dear all,
using Manjaro Openbox on a Dell desktop, Intel i3 cpu, 16 GB Ram, kernel 5.8…
Earlier today I’ve updated with pacman -Sy plus pacman -Su.
After the update I get a notification in the top toolbar that there’s still 1 update (there’s nothing to update, either using pacman -Syu or the Package Manager…) and next to it this message:
/bin/sh: check-network: command not found
(sorry I can’t attach a screenshot and neither a link).
the check-network command - it may have been a part of the scripts but I cannot remember if it has ever been in use - that is - if you customized something using a script which has been deprecated for some time.
If this is message about check-network is a part of polybar - I suggest you edit the polybar configuration and remove the module which calls the script.
The primary config - where modules are defined for the polybar - is ~/.config/polybar/config
At the bottom of the file you find left, middle and right modules inclusion.
thanks, I’ll have a look asap at the config bar and report here what happens.
I have Microsoft Teams (using it in… 45 minutes!) but can’t remember much other AUR stuff since I changed the ssd and reinstalled Manjaro, and can’t remember having customized anything but… I’m quite possibly wrong
