Hello
I have been using Manjaro for years and never had this issue before.
I think it started with the latest upgrade, but could have been dormant issue for longer.
In a nutshell:
Running mkinitcpio -P produces the following error message during the sd-encrypt phase.
==> ERROR: file not found: `'
I can still reboot normally after the error however I’d rather understand and fix it.
Any help with this matter would be appreciated.
I searched forums here, on Arch websites, including Wiki, searched github for bugs, to no avail.
Here is the content of mkinitcpio.conf:
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=(vfio_pci vfio vfio_iommu_type1 vfio_virqfd zfs i915 intel_agp bridge vfio-mdev kvmgt)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=("/usr/lib/libgcc_s.so.1")
# HOOKS
HOOKS=(systemd autodetect modconf sd-vconsole keyboard sd-plymouth sd-encrypt block sd-zfs filesystems)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
Basically after it starts the sd-encrypt hook, at some point it throws an error message that says:
Below is an extract of the error message from running mkinitcpio -v -P for more detailed context.
sudo mkinitcpio -v -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -v -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.41-1-MANJARO
-> Running build hook: [/usr/lib/initcpio/install/systemd]
adding file: /usr/bin/modprobe
adding file: /usr/lib/libzstd.so.1
**-> Running build hook: [/usr/lib/initcpio/install/sd-encrypt]**
adding module: dm-crypt (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/md/dm-crypt.ko.xz)
adding module: dm-mod (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/md/dm-mod.ko.xz)
adding module: encrypted-keys (/lib/modules/5.10.41-1-MANJARO/kernel/security/keys/encrypted-keys/encrypted-keys.ko.xz)
adding module: trusted (/lib/modules/5.10.41-1-MANJARO/kernel/security/keys/trusted-keys/trusted.ko.xz)
adding module: tpm (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/char/tpm/tpm.ko.xz)
adding module: rng-core (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/char/hw_random/rng-core.ko.xz)
adding module: dm-integrity (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/md/dm-integrity.ko.xz)
adding module: dm-bufio (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/md/dm-bufio.ko.xz)
adding module: async_xor (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/async_xor.ko.xz)
adding module: xor (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/xor.ko.xz)
adding module: async_tx (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/async_tx.ko.xz)
adding module: camellia-aesni-avx2 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx2.ko.xz)
adding module: camellia-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/camellia-x86_64.ko.xz)
adding module: glue_helper (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/glue_helper.ko.xz)
adding module: camellia-aesni-avx-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx-x86_64.ko.xz)
adding module: crypto_simd (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/crypto_simd.ko.xz)
adding module: cryptd (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cryptd.ko.xz)
adding module: serpent-sse2-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/serpent-sse2-x86_64.ko.xz)
adding module: serpent_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/serpent_generic.ko.xz)
adding module: blake2s-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/blake2s-x86_64.ko.xz)
adding module: libblake2s-generic (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libblake2s-generic.ko.xz)
adding module: des3_ede-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/des3_ede-x86_64.ko.xz)
adding module: libdes (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libdes.ko.xz)
adding module: twofish-avx-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/twofish-avx-x86_64.ko.xz)
adding module: twofish-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/twofish-x86_64.ko.xz)
adding module: twofish_common (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/twofish_common.ko.xz)
adding module: twofish-x86_64-3way (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/twofish-x86_64-3way.ko.xz)
adding module: nhpoly1305-avx2 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/nhpoly1305-avx2.ko.xz)
adding module: nhpoly1305 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/nhpoly1305.ko.xz)
adding module: libpoly1305 (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libpoly1305.ko.xz)
adding module: aegis128-aesni (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/aegis128-aesni.ko.xz)
adding module: sha1-ssse3 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/sha1-ssse3.ko.xz)
adding module: nhpoly1305-sse2 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/nhpoly1305-sse2.ko.xz)
adding module: poly1305-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/poly1305-x86_64.ko.xz)
adding module: blowfish-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/blowfish-x86_64.ko.xz)
adding module: blowfish_common (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/blowfish_common.ko.xz)
adding module: cast6-avx-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/cast6-avx-x86_64.ko.xz)
adding module: cast_common (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cast_common.ko.xz)
adding module: cast6_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cast6_generic.ko.xz)
adding module: cast5-avx-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/cast5-avx-x86_64.ko.xz)
adding module: cast5_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cast5_generic.ko.xz)
adding module: serpent-avx2 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/serpent-avx2.ko.xz)
adding module: serpent-avx-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/serpent-avx-x86_64.ko.xz)
adding module: aesni-intel (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/aesni-intel.ko.xz)
adding module: crct10dif-pclmul (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/crct10dif-pclmul.ko.xz)
adding module: sha512-ssse3 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/sha512-ssse3.ko.xz)
adding module: crc32-pclmul (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/crc32-pclmul.ko.xz)
adding module: sha256-ssse3 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/sha256-ssse3.ko.xz)
adding module: crc32c-intel (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/crc32c-intel.ko.xz)
adding module: chacha-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/chacha-x86_64.ko.xz)
adding module: libchacha (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libchacha.ko.xz)
adding module: ghash-clmulni-intel (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/ghash-clmulni-intel.ko.xz)
adding module: curve25519-x86_64 (/lib/modules/5.10.41-1-MANJARO/kernel/arch/x86/crypto/curve25519-x86_64.ko.xz)
adding module: libcurve25519-generic (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libcurve25519-generic.ko.xz)
adding module: n5pf (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/cavium/nitrox/n5pf.ko.xz)
adding file: /usr/lib/firmware/cavium/cnn55xx_se.fw
adding module: padlock-sha (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/padlock-sha.ko.xz)
adding module: atmel-sha204a (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/atmel-sha204a.ko.xz)
adding module: atmel-i2c (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/atmel-i2c.ko.xz)
adding module: crc16 (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crc16.ko.xz)
adding module: padlock-aes (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/padlock-aes.ko.xz)
adding module: chcr (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/chelsio/chcr.ko.xz)
adding module: cxgb4 (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/net/ethernet/chelsio/cxgb4/cxgb4.ko.xz)
adding module: tls (/lib/modules/5.10.41-1-MANJARO/kernel/net/tls/tls.ko.xz)
adding file: /usr/lib/firmware/cxgb4/t6fw.bin
adding file: /usr/lib/firmware/cxgb4/t5fw.bin
adding file: /usr/lib/firmware/cxgb4/t4fw.bin
adding module: authenc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/authenc.ko.xz)
adding module: gf128mul (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/gf128mul.ko.xz)
adding module: ccp (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/ccp/ccp.ko.xz)
adding module: ccp-crypto (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/ccp/ccp-crypto.ko.xz)
adding module: crypto_safexcel (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/inside-secure/crypto_safexcel.ko.xz)
adding module: qat_c3xxx (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_c3xxx/qat_c3xxx.ko.xz)
adding module: intel_qat (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_common/intel_qat.ko.xz)
adding file: /usr/lib/firmware/qat_c3xxx_mmp.bin
adding file: /usr/lib/firmware/qat_c3xxx.bin
adding module: qat_c62x (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_c62x/qat_c62x.ko.xz)
adding file: /usr/lib/firmware/qat_c62x_mmp.bin
adding file: /usr/lib/firmware/qat_c62x.bin
adding module: qat_dh895xccvf (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_dh895xccvf/qat_dh895xccvf.ko.xz)
adding module: qat_c3xxxvf (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_c3xxxvf/qat_c3xxxvf.ko.xz)
adding module: qat_dh895xcc (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_dh895xcc/qat_dh895xcc.ko.xz)
adding file: /usr/lib/firmware/qat_895xcc_mmp.bin
adding file: /usr/lib/firmware/qat_895xcc.bin
adding module: qat_c62xvf (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/qat/qat_c62xvf/qat_c62xvf.ko.xz)
adding module: atmel-ecc (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/atmel-ecc.ko.xz)
adding module: ecdh_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ecdh_generic.ko.xz)
adding module: ecc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ecc.ko.xz)
adding module: virtio_crypto (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/virtio/virtio_crypto.ko.xz)
adding module: crypto_engine (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/crypto_engine.ko.xz)
adding module: amlogic-gxl-crypto (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/crypto/amlogic/amlogic-gxl-crypto.ko.xz)
adding module: libarc4 (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libarc4.ko.xz)
adding module: libchacha20poly1305 (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libchacha20poly1305.ko.xz)
adding module: libcurve25519 (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libcurve25519.ko.xz)
adding module: libblake2s (/lib/modules/5.10.41-1-MANJARO/kernel/lib/crypto/libblake2s.ko.xz)
adding module: tgr192 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/tgr192.ko.xz)
adding module: rmd128 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/rmd128.ko.xz)
adding module: essiv (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/essiv.ko.xz)
adding module: michael_mic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/michael_mic.ko.xz)
adding module: lzo (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/lzo.ko.xz)
adding module: ccm (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ccm.ko.xz)
adding module: gcm (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/gcm.ko.xz)
adding module: crc32_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/crc32_generic.ko.xz)
adding module: algif_rng (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/algif_rng.ko.xz)
adding module: af_alg (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/af_alg.ko.xz)
adding module: blake2b_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/blake2b_generic.ko.xz)
adding module: chacha_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/chacha_generic.ko.xz)
adding module: sm4_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/sm4_generic.ko.xz)
adding module: poly1305_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/poly1305_generic.ko.xz)
adding module: sha3_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/sha3_generic.ko.xz)
adding module: chacha20poly1305 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/chacha20poly1305.ko.xz)
adding module: lzo-rle (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/lzo-rle.ko.xz)
adding module: curve25519-generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/curve25519-generic.ko.xz)
adding module: rmd320 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/rmd320.ko.xz)
adding module: tcrypt (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/tcrypt.ko.xz)
adding module: sm3_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/sm3_generic.ko.xz)
adding module: xts (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/xts.ko.xz)
adding module: ghash-generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ghash-generic.ko.xz)
adding module: lz4hc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/lz4hc.ko.xz)
adding module: lz4hc_compress (/lib/modules/5.10.41-1-MANJARO/kernel/lib/lz4/lz4hc_compress.ko.xz)
adding module: crypto_user (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/crypto_user.ko.xz)
adding module: seqiv (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/seqiv.ko.xz)
adding module: streebog_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/streebog_generic.ko.xz)
adding module: cmac (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cmac.ko.xz)
adding module: async_pq (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/async_pq.ko.xz)
adding module: raid6_pq (/lib/modules/5.10.41-1-MANJARO/kernel/lib/raid6/raid6_pq.ko.xz)
adding module: async_memcpy (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/async_memcpy.ko.xz)
adding module: async_raid6_recov (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/async_raid6_recov.ko.xz)
adding module: raid6test (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/async_tx/raid6test.ko.xz)
adding module: algif_hash (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/algif_hash.ko.xz)
adding module: rmd256 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/rmd256.ko.xz)
adding module: des_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/des_generic.ko.xz)
adding module: blake2s_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/blake2s_generic.ko.xz)
adding module: echainiv (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/echainiv.ko.xz)
adding module: keywrap (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/keywrap.ko.xz)
adding module: ansi_cprng (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ansi_cprng.ko.xz)
adding module: crc32c_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/crc32c_generic.ko.xz)
adding module: blowfish_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/blowfish_generic.ko.xz)
adding module: 842 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/842.ko.xz)
adding module: 842_compress (/lib/modules/5.10.41-1-MANJARO/kernel/lib/842/842_compress.ko.xz)
adding module: 842_decompress (/lib/modules/5.10.41-1-MANJARO/kernel/lib/842/842_decompress.ko.xz)
adding module: ecb (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ecb.ko.xz)
adding module: vmac (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/vmac.ko.xz)
adding module: camellia_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/camellia_generic.ko.xz)
adding module: aes_ti (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/aes_ti.ko.xz)
adding module: ecrdsa_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ecrdsa_generic.ko.xz)
adding module: xxhash_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/xxhash_generic.ko.xz)
adding module: deflate (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/deflate.ko.xz)
adding module: lrw (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/lrw.ko.xz)
adding module: algif_aead (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/algif_aead.ko.xz)
adding module: drbg (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/drbg.ko.xz)
adding module: algif_skcipher (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/algif_skcipher.ko.xz)
adding module: cbc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cbc.ko.xz)
adding module: md4 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/md4.ko.xz)
adding module: sm2_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/sm2_generic.ko.xz)
adding module: twofish_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/twofish_generic.ko.xz)
adding module: pcbc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/pcbc.ko.xz)
adding module: pkcs8_key_parser (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/asymmetric_keys/pkcs8_key_parser.ko.xz)
adding module: asym_tpm (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/asymmetric_keys/asym_tpm.ko.xz)
adding module: tpm_key_parser (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/asymmetric_keys/tpm_key_parser.ko.xz)
adding module: rmd160 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/rmd160.ko.xz)
adding module: pcrypt (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/pcrypt.ko.xz)
adding module: cfb (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cfb.ko.xz)
adding module: ofb (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/ofb.ko.xz)
adding module: authencesn (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/authencesn.ko.xz)
adding module: xcbc (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/xcbc.ko.xz)
adding module: fcrypt (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/fcrypt.ko.xz)
adding module: cts (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/cts.ko.xz)
adding module: aegis128 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/aegis128.ko.xz)
adding module: salsa20_generic (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/salsa20_generic.ko.xz)
adding module: adiantum (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/adiantum.ko.xz)
adding module: wp512 (/lib/modules/5.10.41-1-MANJARO/kernel/crypto/wp512.ko.xz)
adding file: /usr/lib/udev/rules.d/10-dm.rules
adding file: /usr/bin/dmsetup
adding file: /usr/lib/libdevmapper.so.1.02
overwriting file: /usr/bin/dmsetup
adding file: /usr/lib/udev/rules.d/13-dm-disk.rules
adding file: /usr/lib/udev/rules.d/60-fido-id.rules
adding file: /usr/lib/udev/fido_id
adding file: /usr/lib/udev/rules.d/95-dm-notify.rules
adding file: /usr/lib/systemd/system/cryptsetup.target
adding symlink: /usr/lib/systemd/system/sysinit.target.wants/cryptsetup.target -> /usr/lib/systemd/system/cryptsetup.target
overwriting symlink /lib/systemd/system/sysinit.target.wants/cryptsetup.target -> /usr/lib/systemd/system/cryptsetup.target
adding file: /usr/lib/systemd/system-generators/systemd-cryptsetup-generator
adding file: /usr/lib/systemd/systemd-cryptsetup
adding file: /usr/lib/libcryptsetup.so.12
adding file: /usr/lib/libuuid.so.1
adding file: /usr/lib/libargon2.so.1
adding file: /usr/lib/libjson-c.so.5
adding file: /usr/lib/systemd/system/systemd-ask-password-console.path
adding symlink: /usr/lib/systemd/system/sysinit.target.wants/systemd-ask-password-console.path -> /usr/lib/systemd/system/systemd-ask-password-console.path
overwriting symlink /lib/systemd/system/sysinit.target.wants/systemd-ask-password-console.path -> /usr/lib/systemd/system/systemd-ask-password-console.path
adding file: /usr/lib/systemd/system/systemd-ask-password-console.service
overwriting file: /usr/sbin/systemd-tty-ask-password-agent
overwriting file: /usr/lib/libgcc_s.so.1
adding file: /usr/sbin/mkswap
adding file: /etc/crypttab
-> Running build hook: [/usr/lib/initcpio/install/block]
adding module: sr_mod (/lib/modules/5.10.41-1-MANJARO/kernel/drivers/scsi/sr_mod.ko.xz)
==> WARNING: errors were encountered during the build. The image may not be complete.
Further investigation using pacman logs:
On May 19th the sd-encrypt hook ran fine after an upgrade:
[2021-05-19T15:55:16+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-05-19T15:55:17+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
On June 7th the sd-encrypt hook started throwing an error after pacman upgrade:
[2021-06-07T17:37:47+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:37:48+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:37:48+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
I can see that this last upgrade included an update of cryptsetup:
[2021-06-07T17:36:12+0100] [ALPM] upgraded cryptsetup (2.3.5-4 -> 2.3.6-1)
However I am not sure this is what is causing the error.
Any advice would be most welcome.
For reference I am posting here the full log of June 7th pacman upgrade showing the list of packages updated as well as the mkinitcpio sd-encrypt error:
[2021-06-07T17:35:54+0100] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-06-07T17:35:54+0100] [ALPM] running '71-dkms-remove.hook'...
[2021-06-07T17:35:54+0100] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod -m it87 -v 154.b159857 -k 5.10.36-2-MANJARO
[2021-06-07T17:35:54+0100] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod -m it87 -v 154.b159857 -k 5.4.118-1-MANJARO
[2021-06-07T17:35:54+0100] [ALPM-SCRIPTLET] ==> depmod 5.4.118-1-MANJARO
[2021-06-07T17:36:01+0100] [ALPM-SCRIPTLET] ==> depmod 5.10.36-2-MANJARO
[2021-06-07T17:36:07+0100] [ALPM] running 'firefox-pre.hook'...
[2021-06-07T17:36:07+0100] [ALPM] transaction started
[2021-06-07T17:36:08+0100] [ALPM] upgraded linux-api-headers (5.10.13-1 -> 5.12.3-1)
[2021-06-07T17:36:08+0100] [ALPM] upgraded glibc (2.33-4 -> 2.33-5)
[2021-06-07T17:36:08+0100] [ALPM-SCRIPTLET] Generating locales...
[2021-06-07T17:36:09+0100] [ALPM-SCRIPTLET] en_IE.UTF-8... done
[2021-06-07T17:36:10+0100] [ALPM-SCRIPTLET] en_US.UTF-8... done
[2021-06-07T17:36:10+0100] [ALPM-SCRIPTLET] Generation complete.
[2021-06-07T17:36:10+0100] [ALPM] upgraded gcc-libs (10.2.0-6 -> 11.1.0-1)
[2021-06-07T17:36:10+0100] [ALPM] upgraded bashrc-manjaro (5.1.008-1 -> 5.1.008-3)
[2021-06-07T17:36:10+0100] [ALPM] upgraded bash (5.1.008-1 -> 5.1.008-3)
[2021-06-07T17:36:11+0100] [ALPM] upgraded perl (5.32.1-1 -> 5.34.0-1)
[2021-06-07T17:36:11+0100] [ALPM] upgraded perl-file-next (1.18-2 -> 1.18-3)
[2021-06-07T17:36:11+0100] [ALPM] upgraded ack (3.5.0-1 -> 3.5.0-2)
[2021-06-07T17:36:11+0100] [ALPM] upgraded acpica (20210105-1 -> 20210331-1)
[2021-06-07T17:36:11+0100] [ALPM] upgraded expat (2.3.0-1 -> 2.4.1-1)
[2021-06-07T17:36:11+0100] [ALPM] upgraded libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-06-07T17:36:11+0100] [ALPM] upgraded lz4 (1:1.9.3-1 -> 1:1.9.3-2)
[2021-06-07T17:36:11+0100] [ALPM] upgraded zstd (1.4.9-1 -> 1.5.0-1)
[2021-06-07T17:36:11+0100] [ALPM] upgraded libldap (2.4.58-2 -> 2.4.58-3)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libtirpc (1.3.1-1 -> 1.3.2-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libcap (2.49-1 -> 2.50-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded lib32-glibc (2.33-4 -> 2.33-5)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libtasn1 (4.16.0-1 -> 4.17.0-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded ca-certificates-mozilla (3.64-1 -> 3.66-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded curl (7.76.1-1 -> 7.77.0-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libelf (0.183-3 -> 0.184-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libdrm (2.4.105-1 -> 2.4.106-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libx11 (1.7.0-4 -> 1.7.1-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded libxfixes (5.0.3-4 -> 6.0.0-1)
[2021-06-07T17:36:12+0100] [ALPM] upgraded mesa (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:13+0100] [ALPM] upgraded pcre2 (10.36-1 -> 10.37-1)
[2021-06-07T17:36:13+0100] [ALPM] upgraded kmod (28-1 -> 29-1)
[2021-06-07T17:36:13+0100] [ALPM] upgraded file (5.40-3 -> 5.40-5)
[2021-06-07T17:36:13+0100] [ALPM] upgraded libnl (3.5.0-2 -> 3.5.0-3)
[2021-06-07T17:36:13+0100] [ALPM] upgraded glib2 (2.68.1-1 -> 2.68.2-1)
[2021-06-07T17:36:13+0100] [ALPM] upgraded libinput (1.17.2-2 -> 1.17.3-1)
[2021-06-07T17:36:13+0100] [ALPM] upgraded libproxy (0.4.17-1 -> 0.4.17-2)
[2021-06-07T17:36:14+0100] [ALPM] upgraded qt5-base (5.15.2+kde+r192-1 -> 5.15.2+kde+r196-1)
[2021-06-07T17:36:14+0100] [ALPM] upgraded adwaita-qt (1.2.1-1 -> 1.3.1-1)
[2021-06-07T17:36:14+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.28-0 -> 1:0.3.28-1)
[2021-06-07T17:36:14+0100] [ALPM] upgraded amd-ucode (20210511.r1922.7685cf4-1 -> 20210518.r1928.f846292-1)
[2021-06-07T17:36:15+0100] [ALPM] upgraded python (3.9.5-1 -> 3.9.5-3)
[2021-06-07T17:36:15+0100] [ALPM] upgraded apparmor (3.0.1-1 -> 3.0.1-3)
[2021-06-07T17:36:15+0100] [ALPM] upgraded libsigc++ (2.10.6-1 -> 2.10.7-2)
[2021-06-07T17:36:15+0100] [ALPM] upgraded glibmm (2.66.0-1 -> 2.66.1-2)
[2021-06-07T17:36:15+0100] [ALPM] upgraded atkmm (2.28.1-1 -> 2.28.2-2)
[2021-06-07T17:36:16+0100] [ALPM] upgraded bat (0.18.0-2 -> 0.18.1-1)
[2021-06-07T17:36:16+0100] [ALPM] upgraded bind (9.16.15-1 -> 9.16.16-1)
[2021-06-07T17:36:16+0100] [ALPM] upgraded elfutils (0.183-3 -> 0.184-1)
[2021-06-07T17:36:16+0100] [ALPM] upgraded binutils (2.36.1-2 -> 2.36.1-3)
[2021-06-07T17:36:16+0100] [ALPM] upgraded python-urllib3 (1.26.4-1 -> 1.26.5-1)
[2021-06-07T17:36:16+0100] [ALPM] upgraded pacman (5.2.2-5 -> 5.2.2-6)
[2021-06-07T17:36:17+0100] [ALPM] upgraded sudo (1.9.6.p1-1 -> 1.9.7-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded fzf (0.27.0-1 -> 0.27.1-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded powertop (2.13-1 -> 2.14-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-encode-locale (1.05-7 -> 1.05-8)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-timedate (2.33-2 -> 2.33-3)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-http-date (6.05-3 -> 6.05-4)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-file-listing (6.14-1 -> 6.14-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-html-tagset (3.20-10 -> 3.20-11)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-clone (0.45-2 -> 0.45-3)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-io-html (1.004-1 -> 1.004-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-lwp-mediatypes (6.02-8 -> 6.02-9)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-uri (5.09-1 -> 5.09-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-http-message (6.29-1 -> 6.32-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-html-parser (3.76-1 -> 3.76-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-http-cookies (6.10-1 -> 6.10-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-http-daemon (6.06-2 -> 6.06-3)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-http-negotiate (6.01-8 -> 6.01-9)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-net-http (6.21-1 -> 6.21-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-try-tiny (0.30-5 -> 0.30-6)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-www-robotrules (6.02-8 -> 6.02-9)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-libwww (6.54-1 -> 6.54-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-xml-parser (2.46-2 -> 2.46-3)
[2021-06-07T17:36:17+0100] [ALPM] upgraded perl-xml-writer (0.625-6 -> 0.625-7)
[2021-06-07T17:36:17+0100] [ALPM] upgraded hwinfo (21.73-1 -> 21.74-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded mhwd-nvidia (460.80-1 -> 465.31-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded bmenu (0.14-1 -> 0.16-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded btrfs-progs (5.12-2 -> 5.12.1-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded cairomm (1.12.2-4 -> 1.14.3-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded nspr (4.30-1 -> 4.31-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded nss (3.64-1 -> 3.66-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded libtool (2.4.6+42+gb88cebd5-15 -> 2.4.6+42+gb88cebd5-16)
[2021-06-07T17:36:17+0100] [ALPM] upgraded ceph-libs (15.2.10-1 -> 15.2.12-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded dav1d (0.8.2-1 -> 0.9.0-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded pango (1:1.48.4-1 -> 1:1.48.5-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded librsvg (2:2.50.5-1 -> 2:2.50.6-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded libmfx (20.5.1-1 -> 21.1.3-2)
[2021-06-07T17:36:17+0100] [ALPM] upgraded svt-av1 (0.8.6-3 -> 0.8.7-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded python-pyqt5-sip (12.8.1-3 -> 12.9.0-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded libepoxy (1.5.7-1 -> 1.5.8-1)
[2021-06-07T17:36:17+0100] [ALPM] upgraded gsettings-desktop-schemas (40.0-2 -> 40.0-3)
[2021-06-07T17:36:18+0100] [ALPM] upgraded chromium (90.0.4430.212-1 -> 91.0.4472.77-1)
[2021-06-07T17:36:18+0100] [ALPM] upgraded chrony (4.0-1 -> 4.1-1)
[2021-06-07T17:36:19+0100] [ALPM] upgraded cmake (3.20.2-1 -> 3.20.3-1)
[2021-06-07T17:36:19+0100] [ALPM] upgraded perl-json (2.97001-2 -> 4.03-1)
[2021-06-07T17:36:19+0100] [ALPM] upgraded perl-locale-po (0.27-6 -> 0.27-7)
[2021-06-07T17:36:19+0100] [ALPM] upgraded cockpit (243-1 -> 245-1)
[2021-06-07T17:36:20+0100] [ALPM] warning: /etc/libvirt/qemu.conf installed as /etc/libvirt/qemu.conf.pacnew
[2021-06-07T17:36:20+0100] [ALPM] upgraded libvirt (1:7.1.0-3 -> 1:7.3.0-1)
[2021-06-07T17:36:20+0100] [ALPM] upgraded cockpit-machines (243.1-1 -> 244.1-1)
[2021-06-07T17:36:20+0100] [ALPM] upgraded d-feet (0.3.15-3 -> 0.3.16-1)
[2021-06-07T17:36:20+0100] [ALPM] upgraded dhclient (4.4.2-2 -> 4.4.2.P1-1)
[2021-06-07T17:36:20+0100] [ALPM] upgraded djvulibre (3.5.28-2 -> 3.5.28-3)
[2021-06-07T17:36:21+0100] [ALPM] upgraded electron (12.0.7-1 -> 12.0.9-1)
[2021-06-07T17:36:22+0100] [ALPM] upgraded electron10 (10.4.5-1 -> 10.4.7-1)
[2021-06-07T17:36:22+0100] [ALPM] upgraded extra-cmake-modules (5.82.0-1 -> 5.82.0-2)
[2021-06-07T17:36:24+0100] [ALPM] upgraded firefox (89.0-0.1 -> 89.0-1)
[2021-06-07T17:36:24+0100] [ALPM] upgraded fish (3.2.2-1 -> 3.2.2-2)
[2021-06-07T17:36:24+0100] [ALPM] upgraded xdg-dbus-proxy (0.1.2-2 -> 0.1.2-3)
[2021-06-07T17:36:25+0100] [ALPM] upgraded pipewire (1:0.3.28-0 -> 1:0.3.28-1)
[2021-06-07T17:36:25+0100] [ALPM] upgraded flatpak (1.10.2-1 -> 1.11.1-1)
[2021-06-07T17:36:25+0100] [ALPM] upgraded fltk (1.3.5-4 -> 1.3.6-1)
[2021-06-07T17:36:27+0100] [ALPM] upgraded gcc (10.2.0-6 -> 11.1.0-1)
[2021-06-07T17:36:27+0100] [ALPM] upgraded imath (3.0.1-1 -> 3.0.3-1)
[2021-06-07T17:36:27+0100] [ALPM] upgraded openexr (3.0.1-2 -> 3.0.3-1)
[2021-06-07T17:36:27+0100] [ALPM] upgraded suitesparse (5.9.0-1 -> 5.10.1-1)
[2021-06-07T17:36:27+0100] [ALPM] upgraded gegl (0.4.30-2 -> 0.4.30-3)
[2021-06-07T17:36:27+0100] [ALPM] upgraded libidn (1.36-1 -> 1.37-1)
[2021-06-07T17:36:28+0100] [ALPM] upgraded graphviz (2.47.1-1 -> 2.47.2-1)
[2021-06-07T17:36:31+0100] [ALPM] upgraded gimp (2.10.24-3 -> 2.10.24-4)
[2021-06-07T17:36:31+0100] [ALPM] upgraded gjs (2:1.68.0-4 -> 2:1.68.1-1)
[2021-06-07T17:36:31+0100] [ALPM] upgraded glances (3.1.5-2 -> 3.1.7-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded glib2-docs (2.68.1-1 -> 2.68.2-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded pangomm (2.46.0-1 -> 2.46.1-2)
[2021-06-07T17:36:32+0100] [ALPM] upgraded gtkmm3 (3.24.4-1 -> 3.24.5-2)
[2021-06-07T17:36:32+0100] [ALPM] upgraded gparted (1.3.0-3 -> 1.3.0-4)
[2021-06-07T17:36:32+0100] [ALPM] upgraded graphicsmagick (1.3.36-2 -> 1.3.36-3)
[2021-06-07T17:36:32+0100] [ALPM] upgraded pipewire-media-session (1:0.3.28-0 -> 1:0.3.28-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded gst-plugin-pipewire (1:0.3.28-0 -> 1:0.3.28-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded gst-plugins-bad-libs (1.18.4-6 -> 1.18.4-7)
[2021-06-07T17:36:32+0100] [ALPM] upgraded svt-hevc (1.5.0-1 -> 1.5.1-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded zxing-cpp (1.1.1-1 -> 1.2.0-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded libcaca (0.99.beta19-4 -> 0.99.beta19-5)
[2021-06-07T17:36:32+0100] [ALPM] upgraded gupnp (1.2.4-1 -> 1.2.6-1)
[2021-06-07T17:36:32+0100] [ALPM] upgraded imagemagick (7.0.11.12-1 -> 7.0.11.13-3)
[2021-06-07T17:36:33+0100] [ALPM] upgraded gst-plugins-bad (1.18.4-6 -> 1.18.4-7)
[2021-06-07T17:36:33+0100] [ALPM] upgraded highlight (4.0-1 -> 4.1-1)
[2021-06-07T17:36:33+0100] [ALPM] upgraded hivex (1.3.19-4 -> 1.3.20-5)
[2021-06-07T17:36:33+0100] [ALPM] installed ragel (6.10-3)
[2021-06-07T17:36:33+0100] [ALPM] installed gtest (1.10.0-6)
[2021-06-07T17:36:33+0100] [ALPM] installed lib2geom (1.1-1)
[2021-06-07T17:36:33+0100] [ALPM] upgraded libwpd (0.10.3-2 -> 0.10.3-3)
[2021-06-07T17:36:34+0100] [ALPM] upgraded inkscape (1.0.2-6 -> 1.1-1)
[2021-06-07T17:36:34+0100] [ALPM] upgraded lib32-libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-06-07T17:36:34+0100] [ALPM] upgraded lib32-curl (7.76.1-1 -> 7.77.0-1)
[2021-06-07T17:36:34+0100] [ALPM] upgraded lib32-expat (2.3.0-2 -> 2.4.1-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-gcc-libs (10.2.0-6 -> 11.1.0-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-glib2 (2.68.1-1 -> 2.68.2-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libcap (2.49-1 -> 2.50-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libdrm (2.4.105-1 -> 2.4.106-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libelf (0.183-3 -> 0.184-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libepoxy (1.5.7-1 -> 1.5.8-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libx11 (1.7.0-1 -> 1.7.1-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-pango (1:1.48.4-1 -> 1:1.48.5-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-libtiff (4.2.0-1 -> 4.3.0-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-librsvg (2.50.5-1 -> 2:2.50.6-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-mesa (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-mesa-vdpau (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-sqlite (3.35.4-1 -> 3.35.5-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-vulkan-intel (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:35+0100] [ALPM] upgraded lib32-vulkan-radeon (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:35+0100] [ALPM] upgraded libcpuid (0.5.1.r1.gccd0ec8-1 -> 0.5.1.r2.g0f1ad69-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded libcurl-gnutls (7.76.1-1 -> 7.77.0-1)
[2021-06-07T17:36:35+0100] [ALPM] upgraded libxml++ (3.2.2-1 -> 3.2.3-1)
[2021-06-07T17:36:36+0100] [ALPM] upgraded libffado (2.4.4-2 -> 2.4.4-3)
[2021-06-07T17:36:36+0100] [ALPM] upgraded libglade (2.6.4-7 -> 2.6.4-8)
[2021-06-07T17:36:36+0100] [ALPM] upgraded virglrenderer (0.8.2-1 -> 0.9.1-1)
[2021-06-07T17:36:36+0100] [ALPM] upgraded libslirp (4.4.0-1 -> 4.5.0-1)
[2021-06-07T17:36:36+0100] [ALPM] upgraded qemu (6.0.0-2 -> 6.0.0-3)
[2021-06-07T17:36:36+0100] [ALPM] upgraded perl-libintl-perl (1.32-1 -> 1.32-2)
[2021-06-07T17:36:37+0100] [ALPM] upgraded vim-runtime (8.2.2845-1 -> 8.2.2891-1)
[2021-06-07T17:36:37+0100] [ALPM] upgraded vim (8.2.2845-1 -> 8.2.2891-1)
[2021-06-07T17:36:37+0100] [ALPM] upgraded mtools (4.0.27-1 -> 4.0.28-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libguestfs (1.42.0-5 -> 1.44.1-4)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libimagequant (2.15.0-1 -> 2.15.1-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libinput-gestures (2.64-1 -> 2.67-1)
[2021-06-07T17:36:38+0100] [ALPM-SCRIPTLET] e[34;1m=== UPGRADE NOTES for libinput-gestures ===
[2021-06-07T17:36:38+0100] [ALPM-SCRIPTLET] e[39;1mA user should restart libinput-gestures, i.e. run:
[2021-06-07T17:36:38+0100] [ALPM-SCRIPTLET] libinput-gestures-setup restart
[2021-06-07T17:36:38+0100] [ALPM-SCRIPTLET] e[0m
[2021-06-07T17:36:38+0100] [ALPM] upgraded libmediaart (1.9.4+1+ga704d0b-2 -> 1.9.5-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libndp (1.7-2 -> 1.8-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libportal (0.3-2 -> 0.4-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libqmi (1.28.2-1 -> 1.28.4-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libsass (3.6.4-1 -> 3.6.5-1)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libsynctex (2020.54586-14 -> 2021.58686-3)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libva-mesa-driver (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:36:38+0100] [ALPM] upgraded libvirt-python (1:7.1.0-1 -> 1:7.3.0-1)
[2021-06-07T17:36:42+0100] [ALPM] upgraded linux-firmware (20210511.r1922.7685cf4-1 -> 20210518.r1928.f846292-1)
[2021-06-07T17:36:46+0100] [ALPM] upgraded linux510 (5.10.36-2 -> 5.10.41-1)
[2021-06-07T17:36:52+0100] [ALPM] upgraded linux510-headers (5.10.36-2 -> 5.10.41-1)
[2021-06-07T17:36:52+0100] [ALPM] upgraded linux510-zfs (2.0.4-15 -> 2.0.4-21)
[2021-06-07T17:37:00+0100] [ALPM] upgraded linux54 (5.4.118-1 -> 5.4.123-1)
[2021-06-07T17:37:04+0100] [ALPM] upgraded linux54-headers (5.4.118-1 -> 5.4.123-1)
[2021-06-07T17:37:04+0100] [ALPM] upgraded linux54-zfs (2.0.4-15 -> 2.0.4-21)
[2021-06-07T17:37:09+0100] [ALPM] upgraded manjaro-release (21.0.5-1 -> 21.0.6-1)
[2021-06-07T17:37:09+0100] [ALPM] upgraded manjaro-settings-manager (0.5.6-13 -> 0.5.6-14)
[2021-06-07T17:37:09+0100] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.6-13 -> 0.5.6-14)
[2021-06-07T17:37:09+0100] [ALPM] upgraded qt5-declarative (5.15.2+kde+r24-1 -> 5.15.2+kde+r26-1)
[2021-06-07T17:37:09+0100] [ALPM] upgraded mediaelch (2.8.6-1 -> 2.8.12-1)
[2021-06-07T17:37:09+0100] [ALPM] upgraded mesa-vdpau (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:37:09+0100] [ALPM] upgraded nodejs (16.1.0-1 -> 16.2.0-1)
[2021-06-07T17:37:10+0100] [ALPM] upgraded node-gyp (8.0.0-1 -> 8.1.0-1)
[2021-06-07T17:37:10+0100] [ALPM] upgraded npm (7.12.1-1 -> 7.15.0-1)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-capture-tiny (0.48-4 -> 0.48-5)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-dbi (1.643-2 -> 1.643-3)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-dbd-sqlite (1.66-1 -> 1.66-2)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-error (0.17029-2 -> 0.17029-3)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-exporter-tiny (1.002002-2 -> 1.002002-3)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-image-exiftool (12.25-1 -> 12.26-2)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-inc-latest (0.500-7 -> 0.500-8)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-list-moreutils-xs (0.430-1 -> 0.430-2)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-list-moreutils (0.430-1 -> 0.430-2)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-mailtools (2.21-4 -> 2.21-5)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-module-build (0.4231-3 -> 0.4231-5)
[2021-06-07T17:37:10+0100] [ALPM] upgraded perl-parse-yapp (1.21-3 -> 1.21-4)
[2021-06-07T17:37:11+0100] [ALPM] upgraded perl-tk (804.036-2 -> 804.036-3)
[2021-06-07T17:37:11+0100] [ALPM] upgraded postgresql-libs (13.2-2 -> 13.3-2)
[2021-06-07T17:37:11+0100] [ALPM] upgraded psensor (1.2.1-1 -> 1.2.1-2)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-attrs (20.3.0-3 -> 21.2.0-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-markupsafe (1.1.1-7 -> 2.0.1-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-numpy (1.20.2-1 -> 1.20.3-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-setuptools (1:56.1.0-1 -> 1:56.2.0-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-wxpython (4.0.7.2-5 -> 4.1.1-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded python-xlib (0.29-1 -> 0.30-1)
[2021-06-07T17:37:11+0100] [ALPM] upgraded qjournalctl (0.6.3-1 -> 0.6.3-2)
[2021-06-07T17:37:12+0100] [ALPM] upgraded qt5-wayland (5.15.2+kde+r19-1 -> 5.15.2+kde+r23-1)
[2021-06-07T17:37:12+0100] [ALPM] upgraded remmina (1:1.4.14-1 -> 1:1.4.17-1)
[2021-06-07T17:37:12+0100] [ALPM] upgraded sassc (3.6.1-2 -> 3.6.2-2)
[2021-06-07T17:37:12+0100] [ALPM] upgraded snapd (2.50-1 -> 2.51-1)
[2021-06-07T17:37:12+0100] [ALPM] upgraded speedtest-cli (2.1.3-0 -> 2.1.3-1)
[2021-06-07T17:37:12+0100] [ALPM] upgraded unrar (1:6.0.5-1 -> 1:6.0.6-1)
[2021-06-07T17:37:12+0100] [ALPM] upgraded uwsgi (2.0.19.1-11 -> 2.0.19.1-13)
[2021-06-07T17:37:13+0100] [ALPM] upgraded vlc (3.0.13-2 -> 3.0.14-1)
[2021-06-07T17:37:13+0100] [ALPM] warning: /etc/vnstat.conf installed as /etc/vnstat.conf.pacnew
[2021-06-07T17:37:13+0100] [ALPM] upgraded vnstat (2.6-1 -> 2.7-1)
[2021-06-07T17:37:13+0100] [ALPM] upgraded vulkan-intel (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:37:13+0100] [ALPM] upgraded vulkan-radeon (21.0.3-3 -> 21.1.2-0)
[2021-06-07T17:37:13+0100] [ALPM] upgraded wpebackend-fdo (1.9.91-1 -> 1.9.92-1)
[2021-06-07T17:37:16+0100] [ALPM] transaction completed
[2021-06-07T17:37:18+0100] [ALPM] running '20-systemd-sysusers.hook'...
[2021-06-07T17:37:18+0100] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-06-07T17:37:18+0100] [ALPM] running '30-systemd-sysctl.hook'...
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM-SCRIPTLET] Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
[2021-06-07T17:37:18+0100] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-06-07T17:37:18+0100] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-06-07T17:37:18+0100] [ALPM] running '30-systemd-update.hook'...
[2021-06-07T17:37:18+0100] [ALPM] running '40-update-ca-trust.hook'...
[2021-06-07T17:37:19+0100] [ALPM] running '60-depmod.hook'...
[2021-06-07T17:37:29+0100] [ALPM] running '70-dkms-install.hook'...
[2021-06-07T17:37:29+0100] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m it87 -v 154.b159857 -k 5.4.123-1-MANJARO
[2021-06-07T17:37:32+0100] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m it87 -v 154.b159857 -k 5.10.41-1-MANJARO
[2021-06-07T17:37:35+0100] [ALPM-SCRIPTLET] ==> depmod 5.4.123-1-MANJARO
[2021-06-07T17:37:40+0100] [ALPM-SCRIPTLET] ==> depmod 5.10.41-1-MANJARO
[2021-06-07T17:37:45+0100] [ALPM] running '80-cronie.hook'...
[2021-06-07T17:37:45+0100] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-06-07T17:37:45+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-06-07T17:37:45+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-06-07T17:37:45+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.41-1-MANJARO
[2021-06-07T17:37:45+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:37:46+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-07T17:37:46+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:37:46+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:37:46+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:37:46+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:37:49+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:37:49+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:37:50+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:37:50+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.10.41-1-MANJARO
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:37:53+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:37:55+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:37:55+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:37:56+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:37:56+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-07T17:37:59+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:37:59+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:38:01+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:38:01+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.123-1-MANJARO
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:38:07+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:38:08+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:38:08+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:38:09+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:38:09+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-07T17:38:11+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:38:11+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:38:11+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:38:12+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2021-06-07T17:38:14+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:38:14+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
[2021-06-07T17:38:14+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2021-06-07T17:38:14+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.4.123-1-MANJARO
[2021-06-07T17:38:14+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:38:15+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:38:15+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:38:15+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:38:16+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:38:17+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:38:17+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:38:18+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-07T17:38:20+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:38:21+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:38:23+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:38:23+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2021-06-07T17:38:28+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:38:28+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
[2021-06-07T17:38:28+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2021-06-07T17:38:28+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-06-07T17:38:28+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:38:29+0100] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-06-07T17:38:29+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:38:29+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:38:29+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:38:30+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:38:30+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:38:31+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:38:31+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-07T17:38:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:38:33+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:38:34+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:38:34+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] ==> Starting build: 5.9.16-1-MANJARO
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-07T17:38:37+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-07T17:38:39+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-07T17:38:40+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-07T17:38:41+0100] [ALPM-SCRIPTLET] ==> ERROR: file not found: `'
[2021-06-07T17:38:41+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-07T17:38:44+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-07T17:38:44+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-07T17:38:46+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-06-07T17:38:47+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2021-06-07T17:38:52+0100] [ALPM-SCRIPTLET] ==> WARNING: errors were encountered during the build. The image may not be complete.
[2021-06-07T17:38:52+0100] [ALPM] running '99-grub.hook'...
[2021-06-07T17:38:52+0100] [ALPM-SCRIPTLET] /usr/bin/grub-probe: error: cannot find a device for / (is /dev mounted?).
[2021-06-07T17:38:52+0100] [ALPM] running 'dbus-reload.hook'...
[2021-06-07T17:38:52+0100] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-06-07T17:38:53+0100] [ALPM-SCRIPTLET] WARNING: '/usr/lib/perl5/5.32' contains data from at least 1 packages which will NOT be used by the installed perl interpreter.
[2021-06-07T17:38:53+0100] [ALPM-SCRIPTLET] -> Run the following command to get a list of affected packages: pacman -Qqo '/usr/lib/perl5/5.32'
[2021-06-07T17:38:53+0100] [ALPM] running 'firefox-post.hook'...
[2021-06-07T17:38:53+0100] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-06-07T17:38:53+0100] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2021-06-07T17:38:53+0100] [ALPM] running 'glib-compile-schemas.hook'...
[2021-06-07T17:38:53+0100] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-06-07T17:38:53+0100] [ALPM] running 'texinfo-install.hook'...
[2021-06-07T17:38:54+0100] [ALPM] running 'update-desktop-database.hook'...
[2021-06-07T17:38:54+0100] [ALPM] running 'update-mime-database.hook'...
[2021-06-07T17:38:54+0100] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2021-06-07T17:38:55+0100] [ALPM] running 'vimdoc.hook'...
[2021-06-07T17:40:24+0100] [ALPM] transaction started
[2021-06-07T17:40:24+0100] [ALPM] upgraded brave-beta-bin (1.26.52-1 -> 1.26.53-1)
[2021-06-07T17:40:24+0100] [ALPM] transaction completed
[2021-06-07T17:40:24+0100] [ALPM] running '30-systemd-update.hook'...
[2021-06-07T17:40:24+0100] [ALPM] running 'update-desktop-database.hook'...
[2021-06-07T18:40:07+0100] [PAMAC] synchronizing package lists
Another update:
I decided to downgrade cryptsetup, since I use ZFS snapshots I could always rollback.
First downloaded the previous cryptsetup build from Arch archive:
sudo wget https://archive.archlinux.org/packages/c/cryptsetup/cryptsetup-2.3.5-4-x86_64.pkg.tar.zst
Then issued a pacman downgrade command:
pacman -U /var/cache/pacman/pkg/cryptsetup-2.3.5-4-x86_64.pkg.tar.zst
Bingo!
The sd-encrypt hook runs flawlessly:
[2021-06-13T09:50:22+0100] [ALPM-SCRIPTLET] -> Running build hook: [systemd]
[2021-06-13T09:50:23+0100] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-06-13T09:50:23+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-vconsole]
[2021-06-13T09:50:23+0100] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-06-13T09:50:24+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-plymouth]
[2021-06-13T09:50:25+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-encrypt]
[2021-06-13T09:50:26+0100] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-06-13T09:50:29+0100] [ALPM-SCRIPTLET] -> Running build hook: [sd-zfs]
[2021-06-13T09:50:30+0100] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-06-13T09:50:32+0100] [ALPM-SCRIPTLET] ==> Generating module dependencies
Therefore I am calling this a confirmed bug and editing the title of this post accordingly.
Also adding crypsetup to IgnorePkg list on pacman.conf, until such time as this is addressed.
I have no idea where to file this bug, if anyone can chime in and advise it would be great, as this needs to be addressed for the benefit of the community
I guess this one needs to be addressed here: Arch Linux Bugtracker:: Arch Linux: Tasklist
Btw… nice catch
Thank you for the advice.
Bug was reported here:
https://bugs.archlinux.org/task/71247
Issue was closed on Arch with the following comment:
This is not the manjaro bugtracker.
Next time I will not take the time to report anything over there.
This would be the right place to report I presume?
I don’t know.
I was following @megavolt advice in good faith.
@aljazzair @Hanzel
If I look here:
pamac info cryptsetup
Version : 2.3.6-1
Description : Userspace setup tool for transparent encryption of block devices using dm-crypt
URL : https://gitlab.com/cryptsetup/cryptsetup/
Licenses : GPL
Repository : core
Installed Size : 2.7 MB
Depends On : device-mapper libdevmapper.so=1.02-64 openssl popt util-linux-libs
libuuid.so=1-64 json-c libjson-c.so=5-64 argon2 libargon2.so=1-64
Make Dependencies : util-linux
Provides : libcryptsetup.so=12-64
Packager : Christian Hesse <arch@eworm.de>
Build Date : 05/28/21
Install Date : 06/08/21
Install Reason : Explicitly installed
Signatures : Yes
Then the packager is from the arch team:
So I presumed it is just ported from archlinux.
If it is a mkinitcpio problem, then sure, it is then a Manjaro Package:
pamac info mkinitcpio ✔
Version : 29-1.0
Description : Modular initramfs image creation utility
URL : https://projects.archlinux.org/mkinitcpio.git/
Licenses : GPL
Repository : core
Installed Size : 105.7 kB
Depends On : awk mkinitcpio-busybox>=1.19.4-2 kmod util-linux>=2.23 libarchive coreutils bash
diffutils findutils grep filesystem>=2011.10-1 gzip systemd asciidoc
Optional Dependencies : xz: Use lzma or xz compression for the initramfs image [Installed]
bzip2: Use bzip2 compression for the initramfs image [Installed]
lzop: Use lzo compression for the initramfs image
lz4: Use lz4 compression for the initramfs image [Installed]
mkinitcpio-nfs-utils: Support for root filesystem on NFS
Provides : initramfs
Packager : Helmut Stult <helmut@manjaro.org>
Build Date : 10/30/20
Install Date : 01/03/21
Install Reason : Installed as a dependency for another package
Signatures : Yes
Backup files : /etc/mkinitcpio.conf
Thank you for following up.
All I know is downgrading cryptsetup removes the error.
The triaging folks over at arch bugtracker are not in agreement however.
Therefore I will leave it at that.
I will let people with more experience with the intricacies of bug filing raise it with the proper teams.
Yeah I think it is difficult to say where to report that:
You use Manjaro with a package from Archlinux, but Archlinux does not support Manjaro and Manjaro has not its own Package, where you could report a bug… however difficult somehow.
philm
13 June 2021 14:58
13
The issue is this: update sd-encrypt hook · archlinux/svntogit-packages@bf77990 · GitHub
People had reported to me to have issues with the newer systemd series. Therefore I did hold it back. However cryptsetup slipped. We have to use the older version if we keep the older systemd series.
So let’s update systemd to the 248 series and you switch over to stable-staging branch to test that out. This should fix the issue. And for stable branch I’ll downgrade cryptsetup for now.
Thanks @philm .
This clears it up.
philm
13 June 2021 15:11
15
sudo pacman-mirrors -aB stable-staging
sudo pacman -Syyu
Would be the cmds to do it. After your tests and we did the stable snap you may switch back to stable branch. Thx.
I tried the stable-staging switch but could not complete upgrade and testing due to unresolved dependencies unrelated to this thread.
(If anyone is curious the reason is my Pacman config is Ignoring Pkgs for pulseaudio, as I am using a custom version of PA by Pali, for enhanced Bluetooth quality called SBC XQ, before moving to full fledged Pipewire ).
So long story short, I will have to wait for the stable branch to evolve.
Thanks again everyone for your kind feedback.
philm
13 June 2021 16:00
17
Well, stable-staging is the next stable update. So please test this branch and resolve your issues. If needed post about them, so we may help.
You are absolutely right.
It means I will have to work on replacing my custom PulseAudio setup with Pipewire in preparation for the next stable release.
That has to be done before I can dive into the stable-staging branch.
Maybe a stupid question:
On my system I also noticed pacman’s warning: “Warning: cryptsetup: Local version (2.3.6-1) is newer than core (2.3.5-4)” (only retranslated from German)
As to Philip’s explanation “core” should be a part of systemd, (which has its own different version number.)
How to display the version number of “core”?
That means “than in core”. Core stands for the repository of core packages, not some package. This message means your currently installed (local) version has a higher version than in remote repository of core packages. You need to do sudo pacman -S cryptsetup
