My system monitor don’t show data circle.
It says missing senors, but it can show those data in the process chart(although it says they are missing). Psensor can also report those sensor data correctly.
I have been checking sensors-dectet of lm_sensor, It reports:
modprobe: FATAL: Module cpuid not found in directory /lib/modules/6.12.21-1-MANJARO-RPI4
Failed to load module cpuid.
But I am actually using a pi5.
I guess this error is caused by wrong directory? I tried swap the 6.12.21-1-MANJARO-RPI4 and 6.12.21-1-MANJARO-RPI5. Didn’t work either.
Maybe this problem is more complicated than this?
Help me plz.
By the way, my system info are as followed:
Kernel: 6.12.21-1-MANJARO-RPI4 arch: aarch64 bits: 64 compiler: gcc v: 14.2.1
clocksource: arch_sys_counter parameters: reboot=w coherent_pool=1M
8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory
numa_policy=interleave numa=fake=8 system_heap.max_order=0
smsc95xx.macaddr=2C:CF:67:A8:6C:44 vc_mem.mem_base=0x3fc00000
vc_mem.mem_size=0x40000000 root=PARTUUID=c7717192-02 rw rootwait
console=ttyAMA10,115200 console=tty3 selinux=0 quiet splash
plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0
kgdboc=ttyAMA10,115200 usbhid.mousepoll=8 audit=0
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 5 Model B Rev 1.1 details: N/A rev: d04171
serial: <filter>
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: N/A available: 7.76 GiB used: 2.93 GiB (37.8%) igpu: 8 MiB
RAM Report: message: No RAM data found using udevadm.
Message: No ARM data found for this feature.
Info: model: N/A variant: cortex-a76 bits: 64 type: MCP arch: ARMv8 family: 8
model-id: 4 stepping: 1
Topology: cpus: 1x clusters: 1 cores: 4 smt: <unsupported> cache:
L1: 512 KiB desc: d-4x64 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 1600 min/max: 1500/2400 scaling: driver: cpufreq-dt
governor: ondemand cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 432
Features: aes asimd asimddp asimdhp asimdrdm atomics cpuid crc32 dcpop
evtstrm fp fphp lrcpc pmull sha1 sha2
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: CSV2, BHB
Device-1: bcm2712-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c701400 class-ID: hdmi
Device-2: bcm2712-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:107c706400 class-ID: hdmi
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev
dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
display-ID: 0
Monitor-1: HDMI-A-1 model: FKS-C215J serial: <filter> built: 2022 res:
mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 102 gamma: 1.2 chroma: red:
x: 0.647 y: 0.345 green: x: 0.322 y: 0.631 blue: x: 0.153 y: 0.059 white:
x: 0.314 y: 0.329 size: 476x268mm (18.74x10.55") diag: 546mm (21.5")
ratio: 16:9 modes: 1920x1080, 1920x1080i, 1680x1050, 1280x1024, 1440x900,
1280x960, 1280x800, 1152x864, 1280x720, 1440x576, 1024x768, 1440x480,
832x624, 800x600, 720x576, 720x576i, 720x480, 720x480i, 640x480, 720x400
API: EGL v: 1.5 hw: drv: broadcom v3d platforms: device: 0 drv: v3d
device: 1 drv: swrast gbm: drv: v3d surfaceless: drv: v3d wayland: drv: v3d
x11: drv: v3d
API: OpenGL v: 4.5 compat-v: 3.1 vendor: broadcom mesa v: 25.0.2-arch1.2
glx-v: 1.4 direct-render: yes renderer: V3D 7.1.10.2 device-ID: 14e4:ffffffff
memory: 7.57 GiB unified: yes display-ID: :1.0
Device-1: bcm2712-hdmi0 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:107c701400
class-ID: hdmi
Device-2: bcm2712-hdmi1 driver: vc4_hdmi bus-ID: N/A
API: ALSA v: k6.12.21-1-MANJARO-RPI4 status: kernel-api
Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Raspberry Pi RP1 PCIe 2.0 South Bridge driver: rp1 v: kernel
port: N/A bus-ID: 0002:01:00.0 chip-ID: 1de4:0001 class-ID: 0200
IF-ID-1: end0 state: down mac: <filter>
Info: services: NetworkManager, sshd, systemd-networkd, systemd-timesyncd,
wpa_supplicant
Device-1: bcm7271-uart driver: bcm7271_uart bus-ID: N/A
chip-ID: brcm:107d50c000 class-ID: serial
Local Storage: total: 465.76 GiB used: 215.5 GiB (46.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S530Q 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SN12380 temp: 26.9 C
scheme: MBR
ID-1: / raw-size: 465.28 GiB size: 456.91 GiB (98.20%)
used: 215.43 GiB (47.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: ROOT_MNJRO uuid: 12e07176-8dda-4674-8532-4ade95134720
ID-2: /boot raw-size: 457.8 MiB size: 457.5 MiB (99.94%)
used: 67.6 MiB (14.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: BOOT_MNJRO uuid: 4525-5221
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100) zswap: no
ID-1: swap-1 type: zram size: 11.64 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4 max-streams: 4 dev: /dev/zram0
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 045e:028e class-ID: ff00
Device-2: 1-2:3 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.0
Device-1: 3-2:2 info: VXE V87 type: keyboard driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 400mA chip-ID: 320f:5055 class-ID: 0301 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.0
System Temperatures: cpu: 46.8 C mobo: N/A
Fan Speeds (rpm): cpu: 5115
Packages: pm: pacman pkgs: 1029 libs: 279 tools: pamac,yay
1: https://mirrors.sonic.net/manjaro/arm-unstable/$repo/$arch
2: https://mirror.init7.net/manjaro/arm-unstable/$repo/$arch
3: https://mirror.hostiko.network/manjaro/arm-unstable/$repo/$arch
4: https://mirror.dkm.cz/manjaro/arm-unstable/$repo/$arch
5: https://manjaro.c3sl.ufpr.br/arm-unstable/$repo/$arch
6: https://mirrors.atlas.net.co/manjaro/arm-unstable/$repo/$arch
7: https://ftp.gwdg.de/pub/linux/manjaro/arm-unstable/$repo/$arch
Processes:
CPU top: 5 of 244
1: cpu: 18.2% command: firefox pid: 1601 mem: 530.0 MiB (6.6%)
2: cpu: 10.3% command: firefox pid: 2569 mem: 267.0 MiB (3.3%)
3: cpu: 6.8% command: firefox pid: 2387 mem: 236.6 MiB (2.9%)
4: cpu: 4.8% command: kwin_wayland pid: 764 mem: 215.4 MiB (2.7%)
5: cpu: 1.3% command: plasmashell pid: 1483 mem: 380.2 MiB (4.7%)
Memory top: 5 of 244
1: mem: 530.0 MiB (6.6%) command: firefox pid: 1601 cpu: 18.2%
2: mem: 380.2 MiB (4.7%) command: plasmashell pid: 1483 cpu: 1.3%
3: mem: 267.0 MiB (3.3%) command: firefox pid: 2569 cpu: 10.3%
4: mem: 236.6 MiB (2.9%) command: firefox pid: 2387 cpu: 6.8%
5: mem: 215.4 MiB (2.7%) command: kwin_wayland pid: 764 cpu: 4.8%
Processes: 244 Power: uptime: 46m suspend: services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
