Mlt: failed to open several libraries
This is the error I get when trying to convert a file with melt:
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltrtaudio.so
  (librtaudio.so.6: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltsox.so
  (libsox.so.3: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltmovit.so
  (libmovit.so.8: cannot open shared object file: No such file or directory)
mlt_repository_init: failed to dlopen /usr/lib/mlt-7/libmltopencv.so
  (libopencv_tracking.so.405: cannot open shared object file: No such file or directory)
Any help?
$ LANG=C pamac search --files libmltrtaudio.so
/usr/lib/mlt-7/libmltrtaudio.so is owned by mlt
/usr/lib/mlt/libmltrtaudio.so is owned by mlt6
As you see the package mlt should have installed the libs.
How did you install it? Maybe reinstall it?
Fixed installing this:
$ pamac build sox movit opencv rtaudio
FYI, Those are all repo packages, there’s nothing to build. The proper command is pamac install. :wink:
Yes but running build wouldn’t ruin anything would it?
