Misunderstanding of mkinitcpio pacnew file
well, there was finally an issue on my computer.
I replaced the /etc/mkinitcpio.conf with the pacnew. After mkinitcpio -P the computer stayed stucked during boot sequence just right after grub menu.
I had to revert to the older mkinitcpio.conf file, then mkinitcpio -P again to be able to boot again.
I hope I won’t have to touch this file again for a long time :grimacing:
So here is the HOOKS constant that worked
HOOKS=(base udev autodetect kms modconf block keyboard keymap consolefont plymouth encrypt filesystems fsck)
And here is the faulty one (the one from pacnew file)
HOOKS=(base systemd autodetect microcode modconf kms keyboard keymap sd-vconsole block filesystems fsck)
You are not supposed to do that. The idea of a .pacnew is that it introduces some new upstream defaults — which may or may not be suitable for your system — and that you inspect both files and wisely merge the new defaults (if applicable) into your existing configuration.
If things were as simple as that the .pacnew could replace the existing file, then the package manager could have done so itself. But it doesn’t, because the .pacnewis only advisory — that’s the whole point.
as stated earlier… pacnews should never be considered a direct replacement for a conf file… you need to compare and merge the appropriate changes for your system… if you are unsure, create a support thread and someone will likely help you out, and until then, leave the old conf as is.
Just stick to your old configs. The change to new systemd default is optional. Obviously, just copying over would be clearly wrong approach as for example encrypt (if really required for you) would have needed to be “translated” into sd-encrypt etc. We can’t see if there have been other settings lost when just copying over the pacnew-file.
The .pacnew isn’t even correct, because it omits the sd-encrypt and plymouth hooks, and it still contains the keymap hook, which is unneeded with sd-vconsole.
Either way, I’ve already explained all of this — including a link to the Arch Wiki article — in this post (and others) on the 2025.12.08 Stable Update thread, but if people only want to post their grievances without looking at the information that’s already up there… :man_shrugging:
If your system is working with the first HOOKS line, it means your root filesystem is encrypted, so you must keep the sd-encrypt hook — the pacnew version removed it, which is why your system got stuck before booting.
Here is the minimal correct HOOKS array for your setup:
HOOKS=(base systemd autodetect microcode modconf kms keyboard sd-vconsole block plymouth sd-encrypt filesystems fsck)
well,
First I forgot to mention, but the actual HOOK I used when my computer crashed in boot was this one:
HOOKS=(base systemd autodetect microcode modconf kms keyboard keymap sd-vconsole sd-encrypt block filesystems fsck)
So there was already the sd-encrypt hook and it didn’t prevent my laptop from crashing at boot.
But anyway, I tried the HOOKS env you suggested:
Then to prevent my computer being stuck again in case the const were wrong (and having to USB boot and chroot to fix), I install linux-6.18 as new kernel using the Manjaro tool (6.12 and 6.6 are already installed).
During kernel installation I can see in logs that mkinitcpio is executed (and mentions about the new hooks), but only on 6.18.
After reboot I landed in Emergency Mode.
Then I reboot on 6.12, put back the HOOKS const as it was prior to the last stable update:
Then mkinitcpio -P
This time I was able to boot on 6.18.
Mod edit:- Removed picture of text. Modified text for continuity. No charge.
@ms34 Please avoid posting picturs of text when a brief description will suffice.
I can only suggest collecting a bit more system information so someone more experienced with systemd initramfs and encrypted setups can take a look and help.
If you can, please post the outputs of the following:
  • cat /proc/cmdline
  • lsblk -f
  • ls /etc/mkinitcpio.d/
  • grep -v -e “^#” -e “^$” /etc/mkinitcpio.d/*.preset
  • grep -v -e “^#” -e “^$” /etc/mkinitcpio.conf
  • cat /etc/fstab
  • sudo mkinitcpio -v -p linux618
Maybe this will reveal what exactly is breaking with the systemd-based initramfs on your machine.
With an encrypted system,
when you switch from the previous HOOKS that are busybox based
to the now systemd based HOOKS
you also need to change the syntax of the kernel command line in /etc/default/grub
… just keep it as it is for now
make copies of the files
and then start to experiment converting to systemd based HOOKS
See this tutorial if it can help.
Was just about to save the new mkinitcpio changes until I saw this :upside_down_face:.
As someone running an encrypted system, what changes would I need to make? (For kernel 6.12 LTS)
the device names in /etc/default/grub start with rd.
… don’t ask me why - I don’t know
it’s the naming convention for a systemd based setup is all I know
perhaps you see the reasoning and logic behind it easier than I do - because I still don’t :grimacing:
The Arch wiki will be helpful, as it always is.
Do not worry just yet.
Just keep everything as it is - it will keep working for quite some time.
No need to rush to implement the “new” systemd based defaults.
Plenty of time to research and try - have backups of the files you alter
to be able to revert to a working setup.
Maybe for “resume device”? :thinking:
Of course, I wouldn’t know, because I don’t have any device names in my /etc/default/grub. :man_shrugging:
the names are just different - not only for the (possible, but not mandatory) resume device :man_shrugging:
What other device names do you have in there, then? :astonished_face:
Edit: My mistake — I presume that if you use an encrypted drive, that would also be in there.
I currently don’t have any.
I do not have an encrypted system as of right now.
Perhaps I’ll try an encrypted Arch or Manjaro install again some day.
In a VM.
I’m currently happy with the Debian derived equivalent Mint (also encrypted)
where this is handled … differently.
RAM Disk? (initramfs) :thinking:
perhaps, probably, maybe
It’s different - and the “old” names won’t work … is pretty much all I know
LLM says:
Short answer: “rd” means ramdisk. GRUB isn’t being cute; it’s being literal.
So when you see things like:
  • rd0, rd1
  • root=/dev/rd/0
  • initrd (initial ramdisk)
I’m done. Back to :popcorn:.
to that I say:
I do not care. :grin:
The “idea” seems plausible - but it’s wrong in this context.
… the limitations of LLM’s - they do not, can not, understand …
