I guess I have a missing font, in the following posts some letters are not shown correctly:
It is shown on my screen as:
It’s because the OP uses a non-utf8
character encoding. I’ve seen it many times before.
Maybe then it’s just because the forum doesn’t support hieroglyphs.
OK, so then there seem nothing to be done, I guess.
LC_ALL=C.UTF-8 your-command-here
might fix it. Ofcourse, the cyrillic user needs to apply that methodology; which is sometimes difficult to communicate.
Here’s an interesting rant on the topic of locales that might amuse you.
