Misinterpreted warnings
Problem during update. I haven’t rebooted yet. I have:
(14/23) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(15/23) Reloading system bus configuration...
(16/23) Checking for old perl modules...
(17/23) Copy Firefox Distribution Settings
(18/23) Compiling GSettings XML schema files...
(19/23) Updating icon theme caches...
(20/23) Changing NetworkManager Connectivity-Ping to manjaro.org
(21/23) Updating the info directory file...
(22/23) Updating the desktop file MIME type cache...
(23/23) Signing EFI binaries...
Generating EFI bundles....
Warning (I can fix it with /etc/default/grub):
Before the update it was: os-prober: disabled
Error:
nvme1n1: ID-2 is the boot device with /boot/efi, / and /home:
$ inxi -D
  Local Storage: total: 2.75 TiB used: 393.82 GiB (14.0%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 EVO Plus 2TB
  ID-2: /dev/nvme1n1 vendor: Micron model: 2550 1024GB size: 953.87 GiB
Thanks
There is nothing to fix – the warning is informational only:
os-prober disabled (Upstream default):
  • #GRUB_DISABLE_OS_PROBER=false: Commented
    (if commented or omitted, the default condition applies)
os-prober enabled (Manjaro default):
  • GRUB_DISABLE_OS_PROBER=false: Uncommented
    (uncommenting the line enables os-prober)
Again, this is only an informational warning. Many (especially more recent) devices are “too new” to be identified, so a warning is triggered. In the case of the NVMe, the device is still recognised as storage and continues to function.
Thanks
