Microphones are no longer working
Microphones are no longer working, neither laptop-internal, nor Bluetooth headset. Any suggestions? I have tried restarting Pipewire and Bluetooth services and checked everything in system sound settings, not sure what else I could try.
It was only the Bluetooth microphone. I did not see the internal microphone’s volume level, because it was permanently at maximum. Recording from that technically worked, but with terrible quality. No idea if that was because of the update or because it is just that bad (would be weird for an expensive laptop).
I “solved” the problem by just not using Pipewire at all anymore, I switched to PulseAudio.
