Mistake with xfce4 folder trying to fix the whisker menu bug
Hello,
since I had the same bug as in this topic “start-menu-disappeared-after-update/49515” (the system tells me I can’t insert links) where favorites of whisker menu got blank.
I tried to repeat the simple solution described there
bug Fixed…I had to copy xfce4 folder to another folder and reboot, then I move folder back and its all perfect…
but I did it mistakenly - I moved the folder xfce4 (in /usr/share/) rather than copying it. Even after having brought it back to its location and reboot, the whisker menu has completely disppeared and even the panel got completely blank.
Is it still possible to fix it back? Thanks
Maybe try to re-install xfce4-whiskermenu-plugin ?
This will restore/reset the menu. Open a terminal & do the following.
xfce4-panel --quit
pkill xfconfd
rm -rf ~/.config/xfce4/panel
rm - rf ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-panel.xml
xfce4-panel
Welcome aboard. :slight_smile:
Thanks Hipster,
the commands restored the panel, but as for the whisker menu, there’s a normal menu instead of it.
Is there anything wrong with the last command?
Output of command lines:
[zero@zero-pc /]$ xfce4-panel --quit
[zero@zero-pc /]$ pkill xfconfd
[zero@zero-pc /]$ rm -rf ~/.config/xfce4/panel
[zero@zero-pc /]$ rm -rf ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-panel.xml
(xfce4-panel:50446): xfce4-panel-CRITICAL **: 08:05:37.997: Plugin xfce4-orageclock-plugin: The Desktop file /usr/share/xfce4/panel/plugins/xfce4-orageclock-plugin.desktop requested the Gtk2 API (v1.0), which is no longer supported.
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.076: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.076: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.076: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.076: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.146: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.146: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.147: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.147: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.198: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.198: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.198: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.198: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.236: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.237: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.237: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.237: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.281: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.281: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.281: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.281: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.317: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.317: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.317: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.317: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
xfce4-panel-Message: 08:05:38.353: Plugin "(null)-7" was not found and has been removed from the configuration
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.372: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.373: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.373: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.373: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.441: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.442: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.442: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.442: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.519: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.519: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.519: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.520: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.581: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.581: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.581: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.581: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.622: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.622: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.622: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.622: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.657: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.658: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.658: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.658: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:38.711: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.715: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.715: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.715: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.715: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:38.756: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.760: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.761: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.761: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.761: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:38.801: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.805: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.805: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.805: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.805: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:38.847: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.851: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.851: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.851: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.851: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.884: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.884: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.885: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.885: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.928: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.928: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.928: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(xfce4-panel:50446): Gtk-WARNING **: 08:05:38.928: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50457): GLib-GIO-CRITICAL **: 08:05:38.987: g_file_new_for_path: assertion 'path != NULL' failed
(wrapper-2.0:50457): GLib-GIO-CRITICAL **: 08:05:38.987: g_file_monitor_file: assertion 'G_IS_FILE (file)' failed
(wrapper-2.0:50457): GLib-GObject-WARNING **: 08:05:38.987: invalid (NULL) pointer instance
(wrapper-2.0:50457): GLib-GObject-CRITICAL **: 08:05:38.987: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:38.988: Attempting to add a widget with type GtkToggleButton to a container of type XfcePanelPlugin, but the widget is already inside a container of type XfcePanelPlugin, please remove the widget from its existing container first.
(wrapper-2.0:50454): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50454): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50454): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50466): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50454): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50466): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50466): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50466): Gtk-WARNING **: 08:05:38.994: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:39.026: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:39.026: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:39.026: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:39.026: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50455): Gtk-WARNING **: 08:05:39.054: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50455): Gtk-WARNING **: 08:05:39.054: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50455): Gtk-WARNING **: 08:05:39.054: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50455): Gtk-WARNING **: 08:05:39.055: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50454): libsystray-CRITICAL **: 08:05:39.111: sn_item_invalidate: assertion 'item->properties_proxy != NULL' failed
(wrapper-2.0:50456): xfce4-power-manager-plugin-WARNING **: 08:05:39.137: Xfce4-power-manager: The panel plugin is present, so the tray icon gets disabled.
(wrapper-2.0:50456): Gtk-WARNING **: 08:05:39.179: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50456): Gtk-WARNING **: 08:05:39.179: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50456): Gtk-WARNING **: 08:05:39.179: Theme parsing error: gtk.css:71:36: The style property GtkCheckMenuItem:indicator-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50456): Gtk-WARNING **: 08:05:39.179: Theme parsing error: gtk.css:76:30: The style property GtkExpander:expander-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(wrapper-2.0:50466): Gtk-WARNING **: 08:05:39.212: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner XfceArrowButton)
(wrapper-2.0:50455): Gtk-WARNING **: 08:05:39.218: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button, owner PulseaudioButton)
(wrapper-2.0:50457): Gtk-WARNING **: 08:05:39.239: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button, owner GtkToggleButton)
(wrapper-2.0:50456): Gtk-WARNING **: 08:05:39.291: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button, owner PowerManagerButton)
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:39.711: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
(xfce4-panel:50446): garcon-CRITICAL **: 08:05:39.712: garcon_gtk_menu_get_desktop_actions_menu: assertion 'actions != NULL' failed
And would it be possible to restore the whisker menu?
yes
I guess you now have a default panel which you can configure.
You can add the whisker menu yourself, place it and then remove the application menu …
To restore the configuration it came with when you installed:
open a terminal as you did before, quit the panel and the configuration daemon
xfce4-panel --quit
pkill xfconfd
then copy the current manjaro default value for the panel from /etc/skel to your home directory, overwriting the files that are there now
cp -r /etc/skel/.config/xfce4/panel ~/.config/xfce4
cp /etc/skel/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-panel.xml ~/.config/xfce4/xfconf/xfce-perchannel-xml
then restart the panel
xfce4-panel
or, better, log out and back in
You can always do the procedure @Hipster gave to get back to where you are now.
Thanks, it worked - now I have again both panel and whisker menu : )
