don’t post pictures - please - you can achieve the same thing with command line - then post the text
$ pamac info minizip
Version : 1:1.3.1-1
Description : Mini zip and unzip based on zlib
URL : https://www.zlib.net/
Licenses : Zlib
Repository : core
Installed Size : 87,9 kB
Groups : --
Depends On : glibc zlib
Optional Dependencies : --
Required By : chromium electron28 qt5-webengine qt6-webengine telegram-desktop
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Levente Polyak <anthraxx@archlinux.org>
Build Date : man 22 jan 2024 20:50:29 CET
Install Date : ons 14 feb 2024 09:49:26 CET
Install Reason : Installed as a dependency for another package
Validated By : Signature
Backup files : --
pamac info minizip ✔
Version : 1:1.3-2
Licenses : Zlib
Repository : core
Installed Size : 87.9 kB
Groups : --
Required By : qt5-webengine
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Build Date : Wed 25 Oct 2023 03:55:57 AM IDT
Install Date : Thu 15 Feb 2024 10:44:40 AM IST
Backup files : --
Well, not exactly. The pamac system icon keeps showing that there is an update waiting for me. So I solved the problem by adding Minizip to the Pamac exception list, until the stable branch catches up to the current state of my system.
Be aware that after switching to a more stable branch you will receive messages from pacman, informing about newer packages installed than available in the repo. Don’t be alarmed as the situation will resolve itself when the packages reaches your current branch.
