I am trying to install the AUR package
aur/epson-inkjet-printer-201211w 1.0.0-9 (+7 0.00)
and the build says that the following macros are missing.
aclocal: macro _LT_COMPILER_PIC' required but not defined aclocal: macro _LT_DECL_SED’ required but not defined
aclocal: macro _LT_DECL_SED' required but not defined aclocal: macro _LT_FUNC_STRIPNAME_CNF’ required but not
defined
==> ERROR: A failure occurred in build().
Have you checked that you have the base-devel meta package installed? autoconf and libtool are both part of that package and you probably need all those other packages to build.
sudo pamac install base-devel Or lookup the group base-devel in the pamac gui
aclocal: macro `_LT_COMPILER_PIC' required but not defined
aclocal: macro `_LT_DECL_SED' required but not defined
aclocal: macro `_LT_FUNC_STRIPNAME_CNF' required but not defined
Ah shame, I’ve change the category to aur support and tagged it with printer so the post is in the right place. Don’t see any solutions on the AUR page.
Are you sure base-devel is installed? I’m not familiar with pamac, but pacman would at least ask if you’d want to reinstall packages if you have them. That Nothing to do. is confusing (maybe it’s normal though).
warning: autoconf-2.69-7 is up to date -- reinstalling
warning: automake-1.16.2-3 is up to date -- reinstalling
warning: binutils-2.35.1-1 is up to date -- reinstalling
warning: bison-3.7.2-1 is up to date -- reinstalling
warning: fakeroot-1.25.3-1 is up to date -- reinstalling
warning: file-5.39-1 is up to date -- reinstalling
warning: findutils-4.7.0-2 is up to date -- reinstalling
warning: flex-2.6.4-3 is up to date -- reinstalling
warning: gawk-5.1.0-1 is up to date -- reinstalling
warning: gcc-10.2.0-4 is up to date -- reinstalling
warning: gettext-0.21-1 is up to date -- reinstalling
warning: grep-3.6-1 is up to date -- reinstalling
warning: groff-1.22.4-3 is up to date -- reinstalling
warning: gzip-1.10-3 is up to date -- reinstalling
warning: libtool-2.4.6+42+gb88cebd5-14 is up to date -- reinstalling
warning: m4-1.4.18-3 is up to date -- reinstalling
warning: make-4.3-3 is up to date -- reinstalling
warning: pacman-5.2.2-3 is up to date -- reinstalling
warning: patch-2.7.6-8 is up to date -- reinstalling
warning: pkgconf-1.7.3-1 is up to date -- reinstalling
warning: sed-4.8-1 is up to date -- reinstalling
warning: sudo-1.9.4.p2-2 is up to date -- reinstalling
warning: texinfo-6.7-3 is up to date -- reinstalling
warning: which-2.21-5 is up to date -- reinstalling
Build software packages autoconf/automake/libtool are all the same version as stable.
Clean out the cache? The error you are getting seems to have to do with the build environment.
