Asking for a friend. He’s just done an update to his system and is getting a Grub message saying that he needs to load the kernel first. We have tried chrooting into his system to re-install the kernel but this fails having tried to mount /dev/sda1. The error message is
/bin/bash Input/output error
Mate has tried starting the machine from one of the fallback images in Grub but nothing happens. I think this is due to there being no initramfs images in /boot. How do we regenerate a initramfs image in this situation?
@ The_Quantum_Alpha
My mate has gone offline for the night. We can have a look @ lsblk in the morning. IIRC boot and system are both on /dev/sda1.
I think it is an EFI install. I think that Grub shows the boot partition as (hd0, gpt2) I have to admit that I tend to stick with MBR on a legacy Bios system.
grub.cfg is hd0, gpt1. Not sure how i tell whether is is an EFI install though. I don’t think /boot/efi exists so I am guessing that this is not an EFI installation
Just in case someone see this later. You can solve this by replacing the first superblock with a backup superblock on the disk:
dumpe2fs -h /dev/sdY
will show you the block number of all superblocks like this:
dumpe2fs 1.42.9 (28-Dec-2013)
Primary superblock at 0, Group descriptors at 1-2
Backup superblock at 32768, Group descriptors at 32769-32770
Backup superblock at 98304, Group descriptors at 98305-98306
Backup superblock at 163840, Group descriptors at 163841-163842
Backup superblock at 229376, Group descriptors at 229377-229378
Backup superblock at 294912, Group descriptors at 294913-294914
Backup superblock at 819200, Group descriptors at 819201-819202
Backup superblock at 884736, Group descriptors at 884737-884738
Backup superblock at 1605632, Group descriptors at 1605633-1605634
Backup superblock at 2654208, Group descriptors at 2654209-2654210
Then you need to repair the file system:
fsck -b 32768 /dev/sdY
You can try every superblock until it repairs correctly.
Also… i would guess that the HDD has badblocks. The file system needs to know that there are badblocks and that it should skip them. More information here: badblocks - ArchWiki
I know the issue is fixed in meantime (by re-install) but reading that made me
Because /dev/sda means the whole disk and /dev/sda1 means first partition on that disk…
So how you guys managed to mount both is me, as you can’t have a partition table if you have a filesystem formatted on the raw disk space…
(Which is the reason for that error message about superblock)
