Hi there!
So i’m kind of a noob and running Manjaro+i3. Mic don’t work but audio output does with no issue. I’ve been fiddling around but can’t get to the issue. I’m running alsa and pulseaudio but am not knowledgeable enough to troubleshoot the issue. Any help would be appreciated.
HP laptop with AMD Ryzen 5 4600H + Nvidia.
Headphone+mic combo behaves just the same as system mic.
Tried this but no luck:
arecord -lL
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
default:CARD=Generic
HD-Audio Generic, ALC285 Analog
Default Audio Device
sysdefault:CARD=Generic
front:CARD=Generic,DEV=0
Front output / input
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
default:CARD=acp
acp,
sysdefault:CARD=acp
acp,
usbstream:CARD=acp
acp
USB Stream Output
**** List of CAPTURE Hardware Devices ****
card 1: Generic [HD-Audio Generic], device 0: ALC285 Analog [ALC285 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: acp [acp], device 0: DMIC capture dmic-hifi-0 []
Subdevices: 1/1
sudo fuser -v /dev/snd/*
USER PID ACCESS COMMAND
/dev/snd/controlC0: eric 160720 F.... pulseaudio
/dev/snd/controlC1: eric 160720 F.... pulseaudio
/dev/snd/controlC2: eric 160720 F.... pulseaudio
… or not, depends on what’s running I guess.
pacmd list-sources | grep -e 'index:' -e device.string -e 'name:'
* index: 0
device.string = "hw:2"
index: 1
device.string = "1"
sudo mhwd --pci -l
> 0000:01:00.0 (0300:10de:1f99) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-450xx-prime 2019.10.25 false PCI
video-hybrid-amd-nvidia-440xx-prime 2019.10.25 false PCI
video-nvidia-450xx 2019.10.25 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:05:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
Overkill inxi -Fzxxxa; System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A parameters: - Pastebin.com
