@spikerguy
Can i use MIMO wifi in vim3 to connect to a 2.5 and a 5 ghz network at the same time?
Or can i use network adaptor to connect to 2.5 ghz network for internet and create a 5ghz hotspot simultaneously??? I’m using latest manjaro plasma on khadas vim3
@yasirjaved990
Install pulseaudio and reboot. that will solve the problem of HDMI audio pipewire-pulse still cannot configure the audio routing so we will have to look into how to get it to work with pipewire.
@JFL For restart issue it is mostly the module and the plymouth. I am still looking into it.
Realtek’s chips seem to be cheaper, and they’re also worse, but given that manufacturing is done in Shenzhen, China, there are probably more cheap embedded chips to choose from locally.
