Hello ARM community.
Boost got updated. Hopefully we got all the rebuilds in order. If we didn’t, please let us know.
Some highlights:
- Most of our kernels got updated
- Boost updated to 1.81. Did we forget any rebuilds?
- Thunderbird updated to 102.7.0
- LibreOffice updated to 7.4.5
- Mesa updated to 22.3.4
- Qemu updated to 7.2.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
End Of Life kernels (will be removed from repo soon):
linux60
(EOL on 2023-01-12)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver
. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1
as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
PHP 8.2 update and introduction of legacy branch
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php
and php-legacy
can be installed at the same time as the latter uses a -legacy
suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap
extension will no longer be provided as it relies on the c-client
library which has been abandoned for many years.
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sat Jan 28 15:51:43 CET 2023)
- arm-testing community aarch64: 437 new and 413 removed package(s)
- arm-testing core aarch64: 50 new and 48 removed package(s)
- arm-testing extra aarch64: 389 new and 377 removed package(s)
- arm-testing kde-unstable aarch64: 188 new and 187 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023-01-21 2023-01-28
bitwarden 2022.12.0-1 2023.1.1-1
callaudiod 0.1.6+1+g0755fde-1 0.1.7-1
electron18 18.3.15-1 -
electron19 19.1.8-1 -
element-desktop 1.11.18-1 1.11.20-1
element-web 1.11.18-1 1.11.20-1
feedbackd 0.0.0+git20220520-1 0.0.2+git20230106-1
filezilla 3.62.2-2.1 -
gnome-calls 43.0+8+g4de23bc-1 43.3-2
handbrake 1.6.0-1 1.6.1-1
handbrake-cli 1.6.0-1 1.6.1-1
libgbinder 1.1.31-1 1.1.32-1
phosh 0.23.0-10.23.0+86+geaf99c26-1
signal-desktop 6.0.1-1 6.2.0-1
sofia-sip 1.13.3-1 1.13.12-1
:: Different sync package(s) in repository community aarch64
acorn 1:8.8.1-1 1:8.8.2-1
aml 0.2.2-1 0.3.0-1
apk-tools 2.12.10-2 2.12.11-1
appstream-generator 0.8.8-2 0.9.0-1
astroid 0.16-5 0.16-6
audacity 1:3.2.3-1 1:3.2.4-1
audacity-docs 1:3.2.3-1 1:3.2.4-1
autorandr 1.13.1-1 1.13.3-1
aws-cli-v2 2.9.12-1 2.9.18-1
awxkit 21.10.2-2 21.11.0-1
b4 0.11.2-1 0.12.0-1
bash-bats 1.7.0-2 1.8.2-1
bash-language-server 4.5.1-1 4.6.1-1
bitwarden-cli 2022.11.0-1 2023.1.0-1
blender 17:3.4.1-7 17:3.4.1-10
bmake 20220928-2 20230126-1
bottom 0.7.1-1 0.8.0-1
bsdiff 4.3-12 -
capnproto 0.10.2-2 0.10.3-1
cargo-edit 0.11.7-2 0.11.8-1
cargo-expand 1.0.37-1 1.0.39-1
cargo-ndk 2.12.2-1 2.12.4-1
cargo-outdated 0.11.1-3 0.11.2-1
cargo-pgx 0.6.1-1 0.7.0-1
cargo-tarpaulin 0.23.1-1 0.24.0-1
cargo-zigbuild 0.14.3-1 0.14.5-1
cclive 0.9.3-28 0.9.3-29
chezmoi 2.29.3-1 2.29.4-1
clap 1.1.6-1 1.1.7-1
cockpit 283-1 284-1
cockpit-machines 281-1 282-1
cockpit-packagekit 283-1 284-1
cockpit-pcp 283-1 284-1
cockpit-podman 59-1 61-1
cockpit-storaged 283-1 284-1
cocogitto 5.2.0-1 5.3.1-1
containerd 1.6.14-1 1.6.15-1
converseen 0.9.10.0-1 0.9.10.1-1
corectrl 1.3.1-1 1.3.1-2
coturn 4.6.0-3 4.6.1-1
cpp-hocon 0.3.0-13 0.3.0-14
crane 0.12.1-1 0.13.0-1
cryfs 0.11.3-2 0.11.3-3
cryptominisat5 5.11.4-1 5.11.4-2
cxxbridge 1.0.86-1 1.0.88-1
datovka 4.21.1-1 4.21.1-2
diesel-cli 2.0.2-1 2.0.3-1
dns-over-https 2.3.2-1 2.3.3-1
docker 1:20.10.22-1 1:20.10.23-1
docker-buildx 0.9.1-1 0.10.0-1
docker-compose 2.14.2-1 2.15.1-1
dpdk 22.07-3 22.11.1-1
dpkg 1.21.17-1 1.21.19-1
dqlite 1.13.0-1 1.14.0-1
drone-cli 1.6.2-1 1.7.0-1
drumkv1 0.9.28-1 0.9.29-1
eclib 20221012-1 20221012-2
elementary-icon-theme 7.1.0-1 7.2.0-1
facter 3.14.24-4 3.14.24-5
fcitx5-chinese-addons 5.0.16-1 5.0.16-2
filezilla 3.62.2-2 3.63.1-1
firetools 0.9.64-2 0.9.72-1
flatbuffers 23.1.4-1 23.1.21-1
forgejo 1.18.2.0-1 1.18.2.1-1
freecad 0.20.2-3 0.20.2-4
ft2-clone 1.62-1 1.63-1
fwupd 1.8.9-2 1.8.10-1
fwupd-efi 1.3-1 1.4-1
fzf 0.35.1-1 0.37.0-1
gaupol 1.11-1 1.12-1
gearmand 1.1.20-2 1.1.20-3
gephi 0.9.7-1 0.10.1-1
gimagereader-common 3.4.0-4 3.4.0-5
gimagereader-gtk 3.4.0-4 3.4.0-5
gimagereader-qt 3.4.0-4 3.4.0-5
gitea 1.18.2-1 1.18.3-1
github-cli 2.21.2-1 2.22.1-1
gitoxide 0.19.0-2 0.20.0-1
glmark2 2021.12-1 2023.01-1
glob2 0.9.4.4-45 0.9.4.4-46
glom 1.32.0-10 1.32.0-11
glow 1.4.1-3 1.5.0-1
gnuradio 3.10.5.0-2 3.10.5.0-3
gnuradio-companion 3.10.5.0-2 3.10.5.0-3
gopass 1.15.2-1 1.15.3-1
gource 0.53-3 0.53-4
gping 1.7.0-1 1.8.0-1
grim 1.4.0-2 1.4.0-3
gtest 1.12.1-1 1.13.0-1
guitarix 0.44.1-3 0.44.1-4
hck 0.7.5-1 0.8.2-1
heaptrack 1.4.0-2 1.4.0-3
helm 3.10.3-1 3.11.0-1
hid-tools 0.3.1-1 0.3.1-2
highway 1.0.2-1 1.0.3-1
home-assistant 1:2023.1.5-1 1:2023.1.7-1
httping 2.5-5 2.9-1
hugin 2022.0.0-1 2022.0.0-3
i2pd 2.45.1-1 2.45.1-2
icewm 3.3.0-1 3.3.1-1
igraph 0.10.3-1 0.10.4-1
imagescan 3.65.0-8 3.65.0-9
influx-cli 2.5.0-1 2.6.1-1
influxdb 2.4.0-1 2.6.1-1
innoextract 1.9-7 1.9-8
ipython 8.8.0-1 8.9.0-1
irker 2.22-1 2.23-1
iwd 2.1-1 2.2-1
jacktrip 1:1.6.8-1 1:1.7.0-1
java-atk-wrapper-common 0.40.0-1 0.40.0-2
java-atk-wrapper-openjdk 0.40.0-1 0.40.0-2
java-atk-wrapper-openjdk11 0.40.0-1 0.40.0-2
java-atk-wrapper-openjdk17 0.40.0-1 0.40.0-2
java-atk-wrapper-openjdk8 0.40.0-1 0.40.0-2
jenkins 2.387-1 2.388-1
jmol 14.32.83-1 16.1.1-1
jsmol 14.32.83-1 16.1.1-1
jupyter-nbclassic 0.4.8-1 0.5.1-2
jupyter-nbconvert 7.2.8-1 7.2.9-1
jupyterlab 3.5.2-1 3.5.3-1
just 1.12.0-1 1.13.0-1
kea 2.2.0-3 2.2.0-4
kea-docs 2.2.0-3 2.2.0-4
kernelshark 2.1.1-2 2.2.0-1
kicad 6.0.10-1 6.0.11-1
kicad-library-3d 6.0.10-1 6.0.11-1
kicad-library 6.0.10-1 6.0.11-1
kubo 0.17.0-1 0.18.0-1
leatherman 1.12.9-1 1.12.9-2
ledger 3.2.1-11 3.2.1-12
lesspipe 2.06-1 2.07-1
libblastrampoline 5.3.0-1 5.4.0-1
libc++ 15.0.7-2 15.0.7-3
libc++abi 15.0.7-2 15.0.7-3
libhx 4.8-1 4.9-1
libime 1.0.16-1 1.0.16-2
liblas1.8.1.r128+gded46373-41.8.1.r128+gded46373-5
libmgba 0.10.0-2 0.10.1-1
librdkafka 2.0.0-1 2.0.2-1
libuhd 4.3.0.0-1 4.3.0.0-2
libwhereami 0.5.0-15 0.5.0-16
lightdm-slick-greeter 1.5.9-1 1.6.0-1
liquidctl 1.12.0-1 1.12.1-1
liteide 38.0-2 38.1-1
lmms 1.2.2-13 1.2.2-14
logwatch 7.7-1 7.8-1
lua-inifile 1.0-2 1.0-3
lua51-inifile 1.0-2 1.0-3
lua52-inifile 1.0-2 1.0-3
lua53-inifile 1.0-2 1.0-3
lucene++ 3.0.8-5 3.0.8-6
luminancehdr 2.6.1-12 2.6.1-13
lxc 1:5.0.1-2 1:5.0.2-1
lxcfs 5.0.2-1 5.0.3-1
lxd 5.10-1 5.10-2
mac 8.92-1 9.04-1
mapnik 3.1.0-16 3.1.0-17
mc 4.8.29-1 4.8.29-2
mediaelch 2.8.18-1 2.8.18-2
mgba-qt 0.10.0-2 0.10.1-1
mgba-sdl 0.10.0-2 0.10.1-1
mididings 20230114-1 20230114-2
mididings-docs 20230114-1 20230114-2
mimetic 0.9.8-2 0.9.8-3
minio 2022.11.11-2 2023.01.20-2
minio-client 2022.11.07-1 2023.01.11-1
miniupnpd 2.3.1-1 2.3.2-1
mkosi 13-1 14-2
mold 1.10.0-1 1.10.1-1
msgpack-c 4.0.0-1 5.0.0-1
msgpack-cxx 4.1.3-1 5.0.0-1
mympd 10.1.7-1 10.2.0-1
ncdu 1.16-2 2.2.2-2
ncmpcpp 0.9.2-9 0.9.2-10
neatvnc 0.5.4-1 0.6.0-1
neochat 22.11-3 22.11-5
nextcloud-app-calendar 1:4.2.1-1 1:4.2.2-1
nextcloud-app-contacts 5.0.2-2 5.0.3-1
nextcloud-app-news 20.0.0-2 20.0.1-1
nextcloud-app-notify_push 0.5.0-1 0.5.2-1
nextcloud-client 2:3.6.4-1 2:3.6.6-1
nextcloud-client-cloudproviders 2:3.6.4-1 2:3.6.6-1
nodejs 19.4.0-1 19.5.0-1
nomacs 1:3.17.2206-11 1:3.17.2206-12
npm-check-updates 16.6.2-1 16.6.3-1
oil 0.13.1-1 0.14.0-1
openimageio 2.4.6.1-3 2.4.6.1-4
openscad 2021.01-6 2021.01-7
openshadinglanguage 1.12.8.0-2 1.12.8.0-3
opensips 3.3.2-1 3.3.3-1
openvdb 10.0.1-1 10.0.1-2
osbuild 66-2 77-1
otf-aurulent-nerd 2.3.1-2 2.3.3-2
otf-cascadia-code-nerd 2.3.1-2 2.3.3-2
otf-codenewroman-nerd 2.3.1-2 2.3.3-2
otf-droid-nerd 2.3.1-2 2.3.3-2
otf-firamono-nerd 2.3.1-2 2.3.3-2
otf-hasklig-nerd 2.3.1-2 2.3.3-2
otf-hermit-nerd 2.3.1-2 2.3.3-2
otf-opendyslexic-nerd 2.3.1-2 2.3.3-2
otf-overpass-nerd 2.3.1-2 2.3.3-2
owncloud-client 3.0.0.9215-1 3.1.0.9872-1
oxyromon 0.13.0-1 0.14.1-1
padthv1 0.9.28-1 0.9.29-1
pantheon-code 6.2.0-1 7.0.0-1
papilo 2.1.2-1 2.1.2-2
parallel 20221222-1 20230122-1
parallel-docs 20221222-1 20230122-1
pd-lua 0.11.2-1 0.11.4-1
pekwm 0.2.1-2 0.3.0-1
perl-class-method-modifiers 2.13-3 2.14-1
perl-cpan-perl-releases 5.20221220-1 5.20230120-1
perl-dbd-sybase 1.20-1 1.22-1
perl-perl-critic 1.146-1 1.148-1
perl-sub-quote 1:2.006_007-2 1:2.006008-1
perl-test-needs 0.002009-3 0.002010-1
perl-test-without-module 0.20-8 0.21-1
perl-yaml-libyaml 0.85-1 0.86-1
poedit 1:3.2.2-1 1:3.2.2-2
povray 2:3.7.0.10-5 2:3.7.0.10-6
powerdns 4.7.3-1 4.7.3-2
powerdns-recursor 4.8.1-1 4.8.1-2
ppl 1.2-4 1.2-5
prjtrellis 1.2.1-3 1.2.1-4
psalm 5.4.0-1 5.6.0-1
pt2-clone 1.56-1 1.57-1
pulseview 0.4.2-8 0.4.2-9
py3status 3.47-1 3.48-1
pypinyin 0.47.1-1 0.48.0-1
pyright 1.1.290-1 1.1.291-1
python-aws-sam-translator 1.55.0-1 1.58.1-1
python-braintree 4.17.1-1 4.18.1-1
python-cachetools 5.2.1-1 5.3.0-1
python-cfn-lint 0.72.6-1 0.72.9-1
python-diff-cover 7.3.0-1 7.4.0-1
python-django-compressor 4.3-1 4.3.1-1
python-dotenv 0.21.0-1 0.21.1-1
python-email-validator 1.3.0-1 1.3.1-1
python-faker 13.14.0-1 13.15.0-1
python-fakeredis 2.4.0-1 2.6.0-1
python-flatbuffers 23.1.4-1 23.1.21-1
python-gitlab 3.12.0-1 3.12.0-2
python-google-auth 2.15.0-2 2.16.0-1
python-identify 2.5.13-1 2.5.15-1
python-iniconfig 1.1.1-5 2.0.0-1
python-j2cli 0.3.12b-6 0.3.12b-7
python-jupyter_client 7.4.9-1 8.0.1-1
python-jupyter_core 5.1.3-1 5.1.5-1
python-lmdb 1.3.0-1 1.4.0-1
python-mistletoe 1.0.0-1 1.0.1-1
python-moto 4.0.12-1 4.1.1-1
python-mt-940 4.27.0-1 4.28.0-1
python-openapi-schema-validator 0.4.0-1 0.4.1-1
python-openapi-spec-validator 0.5.1-1 0.5.2-1
python-pathspec 0.10.3-1 0.11.0-1
python-pikepdf 6.2.8.post1-1 6.2.9-1
python-pycapnp 1.2.2-1 1.2.2-3
python-pynitrokey 0.4.31-1 0.4.32-1
python-pyproject-metadata 0.6.1-1 0.6.1-2
python-pystemmer 2.2.0-1 2.2.0.1-1
python-pytest-httpx 0.21.2-1 0.21.3-1
python-qasync 0.23.0-1 0.23.0-2
python-reedsolo 1.5.4-4 1.7.0-1
python-rich 13.2.0-2 13.3.0-1
python-rope 1.6.0-1 1.7.0-1
python-sphinx-autoapi 2.0.0-1 2.0.1-1
python-sphinxcontrib-applehelp 1.0.2-9 1.0.4-1
python-spyder-kernels 2.4.1-1 2.4.2-1
python-xarray 2022.12.0-1 2023.01.0-1
qmapshack 1.16.1-4 1.16.1-5
qpwgraph 0.3.6-1 0.3.9-1
qtractor 0.9.30-1 0.9.31-1
raft 0.16.0-1 0.17.1-1
roundcubemail 1.6.0-1 1.6.1-1
rssguard 4.2.7-2 4.3.1-1
rssguard-nowebengine 4.2.7-2 -
ruby-bake-modernize 0.14.2-1 0.14.4-1
ruby-json 2.6.2-2 2.6.3-1
ruby-metadata_json_deps 0.5.0-1 1.0.0-1
ruby-mocha 1.14.0-1 1.16.1-1
ruby-multipart-post 2.2.3-2 2.3.0-1
ruby-rugged 1.5.0.1-1 1.5.1-1
ruff 0.0.228-1 0.0.236-1
rust-analyzer 20230116-1 20230123-1
samplv1 0.9.28-1 0.9.29-1
schroot 1.6.13-2 1.6.13-3
seamonkey 2.53.14-2 2.53.15-1
sequoia-wot 0.3.0-1 0.4.1-1
serverless 3.26.0-1 3.27.0-1
sh4d0wup 0.7.0-1 0.8.0-1
sile 0.14.7-1 0.14.8-1
skopeo 1.10.0-1 1.11.0-1
snapper 0.10.4-1 0.10.4-2
sonic-visualiser 4.5.1-1 4.5.1-3
step-ca 0.23.0-1 0.23.1-1
stp 2.3.3-7 2.3.3-8
strawberry 1.0.14-1 1.0.14-2
streamlink 5.1.2-1 5.2.1-1
supercollider 3.12.2-3 3.12.2-4
supertux 0.6.3-5 0.6.3-6
swaylock 1.7-1 1.7.1-1
switchboard-plug-about 6.1.0-2 6.2.0-1
sympol 0.1.9-13 0.1.9-14
synthv1 0.9.28-1 0.9.29-1
terminus-font 4.49.1-2 4.49.1-5
texstudio 4.4.1-1 4.4.1-2
timescaledb 2.9.1-1 2.9.2-1
timescaledb-old-upgrade 2.9.1-2 2.9.2-2
trojan 1.16.0-8 1.16.0-9
ttc-iosevka 17.0.4-1 17.1.0-1
ttc-iosevka-aile 17.0.4-1 17.1.0-1
ttc-iosevka-curly 17.0.4-1 17.1.0-1
ttc-iosevka-curly-slab 17.0.4-1 17.1.0-1
ttc-iosevka-etoile 17.0.4-1 17.1.0-1
ttc-iosevka-slab 17.0.4-1 17.1.0-1
ttc-iosevka-ss01 17.0.4-1 17.1.0-1
ttc-iosevka-ss02 17.0.4-1 17.1.0-1
ttc-iosevka-ss03 17.0.4-1 17.1.0-1
ttc-iosevka-ss04 17.0.4-1 17.1.0-1
ttc-iosevka-ss05 17.0.4-1 17.1.0-1
ttc-iosevka-ss06 17.0.4-1 17.1.0-1
ttc-iosevka-ss07 17.0.4-1 17.1.0-1
ttc-iosevka-ss08 17.0.4-1 17.1.0-1
ttc-iosevka-ss09 17.0.4-1 17.1.0-1
ttc-iosevka-ss10 17.0.4-1 17.1.0-1
ttc-iosevka-ss11 17.0.4-1 17.1.0-1
ttc-iosevka-ss12 17.0.4-1 17.1.0-1
ttc-iosevka-ss13 17.0.4-1 17.1.0-1
ttc-iosevka-ss14 17.0.4-1 17.1.0-1
ttc-iosevka-ss15 17.0.4-1 17.1.0-1
ttc-iosevka-ss16 17.0.4-1 17.1.0-1
ttc-iosevka-ss17 17.0.4-1 17.1.0-1
ttc-iosevka-ss18 17.0.4-1 17.1.0-1
ttf-3270-nerd 2.3.1-2 2.3.3-2
ttf-agave-nerd 2.3.1-2 2.3.3-2
ttf-anonymouspro-nerd 2.3.1-2 2.3.3-2
ttf-arimo-nerd 2.3.1-2 2.3.3-2
ttf-bigblueterminal-nerd 2.3.1-2 2.3.3-2
ttf-bitstream-vera-mono-nerd 2.3.1-2 2.3.3-2
ttf-cousine-nerd 2.3.1-2 2.3.3-2
ttf-daddytime-mono-nerd 2.3.1-2 2.3.3-2
ttf-dejavu-nerd 2.3.1-2 2.3.3-2
ttf-fantasque-nerd 2.3.1-2 2.3.3-2
ttf-firacode-nerd 2.3.1-2 2.3.3-2
ttf-go-nerd 2.3.1-2 2.3.3-2
ttf-hack-nerd 2.3.1-2 2.3.3-2
ttf-heavydata-nerd 2.3.1-2 2.3.3-2
ttf-iawriter-nerd 2.3.1-2 2.3.3-2
ttf-ibmplex-mono-nerd 2.3.1-2 2.3.3-2
ttf-inconsolata-go-nerd 2.3.1-2 2.3.3-2
ttf-inconsolata-lgc-nerd 2.3.1-2 2.3.3-2
ttf-inconsolata-nerd 2.3.1-2 2.3.3-2
ttf-ionicons 6.1.0-1 6.1.1-1
ttf-iosevka-nerd 2.3.1-2 2.3.3-2
ttf-jetbrains-mono-nerd 2.3.1-2 2.3.3-2
ttf-lekton-nerd 2.3.1-2 2.3.3-2
ttf-liberation-mono-nerd 2.3.1-2 2.3.3-2
ttf-lilex-nerd 2.3.1-2 2.3.3-2
ttf-meslo-nerd 2.3.1-2 2.3.3-2
ttf-monofur-nerd 2.3.1-2 2.3.3-2
ttf-monoid-nerd 2.3.1-2 2.3.3-2
ttf-mononoki-nerd 2.3.1-2 2.3.3-2
ttf-mplus-nerd 2.3.1-2 2.3.3-2
ttf-nerd-fonts-symbols-1000-em 2.3.1-2 2.3.3-1
ttf-nerd-fonts-symbols-1000-em-mono 2.3.1-2 2.3.3-1
ttf-nerd-fonts-symbols-2048-em 2.3.1-2 2.3.3-1
ttf-nerd-fonts-symbols-2048-em-mono 2.3.1-2 2.3.3-1
ttf-nerd-fonts-symbols-common 2.3.1-2 2.3.3-1
ttf-noto-nerd 2.3.1-2 2.3.3-2
ttf-profont-nerd 2.3.1-2 2.3.3-2
ttf-proggyclean-nerd 2.3.1-2 2.3.3-2
ttf-roboto-mono-nerd 2.3.1-2 2.3.3-2
ttf-sarasa-gothic 0.38.0-1 0.39.0-1
ttf-sharetech-mono-nerd 2.3.1-2 2.3.3-2
ttf-sourcecodepro-nerd 2.3.1-2 2.3.3-2
ttf-space-mono-nerd 2.3.1-2 2.3.3-2
ttf-terminus-nerd 2.3.1-2 2.3.3-2
ttf-tinos-nerd 2.3.1-2 2.3.3-2
ttf-ubuntu-mono-nerd 2.3.1-2 2.3.3-2
ttf-ubuntu-nerd 2.3.1-2 2.3.3-2
ttf-victor-mono-nerd 2.3.1-2 2.3.3-2
typescript-language-server 3.0.2-1 3.0.3-1
typos 1.13.8-1 1.13.9-1
ugrep 3.9.5-1 3.9.6-1
uutils-coreutils 0.0.16-1 0.0.17-1
v2ray-domain-list-community 20230120050418-1 20230122133243-1
v2ray-geoip 202301190046-1 202301260045-1
vaultwarden-web 2023.1.0-1 2023.1.1-1
verilator 5.004-1 5.006-1
vigra1.11.1.r67+g093d57d1-51.11.1.r67+g093d57d1-6
web-ext 7.4.0-1 7.5.0-1
wmfocus 1.3.0-1 1.4.0-1
wt 4.9.1-1 4.9.1-2
xine-lib 1.2.12-4 1.2.13-1
yosys 0.24-1 0.24-3
zig 0.10.1-1 0.10.1-2
zigbee2mqtt 1.29.1-1 1.29.2-1
znc 1.8.2-13 1.8.2-14
blisp - 0.0.3-1
devtools-git-poc - 20230105-1
openfec - 1.4.2.6-1
perl-b-cow - 0.007-1
python-apeye - 1.3.0-1
python-apeye-core - 1.1.0-1
python-autodocsumm - 0.2.10-1
python-consolekit - 1.4.1-1
python-cython-lint - 0.10.1-1
python-deprecation-alias - 0.3.1-1
python-dict2css - 0.2.4-1
python-dist-meta - 0.6.0-1
python-dom-toml - 0.6.0-1
python-domdf-python-tools - 3.6.0-1
python-dunamai - 1.15.0-1
python-handy-archives - 0.1.4-1
python-hatch-requirements-txt - 0.3.0-1
python-icecream - 2.1.3-2
python-jupyter-server-terminals - 0.4.4-1
python-poetry-dynamic-versioning - 0.21.3-1
python-pyproject-parser - 0.7.0-1
python-rtmidi - 1.4.9-4
python-shippinglabel - 1.4.1-1
python-sphinx-prompt - 1.5.0-1
python-sphinx-tabs - 3.4.1-1
python-versioneer - 0.28-1
python-whey - 0.0.23-1
river - 0.2.3-2
rssguard-lite - 4.3.1-1
:: Different overlay package(s) in repository core aarch64
linux-aml 6.1.7-1 6.1.7-2
linux-aml-headers 6.1.7-1 6.1.7-2
linux-clockworkpi-a06 6.1.7-1 6.1.8-1
linux-clockworkpi-a06-headers 6.1.7-1 6.1.8-1
linux-rc 6.2.rc4-3 6.2.rc5-3
linux-rc-headers 6.2.rc4-3 6.2.rc5-3
linux-rpi4 5.15.89-1 5.15.89-2
linux-rpi4-headers 5.15.89-1 5.15.89-2
linux-rpi4-mainline 6.1.7-1 6.1.8-1
linux-rpi4-mainline-headers 6.1.7-1 6.1.8-1
linux-rpi4-rc 6.2.rc4-1 6.2.rc5-1
linux-rpi4-rc-headers 6.2.rc4-1 6.2.rc5-1
linux61 6.1.7-1 6.1.8-1
linux61-headers 6.1.7-1 6.1.8-1
raspberrypi-bootloader 20230118-1 20230124-1
raspberrypi-bootloader-x 20230118-1 20230124-1
uboot-g1 - 2022.01-1
uboot-pinetab2 - 2022.01.rc4-1
:: Different sync package(s) in repository core aarch64
amd-ucode 20221214.f3c283e-1 20230117.7e4f0ed-1
b43-fwcutter 019-3 019-4
btrfs-progs 6.1.2-1 6.1.3-1
device-mapper 2.03.18-1 2.03.18-4
dosfstools 4.2-2 4.2-3
findutils 4.9.0-1 4.9.0-2
flex 2.6.4-3 2.6.4-4
glib2 2.74.4-1 2.74.5-1
glib2-docs 2.74.4-1 2.74.5-1
guile 3.0.8-3 3.0.9-1
iptables 1:1.8.8-2 1:1.8.8-3
iptables-nft 1:1.8.8-2 1:1.8.8-3
linux-firmware 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-bnx2x 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-liquidio 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-marvell 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-mellanox 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-nfp 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-qcom 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-qlogic 20221214.f3c283e-1 20230117.7e4f0ed-1
linux-firmware-whence 20221214.f3c283e-1 20230117.7e4f0ed-1
lvm2 2.03.18-1 2.03.18-4
lzo 2.10-4 2.10-5
m4 1.4.19-1 1.4.19-2
net-tools 2.10-1 2.10-2
netctl 1.28-1 1.28-2
pcre2 10.40-3 10.41-1
pptpclient 1.10.0-2 1.10.0-3
readline 8.2.001-1 8.2.001-2
reiserfsprogs 3.6.27-3 3.6.27-4
shadow 4.13-1 4.13-2
texinfo 7.0.1-1.1 7.0.2-1
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.61-5 3.2.61-6
libva-mesa-driver 22.3.3-0.2 22.3.4-0.1
mesa 22.3.3-0.2 22.3.4-0.1
mesa-vdpau 22.3.3-0.2 22.3.4-0.1
opencl-mesa 22.3.3-0.2 22.3.4-0.1
qt5-es2-base 5.15.8+kde+r162-1 5.15.8+kde+r177-1
qt5-es2-multimedia 5.15.8+kde+r1-1 5.15.8+kde+r2-1
qt5-es2-xcb-private-headers 5.15.8+kde+r162-1 5.15.8+kde+r177-1
vulkan-broadcom 22.3.3-0.2 22.3.4-0.1
vulkan-mesa-layers 22.3.3-0.2 22.3.4-0.1
vulkan-panfrost 22.3.3-0.2 22.3.4-0.1
vulkan-radeon 22.3.3-0.2 22.3.4-0.1
vulkan-swrast 22.3.3-0.2 22.3.4-0.1
vulkan-virtio 22.3.3-0.2 22.3.4-0.1
:: Different sync package(s) in repository extra aarch64
amf-headers 1.4.28-1 1.4.29-1
apache 2.4.54-3 2.4.55-1
appstream 0.15.6-1 0.16.0-1
appstream-qt 0.15.6-1 0.16.0-1
bind 9.18.10-1 9.18.11-1
bird 2.0.11-1 2.0.12-1
boost 1.80.0-3 1.81.0-2
boost-libs 1.80.0-3 1.81.0-2
breezy 3.3.1-1 3.3.2-1
chromium 109.0.5414.74-1 109.0.5414.119-1
clamav 0.105.1-2 1.0.0-1
clucene 2.3.3.4-13 2.3.3.4-14
cmark 0.30.2-1 0.30.3-1
compiler-rt14 14.0.6-1 14.0.6-2
cups-filters 1.28.16-3 1.28.17-1
ddrescue 1.26-1 1.27-1
deluge 1:2.1.1-2 1:2.1.1-3
deluge-gtk 1:2.1.1-2 1:2.1.1-3
egl-wayland 2:1.1.11-2 2:1.1.11-3
ell 0.55-1 0.56-1
evolution 3.46.3-1 3.46.3-3
evolution-bogofilter 3.46.3-1 3.46.3-3
evolution-spamassassin 3.46.3-1 3.46.3-3
fontconfig 2:2.14.1-2 2:2.14.2-1
freetds 1.3.16-1 1.3.17-1
galera 26.4.13-1 26.4.13-2
geoip-database 20221227-1 20230120-1
geoip-database-extra 20221227-1 20230120-1
gnome-builder 43.4-2 43.4-4
gnome-calendar 43.1-1 43.1-2
gnome-sudoku 43.0-1 43.1-1
gnumeric 1.12.53-1 1.12.54-1
goffice 0.10.53-1 0.10.54-1
graphviz 7.0.6-1 7.1.0-1
gst-plugin-libcamera 0.0.3-3 0.0.3-4
imagemagick 7.1.0.57-2 7.1.0.58-1
imagemagick-doc 7.1.0.57-2 7.1.0.58-1
imath 3.1.6-1 3.1.6-2
inkscape 1.2.2-3 1.2.2-4
kig 22.12.1-1 22.12.1-2
kopeninghours 22.12.1-1 22.12.1-2
krita 5.1.5-1 5.1.5-2
ldb 2:2.6.1-1 2:2.6.1-2
libappimage 1.0.4.5-3 1.0.4.5-4
libcamera-docs 0.0.3-3 0.0.3-4
libcamera-tools 0.0.3-3 0.0.3-4
libchamplain 0.12.20-3 0.12.21-1
libcmis 0.5.2-12 0.5.2-13
libgit2 1:1.5.0-2 1:1.5.1-2
libixion 0.17.0-3 0.17.0-4
libkolabxml 1.2.1-1 1.2.1-2
liborcus 0.17.2-3 0.17.2-4
libreoffice-fresh 7.4.4-1 7.4.5-1
libreoffice-fresh-af 7.4.4-1 7.4.5-1
libreoffice-fresh-am 7.4.4-1 7.4.5-1
libreoffice-fresh-ar 7.4.4-1 7.4.5-1
libreoffice-fresh-as 7.4.4-1 7.4.5-1
libreoffice-fresh-ast 7.4.4-1 7.4.5-1
libreoffice-fresh-be 7.4.4-1 7.4.5-1
libreoffice-fresh-bg 7.4.4-1 7.4.5-1
libreoffice-fresh-bn 7.4.4-1 7.4.5-1
libreoffice-fresh-bn-in 7.4.4-1 7.4.5-1
libreoffice-fresh-bo 7.4.4-1 7.4.5-1
libreoffice-fresh-br 7.4.4-1 7.4.5-1
libreoffice-fresh-brx 7.4.4-1 7.4.5-1
libreoffice-fresh-bs 7.4.4-1 7.4.5-1
libreoffice-fresh-ca 7.4.4-1 7.4.5-1
libreoffice-fresh-ca-valencia 7.4.4-1 7.4.5-1
libreoffice-fresh-ckb 7.4.4-1 7.4.5-1
libreoffice-fresh-cs 7.4.4-1 7.4.5-1
libreoffice-fresh-cy 7.4.4-1 7.4.5-1
libreoffice-fresh-da 7.4.4-1 7.4.5-1
libreoffice-fresh-de 7.4.4-1 7.4.5-1
libreoffice-fresh-dgo 7.4.4-1 7.4.5-1
libreoffice-fresh-dsb 7.4.4-1 7.4.5-1
libreoffice-fresh-dz 7.4.4-1 7.4.5-1
libreoffice-fresh-el 7.4.4-1 7.4.5-1
libreoffice-fresh-en-gb 7.4.4-1 7.4.5-1
libreoffice-fresh-en-za 7.4.4-1 7.4.5-1
libreoffice-fresh-eo 7.4.4-1 7.4.5-1
libreoffice-fresh-es 7.4.4-1 7.4.5-1
libreoffice-fresh-et 7.4.4-1 7.4.5-1
libreoffice-fresh-eu 7.4.4-1 7.4.5-1
libreoffice-fresh-fa 7.4.4-1 7.4.5-1
libreoffice-fresh-fi 7.4.4-1 7.4.5-1
libreoffice-fresh-fr 7.4.4-1 7.4.5-1
libreoffice-fresh-fur 7.4.4-1 7.4.5-1
libreoffice-fresh-fy 7.4.4-1 7.4.5-1
libreoffice-fresh-ga 7.4.4-1 7.4.5-1
libreoffice-fresh-gd 7.4.4-1 7.4.5-1
libreoffice-fresh-gl 7.4.4-1 7.4.5-1
libreoffice-fresh-gu 7.4.4-1 7.4.5-1
libreoffice-fresh-gug 7.4.4-1 7.4.5-1
libreoffice-fresh-he 7.4.4-1 7.4.5-1
libreoffice-fresh-hi 7.4.4-1 7.4.5-1
libreoffice-fresh-hr 7.4.4-1 7.4.5-1
libreoffice-fresh-hsb 7.4.4-1 7.4.5-1
libreoffice-fresh-hu 7.4.4-1 7.4.5-1
libreoffice-fresh-id 7.4.4-1 7.4.5-1
libreoffice-fresh-is 7.4.4-1 7.4.5-1
libreoffice-fresh-it 7.4.4-1 7.4.5-1
libreoffice-fresh-ja 7.4.4-1 7.4.5-1
libreoffice-fresh-ka 7.4.4-1 7.4.5-1
libreoffice-fresh-kab 7.4.4-1 7.4.5-1
libreoffice-fresh-kk 7.4.4-1 7.4.5-1
libreoffice-fresh-km 7.4.4-1 7.4.5-1
libreoffice-fresh-kmr-latn 7.4.4-1 7.4.5-1
libreoffice-fresh-kn 7.4.4-1 7.4.5-1
libreoffice-fresh-ko 7.4.4-1 7.4.5-1
libreoffice-fresh-kok 7.4.4-1 7.4.5-1
libreoffice-fresh-ks 7.4.4-1 7.4.5-1
libreoffice-fresh-lb 7.4.4-1 7.4.5-1
libreoffice-fresh-lo 7.4.4-1 7.4.5-1
libreoffice-fresh-lt 7.4.4-1 7.4.5-1
libreoffice-fresh-lv 7.4.4-1 7.4.5-1
libreoffice-fresh-mai 7.4.4-1 7.4.5-1
libreoffice-fresh-mk 7.4.4-1 7.4.5-1
libreoffice-fresh-ml 7.4.4-1 7.4.5-1
libreoffice-fresh-mn 7.4.4-1 7.4.5-1
libreoffice-fresh-mni 7.4.4-1 7.4.5-1
libreoffice-fresh-mr 7.4.4-1 7.4.5-1
libreoffice-fresh-my 7.4.4-1 7.4.5-1
libreoffice-fresh-nb 7.4.4-1 7.4.5-1
libreoffice-fresh-ne 7.4.4-1 7.4.5-1
libreoffice-fresh-nl 7.4.4-1 7.4.5-1
libreoffice-fresh-nn 7.4.4-1 7.4.5-1
libreoffice-fresh-nr 7.4.4-1 7.4.5-1
libreoffice-fresh-nso 7.4.4-1 7.4.5-1
libreoffice-fresh-oc 7.4.4-1 7.4.5-1
libreoffice-fresh-om 7.4.4-1 7.4.5-1
libreoffice-fresh-or 7.4.4-1 7.4.5-1
libreoffice-fresh-pa-in 7.4.4-1 7.4.5-1
libreoffice-fresh-pl 7.4.4-1 7.4.5-1
libreoffice-fresh-pt 7.4.4-1 7.4.5-1
libreoffice-fresh-pt-br 7.4.4-1 7.4.5-1
libreoffice-fresh-ro 7.4.4-1 7.4.5-1
libreoffice-fresh-ru 7.4.4-1 7.4.5-1
libreoffice-fresh-rw 7.4.4-1 7.4.5-1
libreoffice-fresh-sa-in 7.4.4-1 7.4.5-1
libreoffice-fresh-sat 7.4.4-1 7.4.5-1
libreoffice-fresh-sd 7.4.4-1 7.4.5-1
libreoffice-fresh-sdk 7.4.4-1 7.4.5-1
libreoffice-fresh-si 7.4.4-1 7.4.5-1
libreoffice-fresh-sid 7.4.4-1 7.4.5-1
libreoffice-fresh-sk 7.4.4-1 7.4.5-1
libreoffice-fresh-sl 7.4.4-1 7.4.5-1
libreoffice-fresh-sq 7.4.4-1 7.4.5-1
libreoffice-fresh-sr 7.4.4-1 7.4.5-1
libreoffice-fresh-sr-latn 7.4.4-1 7.4.5-1
libreoffice-fresh-ss 7.4.4-1 7.4.5-1
libreoffice-fresh-st 7.4.4-1 7.4.5-1
libreoffice-fresh-sv 7.4.4-1 7.4.5-1
libreoffice-fresh-sw-tz 7.4.4-1 7.4.5-1
libreoffice-fresh-szl 7.4.4-1 7.4.5-1
libreoffice-fresh-ta 7.4.4-1 7.4.5-1
libreoffice-fresh-te 7.4.4-1 7.4.5-1
libreoffice-fresh-tg 7.4.4-1 7.4.5-1
libreoffice-fresh-th 7.4.4-1 7.4.5-1
libreoffice-fresh-tn 7.4.4-1 7.4.5-1
libreoffice-fresh-tr 7.4.4-1 7.4.5-1
libreoffice-fresh-ts 7.4.4-1 7.4.5-1
libreoffice-fresh-tt 7.4.4-1 7.4.5-1
libreoffice-fresh-ug 7.4.4-1 7.4.5-1
libreoffice-fresh-uk 7.4.4-1 7.4.5-1
libreoffice-fresh-uz 7.4.4-1 7.4.5-1
libreoffice-fresh-ve 7.4.4-1 7.4.5-1
libreoffice-fresh-vec 7.4.4-1 7.4.5-1
libreoffice-fresh-vi 7.4.4-1 7.4.5-1
libreoffice-fresh-xh 7.4.4-1 7.4.5-1
libreoffice-fresh-zh-cn 7.4.4-1 7.4.5-1
libreoffice-fresh-zh-tw 7.4.4-1 7.4.5-1
libreoffice-fresh-zu 7.4.4-1 7.4.5-1
libreoffice-still 7.3.7-2 7.3.7-3
libreoffice-still-sdk 7.3.7-2 7.3.7-3
libtorrent-rasterbar 1:2.0.8-2 1:2.0.8-3
libunrar 1:6.2.3-1 1:6.2.5-1
libvncserver 0.9.13-1 0.9.14-2
libwacom 2.5.0-1 2.6.0-1
libwbclient 4.17.4-4 4.17.5-1
libx11 1.8.3-5 1.8.3-6
libyaml 0.2.5-1 0.2.5-2
lsof 4.96.5-1 4.98.0-1
maeparser 1.3.0-2 1.3.0-3
mkvtoolnix-cli 73.0.0-1 73.0.0-3
mkvtoolnix-gui 73.0.0-1 73.0.0-3
neon 0.32.4-2 0.32.5-1
p7zip 1:17.04-3 1:17.04-4
perl-alien-build 2.76-1 2.77-1
perl-clone 0.45-4 0.46-1
perl-io-socket-ssl 2.078-1 2.080-1
postfix 3.7.3-4 3.7.4-1
postfix-cdb 3.7.3-4 3.7.4-1
postfix-ldap 3.7.3-4 3.7.4-1
postfix-lmdb 3.7.3-4 3.7.4-1
postfix-mysql 3.7.3-4 3.7.4-1
postfix-pcre 3.7.3-4 3.7.4-1
postfix-pgsql 3.7.3-4 3.7.4-1
postfix-sqlite 3.7.3-4 3.7.4-1
pyside2 5.15.8-5 5.15.8-6
pyside2-tools 5.15.8-5 5.15.8-6
python-cryptography 38.0.4-1 39.0.0-1
python-evdev 1.6.0-1 1.6.1-1
python-numpy 1.23.5-1 1.24.0-1
python-shiboken2 5.15.8-5 5.15.8-6
python-validate-pyproject 0.10.1-1 0.12-1
qemu-audio-alsa 7.0.0-12 7.2.0-3
qemu-audio-dbus 7.0.0-12 7.2.0-3
qemu-audio-jack 7.0.0-12 7.2.0-3
qemu-audio-oss 7.0.0-12 7.2.0-3
qemu-audio-pa 7.0.0-12 7.2.0-3
qemu-audio-sdl 7.0.0-12 7.2.0-3
qemu-audio-spice 7.0.0-12 7.2.0-3
qemu-base 7.0.0-12 7.2.0-3
qemu-block-curl 7.0.0-12 7.2.0-3
qemu-block-dmg 7.0.0-12 7.2.0-3
qemu-block-gluster 7.0.0-12 7.2.0-3
qemu-block-iscsi 7.0.0-12 7.2.0-3
qemu-block-nfs 7.0.0-12 7.2.0-3
qemu-block-ssh 7.0.0-12 7.2.0-3
qemu-chardev-baum 7.0.0-12 7.2.0-3
qemu-chardev-spice 7.0.0-12 7.2.0-3
qemu-common 7.0.0-12 7.2.0-3
qemu-desktop 7.0.0-12 7.2.0-3
qemu-docs 7.0.0-12 7.2.0-3
qemu-emulators-full 7.0.0-12 7.2.0-3
qemu-full 7.0.0-12 7.2.0-3
qemu-guest-agent 7.0.0-12 7.2.0-3
qemu-hw-display-qxl 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-gpu 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-gpu-gl 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-gpu-pci 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-gpu-pci-gl 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-vga 7.0.0-12 7.2.0-3
qemu-hw-display-virtio-vga-gl 7.0.0-12 7.2.0-3
qemu-hw-s390x-virtio-gpu-ccw 7.0.0-12 7.2.0-3
qemu-hw-usb-host 7.0.0-12 7.2.0-3
qemu-hw-usb-redirect 7.0.0-12 7.2.0-3
qemu-hw-usb-smartcard 7.0.0-12 7.2.0-3
qemu-img 7.0.0-12 7.2.0-3
qemu-pr-helper 7.0.0-12 7.2.0-3
qemu-system-aarch64 7.0.0-12 7.2.0-3
qemu-system-alpha 7.0.0-12 7.2.0-3
qemu-system-arm 7.0.0-12 7.2.0-3
qemu-system-avr 7.0.0-12 7.2.0-3
qemu-system-cris 7.0.0-12 7.2.0-3
qemu-system-hppa 7.0.0-12 7.2.0-3
qemu-system-m68k 7.0.0-12 7.2.0-3
qemu-system-microblaze 7.0.0-12 7.2.0-3
qemu-system-mips 7.0.0-12 7.2.0-3
qemu-system-nios2 7.0.0-12 7.2.0-3
qemu-system-or1k 7.0.0-12 7.2.0-3
qemu-system-ppc 7.0.0-12 7.2.0-3
qemu-system-riscv 7.0.0-12 7.2.0-3
qemu-system-rx 7.0.0-12 7.2.0-3
qemu-system-s390x 7.0.0-12 7.2.0-3
qemu-system-sh4 7.0.0-12 7.2.0-3
qemu-system-sparc 7.0.0-12 7.2.0-3
qemu-system-tricore 7.0.0-12 7.2.0-3
qemu-system-x86 7.0.0-12 7.2.0-3
qemu-system-xtensa 7.0.0-12 7.2.0-3
qemu-tests 7.0.0-12 7.2.0-3
qemu-tools 7.0.0-12 7.2.0-3
qemu-ui-curses 7.0.0-12 7.2.0-3
qemu-ui-dbus 7.0.0-12 7.2.0-3
qemu-ui-egl-headless 7.0.0-12 7.2.0-3
qemu-ui-gtk 7.0.0-12 7.2.0-3
qemu-ui-opengl 7.0.0-12 7.2.0-3
qemu-ui-sdl 7.0.0-12 7.2.0-3
qemu-ui-spice-app 7.0.0-12 7.2.0-3
qemu-ui-spice-core 7.0.0-12 7.2.0-3
qemu-user 7.0.0-12 7.2.0-3
qemu-vhost-user-gpu 7.0.0-12 7.2.0-3
qemu-virtiofsd 7.0.0-12 7.2.0-3
qt5-base 5.15.8+kde+r174-1 5.15.8+kde+r177-1
qt5-multimedia 5.15.8+kde+r1-1 5.15.8+kde+r2-1
qt5-xcb-private-headers 5.15.8+kde+r174-1 5.15.8+kde+r177-1
quazip-qt5 1.3-1 1.4-1.1
quazip-qt6 1.3-1 1.4-1.1
samba 4.17.4-4 4.17.5-1
shared-mime-info 2.0+155+gf4e7cbc-1 2.2+13+ga2ffb28-1
smbclient 4.17.4-4 4.17.5-1
source-highlight 3.1.9-9 3.1.9-10
suitesparse 7.0.0-1 7.0.1-1
talloc 2.3.4-1 2.4.0-2
tdb 1.4.7-1 1.4.8-1
telepathy-accounts-signon 2.1-2 2.1-3
tevent 1:0.13.0-1 1:0.14.0-1
thunar 4.18.2-1 4.18.3-1
thunderbird 102.6.1-1 102.7.0-1
thunderbird-i18n-af 102.6.1-1 102.7.0-1
thunderbird-i18n-ar 102.6.1-1 102.7.0-1
thunderbird-i18n-ast 102.6.1-1 102.7.0-1
thunderbird-i18n-be 102.6.1-1 102.7.0-1
thunderbird-i18n-bg 102.6.1-1 102.7.0-1
thunderbird-i18n-br 102.6.1-1 102.7.0-1
thunderbird-i18n-ca 102.6.1-1 102.7.0-1
thunderbird-i18n-cak 102.6.1-1 102.7.0-1
thunderbird-i18n-cs 102.6.1-1 102.7.0-1
thunderbird-i18n-cy 102.6.1-1 102.7.0-1
thunderbird-i18n-da 102.6.1-1 102.7.0-1
thunderbird-i18n-de 102.6.1-1 102.7.0-1
thunderbird-i18n-dsb 102.6.1-1 102.7.0-1
thunderbird-i18n-el 102.6.1-1 102.7.0-1
thunderbird-i18n-en-gb 102.6.1-1 102.7.0-1
thunderbird-i18n-en-us 102.6.1-1 102.7.0-1
thunderbird-i18n-es-ar 102.6.1-1 102.7.0-1
thunderbird-i18n-es-es 102.6.1-1 102.7.0-1
thunderbird-i18n-et 102.6.1-1 102.7.0-1
thunderbird-i18n-eu 102.6.1-1 102.7.0-1
thunderbird-i18n-fi 102.6.1-1 102.7.0-1
thunderbird-i18n-fr 102.6.1-1 102.7.0-1
thunderbird-i18n-fy-nl 102.6.1-1 102.7.0-1
thunderbird-i18n-ga-ie 102.6.1-1 102.7.0-1
thunderbird-i18n-gd 102.6.1-1 102.7.0-1
thunderbird-i18n-gl 102.6.1-1 102.7.0-1
thunderbird-i18n-he 102.6.1-1 102.7.0-1
thunderbird-i18n-hr 102.6.1-1 102.7.0-1
thunderbird-i18n-hsb 102.6.1-1 102.7.0-1
thunderbird-i18n-hu 102.6.1-1 102.7.0-1
thunderbird-i18n-hy-am 102.6.1-1 102.7.0-1
thunderbird-i18n-id 102.6.1-1 102.7.0-1
thunderbird-i18n-is 102.6.1-1 102.7.0-1
thunderbird-i18n-it 102.6.1-1 102.7.0-1
thunderbird-i18n-ja 102.6.1-1 102.7.0-1
thunderbird-i18n-ka 102.6.1-1 102.7.0-1
thunderbird-i18n-kab 102.6.1-1 102.7.0-1
thunderbird-i18n-kk 102.6.1-1 102.7.0-1
thunderbird-i18n-ko 102.6.1-1 102.7.0-1
thunderbird-i18n-lt 102.6.1-1 102.7.0-1
thunderbird-i18n-ms 102.6.1-1 102.7.0-1
thunderbird-i18n-nb-no 102.6.1-1 102.7.0-1
thunderbird-i18n-nl 102.6.1-1 102.7.0-1
thunderbird-i18n-nn-no 102.6.1-1 102.7.0-1
thunderbird-i18n-pa-in 102.6.1-1 102.7.0-1
thunderbird-i18n-pl 102.6.1-1 102.7.0-1
thunderbird-i18n-pt-br 102.6.1-1 102.7.0-1
thunderbird-i18n-pt-pt 102.6.1-1 102.7.0-1
thunderbird-i18n-rm 102.6.1-1 102.7.0-1
thunderbird-i18n-ro 102.6.1-1 102.7.0-1
thunderbird-i18n-ru 102.6.1-1 102.7.0-1
thunderbird-i18n-sk 102.6.1-1 102.7.0-1
thunderbird-i18n-sl 102.6.1-1 102.7.0-1
thunderbird-i18n-sq 102.6.1-1 102.7.0-1
thunderbird-i18n-sr 102.6.1-1 102.7.0-1
thunderbird-i18n-sv-se 102.6.1-1 102.7.0-1
thunderbird-i18n-th 102.6.1-1 102.7.0-1
thunderbird-i18n-tr 102.6.1-1 102.7.0-1
thunderbird-i18n-uk 102.6.1-1 102.7.0-1
thunderbird-i18n-uz 102.6.1-1 102.7.0-1
thunderbird-i18n-vi 102.6.1-1 102.7.0-1
thunderbird-i18n-zh-cn 102.6.1-1 102.7.0-1
thunderbird-i18n-zh-tw 102.6.1-1 102.7.0-1
uchardet 0.0.7-1 0.0.8-1
usbmuxd 1.1.1-1 1.1.1-2
wxwidgets-common 3.2.1-1 3.2.1-2
wxwidgets-gtk3 3.2.1-1 3.2.1-2
wxwidgets-qt5 3.2.1-1 3.2.1-2
xfce4-notifyd 0.6.5-1 0.7.2-1
xfdesktop 4.18.0-1 4.18.1-1
zenity 3.43.0-1 3.44.0-1
qemu-system-alpha-firmware - 7.2.0-3
qemu-system-arm-firmware - 7.2.0-3
qemu-system-hppa-firmware - 7.2.0-3
qemu-system-loongarch64 - 7.2.0-3
qemu-system-microblaze-firmware - 7.2.0-3
qemu-system-ppc-firmware - 7.2.0-3
qemu-system-riscv-firmware - 7.2.0-3
qemu-system-s390x-firmware - 7.2.0-3
qemu-system-sparc-firmware - 7.2.0-3
qemu-system-x86-firmware - 7.2.0-3
qemu-user-binfmt - 7.2.0-3
tinycompress - 1.2.8-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.12.1.r12893.g30d6187ab-122.12.1.r12895.g698e5ee08-1
akonadi-calendar22.12.1.r2259.g97f4e37-122.12.1.r2260.g750200a-1
akonadi-notes22.12.1.r1121.g1019a00-122.12.1.r1122.ge64f9e3-1
akregator22.12.1.r6569.g0302b963-122.12.1.r6570.gb13f648e-1
attica5.102.0.r895.g7023125-15.102.0.r904.g2bab489-2
audiotube 22.11.r59.g9261999-1 22.11.r68.g57b1c07-1
aura-browser5.26.0.r170.g0c80713-15.26.0.r173.ga76ee37-1
bluedevil1:5.26.5.r2564.g086ffb8e-11:5.26.5.r2566.g53e71854-1
bluez-qt5.102.0.r733.gb02f8af-15.102.0.r741.ga7b5802-2
breeze5.26.5.r2554.gdc404b0c-15.26.5.r2557.gd01ef422-1
breeze-gtk5.26.5.r495.g830fd1c-15.26.5.r496.gbb7d086-1
breeze-icons5.102.0.r1950.gc80321bf-15.102.0.r1953.gcecfa705-2
calendarsupport22.08.3.r780.g5f50446-122.08.3.r781.g40fd1e9-1
calindori 22.11.r16.g3f57077-1 22.11.r17.g0d59e15-1
discover5.26.5.r9164.ge3ea41303-15.26.5.r9169.gd189f31d3-1
dolphin22.12.1.r7238.gc70938618-122.12.1.r7242.g7be0f2d6f-1
dolphin-plugins22.12.1.r722.g98ffc36-122.12.1.r725.gfe6f2fe-1
drkonqi5.26.5.r875.gbfee0d46-15.26.5.r878.g8d023799-1
elisa22.12.1.r3127.ga8ddcd27-122.12.1.r3128.g82c9ae2b-1
elisa-qtmm22.12.1.r3127.ga8ddcd27-122.12.1.r3128.g82c9ae2b-1
eventviews22.08.3.r930.g32d1749-122.08.3.r931.gf4bd7a7-1
extra-cmake-modules5.102.0.r3548.gc278bb34-15.102.0.r3552.g8fae102d-2
gwenview22.12.1.r7021.gf9db3d1f-122.12.1.r7022.g31bfef69-1
itinerary22.12.1.r2275.g7477438-122.12.1.r2277.gac4b314-1
juk22.12.1.r3223.g73ae1874-122.12.1.r3225.g38d1333c-1
kaccounts-providers22.12.1.r424.gefcee30-122.12.1.r426.g2558b7b-1
kactivities5.102.0.r1421.g7dcba28e-15.102.0.r1428.geb621d60-1
kactivities-stats5.102.0.r428.gc7ab8bd-15.102.0.r435.gdb6bd46-1
kactivitymanagerd5.26.5.r1444.g741248e-15.26.5.r1447.g87f9a7f-1
kaddressbook22.12.1.r6304.gf7c3ac08-122.12.1.r6307.g9811625a-1
kalarm22.12.1.r8239.gb84b98b9-122.12.1.r8240.g4e1252e9-1
kalk 22.11.r38.g833c014-1 22.11.r42.g5595af6-1
kanagram22.12.1.r1370.gf934f98-122.12.1.r1373.ge83155f-1
kapidox5.102.0.r584.gce3a81e-15.102.0.r585.gef3fe99-1
karchive5.102.0.r602.gc079903-15.102.0.r611.g7bf346e-1
kasts 22.11.r77.gdb41655-1 22.11.r87.gcdec053-1
kate22.12.1.r20202.gc3e109d7f-122.12.1.r20214.g3f019b4a8-1
kauth5.102.0.r534.g7158ec0-15.102.0.r543.g0cc153a-2
kcalc22.12.1.r1684.g5091d57-122.12.1.r1685.g4861693-1
kcalendarcore5.102.0.r1359.gcf6ec550d-15.102.0.r1369.g4af6c7006-2
kcodecs5.102.0.r468.gb0afeb5-15.102.0.r477.g1c4825d-2
kconfig5.102.0.r1022.g40ff273f-15.102.0.r1042.g107b9754-1
kcoreaddons5.102.0.r1644.g9d549d42-15.102.0.r1663.g40992e7e-1
kcrash5.102.0.r466.g27051f7-15.102.0.r474.g33df047-2
kcron22.12.1.r881.gccce789-122.12.1.r882.gd3f78c0-1
kdbusaddons5.102.0.r453.g51960f2-15.102.0.r463.gba0f5d3-2
kde-cli-tools5.26.5.r2050.gcb47b5c-15.26.5.r2052.g124d4cc-1
kde-dev-scripts22.12.1.r4176.g3fb22ed-122.12.1.r4177.g88eafbe-1
kde-gtk-config5.26.5.r957.g491f700-15.26.5.r959.gaa9eabd-1
kdebugsettings22.12.1.r1064.g0d42ae6-122.12.1.r1065.g98f2b0b-1
kdeconnect22.12.1.r3672.gb34a0a8f-122.12.1.r3674.g25512968-1
kdecoration5.26.5.r321.g0c34a05-15.26.5.r323.g83f6148-1
kded5.102.0.r488.g851ad03-15.102.0.r498.gd0150b4-1
kdegraphics-mobipocket22.12.1.r278.gd60821d-122.12.1.r285.gac01ff7-1
kdenlive22.12.1.r17324.g2843d9054-122.12.1.r17327.gc9cda2df6-1
kdepim-addons22.12.1.r5041.gd47b66964-122.12.1.r5042.gc7cf8c89d-1
kdepim-runtime22.12.1.r15692.gca8aee570-122.12.1.r15694.gf1a38855d-1
kdeplasma-addons5.26.5.r9281.g3520d34ad-15.26.5.r9284.ge46cf6c67-1
kdesu5.102.0.r544.g0a89280-15.102.0.r553.gcac0121-2
kdialog22.12.1.r1291.gb85a9e3f8-122.12.1.r1292.gf0f0eb65e-1
kdnssd5.102.0.r384.g4351e1a-15.102.0.r390.g9b2e4e0-2
kdoctools5.102.0.r707.g6b44841-15.102.0.r715.gb460fc4-1
kfilemetadata5.102.0.r913.g34637be-15.102.0.r923.ga4f69cd-1
kgamma55.26.5.r509.gbb5bd29-15.26.5.r510.g2fb40b3-1
kget22.12.1.r3308.g2c4f2201-122.12.1.r3311.ga9b949f7-1
kglobalaccel5.102.0.r622.g5d3158c-15.102.0.r630.gdff6e23-2
kguiaddons5.102.0.r527.gc28c8b7-15.102.0.r537.g59054e3-2
kholidays1:5.102.0.r1097.gf407911-11:5.102.0.r1104.gd5514c1-2
khotkeys5.26.5.r2209.g86445a0-15.26.5.r2210.g21637e2-1
ki18n5.102.0.r609.ge219825-15.102.0.r620.gf6a87db-1
kidentitymanagement22.12.1.r3947.g8daa7904-122.12.1.r3948.g4f4602fb-1
kimageformats5.102.0.r475.g14742cb-15.102.0.r483.g5cc7a2b-1
kinfocenter5.26.5.r2296.gd2d95473-15.26.5.r2297.gf65c7f41-1
kirigami-addons1:0.6.1.r26.ge2e0d44-11:0.6.1.r30.g45d7fef-1
kirigami-gallery22.12.1.r314.g838e042-122.12.1.r318.gc1082f3-1
kitemmodels5.102.0.r637.g5a40081-15.102.0.r647.gd9431e5-1
kitemviews5.102.0.r409.g719b760-15.102.0.r418.g39dcefc-2
kiten22.12.1.r1253.gbca4dd2-122.12.1.r1254.g79831a4-1
kldap22.12.1.r1013.g1d38991-122.12.1.r1014.g97571bc-1
kleopatra22.12.1.r7079.g25d9ec29-122.12.1.r7081.g5a2f846e-1
kmahjongg22.12.1.r1611.gb09e112-122.12.1.r1612.g586f5ce-1
kmail22.12.1.r26769.gb5adc4f36-122.12.1.r26770.g636bdbe3d-1
kmail-account-wizard22.12.1.r939.g9ea1977-122.12.1.r940.g3a95926-1
kmailtransport22.12.1.r1849.gb33ddef-122.12.1.r1850.gb20f2c2-1
kmbox22.12.1.r626.ga1a8980-122.12.1.r628.gf4bd7e3-1
kmenuedit5.26.5.r1142.gfd14bf7-15.26.5.r1144.g143cf6b-1
kmime22.12.1.r1573.g20e85b9-122.12.1.r1579.g97571b4-1
kmousetool22.12.1.r486.gb9736da-122.12.1.r487.ga057d8a-1
kmouth22.12.1.r797.g8caa307-122.12.1.r799.ga8fc0fa-1
knights22.12.1.r1206.gd9cce68-122.12.1.r1211.gd1c70b5-1
knotes22.12.1.r3789.gabb69bf9-122.12.1.r3791.g2d242d97-1
knotifications5.102.0.r796.g95557fc-15.102.0.r807.ge2012a7-2
kolourpaint22.12.1.r2484.gcac4ec93-122.12.1.r2485.gb5b1e666-1
kongress 22.11.r10.gb2d114e-1 22.11.r11.g003fdd4-1
konqueror22.12.1.r15296.g301d86199-122.12.1.r15298.gc9a38203f-1
kontact22.12.1.r5644.g2094c91e-122.12.1.r5646.g9bd029bb-1
kontrast22.12.1.r279.ga513b75-122.12.1.r281.g86365ac-1
kpackage5.102.0.r805.g454cfd6-15.102.0.r814.g8b08fa1-1
kpat22.12.1.r2703.g5cf071be-122.12.1.r2706.ge753564f-1
kpimtextedit22.12.1.r1771.g41b5358-122.12.1.r1772.gd9d0687-1
kpipewire5.26.5.r198.g270b99a-15.26.5.r205.g67f8d36-1
kplotting5.102.0.r343.g2a30da7-15.102.0.r351.g7619b1e-2
kpty5.102.0.r406.g1baa7ae-15.102.0.r412.gbd8daf8-2
kpublictransport22.12.1.r2095.g6acdee65-122.12.1.r2096.g85ad4727-1
krdc22.12.1.r1676.g1837692-122.12.1.r1677.gf4b1b8a-1
krfb22.12.1.r1544.gdf52969-122.12.1.r1545.g09e6984-1
kruler22.12.1.r803.g3b43314-122.12.1.r804.gbe24ae9-1
krunner5.102.0.r805.g31accda-15.102.0.r821.g4e65ac4-1
kscreen5.26.5.r1658.g42db554-15.26.5.r1660.g49fb0e6-1
kscreenlocker5.26.5.r1056.g7295aa9-15.26.5.r1058.g7823612-1
kservice5.102.0.r1069.g5740068-15.102.0.r1081.g0ff5417-1
ksshaskpass5.26.5.r248.gcd1b4e2-15.26.5.r249.gb5b20eb-1
ksudoku22.12.1.r1171.g293269c-122.12.1.r1172.g7ed1993-1
ksystemlog22.12.1.r804.g9a34e38-122.12.1.r808.gac02d41-1
ksystemstats5.26.5.r273.gecd05ea-15.26.5.r274.gdb80e1c-1
kturtle22.12.1.r1228.g3139277-122.12.1.r1229.g96a052a-1
kunitconversion5.102.0.r470.g75d06ab-15.102.0.r477.g901863d-2
kwallet-pam5.26.5.r281.g9772b3d-15.26.5.r284.gaf3180a-1
kwalletmanager22.12.1.r1385.g315fba5-122.12.1.r1387.g3f9d90d-1
kwayland-integration5.26.5.r226.g12948ef-15.26.5.r227.g88136ec-1
kwin5.26.5.r23955.gfef1553b9-15.26.5.r23961.g5504edf5f-1
kwindowsystem5.102.0.r740.g2b77836-15.102.0.r751.g7c26e2b-2
kwrite22.12.1.r20202.gc3e109d7f-122.12.1.r20214.g3f019b4a8-1
kwrited5.26.5.r525.gd90ced9-15.26.5.r526.g60615f1-1
layer-shell-qt5.26.5.r71.gd06bcbe-15.26.5.r75.gb9f8f64-1
libakonadi22.12.1.r12893.g30d6187ab-122.12.1.r12895.g698e5ee08-1
libkcompactdisc22.12.1.r414.ge659ce9-122.12.1.r415.g71f5996-1
libkdepim22.12.1.r954.gcd02acc-122.12.1.r956.gc495141-1
libkgapi22.12.1.r1415.g554bccc-122.12.1.r1416.g38a4747-1
libkleo22.12.1.r1374.g6252a89-122.12.1.r1375.gfd14003-1
libkscreen5.26.5.r1727.g8836eed-15.26.5.r1728.gefc3105-1
libksieve22.12.1.r1815.g751f9d60-122.12.1.r1816.g5dbad4bd-1
libksysguard5.26.5.r2524.gd528f7d-15.26.5.r2527.gdf17414-1
mailcommon22.12.1.r1371.g16ab834-122.12.1.r1372.g036c08a-1
messagelib22.12.1.r6867.g11fad1760-122.12.1.r6868.g480d07a8e-1
milou5.26.5.r804.g95c10cc-15.26.5.r805.gb09b8f3-1
modemmanager-qt5.102.0.r573.g4fdd548-15.102.0.r580.g45ee212-2
mycroft-bigscreen 1:0.0.4a25-2 1:0.0.6a20-1
neochat22.11.r130.g3e48578b-122.11.r133.g31fed836-1
networkmanager-qt5.102.0.r1177.gc7072d0-15.102.0.r1185.g9187169-2
oxygen5.26.5.r4546.g5416638b-15.26.5.r4547.g27cd10a8-1
oxygen-icons1:5.102.0.r5.gbff159d-11:5.102.0.r5.gbff159d-2
oxygen-icons-svg1:5.102.0.r5.gbff159d-11:5.102.0.r5.gbff159d-2
partitionmanager22.12.1.r1727.gfefd1ec-122.12.1.r1728.geeff3e6-1
pimcommon22.08.3.r1957.gfa5b323b-122.08.3.r1959.g63c3dd00-1
plank-player5.26.0.r128.g30f7ede-15.26.0.r129.gd158cb6-1
plasma-bigscreen5.26.0.r619.gb03110e-15.26.0.r621.gd9f91dd-1
plasma-camera 1.0.r150.g6799ff1-1 1.0.r151.g710500c-1
plasma-desktop5.26.5.r10037.gddfb587d2-15.26.5.r10045.g63788e652-1
plasma-disks5.26.5.r326.g9d94e5e-15.26.5.r327.gfa11f7d-1
plasma-firewall5.26.5.r708.ge0d8e87-15.26.5.r710.gd35fe96-1
plasma-integration5.26.5.r624.gba1a9e5-15.26.5.r626.g9b37cb0-1
plasma-mobile5.26.5.r2135.g7a9565ff7-15.26.5.r2138.g45cdc532f-1
plasma-mobile-nm5.26.5.r3515.g27e64001-15.26.5.r3520.g33efe4c3-1
plasma-nano5.26.5.r217.g2637714-15.26.5.r218.g4afa361-1
plasma-nm5.26.5.r3515.g27e64001-15.26.5.r3520.g33efe4c3-1
plasma-pa5.26.5.r1174.g8f585d2-15.26.5.r1175.g7acbce1-1
plasma-phonebook 22.11.r32.gdac12fd-1 22.11.r33.g3db6255-1
plasma-remotecontrollers5.26.0.r233.g0845074-15.26.0.r236.g2ad8d98-1
plasma-sdk5.26.5.r2468.g2a613319-15.26.5.r2469.g244e06fd-1
plasma-systemmonitor5.26.5.r691.g046cb2b-15.26.5.r693.g4e4aea6-1
plasma-thunderbolt5.26.5.r220.g9897fef-15.26.5.r221.g274fc57-1
plasma-vault5.26.5.r422.g3ad89cf-15.26.5.r423.ga1eab2f-1
plasma-wayland-protocols1.4.0.r1067.g78fc6ee-11.4.0.r1068.gb9cb11d-2
plasma-wayland-session5.26.5.r13130.g2930a9315-15.26.5.r13138.g14a90bf07-1
plasma-workspace5.26.5.r13130.g2930a9315-15.26.5.r13138.g14a90bf07-1
plasma-workspace-wallpapers5.26.5.r407.g65466f0-15.26.5.r409.gbdb2f46-1
polkit-kde-agent5.26.5.r561.geb8ac06-15.26.5.r562.ga99d98e-1
powerdevil5.26.5.r2671.g9a65a872-15.26.5.r2672.ga4093009-1
prison5.102.0.r417.g79476a5-15.102.0.r424.gd2b0244-2
pulseaudio-qt 1.3.0.r26.g9bba225-1 1.3.0.r26.g9bba225-2
rocs22.12.1.r3164.gbb031f77-122.12.1.r3165.g28b9797f-1
sddm0.19.0.r170.g3e48649-10.19.0.r170.g3e48649-2
sddm-kcm5.26.5.r722.gca0d85b-15.26.5.r725.g4a89f34-1
solid5.102.0.r841.g1f8440a-15.102.0.r850.g2600c7a-2
sonnet5.102.0.r752.g211f60e-15.102.0.r765.g4559ebc-1
spectacle22.12.1.r1490.gdecc9d8-122.12.1.r1492.gb4cde0f-1
step22.12.1.r1295.gd6b401f-122.12.1.r1297.ga403d10-1
syndication5.102.0.r894.g42e4676-15.102.0.r900.g36910bc-2
syntax-highlighting5.102.0.r2083.gbb4b9606-15.102.0.r2097.g0cb9300b-1
systemsettings5.26.5.r2826.gcb81a877-15.26.5.r2831.gd874c2b2-1
telepathy-kde-common-internals22.12.1.r2051.g786e7f0-122.12.1.r2052.gcf060b0-1
threadweaver5.102.0.r563.gc3cc94a-15.102.0.r571.g0e06e69-2
tokodon23.01.0.r84.g0ee5c10-123.01.0.r106.gb1dd080-1
vakzination 22.11.r23.g613ba74-1 22.11.r26.gba224f7-1
vvave 2.2.1.r70.g6799dfb-1 2.2.1.r72.g2eb1225-1
xdg-desktop-portal-kde5.26.5.r629.g50553ad-15.26.5.r634.gd4d65e8-1
polkit-qt6 -5.102.0.r403.g590e710-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
