Hello ARM community.
New LLVM/Clang is here!
Some highlights:
- Most of our kernels got updated
- KDE Frameworks updated to 5.102, which is mainly bugfixes
- Gnome Desktop updated to 43.1
- Firefox updated to 109.0
- Clang/LLVM updated to 15.0.7. Did we miss any rebuilds?
- Grub updated to latest
- Element updated to 1.11.18
- Lots of Mobile specific packages got updated
- Many python packages got updated
End Of Life kernels (will soon be removed from repo):
linux60
(EOL on 2023-01-12)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
PHP 8.2 update and introduction of legacy branch
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php
and php-legacy
can be installed at the same time as the latter uses a -legacy
suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap
extension will no longer be provided as it relies on the c-client
library which has been abandoned for many years.
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sat Jan 21 15:44:26 CET 2023)
- arm-testing community aarch64: 350 new and 296 removed package(s)
- arm-testing core aarch64: 38 new and 37 removed package(s)
- arm-testing extra aarch64: 305 new and 301 removed package(s)
- arm-testing kde-unstable aarch64: 351 new and 351 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023-01-15 2023-01-21
element-desktop 1.11.17-1 1.11.18-1
element-web 1.11.17-1 1.11.18-1
mesa-apple-silicon-edge 23.0.0_pre20221229-1 23.0.0_pre20221229-2
mesa-apple-silicon-edge-debug 23.0.0_pre20221229-1 -
rpi-eeprom 20230105-1 20230118-1
vulkan-swrast-apple-silicon-edge 23.0.0_pre20221229-1 23.0.0_pre20221229-2
waydroid-image 18.1_20230114-1 18.1_20230119-1
rtl8723ds-dkms-git -5.1.1.5.r66.ga638cc8-1
:: Different sync package(s) in repository community aarch64
afl 2.57b-11 2.57b-13
alembic 1.8.4-1 1.8.4-2
ansible-lint 6.10.2-2 6.11.0-1
arp-scan 1.10.0-1 1.10.0-2
autorandr 1.12.1-2 1.13.1-1
aws-vault 6.6.1-1 6.6.2-1
bacon 2.4.0-1 2.5.0-1
bash-language-server 4.4.0-2 4.5.1-1
bcc 0.26.0-1 0.26.0-2
bcc-tools 0.26.0-1 0.26.0-2
blender 17:3.4.1-4 17:3.4.1-7
bpftrace 0.16.0-1 0.16.0-2
brial 1.2.11-1 1.2.12-1
brook 20220707-1 20221010-1
buildkit 0.11.0-1 0.11.1-1
cargo-generate 0.17.4-1 0.17.6-1
cargo-spellcheck 0.12.2-1 0.12.3-1
cargo-tauri 1.2.2-1 1.2.3-1
carla 2.5.2-2 2.5.3-1
ccls 0.20220729-1 0.20220729-3
cgit-archweb 1.2.3-2 -
cgit-aurweb 1.2.3-2 1.2.3-3
chezmoi 2.29.1-1 2.29.3-1
chuck 1.4.1.1-1 1.4.2.0-1
cinnamon 5.6.6-1 5.6.7-1
cloudflared 2022.12.1-1 2023.1.0-1
cni-plugins 1.1.1-2 1.2.0-2
copyq 6.3.2-1 6.4.0-1
cri-o 1.25.1-1 1.26.1-1
crictl 1.25.0-1 1.26.0-1
critest 1.25.0-1 1.26.0-1
crystal 1.6.2-1 1.7.1-1
dagger 0.3.9-1 0.3.9-2
ddclient 3.9.1-1 3.10.0-1
diffoscope 232-1 233-1
difftastic 0.41.0-1 0.42.0-1
dovecot 2.3.19.1-3 2.3.20-1
dovecot-fts-elastic 1.1.0-3 1.1.0-4
dovecot-fts-xapian 1.5.5-4 1.5.5-5
faust 2.54.9-1 2.54.9-2
firejail 0.9.70-4 0.9.72-1
fish 3.5.1-1 3.6.0-1
flashgbx 3.20-1 3.21-1
forgejo 1.18.0.1-2 1.18.2.0-1
freecad 0.20.2-2 0.20.2-3
fwupd 1.8.9-1 1.8.9-2
gcompris-qt 2.4-2 3.0-1
gdu 5.21.1-1 5.21.1-2
gedit 44.1-1 44.2-1
gedit-plugins 44.0-1 44.1-1
giac 1.9.0.35-1 1.9.0.37-1
gimp-plugin-gmic 3.1.6-3 3.2.0-1
git-cliff 1.1.1-1 1.1.2-1
gitea 1.18.0-1 1.18.2-1
gitlab-runner 15.7.2-1 15.8.0-1
glewlwyd 2.7.5-1 2.7.5-2
gnuradio 3.10.5.0-1 3.10.5.0-2
gnuradio-companion 3.10.5.0-1 3.10.5.0-2
gnuradio-iqbal 0.38.2-9 0.38.2.r9.gfbee239-1
go-licenses 1.5.0-1 1.6.0-1
go-swagger 0.30.3-2 0.30.4-1
gum 0.9.0-1 0.9.0-2
gxplugins.lv2 0.9-1 1.0-1
hamlib 4.5-2 4.5.4-1
haproxy 2.7.1-1 2.7.2-1
home-assistant 1:2023.1.1-1 1:2023.1.5-1
igsc 0.6.0-1 0.8.6-2
imv 4.3.1-7 4.4.0-1
intel-metee 3.1.3-1 3.1.5-1
intel-metee-doc 3.1.3-1 3.1.5-1
jenkins 2.386-1 2.387-1
jupyter-nbconvert 7.2.7-1 7.2.8-1
just 1.11.0-1 1.12.0-1
klayout 0.28.2-1 0.28.3-1
kube-apiserver 1.25.5-1 1.26.1-1
kube-controller-manager 1.25.5-1 1.26.1-1
kube-linter 0.5.1-1 0.6.0-1
kube-proxy 1.25.5-1 1.26.1-1
kube-scheduler 1.25.5-1 1.26.1-1
kubeadm 1.25.5-1 1.26.1-1
kubectl 1.25.5-1 1.26.1-1
kubelet 1.25.5-1 1.26.1-1
kubernetes-control-plane-common 1.25.5-1 1.26.1-1
ldc 3:1.30.0-1 3:1.30.0-2
libc++ 14.0.6-1 15.0.7-2
libc++abi 14.0.6-1 15.0.7-2
libc++experimental 14.0.6-1 -
libdeflate 1.15-1 1.17-1
liblphobos 3:1.30.0-1 3:1.30.0-2
librdkafka 1.9.2-2 2.0.0-1
libretro-beetle-pce 1157-1 1161-1
libretro-beetle-pce-fast 1196-1 1203-1
libretro-beetle-psx 2642-1 2646-1
libretro-beetle-psx-hw 2642-1 2646-1
libretro-beetle-supergrafx 963-1 967-1
libretro-flycast 5251-1 5390-1
libretro-gambatte 977-1 982-1
libretro-genesis-plus-gx 1962-1 1974-1
libretro-mame 85432-1 85763-1
libretro-mgba 8702-1 8704-1
libretro-nestopia 1:95-1 1:100-1
libretro-picodrive 2235-1 2270-1
libretro-play 7473-1 7480-1
libretro-shaders-slang 1137-1 1146-1
libretro-snes9x 2168-1 2170-1
libvirt 1:8.10.0-1 1:9.0.0-1
libvirt-python 1:8.10.0-1 1:9.0.0-1
libvirt-storage-gluster 1:8.10.0-1 1:9.0.0-1
libvirt-storage-iscsi-direct 1:8.10.0-1 1:9.0.0-1
lttng-ust 2.13.3-1 2.13.4-1
lua-language-server 3.6.4-1 3.6.7-1
man-pages-cs 4.16.0-1 4.17.0-1
man-pages-da 4.16.0-1 4.17.0-1
man-pages-de 4.16.0-1 4.17.0-1
man-pages-el 4.16.0-1 4.17.0-1
man-pages-es 4.16.0-1 4.17.0-1
man-pages-fi 4.16.0-1 4.17.0-1
man-pages-fr 4.16.0-1 4.17.0-1
man-pages-hu 4.16.0-1 4.17.0-1
man-pages-id 4.16.0-1 4.17.0-1
man-pages-it 4.16.0-1 4.17.0-1
man-pages-mk 4.16.0-1 4.17.0-1
man-pages-nb 4.16.0-1 4.17.0-1
man-pages-nl 4.16.0-1 4.17.0-1
man-pages-pl 4.16.0-1 4.17.0-1
man-pages-pt_br 4.16.0-1 4.17.0-1
man-pages-ro 4.16.0-1 4.17.0-1
man-pages-sr 4.16.0-1 4.17.0-1
man-pages-sv 4.16.0-1 4.17.0-1
man-pages-uk 4.16.0-1 4.17.0-1
man-pages-vi 4.16.0-1 4.17.0-1
maven 3.8.6-1 3.8.7-1
mbedtls 2.28.1-1 2.28.2-1
mc 4.8.28-2 4.8.29-1
memray 1.5.0-1 1.6.0-1
minisign 0.10-1 0.11-1
mmctl 7.5.1-1 7.7.1-1
mold 1.9.0-1 1.10.0-1
mpv 1:0.35.0-4 1:0.35.0-5
musescore 4.0-2 4.0.1-1
mysql-workbench 8.0.31-3 8.0.32-1
nemo 5.6.2-1 5.6.3-1
nextcloud 25.0.2-4 25.0.3-1
nodejs-yaml 2.2.0-1 2.2.1-1
octave 7.3.0-4 7.3.0-5
onefetch 2.14.2-1 2.15.1-1
opencascade 1:7.6.3-1 1:7.6.3-2
openshadinglanguage 1.12.8.0-1 1.12.8.0-2
pantheon-calendar 6.1.1-1 6.1.2-1
pasystray 0.8.0-2 0.8.1-1
pdal 2.4.3-3 2.5.0-1
perl-mime-tools 5.509-10 5.510-1
phrase-pinyin-data 0.13.0-1 0.14.0-1
pigeonhole 0.5.19-2 0.5.20-1
polybar 3.6.3-2 3.6.3-3
powerdns-recursor 4.8.0-1 4.8.1-1
pyenv 2.3.10-1 2.3.11-1
pyright 1.1.289-1 1.1.290-1
python-aenum 3.1.11-1 3.1.11-2
python-aiosmtpd 1.4.3-1 1.4.4.post2-1
python-astroid 2.13.2-1 2.13.3-1
python-bcc 0.26.0-1 0.26.0-2
python-debugpy 1.6.5-1 1.6.6-1
python-dulwich 0.20.50-1 0.21.2-1
python-findpython 0.2.2-1 0.2.3-1
python-ipykernel 6.20.1-1 6.20.2-1
python-jupyterlab_server 2.18.0-1 2.19.0-1
python-kubernetes 25.3.0-1 25.3.0-2
python-libtmux 0.19.1-1 0.20.0-1
python-license-expression 30.0.0-2 30.1.0-1
python-logutils 0.3.5-10 0.3.5-11
python-lttngust 2.13.3-1 2.13.4-1
python-mistletoe 0.9.0-1 1.0.0-1
python-mysql-connector 8.0.31-1 8.0.32-1
python-nine 1.1.0-5 1.1.0-6
python-openapi-core 0.16.3-1 0.16.5-1
python-osc 1.8.0-2 1.8.1-1
python-pandas 1.5.2-1 1.5.3-1
python-pdm 2.3.4-1 2.4.0-1
python-pep517 0.13.0-1 -
python-psycopg 3.1.7-1 3.1.8-1
python-pyfakefs 5.0.0-1 5.1.0-1
python-pygame-sdl21:2.1.0.r414.a3c9121-11:2.1.0.r419.de82dfb-1
python-pyglet 2.0.1-1 2.0.2-1
python-pythran 0.12.0-1 0.12.1-1
python-qiniu 7.9.0-2 7.10.0-1
python-rich 13.1.0-1 13.2.0-2
python-tempora 5.1.0-1 5.2.0-1
python-trio-asyncio 0.12.0-3 0.12.0-5
python-txaio 22.2.1-2 23.1.1-1
python-ujson 5.6.0-1 5.7.0-1
python-wilderness 0.1.8-1 0.1.9-1
python-xlsxwriter 3.0.6-1 3.0.7-1
qcad 3.27.8.6-2 3.27.9.0-1
qgis 3.28.2-1 3.28.2-2
quodlibet 4.5.0-1 4.5.0-2
reapack 1.2.4.2-2 1.2.4.2-3
redis 7.0.7-1 7.0.8-1
repro-get 0.2.1-1 0.3.0-1
ruby-bake-modernize 0.14.1-1 0.14.2-1
ruby-cucumber-cucumber-expressions 16.1.1-1 16.1.2-1
ruff 0.0.221-1 0.0.228-1
ruff-lsp 0.0.15-1 0.0.16-1
rust-analyzer 20230109-1 20230116-1
scaleway-cli 2.7.0-1 2.9.0-1
scrot 1.8-1 1.8.1-1
signify 31-1 31-2
sparse 0.6.4-3 0.6.4-4
spdlog 1.11.0-1 1.11.0-2
spirv-llvm-translator14.0.0.r57+g33898cef-315.0.0.r10+g78ad93b9-1
spotify-launcher 0.4.1-1 0.5.0-1
sscg 3.0.2-2 3.0.3-1
stress 1.0.5-1 1.0.6-1
supertuxkart 1.4-4 1.4-5
tmuxp 1.25.0-1 1.26.0-1
torsocks 2.3.0-2 2.4.0-1
translate-toolkit 3.7.4-1 3.7.4-2
ttc-iosevka 17.0.2-1 17.0.4-1
ttc-iosevka-aile 17.0.2-1 17.0.4-1
ttc-iosevka-curly 17.0.2-1 17.0.4-1
ttc-iosevka-curly-slab 17.0.2-1 17.0.4-1
ttc-iosevka-etoile 17.0.2-1 17.0.4-1
ttc-iosevka-slab 17.0.2-1 17.0.4-1
ttc-iosevka-ss01 17.0.2-1 17.0.4-1
ttc-iosevka-ss02 17.0.2-1 17.0.4-1
ttc-iosevka-ss03 17.0.2-1 17.0.4-1
ttc-iosevka-ss04 17.0.2-1 17.0.4-1
ttc-iosevka-ss05 17.0.2-1 17.0.4-1
ttc-iosevka-ss06 17.0.2-1 17.0.4-1
ttc-iosevka-ss07 17.0.2-1 17.0.4-1
ttc-iosevka-ss08 17.0.2-1 17.0.4-1
ttc-iosevka-ss09 17.0.2-1 17.0.4-1
ttc-iosevka-ss10 17.0.2-1 17.0.4-1
ttc-iosevka-ss11 17.0.2-1 17.0.4-1
ttc-iosevka-ss12 17.0.2-1 17.0.4-1
ttc-iosevka-ss13 17.0.2-1 17.0.4-1
ttc-iosevka-ss14 17.0.2-1 17.0.4-1
ttc-iosevka-ss15 17.0.2-1 17.0.4-1
ttc-iosevka-ss16 17.0.2-1 17.0.4-1
ttc-iosevka-ss17 17.0.2-1 17.0.4-1
ttc-iosevka-ss18 17.0.2-1 17.0.4-1
ttf-arimo-nerd 2.2.2-1 2.3.1-2
ttf-firacode-nerd 2.2.2-2 2.3.1-2
ttf-hack-nerd 2.2.2-2 2.3.1-2
ttf-ibm-plex 6.0.2-1 6.1.1-1
ttf-ionicons 6.0.4-1 6.1.0-1
ttf-iosevka-nerd 2.2.2-1 2.3.1-2
ttf-nerd-fonts-symbols-1000-em 2.2.2-5 2.3.1-2
ttf-nerd-fonts-symbols-1000-em-mono 2.2.2-5 2.3.1-2
ttf-nerd-fonts-symbols-2048-em 2.2.2-5 2.3.1-2
ttf-nerd-fonts-symbols-2048-em-mono 2.2.2-5 2.3.1-2
ttf-nerd-fonts-symbols-common 2.2.2-5 2.3.1-2
ttf-sourcecodepro-nerd 2.2.2-1 2.3.1-2
ttf-terminus-nerd 2.2.2-2 2.3.1-2
ttf-ubuntumono-nerd 2.2.2-3 -
ttyd 1.7.2-3 1.7.3-1
typos 1.13.7-1 1.13.8-1
ugrep 3.9.4-1 3.9.5-1
uwsgi 2.0.21-3 2.0.21-5
uwsgi-plugin-cgi 2.0.21-3 2.0.21-5
uwsgi-plugin-lua51 2.0.21-3 2.0.21-5
uwsgi-plugin-notfound 2.0.21-3 2.0.21-5
uwsgi-plugin-php 2.0.21-3 2.0.21-5
uwsgi-plugin-php-legacy 2.0.21-3 2.0.21-5
uwsgi-plugin-psgi 2.0.21-3 2.0.21-5
uwsgi-plugin-python 2.0.21-3 2.0.21-5
uwsgi-plugin-rack 2.0.21-3 2.0.21-5
uwsgi-plugin-webdav 2.0.21-3 2.0.21-5
uwsgi-plugin-zabbix 2.0.21-3 2.0.21-5
v2ray 5.1.0-2 5.2.1-1
v2ray-domain-list-community 20230112070720-1 20230120050418-1
v2ray-geoip 202301120046-1 202301190046-1
vc-intrinsics 0.5.0-1 0.11.0-2
virt-firmware 1.7-1 1.8-1
visidata 2.10.2-3 2.11-1
vtk 9.1.0-24 9.1.0-25
vulture 2.6-2 2.7-1
wallutils 5.12.4-1 5.12.5-1
wasmtime 4.0.0-1 5.0.0-1
wireshark-cli 4.0.2-1 4.0.3-1
wireshark-qt 4.0.2-1 4.0.3-1
words 2.1-6 2.1-7
wt 4.9.0-1 4.9.1-1
xcursor-flatbed 0.4-3 0.5-1
xfce4-whiskermenu-plugin 2.7.1-1 2.7.2-1
xonsh 0.13.3-1 0.13.4-1
ytfzf 2.5.3-1 2.5.4-1
zig 0.9.1-2 0.10.1-1
av1an - 0.4.0-1
cargo-llvm-cov - 0.5.9-1
cargo-ndk - 2.12.2-1
cargo-update - 11.1.1-2
felix-rs - 2.2.3-1
man-pages-ru - 4.17.0-1
otf-aurulent-nerd - 2.3.1-2
otf-cascadia-code-nerd - 2.3.1-2
otf-codenewroman-nerd - 2.3.1-2
otf-droid-nerd - 2.3.1-2
otf-firamono-nerd - 2.3.1-2
otf-hasklig-nerd - 2.3.1-2
otf-hermit-nerd - 2.3.1-2
otf-opendyslexic-nerd - 2.3.1-2
otf-overpass-nerd - 2.3.1-2
papilo - 2.1.2-1
pipewire-media-session - 1:0.4.2-1
pipewire-media-session-docs - 1:0.4.2-1
python-poetry-plugin-up - 0.2.1-1
python-pyscipopt - 4.2.0-1
python-rfc3986-validator - 0.1.1-1
scip - 8.0.3-2
soplex - 6.0.3-2
ttf-3270-nerd - 2.3.1-2
ttf-agave-nerd - 2.3.1-2
ttf-anonymouspro-nerd - 2.3.1-2
ttf-bigblueterminal-nerd - 2.3.1-2
ttf-bitstream-vera-mono-nerd - 2.3.1-2
ttf-cousine-nerd - 2.3.1-2
ttf-daddytime-mono-nerd - 2.3.1-2
ttf-dejavu-nerd - 2.3.1-2
ttf-fantasque-nerd - 2.3.1-2
ttf-go-nerd - 2.3.1-2
ttf-heavydata-nerd - 2.3.1-2
ttf-iawriter-nerd - 2.3.1-2
ttf-ibmplex-mono-nerd - 2.3.1-2
ttf-inconsolata-go-nerd - 2.3.1-2
ttf-inconsolata-lgc-nerd - 2.3.1-2
ttf-inconsolata-nerd - 2.3.1-2
ttf-jetbrains-mono-nerd - 2.3.1-2
ttf-lekton-nerd - 2.3.1-2
ttf-liberation-mono-nerd - 2.3.1-2
ttf-lilex-nerd - 2.3.1-2
ttf-meslo-nerd - 2.3.1-2
ttf-monofur-nerd - 2.3.1-2
ttf-monoid-nerd - 2.3.1-2
ttf-mononoki-nerd - 2.3.1-2
ttf-mplus-nerd - 2.3.1-2
ttf-noto-nerd - 2.3.1-2
ttf-profont-nerd - 2.3.1-2
ttf-proggyclean-nerd - 2.3.1-2
ttf-roboto-mono-nerd - 2.3.1-2
ttf-sharetech-mono-nerd - 2.3.1-2
ttf-space-mono-nerd - 2.3.1-2
ttf-tinos-nerd - 2.3.1-2
ttf-ubuntu-mono-nerd - 2.3.1-2
ttf-ubuntu-nerd - 2.3.1-2
ttf-victor-mono-nerd - 2.3.1-2
:: Different overlay package(s) in repository core aarch64
grub2:2.06.r334.g340377470-32:2.06.r440.g4de39a2af-1
linux 6.1.6-2 6.1.7-1
linux-aml 6.1.5-1 6.1.7-1
linux-aml-headers 6.1.5-1 6.1.7-1
linux-clockworkpi-a06 6.1.6-1 6.1.7-1
linux-clockworkpi-a06-headers 6.1.6-1 6.1.7-1
linux-headers 6.1.6-2 6.1.7-1
linux-pinephone 6.1.3-1 6.1.7-1
linux-pinephone-headers 6.1.3-1 6.1.7-1
linux-pinephonepro 6.1.3-1 6.1.7-1
linux-pinephonepro-headers 6.1.3-1 6.1.7-1
linux-rc 6.2.rc4-1 6.2.rc4-3
linux-rc-headers 6.2.rc4-1 6.2.rc4-3
linux-rpi4 5.15.84-1 5.15.89-1
linux-rpi4-headers 5.15.84-1 5.15.89-1
linux-rpi4-mainline 6.1.5-1 6.1.7-1
linux-rpi4-mainline-headers 6.1.5-1 6.1.7-1
linux-rpi4-rc 6.2.rc3-1 6.2.rc4-1
linux-rpi4-rc-headers 6.2.rc3-1 6.2.rc4-1
linux61 6.1.6-2 6.1.7-1
linux61-headers 6.1.6-2 6.1.7-1
raspberrypi-bootloader 20230113-1 20230118-1
raspberrypi-bootloader-x 20230113-1 20230118-1
uboot-pinebook 2022.10-1 2022.10-2
uboot-pinephone 2022.10-0 2022.10-1
boot-g1 - 2023.01-2
:: Different sync package(s) in repository core aarch64
debuginfod 0.188-1 0.188-2
ed 1.18-1 1.19-1
elfutils 0.188-1 0.188-2
gpgme 1.18.0-1 1.18.0-2
libelf 0.188-1 0.188-2
libpcap 1.10.2-1 1.10.3-1
mpfr 4.1.1.p1-1 4.2.0-2
nano 7.1-1 7.2-1
python-gpgme 1.18.0-1 1.18.0-2
qgpgme 1.18.0-1 1.18.0-2
sudo 1.9.12-5 1.9.12.p2-1
xfsprogs 6.1.0-1 6.1.1-2
:: Different overlay package(s) in repository extra aarch64
libva-mesa-driver 22.3.3-0.1 22.3.3-0.2
mesa 22.3.3-0.1 22.3.3-0.2
mesa-vdpau 22.3.3-0.1 22.3.3-0.2
opencl-mesa 22.3.3-0.1 22.3.3-0.2
vulkan-broadcom 22.3.3-0.1 22.3.3-0.2
vulkan-mesa-layers 22.3.3-0.1 22.3.3-0.2
vulkan-panfrost 22.3.3-0.1 22.3.3-0.2
vulkan-radeon 22.3.3-0.1 22.3.3-0.2
vulkan-swrast 22.3.3-0.1 22.3.3-0.2
vulkan-virtio 22.3.3-0.1 22.3.3-0.2
:: Different sync package(s) in repository extra aarch64
adobe-source-serif-fonts 4.004-2 4.005-1
archlinux-appstream-data 20221210-1 20230115-1
attica 5.101.0-1 5.102.0-1
avogadrolibs 1.97.0-1 1.97.0-2
avogadrolibs-qt5 1.97.0-1 1.97.0-2
baloo 5.101.0-1 5.102.0-1
bluez-qt 5.101.0-1 5.102.0-1
breeze-icons 5.101.0-1 5.102.0-1
clang 14.0.6-4 15.0.7-1
clazy 1.11-2 1.11-3
cmake 3.25.1-1 3.25.2-1
compiler-rt 14.0.6-1 15.0.7-1
dejagnu 1.6.3-3 1.6.3-4
directx-headers 1.608.0-1 1.608.2-1
dkms 3.0.9-1 3.0.10-1
easy-rsa 3.1.1-1 3.1.2-1
editorconfig-core-c 0.12.5-1 0.12.6-1
exiv2 0.27.5-3 0.27.6-1
extra-cmake-modules 5.101.0-1 5.102.0-1
firefox 108.0.2-1 109.0-1
firefox-i18n-ach 108.0.2-1 109.0-1
firefox-i18n-af 108.0.2-1 109.0-1
firefox-i18n-an 108.0.2-1 109.0-1
firefox-i18n-ar 108.0.2-1 109.0-1
firefox-i18n-ast 108.0.2-1 109.0-1
firefox-i18n-az 108.0.2-1 109.0-1
firefox-i18n-be 108.0.2-1 109.0-1
firefox-i18n-bg 108.0.2-1 109.0-1
firefox-i18n-bn 108.0.2-1 109.0-1
firefox-i18n-br 108.0.2-1 109.0-1
firefox-i18n-bs 108.0.2-1 109.0-1
firefox-i18n-ca 108.0.2-1 109.0-1
firefox-i18n-ca-valencia 108.0.2-1 109.0-1
firefox-i18n-cak 108.0.2-1 109.0-1
firefox-i18n-cs 108.0.2-1 109.0-1
firefox-i18n-cy 108.0.2-1 109.0-1
firefox-i18n-da 108.0.2-1 109.0-1
firefox-i18n-de 108.0.2-1 109.0-1
firefox-i18n-dsb 108.0.2-1 109.0-1
firefox-i18n-el 108.0.2-1 109.0-1
firefox-i18n-en-ca 108.0.2-1 109.0-1
firefox-i18n-en-gb 108.0.2-1 109.0-1
firefox-i18n-en-us 108.0.2-1 109.0-1
firefox-i18n-eo 108.0.2-1 109.0-1
firefox-i18n-es-ar 108.0.2-1 109.0-1
firefox-i18n-es-cl 108.0.2-1 109.0-1
firefox-i18n-es-es 108.0.2-1 109.0-1
firefox-i18n-es-mx 108.0.2-1 109.0-1
firefox-i18n-et 108.0.2-1 109.0-1
firefox-i18n-eu 108.0.2-1 109.0-1
firefox-i18n-fa 108.0.2-1 109.0-1
firefox-i18n-ff 108.0.2-1 109.0-1
firefox-i18n-fi 108.0.2-1 109.0-1
firefox-i18n-fr 108.0.2-1 109.0-1
firefox-i18n-fy-nl 108.0.2-1 109.0-1
firefox-i18n-ga-ie 108.0.2-1 109.0-1
firefox-i18n-gd 108.0.2-1 109.0-1
firefox-i18n-gl 108.0.2-1 109.0-1
firefox-i18n-gn 108.0.2-1 109.0-1
firefox-i18n-gu-in 108.0.2-1 109.0-1
firefox-i18n-he 108.0.2-1 109.0-1
firefox-i18n-hi-in 108.0.2-1 109.0-1
firefox-i18n-hr 108.0.2-1 109.0-1
firefox-i18n-hsb 108.0.2-1 109.0-1
firefox-i18n-hu 108.0.2-1 109.0-1
firefox-i18n-hy-am 108.0.2-1 109.0-1
firefox-i18n-ia 108.0.2-1 109.0-1
firefox-i18n-id 108.0.2-1 109.0-1
firefox-i18n-is 108.0.2-1 109.0-1
firefox-i18n-it 108.0.2-1 109.0-1
firefox-i18n-ja 108.0.2-1 109.0-1
firefox-i18n-ka 108.0.2-1 109.0-1
firefox-i18n-kab 108.0.2-1 109.0-1
firefox-i18n-kk 108.0.2-1 109.0-1
firefox-i18n-km 108.0.2-1 109.0-1
firefox-i18n-kn 108.0.2-1 109.0-1
firefox-i18n-ko 108.0.2-1 109.0-1
firefox-i18n-lij 108.0.2-1 109.0-1
firefox-i18n-lt 108.0.2-1 109.0-1
firefox-i18n-lv 108.0.2-1 109.0-1
firefox-i18n-mk 108.0.2-1 109.0-1
firefox-i18n-mr 108.0.2-1 109.0-1
firefox-i18n-ms 108.0.2-1 109.0-1
firefox-i18n-my 108.0.2-1 109.0-1
firefox-i18n-nb-no 108.0.2-1 109.0-1
firefox-i18n-ne-np 108.0.2-1 109.0-1
firefox-i18n-nl 108.0.2-1 109.0-1
firefox-i18n-nn-no 108.0.2-1 109.0-1
firefox-i18n-oc 108.0.2-1 109.0-1
firefox-i18n-pa-in 108.0.2-1 109.0-1
firefox-i18n-pl 108.0.2-1 109.0-1
firefox-i18n-pt-br 108.0.2-1 109.0-1
firefox-i18n-pt-pt 108.0.2-1 109.0-1
firefox-i18n-rm 108.0.2-1 109.0-1
firefox-i18n-ro 108.0.2-1 109.0-1
firefox-i18n-ru 108.0.2-1 109.0-1
firefox-i18n-sco 108.0.2-1 109.0-1
firefox-i18n-si 108.0.2-1 109.0-1
firefox-i18n-sk 108.0.2-1 109.0-1
firefox-i18n-sl 108.0.2-1 109.0-1
firefox-i18n-son 108.0.2-1 109.0-1
firefox-i18n-sq 108.0.2-1 109.0-1
firefox-i18n-sr 108.0.2-1 109.0-1
firefox-i18n-sv-se 108.0.2-1 109.0-1
firefox-i18n-szl 108.0.2-1 109.0-1
firefox-i18n-ta 108.0.2-1 109.0-1
firefox-i18n-te 108.0.2-1 109.0-1
firefox-i18n-th 108.0.2-1 109.0-1
firefox-i18n-tl 108.0.2-1 109.0-1
firefox-i18n-tr 108.0.2-1 109.0-1
firefox-i18n-trs 108.0.2-1 109.0-1
firefox-i18n-uk 108.0.2-1 109.0-1
firefox-i18n-ur 108.0.2-1 109.0-1
firefox-i18n-uz 108.0.2-1 109.0-1
firefox-i18n-vi 108.0.2-1 109.0-1
firefox-i18n-xh 108.0.2-1 109.0-1
firefox-i18n-zh-cn 108.0.2-1 109.0-1
firefox-i18n-zh-tw 108.0.2-1 109.0-1
foomatic-db 3:20221004-1 3:20230115-1
foomatic-db-nonfree 3:20221004-1 3:20230115-1
foomatic-db-nonfree-ppds 3:20221004-1 3:20230115-1
foomatic-db-ppds 3:20221004-1 3:20230115-1
frameworkintegration 5.101.0-1 5.102.0-1
fuse-common 3.12.0-1 3.13.0-1
fuse3 3.12.0-1 3.13.0-1
git 2.39.0-1 2.39.1-1
gnome-builder 43.4-1 43.4-2
gnome-desktop 1:43-1 1:43.1-1
gnome-desktop-4 1:43-1 1:43.1-1
gnome-desktop-common 1:43-1 1:43.1-1
graphicsmagick 1.3.39-2 1.3.40-1
gthumb 3.12.2-3 3.12.2-4
hplip 1:3.22.10-2 1:3.22.10-3
inkscape 1.2.2-2 1.2.2-3
java-environment-common 3-3 3-5
java-runtime-common 3-3 3-5
jdk-openjdk 19.0.1.u10-3 19.0.2.u7-2
jdk11-openjdk 11.0.17.u1-1 11.0.18.u10-2
jdk17-openjdk 17.0.5.u1-1 17.0.6.u10-2
jre-openjdk 19.0.1.u10-3 19.0.2.u7-2
jre-openjdk-headless 19.0.1.u10-3 19.0.2.u7-2
jre11-openjdk 11.0.17.u1-1 11.0.18.u10-2
jre11-openjdk-headless 11.0.17.u1-1 11.0.18.u10-2
jre17-openjdk 17.0.5.u1-1 17.0.6.u10-2
jre17-openjdk-headless 17.0.5.u1-1 17.0.6.u10-2
kactivities 5.101.0-1 5.102.0-1
kactivities-stats 5.101.0-1 5.102.0-1
kapidox 5.101.0-1 5.102.0-1
karchive 5.101.0-1 5.102.0-1
kauth 5.101.0-1 5.102.0-1
kbookmarks 5.101.0-1 5.102.0-1
kcalendarcore 5.101.0-1 5.102.0-1
kcmutils 5.101.0-1 5.102.0-1
kcodecs 5.101.0-1 5.102.0-1
kcompletion 5.101.0-1 5.102.0-1
kconfig 5.101.0-1 5.102.0-1
kconfigwidgets 5.101.0-1 5.102.0-1
kcontacts 1:5.101.0-1 1:5.102.0-1
kcoreaddons 5.101.0-1 5.102.0-1
kcrash 5.101.0-1 5.102.0-1
kdav 1:5.101.0-1 1:5.102.0-1
kdbusaddons 5.101.0-1 5.102.0-1
kdeclarative 5.101.0-1 5.102.0-1
kded 5.101.0-1 5.102.0-1
kdelibs4support 5.101.0-1 5.102.0-1
kdesignerplugin 5.101.0-1 5.102.0-1
kdesu 5.101.0-1 5.102.0-1
kdevelop 22.12.1-1 22.12.1-3
kdnssd 5.101.0-1 5.102.0-1
kdoctools 5.101.0-1 5.102.0-1
kemoticons 5.101.0-1 5.102.0-1
kfilemetadata 5.101.0-1 5.102.0-1
kglobalaccel 5.101.0-1 5.102.0-1
kguiaddons 5.101.0-1 5.102.0-1
kholidays 1:5.101.0-1 1:5.102.0-1
khtml 5.101.0-1 5.102.0-1
ki18n 5.101.0-1 5.102.0-1
kiconthemes 5.101.0-1 5.102.0-1
kidletime 5.101.0-1 5.102.0-1
kimageformats 5.101.0-2 5.102.0-1
kinit 5.101.0-1 5.102.0-1
kio 5.101.0-2 5.102.0-1
kirigami2 5.101.0-1 5.102.0-1
kitemmodels 5.101.0-1 5.102.0-1
kitemviews 5.101.0-1 5.102.0-1
kjobwidgets 5.101.0-1 5.102.0-1
kjs 5.101.0-1 5.102.0-1
knewstuff 5.101.0-1 5.102.0-1
knotifications 5.101.0-1 5.102.0-1
knotifyconfig 5.101.0-1 5.102.0-1
kpackage 5.101.0-1 5.102.0-1
kparts 5.101.0-1 5.102.0-1
kpeople 5.101.0-1 5.102.0-1
kplotting 5.101.0-1 5.102.0-1
kpty 5.101.0-1 5.102.0-1
kquickcharts 5.101.0-1 5.102.0-1
kross 5.101.0-1 5.102.0-1
krunner 5.101.0-1 5.102.0-1
kservice 5.101.0-1 5.102.0-1
ktexteditor 5.101.0-1 5.102.0-1
ktextwidgets 5.101.0-1 5.102.0-1
kunitconversion 5.101.0-1 5.102.0-1
kwallet 5.101.0-1 5.102.0-1
kwayland 5.101.0-1 5.102.0-1
kwidgetsaddons 5.101.0-1 5.102.0-1
kwindowsystem 5.101.0-1 5.102.0-1
kxmlgui 5.101.0-1 5.102.0-1
libcbor 0.9.0-1 0.10.1-1
libclc 14.0.6-1 15.0.7-1
libfido2 1.12.0-4 1.12.0-5
libinput 1.22.0-1 1.22.1-1
libsysprof-capture 3.46.0-1 3.46.0-3
libxpm 3.5.14-1 3.5.15-1
liferea 1.13.9-1 1.14.0-1
lld 14.0.6-1 15.0.7-1
lldb 14.0.6-1 15.0.7-1
llvm 14.0.6-4 15.0.7-1
llvm-libs 14.0.6-4 15.0.7-1
mesa-amber 21.3.9-3 21.3.9-4
modemmanager-qt 5.101.0-1 5.102.0-1
mpd 0.23.11-1 0.23.12-1
mpg123 1.31.1-1 1.31.2-1
ndctl 74-1 75-1
networkmanager-qt 5.101.0-1 5.102.0-1
openjdk-src 19.0.1.u10-3 19.0.2.u7-2
openjdk11-src 11.0.17.u1-1 11.0.18.u10-2
openjdk17-src 17.0.5.u1-1 17.0.6.u10-2
openmp 14.0.6-1 15.0.7-1
oxygen-icons 1:5.101.0-1 1:5.102.0-1
oxygen-icons-svg 1:5.101.0-1 1:5.102.0-1
pahole 1:1.24-11:1.24+r29+g02d67c5-1
perl-email-date-format 1.007-1 1.008-1
php-legacy 8.1.14-1.1 8.1.14-3
php-legacy-apache 8.1.14-1.1 8.1.14-3
php-legacy-cgi 8.1.14-1.1 8.1.14-3
php-legacy-dblib 8.1.14-1.1 8.1.14-3
php-legacy-embed 8.1.14-1.1 8.1.14-3
php-legacy-enchant 8.1.14-1.1 8.1.14-3
php-legacy-fpm 8.1.14-1.1 8.1.14-3
php-legacy-gd 8.1.14-1.1 8.1.14-3
php-legacy-odbc 8.1.14-1.1 8.1.14-3
php-legacy-pgsql 8.1.14-1.1 8.1.14-3
php-legacy-phpdbg 8.1.14-1.1 8.1.14-3
php-legacy-pspell 8.1.14-1.1 8.1.14-3
php-legacy-snmp 8.1.14-1.1 8.1.14-3
php-legacy-sodium 8.1.14-1.1 8.1.14-3
php-legacy-sqlite 8.1.14-1.1 8.1.14-3
php-legacy-tidy 8.1.14-1.1 8.1.14-3
php-legacy-xsl 8.1.14-1.1 8.1.14-3
pipewire-media-session 1:0.4.1-2 -
pipewire-media-session-docs 1:0.4.1-2 -
plasma-framework 5.101.0-1 5.102.0-1
plasma-wayland-protocols 1.9.0-1 1.10.0-1
polly 14.0.6-1 15.0.7-1
postgresql 14.6-1 14.6-2
postgresql-docs 14.6-1 14.6-2
postgresql-libs 14.6-1 14.6-2
postgresql-old-upgrade 13.9-1 13.9-2
prison 5.101.0-2 5.102.0-1
purpose 5.101.0-1 5.102.0-1
pyside2 5.15.8-3 5.15.8-5
pyside2-tools 5.15.8-3 5.15.8-5
pyside6 6.4.2-1 6.4.2-5
python-shiboken2 5.15.8-3 5.15.8-5
python-trove-classifiers 2023.1.12-1 2023.1.20-1
qqc2-desktop-style 5.101.0-1 5.102.0-1
qt5-base 5.15.8+kde+r162-1 5.15.8+kde+r174-1
qt5-imageformats 5.15.8+kde+r6-1 5.15.8+kde+r9-1
qt5-tools 5.15.8+kde+r1-1 5.15.8+kde+r1-3
qt5-xcb-private-headers 5.15.8+kde+r162-1 5.15.8+kde+r174-1
qt6-tools 6.4.2-1 6.4.2-3
qtcreator 9.0.1-1 9.0.1-3
qtcreator-devel 9.0.1-1 9.0.1-3
rust 1:1.66.1-1 1:1.66.1-2
rust-src 1:1.66.1-1 1:1.66.1-2
shiboken6 6.4.2-1 6.4.2-5
solid 5.101.0-1 5.102.0-1
sonnet 5.101.0-1 5.102.0-1
spamassassin 3.4.6-4 4.0.0-1
suitesparse 6.0.3-1 7.0.0-1
syndication 5.101.0-1 5.102.0-1
syntax-highlighting 5.101.0-1 5.102.0-1
sysprof 3.46.0-1 3.46.0-3
tcpdump 4.99.2-1 4.99.3-1
threadweaver 5.101.0-1 5.102.0-1
tomcat10 10.1.4-1 10.1.5-1
tomcat9 9.0.70-1 9.0.71-1
virglrenderer 0.10.3-2 0.10.4-1
wildmidi 0.4.4-1 0.4.5-1
xfce4-datetime-plugin 0.8.2-1 0.8.3-1
base-devel - 1-1
clang14 - 14.0.6-1
compiler-rt14 - 14.0.6-1
llvm14 - 14.0.6-2
llvm14-libs - 14.0.6-2
pyside6-tools - 6.4.2-5
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.12.1.r12884.g90e6b42a2-122.12.1.r12893.g30d6187ab-1
akonadi-calendar22.12.1.r2255.gf80d25b-122.12.1.r2259.g97f4e37-1
akonadi-calendar-tools22.12.1.r998.gd59d9fa-122.12.1.r1001.g981eb20-1
akonadi-contacts22.12.1.r3323.g02c344d1-122.12.1.r3328.gac9067e0-1
akonadi-import-wizard22.12.1.r1888.g40c3511-122.12.1.r1890.gf9baf75-1
akonadi-mime22.12.1.r1803.g8940226-122.12.1.r1805.g49850a9-1
akonadi-notes22.12.1.r1119.g62b2ba6-122.12.1.r1121.g1019a00-1
akonadi-search22.12.1.r1321.g79f4f74-122.12.1.r1323.gc02acf5-1
akonadiconsole22.12.1.r1642.g2dab62f-122.12.1.r1644.g04aada0-1
akregator22.12.1.r6556.g03459401-122.12.1.r6569.g0302b963-1
alligator 22.11.r26.g67af0dd-1 22.11.r27.gfbabd3b-1
analitza22.12.1.r2377.g72d81727-122.12.1.r2379.g7fd23cf7-1
angelfish 22.11.r32.g1eeddb8-1 22.11.r34.ga0a354a-1
ark22.12.1.r4985.g14665aeb-122.12.1.r4988.ge2161ab6-1
artikulate22.12.1.r1488.gc8d3c6c-122.12.1.r1491.g0bc1e16-1
attica5.101.0.r895.g7023125-15.102.0.r895.g7023125-1
audiocd-kio22.12.1.r1150.g46beaa3-122.12.1.r1152.g89094fc-1
audiotube 22.11.r55.g4237746-1 22.11.r59.g9261999-1
aura-browser5.26.0.r167.g3e42f95-15.26.0.r170.g0c80713-1
baloo5.101.0.r3125.g1a9ed786-15.102.0.r3126.g3181bd87-1
baloo-widgets22.12.1.r806.g344e399-122.12.1.r807.gce8508b-1
blinken22.12.1.r713.g3092e90-122.12.1.r714.gc6b2588-1
bluedevil1:5.26.5.r2559.gb9740b56-11:5.26.5.r2564.g086ffb8e-1
bluez-qt5.101.0.r733.gb02f8af-15.102.0.r733.gb02f8af-1
bomber22.12.1.r611.g2d9eba3-122.12.1.r612.g54f0d66-1
bovo22.12.1.r823.g08ff085-122.12.1.r824.ge7a0615-1
breeze5.26.5.r2548.gf4fc55d6-15.26.5.r2554.gdc404b0c-1
breeze-gtk5.26.5.r493.g4a1108c-15.26.5.r495.g830fd1c-1
breeze-icons5.101.0.r1946.gd6f83058-15.102.0.r1950.gc80321bf-1
calendarsupport22.08.3.r777.ga86b4eb-122.08.3.r780.g5f50446-1
calindori 22.11.r15.gbc5c657-1 22.11.r16.g3f57077-1
cervisia22.12.1.r1739.gbfb5e20-122.12.1.r1741.gd23c18c-1
discover5.26.5.r9152.g76cec88bc-15.26.5.r9164.ge3ea41303-1
dolphin22.12.1.r7233.g135174d6b-122.12.1.r7238.gc70938618-1
dolphin-plugins22.12.1.r720.g107a339-122.12.1.r722.g98ffc36-1
dragon22.12.1.r1130.g22f5ec2-122.12.1.r1133.gbb4153e-1
drkonqi5.26.5.r873.gd923e6d0-15.26.5.r875.gbfee0d46-1
elisa22.12.1.r3120.gf8478b91-122.12.1.r3127.ga8ddcd27-1
elisa-qtmm22.12.1.r3120.gf8478b91-122.12.1.r3127.ga8ddcd27-1
eventviews22.08.3.r927.gd1be10f-122.08.3.r930.g32d1749-1
extra-cmake-modules5.101.0.r3545.g34fd474a-15.102.0.r3548.gc278bb34-1
ffmpegthumbs22.12.1.r244.g76f786b-122.12.1.r249.g5a6ff57-1
filelight22.12.1.r1317.g3f6bc9a-122.12.1.r1324.gec4db67-1
frameworkintegration5.101.0.r665.g7a5a095-15.102.0.r665.g7a5a095-1
granatier22.12.1.r1023.gb4c7564-122.12.1.r1025.g20c53f6-1
grantlee-editor22.12.1.r892.g7bc9b6a-122.12.1.r895.gfe7865f-1
grantleetheme22.12.1.r455.gc71d785-122.12.1.r457.gc33609b-1
gwenview22.12.1.r7015.gbb3388b1-122.12.1.r7021.gf9db3d1f-1
incidenceeditor22.12.1.r979.g8306dc7-122.12.1.r983.gf8752c2-1
itinerary22.12.1.r2243.g81e57a3-122.12.1.r2275.g7477438-1
juk22.12.1.r3221.g05fdc509-122.12.1.r3223.g73ae1874-1
k3b1:22.12.1.r6902.gef88bd479-11:22.12.1.r6905.g338a5e86b-1
kaccounts-integration22.12.1.r1326.g54d5f0c-122.12.1.r1327.g7fb38c5-1
kactivities5.101.0.r1421.g7dcba28e-15.102.0.r1421.g7dcba28e-1
kactivities-stats5.101.0.r428.gc7ab8bd-15.102.0.r428.gc7ab8bd-1
kaddressbook22.12.1.r6299.g4d0ef0a6-122.12.1.r6304.gf7c3ac08-1
kajongg22.12.1.r4386.gb948aa76-122.12.1.r4390.g5819af52-1
kalarm22.12.1.r8228.gd9440418-122.12.1.r8239.gb84b98b9-1
kalgebra22.12.1.r2121.g1cf6cda-122.12.1.r2123.ge77c387-1
kalk 22.11.r27.g1832e6c-1 22.11.r38.g833c014-1
kalzium22.12.1.r4456.gcdd7f968-122.12.1.r4458.g23bb7962-1
kamera22.12.1.r782.gc4209e2-122.12.1.r786.gb135e49-1
kamoso22.12.1.r1523.g61a8082-122.12.1.r1524.g8ce8642-1
kanagram22.12.1.r1368.g67a8c97-122.12.1.r1370.gf934f98-1
kapidox5.101.0.r584.gce3a81e-15.102.0.r584.gce3a81e-1
kapman22.12.1.r704.g1875a26-122.12.1.r705.g440d6fc-1
karchive5.101.0.r602.gc079903-15.102.0.r602.gc079903-1
kasts 22.11.r61.g420a053-1 22.11.r77.gdb41655-1
kate22.12.1.r20185.gf6e2e422c-122.12.1.r20202.gc3e109d7f-1
katomic22.12.1.r1006.g747eb0b-122.12.1.r1007.g780564a-1
kauth5.101.0.r534.g7158ec0-15.102.0.r534.g7158ec0-1
kbackup22.12.1.r497.gd8aeeb5-122.12.1.r500.g7dc5f2e-1
kblackbox22.12.1.r813.g5de4e8e-122.12.1.r814.g5dccadf-1
kblocks22.12.1.r788.g14cac55-122.12.1.r789.g1ac3b5f-1
kbookmarks5.101.0.r499.g62c4d23-15.102.0.r499.g62c4d23-1
kbruch22.12.1.r924.gbaea8a7-122.12.1.r926.gd978f5d-1
kcachegrind22.12.1.r1230.g98d5e96-122.12.1.r1231.gdcb8f76-1
kcachegrind-common22.12.1.r1230.g98d5e96-122.12.1.r1231.gdcb8f76-1
kcalc22.12.1.r1674.g0020b82-122.12.1.r1684.g5091d57-1
kcalendarcore5.101.0.r1358.g6585c73a9-15.102.0.r1359.gcf6ec550d-1
kcalutils22.12.1.r1026.gcb8e8df88-122.12.1.r1029.ge6598f099-1
kcharselect22.12.1.r585.gc7301e1-122.12.1.r586.gc9e4458-1
kclock 22.11.r37.g571858a-1 22.11.r39.g499f6cc-1
kcmutils5.101.0.r703.ged76bce-15.102.0.r703.ged76bce-1
kcodecs5.101.0.r468.gb0afeb5-15.102.0.r468.gb0afeb5-1
kcompletion5.101.0.r537.gec9fbb1-15.102.0.r537.gec9fbb1-1
kconfig5.101.0.r1022.g40ff273f-15.102.0.r1022.g40ff273f-1
kconfigwidgets5.101.0.r846.g2f5d6a41-15.102.0.r846.g2f5d6a41-1
kcontacts1:5.101.0.r3387.g6e595406-11:5.102.0.r3390.g25971668-1
kcoreaddons5.101.0.r1643.g92b4a95c-15.102.0.r1644.g9d549d42-1
kcrash5.101.0.r466.g27051f7-15.102.0.r466.g27051f7-1
kcron22.12.1.r879.ge5fbb95-122.12.1.r881.gccce789-1
kdav1:5.101.0.r1381.g7467040-11:5.102.0.r1381.g7467040-1
kdbusaddons5.101.0.r453.g51960f2-15.102.0.r453.g51960f2-1
kde-cli-tools5.26.5.r2041.gbaab41e-15.26.5.r2050.gcb47b5c-1
kde-gtk-config5.26.5.r955.g380682d-15.26.5.r957.g491f700-1
kdebugsettings22.12.1.r1061.gb73f4f9-122.12.1.r1064.g0d42ae6-1
kdeclarative5.101.0.r1091.g9720a04-15.102.0.r1091.g9720a04-1
kdeconnect22.12.1.r3661.g5db7d31e-122.12.1.r3672.gb34a0a8f-1
kdecoration5.26.5.r319.gb32fb3f-15.26.5.r321.g0c34a05-1
kded5.101.0.r488.g851ad03-15.102.0.r488.g851ad03-1
kdelibs4support5.101.0.r1144.g4c913503-15.102.0.r1144.g4c913503-1
kdenetwork-filesharing22.12.1.r1031.g88e61d1-122.12.1.r1032.ga4c47ae-1
kdenlive22.12.1.r17309.g33cf53602-122.12.1.r17324.g2843d9054-1
kdepim-addons22.12.1.r5022.g7be26c88b-122.12.1.r5041.gd47b66964-1
kdepim-runtime22.12.1.r15684.g7221cf565-122.12.1.r15692.gca8aee570-1
kdeplasma-addons5.26.5.r9268.gd41e79124-15.26.5.r9281.g3520d34ad-1
kdesignerplugin5.101.0.r386.g48a8e4e-15.102.0.r386.g48a8e4e-1
kdesu5.101.0.r544.g0a89280-15.102.0.r544.g0a89280-1
kdf22.12.1.r916.g217f8c4-122.12.1.r918.g8f8a3e8-1
kdialog22.12.1.r1286.gaac92e91c-122.12.1.r1291.gb85a9e3f8-1
kdiamond22.12.1.r767.g7a9729f-122.12.1.r768.gb7bed27-1
kdnssd5.101.0.r384.g4351e1a-15.102.0.r384.g4351e1a-1
kdoctools5.101.0.r707.g6b44841-15.102.0.r707.g6b44841-1
keditbookmarks22.12.1.r2798.g582cbc1cd-122.12.1.r2802.g6cac516d8-1
kemoticons5.101.0.r434.g09b2759-15.102.0.r434.g09b2759-1
keysmith 22.11.r10.g16cfcd2-1 22.11.r12.gb5d92ab-1
kfilemetadata5.101.0.r912.g5bd67e9-15.102.0.r913.g34637be-1
kfind22.12.1.r2771.gce8db2e32-122.12.1.r2773.g562afb01a-1
kfloppy22.12.1.r836.g6617053-122.12.1.r839.g59d7629-1
kfourinline22.12.1.r1074.g400840f-122.12.1.r1075.g19a8902-1
kgamma55.26.5.r505.g1ff44c3-15.26.5.r509.gbb5bd29-1
kgeography22.12.1.r1222.g41a1abf-122.12.1.r1223.g3adbf50-1
kget22.12.1.r3303.g00986787-122.12.1.r3308.g2c4f2201-1
kglobalaccel5.101.0.r622.g5d3158c-15.102.0.r622.g5d3158c-1
kgoldrunner22.12.1.r1339.g0ee52bc-122.12.1.r1343.gf967785-1
kguiaddons5.101.0.r527.gc28c8b7-15.102.0.r527.gc28c8b7-1
khangman22.12.1.r1662.g56cbdb1-122.12.1.r1663.geea94fc-1
khealthcertificate 22.11.r4.gf456172-1 22.11.r5.gdd2c53a-1
khelpcenter22.12.1.r2850.g7f8f183a-122.12.1.r2853.gbd102f5c-1
kholidays1:5.101.0.r1097.gf407911-11:5.102.0.r1097.gf407911-1
khotkeys5.26.5.r2203.g8e4255b-15.26.5.r2209.g86445a0-1
khtml5.101.0.r642.gaa8e54d-15.102.0.r642.gaa8e54d-1
ki18n5.101.0.r609.ge219825-15.102.0.r609.ge219825-1
kiconthemes5.101.0.r664.gb4ac654-15.102.0.r664.gb4ac654-1
kidentitymanagement22.12.1.r3944.g9e53f6d3-122.12.1.r3947.g8daa7904-1
kidletime5.101.0.r388.g897991a-15.102.0.r388.g897991a-1
kig22.12.1.r3276.gf397b806-122.12.1.r3279.ge68af818-1
kigo22.12.1.r621.g3245d5f-122.12.1.r624.gf24db27-1
killbots22.12.1.r844.g1065fca-122.12.1.r846.g22b741d-1
kimageformats5.101.0.r475.g14742cb-15.102.0.r475.g14742cb-1
kimagemapeditor22.12.1.r558.g47c99d9-122.12.1.r559.gb2b265a-1
kimap22.12.1.r1240.g374e487-122.12.1.r1242.g3ac4581-1
kinfocenter5.26.5.r2284.gd2f462b0-15.26.5.r2296.gd2d95473-1
kinit5.101.0.r474.g9750384-15.102.0.r474.g9750384-1
kio5.101.0.r6013.ga831d650e-15.102.0.r6016.g6ed4ba88d-1
kio-extras22.12.1.r7474.ga176945a7-122.12.1.r7478.gce9686268-1
kio-gdrive22.12.1.r691.ge1ad779-122.12.1.r695.g006760e-1
kirigami-addons1:0.6.1.r24.gff9598e-11:0.6.1.r26.ge2e0d44-1
kirigami25.101.0.r3569.ge9f19ecd-15.102.0.r3570.g38caa088-1
kitemmodels5.101.0.r637.g5a40081-15.102.0.r637.g5a40081-1
kitemviews5.101.0.r409.g719b760-15.102.0.r409.g719b760-1
kiten22.12.1.r1252.g1aa1e45-122.12.1.r1253.gbca4dd2-1
kitinerary22.12.1.r2630.g6e30e92a-122.12.1.r2650.g33144ce4-1
kjobwidgets5.101.0.r458.ge2c9bed-15.102.0.r458.ge2c9bed-1
kjs5.101.0.r386.g62ecf47-15.102.0.r386.g62ecf47-1
kjsembed5.101.0.r358.g9f818ff-15.102.0.r358.g9f818ff-1
kjumpingcube22.12.1.r888.g8dcc023-122.12.1.r890.gbc1064f-1
kldap22.12.1.r1009.gfaeea56-122.12.1.r1013.g1d38991-1
kleopatra22.12.1.r7070.g9c441441-122.12.1.r7079.g25d9ec29-1
klettres22.12.1.r1013.geba013c-122.12.1.r1014.gfde03a9-1
klickety22.12.1.r748.gaf1b176-122.12.1.r749.g7c331de-1
klines22.12.1.r862.gc88fb2f-122.12.1.r863.g9c7d586-1
kmag22.12.1.r779.gea64760-122.12.1.r782.ga49e9bd-1
kmahjongg22.12.1.r1608.g3382562-122.12.1.r1611.gb09e112-1
kmail22.12.1.r26755.g8d4d897c1-122.12.1.r26769.gb5adc4f36-1
kmail-account-wizard22.12.1.r936.g655d447-122.12.1.r939.g9ea1977-1
kmailtransport22.12.1.r1844.gc197378-122.12.1.r1849.gb33ddef-1
kmbox22.12.1.r623.gf16aaeb-122.12.1.r626.ga1a8980-1
kmediaplayer5.101.0.r332.gabed31a-15.102.0.r332.gabed31a-1
kmenuedit5.26.5.r1139.g11060fe-15.26.5.r1142.gfd14bf7-1
kmime22.12.1.r1571.gcb18c70-122.12.1.r1573.g20e85b9-1
kmines22.12.1.r1813.g4ecf55b-122.12.1.r1814.g7f2c516-1
kmix22.12.1.r2497.gb3011429-122.12.1.r2500.g3f0cf089-1
kmousetool22.12.1.r485.g9017d64-122.12.1.r486.gb9736da-1
kmouth22.12.1.r792.ge649fdd-122.12.1.r797.g8caa307-1
kmplot22.12.1.r1559.g1e5a01d-122.12.1.r1560.g92aa297-1
knetwalk22.12.1.r759.g25fd263-122.12.1.r760.g33f81dc-1
knewstuff5.101.0.r1454.g06ddecf7-15.102.0.r1454.g06ddecf7-1
knights22.12.1.r1204.g7bed0ae-122.12.1.r1206.gd9cce68-1
knotes22.12.1.r3776.gc4779449-122.12.1.r3789.gabb69bf9-1
knotifications5.101.0.r796.g95557fc-15.102.0.r796.g95557fc-1
knotifyconfig5.101.0.r417.gfddd532-15.102.0.r417.gfddd532-1
koko 22.11.r8.g01d0953-1 22.11.r9.gede942f-1
kolf22.12.1.r1573.gbe56894-122.12.1.r1575.g36b00aa-1
kollision22.12.1.r579.ge8f1618-122.12.1.r580.g3335f84-1
kolourpaint22.12.1.r2481.g1be76a8b-122.12.1.r2484.gcac4ec93-1
kompare22.12.1.r1230.g041e440-122.12.1.r1233.g4790fc0-1
kongress 22.11.r9.g9398368-1 22.11.r10.gb2d114e-1
konqueror22.12.1.r15288.g2bfd4c7cb-122.12.1.r15296.g301d86199-1
konquest22.12.1.r994.gee1d0e1-122.12.1.r995.gd0fa761-1
konsole22.12.1.r8831.gb783fdcb4-122.12.1.r8832.g0fe5d5bba-1
kontact22.12.1.r5641.g66bf88e4-122.12.1.r5644.g2094c91e-1
kontactinterface22.12.1.r739.g0b5a9d8-122.12.1.r741.g87962cf-1
kontrast22.12.1.r278.ga1e7a64-122.12.1.r279.ga513b75-1
konversation22.12.1.r9237.gaf5eee7e-122.12.1.r9239.gd3a12c17-1
kopete22.12.1.r16518.g98437e708-122.12.1.r16521.g78e43f27c-1
korganizer22.12.1.r11917.g55faf0010-122.12.1.r11924.g3355590e1-1
kosmindoormap22.12.1.r900.g0a940b2-122.12.1.r901.ga23a68f-1
kpackage5.101.0.r805.g454cfd6-15.102.0.r805.g454cfd6-1
kparts5.101.0.r649.g8bf8256-15.102.0.r649.g8bf8256-1
kpat22.12.1.r2689.g763df906-122.12.1.r2703.g5cf071be-1
kpeople5.101.0.r1411.geb539dc-15.102.0.r1411.geb539dc-1
kpeoplevcard 0.1.r64.g11d8e74-1 0.1.r65.gd77c159-1
kpimtextedit22.12.1.r1756.gbd2eef9-122.12.1.r1771.g41b5358-1
kpipewire5.26.5.r195.g41d8692-15.26.5.r198.g270b99a-1
kpkpass22.12.1.r321.gb9fc4a0-122.12.1.r323.gd199b02-1
kplotting5.101.0.r343.g2a30da7-15.102.0.r343.g2a30da7-1
kpmcore22.12.1.r1342.g6582336-122.12.1.r1345.g1031e44-1
kpty5.101.0.r406.g1baa7ae-15.102.0.r406.g1baa7ae-1
kpublictransport22.12.1.r2093.gb38885f2-122.12.1.r2095.g6acdee65-1
kquickcharts5.101.0.r550.ga6d0e25-15.102.0.r550.ga6d0e25-1
krdc22.12.1.r1673.g2437822-122.12.1.r1676.g1837692-1
krecorder 22.11.r31.g807b968-1 22.11.r32.g9edceef-1
kreversi22.12.1.r1322.g3f0b79e-122.12.1.r1323.g3d2e646-1
krfb22.12.1.r1543.ge0ec84e-122.12.1.r1544.gdf52969-1
kross5.101.0.r389.g7f9c623-15.102.0.r389.g7f9c623-1
kruler22.12.1.r801.gd4b472d-122.12.1.r803.g3b43314-1
krunner5.101.0.r805.g31accda-15.102.0.r805.g31accda-1
ksanecore r668.g5e3d71f-1 r669.gdfc5065-1
kscreen5.26.5.r1653.g78e508c-15.26.5.r1658.g42db554-1
kscreenlocker5.26.5.r1053.gec651b2-15.26.5.r1056.g7295aa9-1
kservice5.101.0.r1069.g5740068-15.102.0.r1069.g5740068-1
kshisen22.12.1.r1289.g3c3eaf5-122.12.1.r1291.gd3663d9-1
ksirk22.12.1.r1100.gdedf84c-122.12.1.r1103.g9a61e28-1
ksmtp22.12.1.r487.g4e1250c-122.12.1.r489.g30512e7-1
ksnakeduel22.12.1.r899.g7b25dc3-122.12.1.r900.gc1e48f8-1
kspaceduel22.12.1.r717.ge72b844-122.12.1.r718.g835f150-1
ksquares22.12.1.r628.gb0739bf-122.12.1.r629.g3c70642-1
ksshaskpass5.26.5.r245.ge96b12b-15.26.5.r248.gcd1b4e2-1
ksudoku22.12.1.r1166.g23dd547-122.12.1.r1171.g293269c-1
ksysguard5.26.5.r3578.g05bad52b-15.26.5.r3581.g9edb14c0-1
ksystemlog22.12.1.r802.g7180d1f-122.12.1.r804.g9a34e38-1
ksystemstats5.26.5.r270.g46441ad-15.26.5.r273.gecd05ea-1
kteatime22.12.1.r796.g4e7a3b8-122.12.1.r797.g950254d-1
ktexteditor5.101.0.r3723.g800af913-15.102.0.r3724.g12589220-1
ktextwidgets5.101.0.r492.g6655177-15.102.0.r492.g6655177-1
ktimer22.12.1.r564.g6cfd638-122.12.1.r568.g794e4be-1
ktnef22.12.1.r769.g35ff43c-122.12.1.r771.gfac09d0-1
ktorrent22.12.1.r2940.g5aae5aa1-122.12.1.r2943.g089c4838-1
ktouch22.12.1.r2238.gefbfd72-122.12.1.r2240.ga118f1d-1
ktrip 22.11.r8.g7d39985-1 22.11.r9.gddb7389-1
ktuberling22.12.1.r1125.g57a9636-122.12.1.r1128.g97b3b84-1
kturtle22.12.1.r1225.g4acbba0-122.12.1.r1228.g3139277-1
kubrick22.12.1.r463.g260ba83-122.12.1.r467.g42179bd-1
kunitconversion5.101.0.r470.g75d06ab-15.102.0.r470.g75d06ab-1
kwallet5.101.0.r1222.ga5df942-15.102.0.r1222.ga5df942-1
kwallet-pam5.26.5.r279.g919e188-15.26.5.r281.g9772b3d-1
kwalletmanager22.12.1.r1376.gbda0283-122.12.1.r1385.g315fba5-1
kwave22.12.1.r3846.g46a07707-122.12.1.r3849.g68c06df4-1
kwayland5.101.0.r1202.g9ad5a21-15.102.0.r1202.g9ad5a21-1
kwayland-integration5.26.5.r224.ge771883-15.26.5.r226.g12948ef-1
kweather 22.11.r25.gaa48b47-1 22.11.r28.gf71d2e1-1
kwidgetsaddons5.101.0.r1043.g3d9d07dc-15.102.0.r1043.g3d9d07dc-1
kwin5.26.5.r23917.g9cd52b406-15.26.5.r23955.gfef1553b9-1
kwindowsystem5.101.0.r740.g2b77836-15.102.0.r740.g2b77836-1
kwordquiz22.12.1.r1269.g62b1533-122.12.1.r1271.g402ff1c-1
kwrite22.12.1.r20185.gf6e2e422c-122.12.1.r20202.gc3e109d7f-1
kwrited5.26.5.r523.g1430a52-15.26.5.r525.gd90ced9-1
kxmlgui5.101.0.r987.g770bca68-15.102.0.r988.g5856097e-1
kxmlrpcclient5.101.0.r507.g5e4e54938-15.102.0.r507.g5e4e54938-1
layer-shell-qt5.26.5.r69.gb95910c-15.26.5.r71.gd06bcbe-1
libakonadi22.12.1.r12884.g90e6b42a2-122.12.1.r12893.g30d6187ab-1
libgravatar22.12.1.r463.g3730e17-122.12.1.r467.gae492b3-1
libkcddb22.12.1.r789.gcb914dd-122.12.1.r790.g7ec96c9-1
libkdegames22.12.1.r2288.g2e1e574c-122.12.1.r2290.g95d9dea4-1
libkdepim22.12.1.r952.g29596ea-122.12.1.r954.gcd02acc-1
libkgapi22.12.1.r1412.gc9c39a2-122.12.1.r1415.g554bccc-1
libkleo22.12.1.r1368.g5f90a60-122.12.1.r1374.g6252a89-1
libkmahjongg22.12.1.r513.g2fe3cc3-122.12.1.r514.g89af43e-1
libksane22.12.1.r630.g0160b4c-122.12.1.r632.g64ae234-1
libkscreen5.26.5.r1722.g5c160c4-15.26.5.r1727.g8836eed-1
libksieve22.12.1.r1802.gbbf9030f-122.12.1.r1815.g751f9d60-1
libksysguard5.26.5.r2517.g2802a0e-15.26.5.r2524.gd528f7d-1
lokalize22.12.1.r1898.gad5c260d-122.12.1.r1901.g58d21979-1
lskat22.12.1.r899.gd6035ba-122.12.1.r900.g7448d3f-1
mailcommon22.12.1.r1364.gadfaf6f-122.12.1.r1371.g16ab834-1
mailimporter22.12.1.r575.g715710e-122.12.1.r578.g2298602-1
mbox-importer22.12.1.r610.ge4a5e18-122.12.1.r613.g53d8101-1
messagelib22.12.1.r6852.g21fe13adc-122.12.1.r6867.g11fad1760-1
milou5.26.5.r802.g53aef7f-15.26.5.r804.g95c10cc-1
modemmanager-qt5.101.0.r573.g4fdd548-15.102.0.r573.g4fdd548-1
neochat22.11.r119.g7818747e-122.11.r130.g3e48578b-1
networkmanager-qt5.101.0.r1177.gc7072d0-15.102.0.r1177.gc7072d0-1
okular22.12.1.r9940.g0b705a4b7-122.12.1.r9948.gffc1d2d36-1
oxygen5.26.5.r4543.g079b51bf-15.26.5.r4546.g5416638b-1
oxygen-icons1:5.101.0.r5.gbff159d-11:5.102.0.r5.gbff159d-1
oxygen-icons-svg1:5.101.0.r5.gbff159d-11:5.102.0.r5.gbff159d-1
palapeli22.12.1.r1358.gda5aafd-122.12.1.r1360.g006dc68-1
parley22.12.1.r4580.g3eb71d55-122.12.1.r4583.g578a751e-1
partitionmanager22.12.1.r1724.g84e0ed6-122.12.1.r1727.gfefd1ec-1
picmi22.12.1.r616.gc3eb48d-122.12.1.r618.gb335862-1
pim-data-exporter22.12.1.r2855.g23dfdf15-122.12.1.r2859.g7feb1b56-1
pim-sieve-editor22.12.1.r1719.g44a1a91-122.12.1.r1725.g2f396fd-1
pimcommon22.08.3.r1909.g9c17b8b1-122.08.3.r1957.gfa5b323b-1
plank-player5.26.0.r126.g15fa7d8-15.26.0.r128.g30f7ede-1
plasma-bigscreen5.26.0.r614.g0690960-15.26.0.r619.gb03110e-1
plasma-browser-integration5.26.5.r1413.gf8da3d31-15.26.5.r1416.gf0cbef15-1
plasma-desktop5.26.5.r10018.gd450e5605-15.26.5.r10037.gddfb587d2-1
plasma-dialer 22.11.r44.g7c10c02-1 22.11.r52.g79de070-1
plasma-disks5.26.5.r323.gd82488f-15.26.5.r326.g9d94e5e-1
plasma-firewall5.26.5.r704.g8edb5f3-15.26.5.r708.ge0d8e87-1
plasma-framework5.101.0.r16582.gdedbfb905-15.102.0.r16585.g1d339c8a9-1
plasma-integration5.26.5.r621.g19f9874-15.26.5.r624.gba1a9e5-1
plasma-mobile5.26.5.r2128.gfa9b25077-15.26.5.r2135.g7a9565ff7-1
plasma-mobile-nm5.26.5.r3504.gda02162b-15.26.5.r3515.g27e64001-1
plasma-nm5.26.5.r3504.gda02162b-15.26.5.r3515.g27e64001-1
plasma-pa5.26.5.r1169.g574bf11-15.26.5.r1174.g8f585d2-1
plasma-phonebook 22.11.r26.ge3cb60c-1 22.11.r32.gdac12fd-1
plasma-remotecontrollers5.26.0.r221.g72a0956-15.26.0.r233.g0845074-1
plasma-sdk5.26.5.r2465.gfe980a93-15.26.5.r2468.g2a613319-1
plasma-settings 22.11.r24.gf85d63c-1 22.11.r30.gb4f28dd-1
plasma-systemmonitor5.26.5.r683.g096af7f-15.26.5.r691.g046cb2b-1
plasma-thunderbolt5.26.5.r219.g682ba05-15.26.5.r220.g9897fef-1
plasma-vault5.26.5.r419.gf6f004d-15.26.5.r422.g3ad89cf-1
plasma-wayland-session5.26.5.r13103.ge365c363a-15.26.5.r13130.g2930a9315-1
plasma-workspace5.26.5.r13103.ge365c363a-15.26.5.r13130.g2930a9315-1
plasma-workspace-wallpapers5.26.5.r405.gd0295f2-15.26.5.r407.g65466f0-1
plasmatube 22.11.r38.g00d6439-1 22.11.r39.gf63fae1-1
polkit-kde-agent5.26.5.r558.g5d96246-15.26.5.r561.geb8ac06-1
powerdevil5.26.5.r2666.g14f963a8-15.26.5.r2671.g9a65a872-1
print-manager22.12.1.r1228.g86bdf2e-122.12.1.r1235.gd15b3ac-1
prison5.101.0.r417.g79476a5-15.102.0.r417.g79476a5-1
purpose5.101.0.r1054.g9167c7c-15.102.0.r1054.g9167c7c-1
qcachegrind22.12.1.r1230.g98d5e96-122.12.1.r1231.gdcb8f76-1
qmlkonsole 22.11.r35.g489fa89-1 22.11.r37.g1d83e9f-1
qqc2-desktop-style5.101.0.r711.g122cd90-15.102.0.r711.g122cd90-1
sddm-kcm5.26.5.r719.ga157ffc-15.26.5.r722.gca0d85b-1
solid5.101.0.r841.g1f8440a-15.102.0.r841.g1f8440a-1
sonnet5.101.0.r752.g211f60e-15.102.0.r752.g211f60e-1
spacebar 22.11.r47.gadb6ada-1 22.11.r55.ga20582e-1
spectacle22.12.1.r1476.gfb31896-122.12.1.r1490.gdecc9d8-1
step22.12.1.r1292.g3b6e3e9-122.12.1.r1295.gd6b401f-1
svgpart22.12.1.r264.g4e9ae1d-122.12.1.r265.ga3146d1-1
sweeper22.12.1.r617.g60766b9-122.12.1.r619.gce59b27-1
syndication5.101.0.r894.g42e4676-15.102.0.r894.g42e4676-1
syntax-highlighting5.101.0.r2073.ga7b12583-15.102.0.r2083.gbb4b9606-1
systemsettings5.26.5.r2818.gb14ae84a-15.26.5.r2826.gcb81a877-1
telepathy-kde-accounts-kcm22.12.1.r1243.gd92306d-122.12.1.r1245.g3989127-1
telepathy-kde-auth-handler22.12.1.r302.g44a646f-122.12.1.r303.ge72be36-1
telepathy-kde-common-internals22.12.1.r2050.geea02f1-122.12.1.r2051.g786e7f0-1
telepathy-kde-contact-list22.12.1.r1117.gb607187-122.12.1.r1119.g3c55cf5-1
telepathy-kde-desktop-applets22.12.1.r1023.g44c0fcf-122.12.1.r1024.g8b55b1b-1
telepathy-kde-send-file22.12.1.r253.g3d8896b-122.12.1.r254.g85263b7-1
telepathy-kde-text-ui22.12.1.r2080.gc8a203a5-122.12.1.r2082.g3e938fad-1
threadweaver5.101.0.r563.gc3cc94a-15.102.0.r563.gc3cc94a-1
tokodon23.01.0.r62.gd5aad00-123.01.0.r84.g0ee5c10-1
vakzination 22.11.r14.g408bb9b-1 22.11.r23.g613ba74-1
vvave 2.2.1.r66.g9554287-1 2.2.1.r70.g6799dfb-1
xdg-desktop-portal-kde5.26.5.r607.g828b53d-15.26.5.r629.g50553ad-1
yakuake22.12.1.r902.g7c1935c-122.12.1.r904.g74f56ca-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
