Hello,
Every version 1.13 and above almost always crashes my computer, but sometimes will just crash itself. I have tried using the official launcher and multimc, and I have also tried reinstalling minecraft and java. Launching my minecraft server also does not work. I installed minecraft on my laptop also running manjaro and it worked just fine.
Here is the crash report:
---- Minecraft Crash Report ----
// But it works on my machine.
Time: 1/9/21 11:24 AM
Description: Initializing game
java.lang.ExceptionInInitializerError
at dkd.<init>(SourceFile:146)
at djz.<init>(SourceFile:440)
at net.minecraft.client.main.Main.main(SourceFile:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.multimc.onesix.OneSixLauncher.launchWithMainClass(OneSixLauncher.java:196)
at org.multimc.onesix.OneSixLauncher.launch(OneSixLauncher.java:231)
at org.multimc.EntryPoint.listen(EntryPoint.java:143)
at org.multimc.EntryPoint.main(EntryPoint.java:34)
Caused by: java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: Failed to locate library: libglfw.so
at deo.<clinit>(SourceFile:46)
... 11 more
Caused by: java.lang.UnsatisfiedLinkError: Failed to locate library: libglfw.so
at org.lwjgl.system.Library.loadNative(Library.java:299)
at org.lwjgl.system.Library.loadNative(Library.java:205)
at org.lwjgl.glfw.GLFW.<clinit>(GLFW.java:674)
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:330)
at java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:327)
at java.lang.ClassValue.getFromHashMap(ClassValue.java:227)
at java.lang.ClassValue.getFromBackup(ClassValue.java:209)
at java.lang.ClassValue.get(ClassValue.java:115)
at java.lang.invoke.DirectMethodHandle.checkInitialized(DirectMethodHandle.java:351)
at java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:341)
at java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:373)
at deo.<clinit>(SourceFile:43)
... 11 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Render thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.16.4
Minecraft Version ID: 1.16.4
Operating System: Linux (amd64) version 5.9.16-1-MANJARO
Java Version: 1.8.0_265, Oracle Corporation
Java VM Version: OpenJDK 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 697479088 bytes (665 MB) / 1425014784 bytes (1359 MB) up to 7516192768 bytes (7168 MB)
CPUs: 8
JVM Flags: 2 total; -Xms256m -Xmx8064m
Launched Version: MultiMC5
Backend library: LWJGL version 3.2.2 build 10
Backend API: ~~ERROR~~ NoClassDefFoundError: Could not initialize class org.lwjgl.glfw.GLFW
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
CPU: <unknown>
