Hello,
I want to install the Maui-Shell on the latest Manjaro KDE Plasma 22.02 for Radxa Zero.
This is the tutorial I use:
The Mauikit and the Mauikit-FileBrowsing compiled and installed fine. But the Maui-Shell itself throws a error when compiling it.
CMake Error at /usr/share/cmake/Mudules/FindPackageHandleStandardArgs.cmake:238 (message):
Could NOT find KF5 (missing: DocTools Init) (found version "5.91.0")
Call Stack ( most recent call first):
/usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
/usr/share/ECM/find-modules/FindKF5.cmake:93 (find_package_handle_standard_args)
startcask/CMakeLists.txt:1 (find_package)
Does it work with that version of system or not?
The guys from Nitrux wrote to me that I am missing some packages in Manjaro provide kdoctools and kinit.
Does anyone tried the same and knows this issue?
I don’t know - I am not a KDE specialist - nor a audio specialist - but from the bits and pieces I picked up - KDE Plasma has shifted towards using pipewire - presumably a successor to pulseaudio - and that pulseaudio and pipewire are mutually exclusive.
I am a coder writing business software and when it comes to audio I use it very little and when I use it I know where to select the correct input and the correct output (headset) - so I am of very little help in that regard.
@Oli Instead of building it from source from github you should install maui-shell package which in available for ARM in kde-unstable repos. You can switch to ARM and check here Manjaro - Branch Compare. To enable it, add the following lines to /etc/pacman.conf:
[kde-unstable] Include = /etc/pacman.d/mirrorlist
The kde-unstable entry should be first in the list of repositories (i.e. , above the [core] entry). Also if you are using this repo it is advisable to switch to manjaro unstable branch. See Switching Branches - Manjaro.
Ah thank you. I switched the repository.
Can I download the package from unstable repo using git clone --depth 1 --branch master https://invent.kde.org/maui/mauikit.git or do I have to execute something different?
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
#CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
HoldPkg = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst = manjaro-system manjaro-keyring manjaro-arm-keyring archlinux-keyring archlinuxarm-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = aarch64
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinuxarm manjaro-arm`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[core]
[extra]
[community]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
But only do so on unstable branch. I suspect this repo will require the latests system libraries as well and if you may get into trouble if you don’t have the latest.
