Here are my specs:
Specs
KDE Plasma Version: 5.27.7
KDE Frameworks Version: 5.108.0
Qt Version: 5.15.10
Kernel Version: 6.4.9-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Core™ i5-6500 CPU @ 3.20GHz
Memory: 23.3 GiB of RAM
Graphics Processor: AMD Radeon RX 6400
Manufacturer: Dell Inc.
Product Name: OptiPlex 7050
So I have two monitors. Whenever I play Minecraft on 1.8.9, the game does not capture the cursor. If I turn to the left, the cursor will go onto my second monitor. If I turn to the right, the cursor, although not visible, will hit the border of my main monitor and my view will stop turning.
I am using Prism Launcher. I’ve tried another solution out there where gamescope -f -H $HEIGHT -h $HEIGHT --
is used (in my case, since my monitor is 1920x1080, the command (i think) would be gamescope -f -H 1920 -h 1080 --
). I’ve tried pitting that in the “Wrapper Command” and “Pre-launch Command” sections in the Custom Commands tab of the instance settings in Prism. I get two different errors, depending on which field I put it in.
If I put it in Pre-Launch, I get The process failed to start. Pre-Launch command failed with code 0.
(Which is strange, because if I run the same command in a terminal, it initializes.)
If I put it in Wrapper Command, I get The wrapper command "gamescope" couldn't be found.
(Maybe Prism only supports a few wrappers.)
