Missing hardware detection problem with drivers?!
Hello, firstly I am really pretty new in Linux environment, spend last 2 days just trying to make my pc workable and I already manage to ■■■■ my disk/OS so I did not had other choice then reinstall whole OS again… for like fourth times now.
My current problem is that in my previous build I manage to install every (for me essential) software, everything worked fine and even manage to play couple hours of ESO, which a thought would be on Linux impossible, I tried to follow guide which should auto-mount my disks and manage to f* my system again (I even could not start terminal through alt + ctrl f1). So I install it whole again I manage to install steam, set on proton and mount my disks so I can setup Steam library… well ESO worked I mean it started load up but in character selection screen was whole pc suddenly slowed down I manage to start game itself and I had missing textures and some graphical glitches. I figure out the problem can be in drivers.
I found out that Manjaro has tool named Hardware detection but… suprise suprise my version is very special (Cinnamon 20.2 full version) and do not have Hardware detection (at least i cannot find it start + find + hardware/hardware detection/hwids) even it show in package manager that it is downloaded. I have NVIDIA GTX 1660 Ti if it help somehow.
I am just generally frustrated, spend my whole life troubleshooting problems with Windows but in two days I encounter so many problems so I am feeling like real idiot whose cannot even run one of more wholesome linux distro and cannot setup it without breaking it… one step forward and two back.
Any help is appreciated, thank you!
edit: this screen should somehow help understand my spec
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=405a7c9d-1e0a-4e51-81d4-de2f9f9cf39d rw quiet apparmor=1
  Desktop: Cinnamon 4.8.6 tk: GTK 3.24.27 vt: 7 dm: LightDM 1.30.0
  Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
  Mobo: ASUSTeK model: Z87-A v: Rev 1.xx serial: <filter>
  UEFI: American Megatrends v: 1602 date: 10/29/2013
  Info: Quad Core model: Intel Core i5-4570 bits: 64 type: MCP arch: Haswell
  family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 26120
  Speed: 1001 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 1001 2: 889
  3: 1291 4: 2409
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
  class-ID: 0380
  Device-2: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte
  driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
  Display: x11 server: X. Org 1.20.10 driver: loaded: modesetting,nouveau
  unloaded: intel alternate: fbdev,nv,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
  s-diag: 1055mm (41.6")
  Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
  diag: 546mm (21.5")
  Monitor-2: HDMI-4 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  OpenGL: renderer: NV168 v: 4.3 Mesa 20.3.4 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-3: NVIDIA TU116 High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
  class-ID: 0403
  Device-4: Z-Star Micro Venus USB2.0 Camera type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 2-14:5 chip-ID: 0ac8:3420
  class-ID: 0102
  Device-5: C-Media CM108 Audio Controller type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-3:2 chip-ID: 0d8c:013c
  class-ID: 0300
  Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: no
  vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: d000
  bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 2.6 TiB used: 126.92 GiB (4.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G
  size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: BBF0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST32000641AS
  size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: CC13 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500DM002-1BD142
  size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: KC48 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Patriot model: Burst size: 223.57 GiB
  block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
  serial: <filter> rev: 61.3 scheme: GPT
  ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%)
  used: 14.22 GiB (6.5%) fs: ext4 dev: /dev/sdd2 maj-min: 8:50
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 31.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 899
  Processes: 215 Uptime: 8m wakeups: 0 Memory: 19.43 GiB
  used: 2.13 GiB (11.0%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1346 lib: 434 flatpak: 0 Shell: Bash v: 5.1.0
  running-in: gnome-terminal inxi: 3.3.03
Welcome to the forum! :wave:
Please edit your post and add your full your system info with inxi -Fazy as outlined here:
See Manjaro Hardware Detection - Manjaro
Manjaro Settings Manager > Hardware Configuration
Well positive is that I finally find hardware detection! Thank you!
Negative is that after I updated drivers and restarted computer the OS did not boot. It came right in to the black screen.
That’s the open-source driver, you’ll probably want the proprietary NVIDIA driver. The easiest way is using the Auto Install Proprietary Driver Button in Hardware Configuration.
Are you able to switch to a TTY (Ctrl + Alt + F1 - F7)? If not, you may need to boot from a live USB and use manjaro-chroot.
What’s the output of:
mhwd -l --pci
See Configure Graphics Cards - Manjaro
Yep click on that and after that i restart it.
Yep fortunately I was able to get in manjaro-chroot
Network controller Realtek semiconductor Co., Ltd.:
name version freedriver Type
network-r8618 2016.04.20 true PCI
Display controller nVidia Corporation
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Display controllerIntel Corporation:
video-nvidia is missing from that output.
What’s the output of the following (the same as clicking the Auto Install Proprietary Driver button):
sudo mhwd -a pci nonfree 0300
Skipping already installed config ‘video-linux’ for device 0000:01:00.0 (0300:10de:2182) Display controller nVidia Corporation TU116 (GeFroce GTX 1660 Ti)
What’s the output of the following? It will show the currently installed configs:
mhwd -li --pci
edit: it basicly said same thing but in one tab
That’s the full output? That does not compute as video-linux is the free driver. Also, please post terminal output between three backticks ` above and below the text:
text
It appears you’ll need the hybrid drivers since you have an Intel / NVIDIA combo:
sudo mhwd -i pci video-hybrid-intel-nvidia-460xx-bumblebee
See also:
Error: config ´video-hybrid-intel-nvidia-460xx-bumblebee´ does not exist!
also sorry for terrible formating
Oh, sorry. It should be:
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
Or:
sudo mhwd -i pci video-hybrid-intel-nvidia-460xx-prime
hmm wierd, both commands throw error
does not exist!
Please reinstall the mhwd-db package and try sudo mhwd -a pci nonfree 0300 again.
Since you are on a Desktop PC and do not seem to have any monitor connected to the Intel GPU, why not disable it from BIOS and then have proper dGPU, the Nvidia one, work with the video-nvidia drivers ?
Hmm did not think about that, guess that would make things easier.
