When looking up information about Microsoft Edge on Linux, it seems like hardware video acceleration should be working out of the box, but I’m having doubts about this being the case.
Here’s Firefox playing a 4K video after enabling VAAPI through about:config:
And here’s Edge doing the same thing - note the severely higher CPU usage:
Youtube served a VP9 video in both situations.
I’ve tried the following flags for Edge:
--use-gl=angle --use-angle=swiftshader make the situation much worse and cause the CPU usage to increase even further, nearly maxing out all cores and making the entire browser very slow.
--enable-features=VaapiVideoDecoder,VaapiVideoEncoder --disable-features=UseChromeOSDirectVideoDecoder --use-gl=egl does not seem to change anything.
Using either combination seems to disable hardware acceleration completely, at least according to edge://gpu. Without any flags, “Video decode” shows up as “Hardware accelerated”, although “Video Acceleration Information” on the bottom of the page shows empty “Decoding” and “Encoding” rows.
The system is a laptop running dual graphics (Ryzen 5 4600H w/ Radeon Graphics and Nvidia Geforce GTX 1650), running the latest version of Manjaro KDE as of 2024-09-03 with the Nvidia proprietary driver installed.
Output of vdpauinfo seems to indicate VP9 is not supported, but shouldn’t this iGPU support it on the hardware level?
display: :0 screen: 0
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name width height types
420 16384 16384 NV12 YV12
422 16384 16384 UYVY YUYV
444 16384 16384 Y8U8V8A8 V8U8Y8A8
420_16 16384 16384 P010 P016
422_16 16384 16384
444_16 16384 16384
Decoder capabilities:
name level macbs width height
MPEG1 --- not supported ---
MPEG2_SIMPLE 3 65536 4096 4096
MPEG2_MAIN 3 65536 4096 4096
H264_BASELINE 52 65536 4096 4096
H264_MAIN 52 65536 4096 4096
H264_HIGH 52 65536 4096 4096
VC1_SIMPLE 1 65536 4096 4096
VC1_MAIN 2 65536 4096 4096
VC1_ADVANCED 4 65536 4096 4096
MPEG4_PART2_SP 3 65536 4096 4096
MPEG4_PART2_ASP 5 65536 4096 4096
DIVX4_QMOBILE --- not supported ---
DIVX4_MOBILE --- not supported ---
DIVX4_HOME_THEATER --- not supported ---
DIVX4_HD_1080P --- not supported ---
DIVX5_QMOBILE --- not supported ---
DIVX5_MOBILE --- not supported ---
DIVX5_HOME_THEATER --- not supported ---
DIVX5_HD_1080P --- not supported ---
H264_CONSTRAINED_BASELINE 0 65536 4096 4096
H264_EXTENDED --- not supported ---
H264_PROGRESSIVE_HIGH --- not supported ---
H264_CONSTRAINED_HIGH --- not supported ---
H264_HIGH_444_PREDICTIVE --- not supported ---
VP9_PROFILE_0 --- not supported ---
VP9_PROFILE_1 --- not supported ---
VP9_PROFILE_2 --- not supported ---
VP9_PROFILE_3 --- not supported ---
HEVC_MAIN 186 139264 8192 4352
HEVC_MAIN_10 186 139264 8192 4352
HEVC_MAIN_STILL --- not supported ---
HEVC_MAIN_12 --- not supported ---
HEVC_MAIN_444 --- not supported ---
HEVC_MAIN_444_10 --- not supported ---
HEVC_MAIN_444_12 --- not supported ---
AV1_MAIN --- not supported ---
AV1_HIGH --- not supported ---
AV1_PROFESSIONAL --- not supported ---
Output surface:
name width height nat types
B8G8R8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 I8A8
R8G8B8A8 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 I8A8
R10G10B10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 I8A8
B10G10R10A2 16384 16384 y NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 I8A8
Bitmap surface:
name width height
A8 16384 16384
Video mixer:
feature name sup
DEINTERLACE_TEMPORAL y
DEINTERLACE_TEMPORAL_SPATIAL -
INVERSE_TELECINE -
NOISE_REDUCTION y
SHARPNESS y
LUMA_KEY y
HIGH QUALITY SCALING - L1 y
HIGH QUALITY SCALING - L2 -
HIGH QUALITY SCALING - L3 -
HIGH QUALITY SCALING - L4 -
HIGH QUALITY SCALING - L5 -
HIGH QUALITY SCALING - L6 -
HIGH QUALITY SCALING - L7 -
HIGH QUALITY SCALING - L8 -
HIGH QUALITY SCALING - L9 -
parameter name sup min max
VIDEO_SURFACE_WIDTH y 48 4096
VIDEO_SURFACE_HEIGHT y 48 4096
CHROMA_TYPE y
LAYERS y 0 4
attribute name sup min max
BACKGROUND_COLOR y
CSC_MATRIX y
NOISE_REDUCTION_LEVEL y 0.00 1.00
SHARPNESS_LEVEL y -1.00 1.00
LUMA_KEY_MIN_LUMA y
LUMA_KEY_MAX_LUMA y
Yet vainfo seems to be providing different information, what gives? Could that be the reason of Edge’s problems?
Trying display: wayland
Trying display: x11
vainfo: VA-API version: 1.22 (libva 2.22.0)
vainfo: Driver version: Mesa Gallium driver 24.1.6-arch1.1 for AMD Radeon Graphics (radeonsi, renoir, LLVM 18.1.8, DRM 3.57, 6.9.12-3-MANJARO)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSlice
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
