppress the error or tell the computer to ignore the “mmc0: timeout waiting for hardware interrupt” error so it does not loop during shutdown? Without blacklist the entire module? The sd card reader works fine during use and boot. Its only during shutdown it causes issues.
I also may of forgot to mention I get this error even if there is no sd card in the slot.
Finally found the fix to the issue in this reddit post.
Add the following lines to /etc/modprobe.d/sdhci.conf or /etc/default/grub
For the .conf file add
options sdhci debug_quirks=SDHCI_QUIRK_BROKEN_ADMA debug_quirks2=SDHCI_QUIRK2_NO_1_8_V
And then run sudo mkinitcpio -p linux(kernel number) so for example if your running linux kernel 6.6 it would be linux66
Or for the grub method add: sdhci.debug_quirks=SDHCI_QUIRK_BROKEN_ADMA sdhci.debug_quirks2=SDHCI_QUIRK2_NO_1_8_V to the CMDLINE_LINUX_DEFAULT line.
(In the reddit post it also suggests to add quirks=0x40 debug_quirks2=0x04 to the conf file or sdhci.debug_quirks=0x40 sdhci.debug_quirks2=0x04 to the grub file. But in my case it turned out to not be necessary).
