Following Arch-wiki page on Vulkan and have installed everything it says and Pacman confirms.
However when I run
ls /usr/share/vulkan/icd.d/
to see what Vulkan implementation my system has it fails because icd.d does not exist.
The wiki page is a bit short on info on where this comes from and why it may fail. nvidia driver?
I have installed the nvidia 440.100-1 driver which pacman info says provides vulkan driver.
Ok using vulkaninfo looks like I do have vulkan installed and running, so what’s this icd.d folder? is it actually needed?
Vulkan is an explicit API, enabling direct control over how GPUs actually work. As such, Vulkan supports systems that have multiple GPUs, each running with a different driver, or ICD (Installable Client Driver)
So if you only have one card, no worries; please give some feedback to the author of the Arch article itself…
