Hey all!
I’ve install npm & nodejs via the following command: sudo pacman -S nodejs npm
while i tried to run the command npm -v i encountered the following error: node: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.29’ not found (required by node)
where can i find the missing library? (GLIBCXX_3.4.29)
