error: failed retrieving file 'multilib.db' from manjaro.kurdy.org : Resolving timed out after 10000 milliseconds
warning: too many errors from manjaro.kurdy.org, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.23m.com : Resolving timed out after 10002 milliseconds
error: failed retrieving file 'extra.db' from mirror.23m.com : Resolving timed out after 10002 milliseconds
error: failed retrieving file 'multilib.db' from mirror.23m.com : Resolving timed out after 10002 milliseconds
Whenever there is any problem with the mirrors like that, I don’t wait or even investigate, I simply run pacman-mirrors -c Germany
and another one will make the top of the list and will work.
From that it does not follow that you don’t have DNS problems - they could all be configured to use a different one.
They probably are not - I was just saying that it is not automatically true.
And:
each system may have picked another mirror as the first in list - depending on when pacman-mirrors was run and what the best one was at the time.
They might all be different …
