Missing Intel Meteor Lake Drivers
Hello all!
I recently got my hands on a meteor lake based laptop and installed Manjaro on it, but it doesn’t seem to have any of the needed drivers for audio, WiFi, and Bluetooth to function.
Audio seems to be handled by an independent section of the processor and settings reports it as “Dummy Output”, and my wireless/bluetooth card is an Intel AX411NGW.
I found a couple of other forums on here but most of them are dead ends except for one where a user mentioned that the drivers were left out of the current kernel and they created a custom kernel with the drivers that were missing. I’m not sure how to do that and the user is no longer on the forums, so I’m SOL.
Here are my inxi -Fazy results, I’m hoping these will help!
  Device-1: Intel Meteor Lake-P HD Audio vendor: Dell
    driver: sof-audio-pci-intel-mtl
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0401
  API: ALSA v: k6.15.0-rc6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: N/A modules: iwlwifi
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5 chip-ID: 0bda:8153
    class-ID: 0000 serial: <filter>
  IF: enp0s20f0u8 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
Please always enclose code or command output within a preformatted text box as per forum guidlines for presentation.
This has been corrected for you in this instance;
In future, please tend to this yourself.
I’m sure someone will help when they are able.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Please include the full inxi - not just audio and network parts:
inxi -zv8
It might be due to an older kernel when (for instance) the ISO you used to install from was not a recent one.
Or just install a newer kernel and try with that.
Dummy Output is created by PipeWire if there is no audio device available for playback
I suggest you start a reply to this topic;
click on the arrow in top-left corner of reply window and select “Reply as a linked topic”
and create a new topic in the sound category with more information about audio devices:
pactl list cards
sudo alsa-info.sh --upload
Hi there, sorry for the extremely slow response. I set this machine aside because it was having stability issues, however I seem to have that worked out now.
Here’s the info you requested.
http://alsa-project.org/db/?f=78f1cf0a94ebdcfc3dfbe58b7df6a8b3d3deecde
inxi -zv8 results:
  Kernel: 6.17.0-rc4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
    root=UUID=f7c33dc7-3486-4da0-8b8c-24d50525a5ef rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 16 5631 v: N/A
  Mobo: Dell model: N/A serial: <superuser required> part-nu: 0C2A
    UEFI: Dell v: 82.12.1 date: 03/27/2023
  ID-1: BAT0 charge: 19 Wh (29.8%) condition: 63.6/64 Wh (99.4%) health: good
    temp: 27.3 C volts: 14.79 min: 15.2 model: BYD DELL JGCCT28 made: 2022-08-10
    type: Li-poly serial: <filter> charging: status: discharging control:
    start: 50% end: 90% type: adaptive
    avail: adaptive,custom,fast,standard,trickle cycles: 5
  System RAM: total: 16 GiB available: 15.31 GiB used: 2.82 GiB (18.4%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
    spec: 6400 MT/s actual: 4267 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: N/A part-no: N/A serial: N/A
  Device-2: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-3: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-4: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-5: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-6: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-7: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Device-8: Motherboard type: LPDDR5 detail: synchronous size: 2 GiB speed:
  Info: model: Intel 0000 bits: 64 type: MST AMCP arch: Meteor Lake level: v3
    note: check built: 2023+ process: Intel 4 (7nm) family: 6
    model-id: 0xAA (170) stepping: 1 microcode: 0x14
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
    st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 6x48 KiB; i-14x64
    KiB L2: 16 MiB desc: 8x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 400 min/max: 400/4000:3000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    17: 400 18: 400 19: 400 20: 400 bogomips: 47616
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Dell driver: i915
    v: kernel alternate: xe arch: Xe-LPG process: Intel 4 (7nm+) built: 2023+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0c45:6a21
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1613 built: 2021 res: 1920x1200
    dpi: 142 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10
    modes: 1920x1200
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 14.95 GiB unified: yes display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
    alternate: snd_sof_pci_intel_mtl,snd_hda_intel bus-ID: 0000:00:1f.3
  API: ALSA v: k6.17.0-rc4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
    tools: pacat,pactl,pulsemixer
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
    bus-ID: 0000:39:00.0 chip-ID: 8086:24fd class-ID: 0280
  IF: wlp57s0 state: up mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0a2b
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:7d0b rev:
    class-ID: 0104
  Local Storage: total: 931.51 GiB used: 10.66 GiB (1.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P2SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 10.66 GiB (1.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f7c33dc7-3486-4da0-8b8c-24d50525a5ef
    used: 648 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: BF07-670D
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:639c class-ID: ef00 serial: <filter>
  Device-2: 3-7:3 info: Microdia Integrated_Webcam_FHD type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6a21 class-ID: fe01
    serial: <filter>
  Device-3: 3-10:4 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
  System Temperatures: cpu: 68.0 C mobo: 64.0 C sodimm: 44.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1222 libs: 348 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    2: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    3: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 376
  1: cpu: 26.6% command: firefox pid: 2735 mem: 633.3 MiB (4.0%)
  2: cpu: 11.9% command: gnome-shell pid: 1649 mem: 284.4 MiB (1.8%)
  3: cpu: 6.9% command: firefox pid: 4118 mem: 304.4 MiB (1.9%)
  4: cpu: 2.6% command: firefox pid: 2839 mem: 211.8 MiB (1.3%)
  5: cpu: 2.2% command: kgx pid: 2391 mem: 166.8 MiB (1.0%)
  Memory top: 5 of 376
  1: mem: 633.3 MiB (4.0%) command: firefox pid: 2735 cpu: 26.6%
  2: mem: 304.4 MiB (1.9%) command: firefox pid: 4118 cpu: 6.9%
  3: mem: 284.4 MiB (1.8%) command: gnome-shell pid: 1649 cpu: 11.9%
  4: mem: 235.3 MiB (1.5%) command: firefox pid: 2964 cpu: 1.6%
  5: mem: 211.8 MiB (1.3%) command: firefox pid: 2839 cpu: 2.6%
  Processes: 376 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
    image: 6.11 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: N/A Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.39```
I’ve quoted the text from your other thread here:
… just so it isn’t missed. It’s recommended to keep things in one thread. Cheers! :wink:
Please, pipewire OR pulseaudio
Please Test : Disable TPM in your BIOS and Test Sound
PS:
nice CPU
Dell support has a lot of information about Inspirion 16 5630, but nothing about Inspiron 16 5631
I suggest contact Dell support to check if there is a BIOS update available
PipeWire is a mutimedia server and is required on Gnome and KDE for wayland if pipewire-pulse is not installed
Changing software audio servers will not help considering there are no audio devices detected in ALSA
!!Soundcards recognised by ALSA
--- no soundcards ---
[   15.272323] sof-audio-pci-intel-mtl 0000:00:1f.3: ------------[ DSP dump start ]------------
[   15.272326] sof-audio-pci-intel-mtl 0000:00:1f.3: Firmware download failed
[   15.272329] sof-audio-pci-intel-mtl 0000:00:1f.3: fw_state: SOF_FW_BOOT_IN_PROGRESS (3)
[   15.272352] sof-audio-pci-intel-mtl 0000:00:1f.3: 0xd000000c: module: ROM_EXT, state: VALIDATE_PUB_KEY, not running
[   15.272377] sof-audio-pci-intel-mtl 0000:00:1f.3: error code: 0x97 (unknown)
[   15.272406] sof-audio-pci-intel-mtl 0000:00:1f.3: ------------[ DSP dump end ]------------
[   15.272419] sof-audio-pci-intel-mtl 0000:00:1f.3: Failed to start DSP
[   15.272421] sof-audio-pci-intel-mtl 0000:00:1f.3: error: failed to boot DSP firmware -110
[   15.274798] sof-audio-pci-intel-mtl 0000:00:1f.3: error: sof_probe_work failed err: -110
OP was requested in post #4 to post information about audio devices as a linked topic in sound category
A more logical approach conforming to forum guidelines would have been to simply move the topic to the “Sound” category;
now actioned on behalf all concerned.
Ah, noticed that did you? I think this is an Intel Meteor Lake 1335u, specs are very similar to that model.
Which I did, here’s the link.
can you check if there is a newer bios available ? if so install it first. the splitting of your RAM into 2GB sections is also very curious. never seen that before and i wonder if this is correct.
also check if the linux-firmware is installed correct.
The RAM being split is very curious, I never noticed that. To be fair, this isn’t a normal laptop, so that might be a setting somewhere that I don’t know about.
I can try to find a BIOS update for this machine, but I don’t I will since it doesn’t officially have any support and the model technically doesn’t exist. I’ve tried looking for drivers on Dell’s website before and nothing came up. In fact even google searching the laptop model results in no information, the laptop is essentially a ghost, but it does work on Windows.
Well, my other posting in the proper location got taken down for being a duplicate post…so here we are again.
Here’s a quick update, I do not have any BIOS updates available to me, I spent most of the day today looking for anything in he BIOS related to update and online to no avail…which isn’t surprising as this laptop isn’t supposed to exist.
Something that’s worth noting and I find very interesting is that the sound from the laptop does work on HDMI or USB C devices (like docks) but does not work though the 3.5mm headphone jack.
Something else unrelated that I’ve noticed is missing is the proper keyboard drivers, I presently have no control over the keyboard backlight, and sometimes it flashes at me while I’m typing. I suspect a keyboard driver for the Dell Inspiron 16 5630 would probably remedy this issue if I knew how to install it.
Side thought, do drivers for the 5630 exist in the arch databases or does that model only have debian support because that’s what Dell decided to support?
you can run the inxi-command with sudo to gather more information and repost the result
sudo inxi -zv8
Here’s that info for you.
sudo inxi -zv8         ✔  5s 
[sudo] password for mysteriousmachine:
  Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=43beb4b4-7a44-4419-bc25-af683a944e7d rw rootflags=subvol=@
    resume=UUID=7a28444d-c9e6-4884-a016-b87ae7088848 udev.log_priority=3
    base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 16 5631 v: N/A serial: N/A
    Chassis: type: 10 serial: N/A
  Mobo: Dell model: N/A serial: <filter> part-nu: 0C2A UEFI: Dell v: 82.12.1
    date: 03/27/2023
  ID-1: BAT0 charge: 50.4 Wh (79.2%) condition: 63.6/64 Wh (99.4%)
    temp: 24.5 C volts: 17.38 min: 15.2 model: BYD DELL JGCCT28 type: Li-poly
    serial: <filter> charging: status: charging control: start: 50% end: 90%
    type: adaptive avail: adaptive,custom,fast,standard,trickle cycles: 6
  System RAM: total: 16 GiB available: 15.31 GiB used: 3.03 GiB (19.8%)
    spec: 6400 MT/s actual: 4133 MT/s volts: curr: 0.5 width (bits): data: 16
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 00:1c.0
    children: 1: 39:00.0 class-ID: 0280 type: network
  Slot: 1 type: PCIe gen: 1 status: available length: long volts: 3.3
    bus-ID: 00:1c.1
  Slot: 2 type: PCIe gen: 2 status: available length: long volts: 3.3
    bus-ID: 00:1c.2
  Slot: 3 type: PCIe gen: 3 status: available length: long volts: 3.3
    bus-ID: 00:1c.3
  Slot: 4 type: PCIe gen: 4 status: available length: long volts: 3.3
    bus-ID: 00:1c.4
  Slot: 5 type: PCIe gen: 5 status: available length: long volts: 3.3
    bus-ID: 00:1c.5
  Slot: 6 type: PCIe gen: 6 status: available length: long volts: 3.3
    bus-ID: 00:1c.6
  Info: model: Intel 0000 socket: U3E1 bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 1 microcode: 0x14
  Speed (MHz): avg: 400 min/max: 400/4000:3000 base/boost: 1188/4200
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    17: 400 18: 400 19: 400 20: 400 bogomips: 47620
  Display: unspecified server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    compositor: gnome-shell driver: gpu: i915 display-ID: :0
    note: <missing: xdpyinfo/xrandr>
    modes: 1920x1200
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
    device-ID: 8086:7d55 memory: 14.96 GiB unified: yes
    alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 0000:00:1f.3
  API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: n/a (root, process) with:
    class-ID: e001
    class-ID: 0104
  Local Storage: total: 931.51 GiB used: 12.81 GiB (1.4%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 27.9 C
    scheme: GPT
  ID-1: / raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
    used: 12.81 GiB (1.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 43beb4b4-7a44-4419-bc25-af683a944e7d
    used: 672 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: AAE6-CE2D
  ID-3: /home raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-4: /var/cache raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-5: /var/log raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 7a28444d-c9e6-4884-a016-b87ae7088848
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiOh I should mention that this thing has the ability to create RAM disks, that might be why the RAM is sectioned strangely.B/s)
    serial: <filter>
  System Temperatures: cpu: 61.0 C mobo: 57.0 C sodimm: 37.0 C
  Packages: pm: pacman pkgs: 1204 libs: 347 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 435
  1: cpu: 300% command: ps pid: 4377 mem: 4.19 MiB (0.0%)
  2: cpu: 31.7% command: firefox pid: 2528 mem: 529.8 MiB (3.3%)
  3: cpu: 11.0% command: gnome-shell pid: 1678 mem: 305.0 MiB (1.9%)
  4: cpu: 9.5% command: firefox pid: 2784 mem: 282.1 MiB (1.7%)
  5: cpu: 8.7% command: kgx pid: 3935 mem: 124.9 MiB (0.7%)
  Memory top: 5 of 435
  1: mem: 529.8 MiB (3.3%) command: firefox pid: 2528 cpu: 31.7%
  2: mem: 305.0 MiB (1.9%) command: gnome-shell pid: 1678 cpu: 11.0%
  3: mem: 294.5 MiB (1.8%) command: pamac-manager pid: 2440 cpu: 6.5%
  4: mem: 282.1 MiB (1.7%) command: firefox pid: 2784 cpu: 9.5%
  5: mem: 186.9 MiB (1.1%) command: firefox pid: 2688 cpu: 5.0%
  Processes: 435 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
  Compilers: N/A Shell: Sudo (sudo) v: 1.9.17p1 default: Bash v: 5.3.3
And I forgot to note that this laptop also displays a message on the UEFI splash screen when booting it up, something I’ve never seen before, 1D5C5B44.
I tried looking that up but it didn’t really help. My guess is there’s a BIOS setting somewhere that still isn’t happy.
Speaking of BIOS…I have 2, one UEFI, one more like CMOS. There’s tons of extra settings in the CMOS styled one, one of them being a fireware running mode which I presently have set in “Test” mode, but I have also run in “Production” mode and had no luck getting the missing drivers to work, but that does do something in Windows.
@LegoPadawan Whoops, it seems we were both editing at the same time. Notice I merged your replies. Please edit your previous reply if no one has responded yet instead of posting twice in a row. :wink:
As far as I know Arch does not have a hardware certification program. Laptop hardware quirks are usually posted on ArchWiki - Laptop/Dell#Inspiron - ArchWiki
Debian is considering a certification a program similar to RHEL, SUSE and Ubuntu
Hardware/Certification - Debian Wiki
Ubuntu certification program does not include Inspiron 5631
Information for Inspiron 5630 shows they are Raptor Lake, not Meteor Lake
Dell Inspiron 16 5630 (Core i7-1360P) certified with Ubuntu 22.04 LTS | Ubuntu
Dell Inspiron 16 5630 (Core i7-1355U) certified with Ubuntu 22.04 LTS | Ubuntu
Audio   Intel Corp. Raptor Lake-P/U/H cAVS (8086:51ca 1028:0c15)
Most Realtek onboard audio devices work with snd_hda_intel driver provided by the kernel
some devices require a driver patch from ALSA developers
Laptops also require a Sound Open Firmware driver to support internal digital microphones, but the Intel HDA driver is still needed for analog inputs and outputs (external microphones, headphones and built-in speakers)
Try using this to force use of snd_hda_intel only, without sof-audio-pci-intel-mtl
sudo tee /etc/modprobe.d/alsa-intel-hda.conf <<< "options snd_intel_dspcfg dsp_driver=1"
Reboot system to reload ALSA device and check ALSA information again
Here’s what I got.
http://alsa-project.org/db/?f=615b13c51bf8384c4b9dadbd7e526ac76944f3ea
I have this info as well.
!!Modprobe options (Sound related)
snd_intel_dspcfg: dsp_driver=1~
[   10.611788] snd_intel_dspcfg: `1~' invalid for parameter `dsp_driver'
[   11.302345] snd_intel_dspcfg: `1~' invalid for parameter `dsp_driver'
$ modinfo -p snd_intel_dspcfg
dsp_driver:Force the DSP driver for Intel DSP (0=auto, 1=legacy, 2=SST, 3=SOF, 4=AVS) (int)
