After updated a few days ago max display resolution is no longer available. I am not sure what update caused the problem but I am now stuck on 2048x1080 instead of 2560x1440 which worked perfectly fine before.
I’ve tried reinstalling and also removed and installed Nvidia drivers but it didn’t help.
hwinfo --monitor ✔ 11m 3s
56: None 00.0: 10002 LCD Monitor
[Created at monitor.125]
Unique ID: rdCR.Ejh+PCpWWl1
Parent ID: VCu0.h0X+GP4qoQB
Hardware Class: monitor
Model: "DELL U2721DE"
Vendor: DEL "DELL"
Device: eisa 0x41de "DELL U2721DE"
Serial ID: "CRF1C23"
Resolution: 720x400@70Hz
Resolution: 640x480@60Hz
Resolution: 640x480@75Hz
Resolution: 800x600@60Hz
Resolution: 800x600@75Hz
Resolution: 1024x768@60Hz
Resolution: 1024x768@75Hz
Resolution: 1280x1024@75Hz
Resolution: 1152x864@75Hz
Resolution: 1280x1024@60Hz
Resolution: 1600x1200@60Hz
Resolution: 1920x1080@60Hz
Resolution: 2560x1440@60Hz
Year of Manufacture: 2020
Week of Manufacture: 52
Detailed Timings #0:
Horizontal: 2560 2608 2640 2720 (+48 +80 +160) -hsync
Vertical: 1440 1443 1448 1481 (+3 +8 +41) +vsync
Frequencies: 241.50 MHz, 88.79 kHz, 59.95 Hz
Driver Info #0:
Max. Resolution: 2560x1440
Vert. Sync Range: 56-76 Hz
Hor. Sync Range: 30-90 kHz
Bandwidth: 241 MHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #20 (VGA compatible controller)
xrandr ✔
Screen 0: minimum 16 x 16, current 2048 x 1080, maximum 32767 x 32767
HDMI-A-2 connected primary 2048x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2048x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.29
1680x1050 59.95
1440x900 59.89
1280x800 59.81
1152x720 59.75
960x600 59.63
928x580 59.88
800x500 59.50
768x480 59.90
720x480 59.71
640x400 59.95
320x200 58.14
1920x1080 59.96
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.27
640x350 59.28
Adding resolution with xrandr fails:
cvt 2560 1440
# 2560x1440 59.96 Hz (CVT 3.69M9) hsync: 89.52 kHz; pclk: 312.25 MHz
Modeline "2560x1440_60.00" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync
xrandr --newmode "2560x1440_60.00" 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync ✔
xrandr --addmode HDMI-A-2 2560x1440_60.00
xrandr --output HDMI-A-2 --mode 2560x1440_60.00
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x0
Serial number of failed request: 22
Current serial number in output stream: 22
inxi -zv8:
Kernel: 6.17.7-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=8515cdac-5b1c-4794-a265-2d2b7e52bfb7 rw quiet splash
resume=UUID=e371827e-91f1-4099-be1b-b65e0dfc5878 udev.log_priority=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop Mobo: Gigabyte model: B850 AORUS ELITE WIFI7 ICE v: x.x
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F3 date: 03/12/2025
System RAM: total: 32 GiB available: 30.46 GiB used: 5.08 GiB (16.7%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF560C30-16 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3021 min/max: 422/5393 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3021 2: 3021 3: 3021
4: 3021 5: 3021 6: 3021 7: 3021 8: 3021 9: 3021 10: 3021 11: 3021 12: 3021
13: 3021 14: 3021 15: 3021 16: 3021 bogomips: 121364
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GB205 [GeForce RTX 5070] vendor: ASUSTeK driver: nvidia
v: 580.105.08 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: HDMI-A-2 empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0
chip-ID: 10de:2f04 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 11:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 31.0 C
Display: wayland server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: nvidia
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-2 model: Dell U2721DE serial: <filter> built: 2020 res:
mode: 2048x1080 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 2048x1080, 1920x1080, 1600x1200, 1280x1024, 1152x864,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5070/PCIe/SSE2
memory: 11.66 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 5070 driver: nvidia v: 580.105.08
device-ID: 10de:2f04 surfaces: N/A
Device-1: NVIDIA GB205 High Definition Audio driver: snd_hda_intel v: kernel
alternate: nova_core pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2f80 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.7-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8922 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
modules: r8125 pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000
bus-ID: 08:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 0bda:8922
Local Storage: total: 4.09 TiB used: 915.44 GiB (21.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
model: SSD 990 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QKXG7 temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 990 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 897.71 GiB size: 882.54 GiB (98.31%) used: 63.4 GiB (7.2%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:3 label: N/A
uuid: 8515cdac-5b1c-4794-a265-2d2b7e52bfb7
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2 label: N/A
uuid: 311E-C70B
ID-3: /home/<filter>/storage raw-size: 931.51 GiB size: 916.7 GiB (98.41%)
used: 852.04 GiB (92.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: storage
uuid: 78d24997-855d-49a6-be2c-056e20951bd1
ID-1: swap-1 type: partition size: 33.51 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:4 label: swap
uuid: e371827e-91f1-4099-be1b-b65e0dfc5878
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
uuid: E0A1-78D3
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 1.82 TiB fs: ntfs label: N/A
uuid: 621CA20E1CA1DCF3
ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 530 MiB fs: ntfs label: N/A
uuid: 6EA65103A650CD69
ID-5: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
ID-6: /dev/sdb2 maj-min: 8:18 size: 465.63 GiB fs: ntfs label: Games
uuid: 84AE6920AE690C4C
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-3:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-3: 1-3.1:4 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-3.1.3:6 info: China Resource Semico BladeMaster TE 88K
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 1a2c:b58f class-ID: 0301
Device-2: 1-3.1.4:7 info: Razer USA DeathAdder Elite type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-3: 1-6:3 info: Integrated Express GIGABYTE Device type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
Device-4: 1-9:5 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:8922 class-ID: e001 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-5: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-12: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 36.5 C mobo: 34.0 C gpu: amdgpu temp: 32.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1377 libs: 342 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://manjaro.mirrors.uk2.net/unstable/$repo/$arch
2: https://manjaro.ynh.ovh/unstable/$repo/$arch
3: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
4: https://mirrors.up.pt/pub/manjaro/unstable/$repo/$arch
5: https://cofractal-ewr.mm.fcix.net/manjaro/unstable/$repo/$arch
6: https://mirror.fcix.net/manjaro/unstable/$repo/$arch
7: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
CPU top: 5 of 390
1: cpu: 9.9% command: firefox pid: 3921 mem: 1076.2 MiB (3.4%)
2: cpu: 8.8% command: firefox pid: 4286 mem: 171.3 MiB (0.5%)
3: cpu: 8.3% command: brave pid: 4024 mem: 310.2 MiB (0.9%)
4: cpu: 7.3% command: brave pid: 4162 mem: 320.2 MiB (1.0%)
5: cpu: 4.1% command: konsole pid: 37184 mem: 279.9 MiB (0.8%)
Memory top: 5 of 390
1: mem: 1076.2 MiB (3.4%) command: firefox pid: 3921 cpu: 9.9%
2: mem: 625.6 MiB (2.0%) command: firefox pid: 5140 cpu: 1.4%
3: mem: 520.7 MiB (1.6%) command: brave pid: 3874 cpu: 1.3%
4: mem: 514.8 MiB (1.6%) command: firefox pid: 4677 cpu: 0.5%
5: mem: 465.2 MiB (1.4%) command: brave pid: 19859 cpu: 0.3%
Processes: 390 Power: uptime: 2h 33m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.12 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
running-in: konsole inxi: 3.3.39
I am out of ideas what else to try.
Mod edit:- Replaced inxi output. No charge.
