Oh, thanks a lot! I did completely misinterpret it
I can confirm that switching to stable-staging solved this error for me! Thanks
sudo mkinitcpio -p linux510
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.42-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [systemd]
-> Running build hook: [sd-vconsole]
-> Running build hook: [sd-plymouth]
-> Running build hook: [sd-encrypt]
-> Running build hook: [lvm2]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
I’m just marking this post as accepted solution for this thread.
So far this is the best answer you guys can get at the moment.
unfortunately I had to revert to the older systemd and cryptsetup! I use a keyfile in my crypttab and I was not able to decrypt with it anymore - even without systemd (i.e. no sd-encrypt but encrypt). I guess that is related to cryptsetup then but anyways this is not working atm as it should. using cryptsetup open … --keyfile … was still working fine so so no idea where the bug actually is…
the error I get is:
Jul 03 20:17:32 systemd-cryptsetup[534]: Set cipher aes, mode xts-plain64, key size 512 bits for device /dev/sdb1.
Jul 03 20:17:32 systemd-cryptsetup[534]: Failed to activate with key file '/home/tfi/2tb.k': Invalid argument
Jul 03 20:17:32 systemd[1]: systemd-cryptsetup@bigopt.service: Main process exited, code=exited, status=1/FAILURE
Jul 03 20:17:32 systemd[1]: systemd-cryptsetup@bigopt.service: Failed with result 'exit-code'.
Jul 03 20:17:32 systemd[1]: Failed to start Cryptography Setup for bigopt
where bigopt is the name for the encrypted device.
/etc/crypttab:
bigopt /dev/sdb1 /home/myname/2tb.k timeout=30,nofail
I have also tried to put it in /etc/cryptsetup-keys.d/bigopt.key and specifying it with luks.key=xx-uuid=/path/to/keyfile (when sd-encrypt was enabled) but whatever I tried nothing worked. the only thing which worked was downgrading systemd + cryptsetup (I did that in one run so dunno if it is the one or the other or both…)
currently on (working - without sd-encrypt):
systemd 247.6-1.0
cryptsetup 2.3.5-4
will now upgrade to
cryptsetup-2.3.6-1
systemd-248.3-3
(I wasnt sure about the previous version I had installed so downgraded too much. now I am back at stable and not stable-staging anymore and so upgrade to the latest version there)
upgraded to
cryptsetup-2.3.6-1
systemd-248.3-3
and keyfile stops working again.
downgraded to:
systemd 247.7-1 <--- newer then on my above other try
cryptsetup 2.3.5-4
and it works again… im lost.
