Minecraft 1.8.9 (Using utility mods) used to run at around 150-200 fps, Minecraft 1.17 (also using utility mods) runs at around 110-150 fps and around 60-80 fps with shaders. After a couple of system updates and some packages (mostly tlp
, powertop
and optimus-manager
, the first two i promptly uninstalled, to try and fix the issue) , both versions and 1.18 were running at around 20-50 fps with slightly worse settings (lowered the render distance, changed from fancy to fast), but with no luck.
moderated - please refrain from using images - they are useless for search/indexing
Information:
1.18 with all my mods (listed in the logs)
logs (same session as image): https://drive.google.com/file/d/1tk3X2HhKFij1Ibrfk1Xe0gIcXOGkvVU7/view?usp=sharing
1.18 with needed mods (fabric api, sodium, iris)
logs https://drive.google.com/file/d/1KaApBU3M27S533j7Jstp4OWjgzwpblmw/view?usp=sharing
1.8 with all mods
logs https://drive.google.com/file/d/1BzyEAu2joyb220zUcTPUkNalNjZE9CGt/view?usp=sharing
1.8 with needed mods (optifine, patcher)
logs https://drive.google.com/file/d/1KUkDMFWBLAGZx8Ho1Cka3tPufQS3oZYx/view?usp=sharing
~ inxi -SPARM -GCDN -v1 -xGCRS ✔
Host: iwant2tryhard-manjaro Kernel: 5.15.7-1-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LH_FX506LH
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX506LH v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LH.309 date: 02/02/2021
Info: quad core model: Intel Core i5-10300H bits: 64 type: MT MCP
arch: Comet Lake rev: 2 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 4083 high: 4100 min/max: 800/4500 cores: 1: 4073
2: 4056 3: 4072 4: 4065 5: 4100 6: 4100 7: 4100 8: 4100 bogomips: 40009
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0
Device-2: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 495.44
bus-ID: 01:00.0
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:5
Display: x11 server: X.Org 1.21.1.2 driver: loaded: modesetting
unloaded: nvidia resolution: 1920x1080~144Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel port: N/A
bus-ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
Local Storage: total: 476.94 GiB used: 127.3 GiB (26.7%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2210 MTFDHBA512QFD
size: 476.94 GiB temp: 37.9 C
ID-1: / size: 205.6 GiB used: 123.77 GiB (60.2%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 292 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: swap-1 size: 8 GiB used: 3.53 GiB (44.1%) fs: swap
dev: /dev/nvme0n1p5
Processes: 313 Uptime: 4h 6m Memory: 7.6 GiB used: 6.19 GiB (81.4%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1741 Shell: Zsh v: 5.8
inxi: 3.3.11
| NVIDIA-SMI 495.44 Driver Version: 495.44 CUDA Version: 11.5 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 63C P8 3W / N/A | 0MiB / 3911MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
How do I get my fps back? (It’s very frustrating, i expected more out of this machine)
