Hi, i have the following situtation: at the moment i cannot upgrade ceph-libs from 17.2.6-2 to 17.2.6-3, im getting the following error:
% sudo pamac install ceph-libs
-- Found Python3: /usr/bin/python3.9 (found suitable exact version "3.9.17") found components: Interpreter Development
-- Found ZLIB: /usr/lib/libz.so (found version "1.2.13")
CMake Error at /usr/lib/cmake/Boost-1.81.0/BoostConfig.cmake:141 (find_package):
Found package configuration file:
/usr/lib/cmake/boost_python-1.81.0/boost_python-config.cmake
but it set boost_python_FOUND to FALSE so package "boost_python" is
considered to be NOT FOUND. Reason given by package:
No suitable build variant has been found.
The following variants have been tried and rejected:
* libboost_python27.so.1.81.0 (2.7, Boost_PYTHON_VERSION=3.9)
* libboost_python311.so.1.81.0 (3.11, Boost_PYTHON_VERSION=3.9)
* libboost_python27.a (2.7, Boost_PYTHON_VERSION=3.9)
* libboost_python311.a (3.11, Boost_PYTHON_VERSION=3.9)
Call Stack (most recent call first):
/usr/lib/cmake/Boost-1.81.0/BoostConfig.cmake:262 (boost_find_component)
cmake/modules/FindBoost.cmake:597 (find_package)
CMakeLists.txt:625 (find_package)
-- Configuring incomplete, errors occurred!
==> ERROR: A failure occurred in build().
Aborting...
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 14.798s
CPU time consumed: 11.440s
so it looks to me like this somehow wants to use boost-python bindings for python 3.9 but i only have 3.11 there. So i downloaded boost and compiled the libs using --with-python=3.9, which did produce the libs as expected. I copied the 3.9 lib and archive next to the 3.11 under /usr/lib/ =>
$ ls -la /usr/lib/libboost_python*
-rw-r--r-- 1 root root 642150 22. Aug 20:22 /usr/lib/libboost_python27.a
lrwxrwxrwx 1 root root 27 22. Aug 20:22 /usr/lib/libboost_python27.so -> libboost_python27.so.1.81.0
-rwxr-xr-x 1 root root 259432 22. Aug 20:22 /usr/lib/libboost_python27.so.1.81.0
-rw-r--r-- 1 root root 685046 17. Jun 15:26 /usr/lib/libboost_python311.a
lrwxrwxrwx 1 root root 28 17. Jun 15:26 /usr/lib/libboost_python311.so -> libboost_python311.so.1.81.0
-rwxr-xr-x 1 root root 255512 23. Aug 14:20 /usr/lib/libboost_python311.so.1.81.0
-rwxr-xr-x 1 root root 255512 23. Aug 14:19 /usr/lib/libboost_python311.so.1.81.0.bak
-rw-r--r-- 1 root root 667032 23. Aug 14:12 /usr/lib/libboost_python39.a
-rwxr-xr-x 1 root root 344112 23. Aug 13:47 /usr/lib/libboost_python39.so
-rwxr-xr-x 1 root root 344112 23. Aug 14:15 /usr/lib/libboost_python39.so.1.81.0
-rwxr-xr-x 1 root root 344112 23. Aug 13:59 /usr/lib/libboost_python39.so.1.83.0
lrwxrwxrwx 1 root root 27 23. Aug 14:18 /usr/lib/libboost_python3.so -> libboost_python39.so.1.81.0
lrwxrwxrwx 1 root root 27 22. Aug 20:22 /usr/lib/libboost_python.so -> libboost_python27.so.1.81.0
But the error still shows up. For fun and profit i also tried forcing python 3.11 by adding
set(Boost_PYTHON_VERSION "3.11")
to /usr/lib/cmake/Boost-1.81.0/BoostConfig.cmake, and that does result in some building, but then i run into weird errors later where it says that cython was not found (but the module is there, even with the python executable from the error message ![]()
All of this feels very wrong, any ideas what the arch-agnostic way of dealing with this would be?
Cheers!
