Hi
After the “big” update in the system settings (the gui tool), a bunch of options are missing:
-network settings
-hardware settings, driver settings
-kernel settings
these are just from the top of my mind.
How can I get those back?
Hi
-network settings
-kernel settings
With the transition from Plasma 5 to Plasma 6 you need to remove all kde plasma related files from ~/.local and ~/.config - and finally remove your ~/.cache folder.
This should preferably be done by logging out, switching to a TTY, login and remove the files.
If you find it difficult to navigate there is great terminal file manager called Midnight Commander - package mc which can visualize your filesystem
These are now to be found in manjaro-settings-manager.
I don’t know if it’s planned to re-incorporate them in systemsettings, though I imagine it is.
Thank you
Just remove them, and that’s it?
If you do remove files in ~/.config and ~/.local, you’ll lose all of your desktop-related configuration. I left mine where it was and apart from having to tweak a few things and replace incompatible widgets, it all went smoothly.
Clearing ~/.cache on the other hand is a good idea and can’t cause any harm. You can always remove stuff from ~/.config and ~/.local if you’re unfortunate enough to have problems after the upgrade.
Deleted cache, systemd restart display-manager … nothing changed, so
I created a new user, to see what plasma related items generating in .config, .cache and .local, to delete only those on my main user account.
When I relogged to my account, the settings came back ![]()
I can’t really understad this, but problem is solved, I guess ![]()
Thank you all!
Not all settings btw, the driver settings, and kernel settings are only in the manjaro settings, but a lot of missing feature came back, like the network settings.
These have always been found in manjaro settings manager. ftfy ![]()
