Hi! I’m experiencing the issue of Manjaro not recognizing my microphones (either built in or external) for almost a year now. I know this is a common issue but after reading almost every post on the topic, I’m still not capable of solving my problem.
I was in the mid of a call and all of sudden my microphone went mute. Turns out it doesn’t appear in the settings anymore. It’s also missing from PulseAudio and Alsamixer.
I’ve already tried the solutions listed here without success: https://wiki.archlinux.org/title/PulseAudio/Troubleshooting#Microphone
Some useful info:
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c92a76ec-d531-4445-8cd5-4a25b2c92fef ro quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Avell High Performance product: A65 LIV v: Standard
serial: <superuser required>
Mobo: Avell High Performance model: Avell High Performance v: Standard
serial: <superuser required> UEFI: American Megatrends v: N.1.01
date: 04/14/2020
ID-1: BAT0 charge: 92.5 Wh (98.9%) condition: 93.5/93.5 Wh (100.0%)
volts: 12.3 min: 11.4 model: standard type: Li-ion serial: <filter>
status: charging
RAM: total: 15.46 GiB used: 4.68 GiB (30.3%)
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1087 high: 4128 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 4128 2: 869 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 2008 11: 800 12: 801 13: 800 14: 800
15: 800 16: 800 bogomips: 70421
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Tongfang Hongkong
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Tongfang Hongkong
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:4
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1048x291mm (41.26x11.46")
s-diag: 1088mm (42.82")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: right
model: Acer XZ242Q built: 2019 res: 1920x1080 hz: 144 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 pos: primary,left
model: BOE Display 0x084d built: 2018 res: 1920x1080 hz: 144 dpi: 142
gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3d:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp61s0 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 385.16 GiB (80.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: IM2P33F8BR2-512GB
lanes: 4 type: SSD serial: <filter> rev: T0214B0L temp: 39.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 70.02 GiB (73.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
uuid: c92a76ec-d531-4445-8cd5-4a25b2c92fef
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 9244-3955
ID-3: /home raw-size: 362.19 GiB size: 355.44 GiB (98.14%)
used: 315.14 GiB (88.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: Home uuid: 24798838-5ebf-41de-8862-b09df9b60681
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
uuid: efa25c7f-58e7-48ca-b443-411bac1aefbe
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-6:2 info: Integrated Express ITE Device(8291)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:6004 class-ID: 0300
Device-2: 1-9:3 info: Logitech G403 HERO Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 046d:c08f class-ID: 0300 serial: <filter>
Device-3: 1-13:4 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Device-4: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0316 class-ID: 0806 serial: <filter>
Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 67.0 C pch: 73.0 C mobo: N/A gpu: nvidia temp: 63 C
Processes: 351 Uptime: 23m wakeups: 3 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1963
pm: pacman pkgs: 1939 libs: 458 tools: pamac pm: appimage pkgs: 0 pm: flatpak
pkgs: 11 pm: snap pkgs: 13 Shell: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.24
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC274 Analog [ALC274 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
amixer -D sysdefault info; amixer -D sysdefault
Card sysdefault 'PCH'/'HDA Intel PCH at 0x6045110000 irq 185'
Mixer name : 'Realtek ALC274'
Components : 'HDA:10ec0274,1d051098,00100004 HDA:8086280b,80860101,00100000'
Controls : 53
Simple ctrls : 13
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 59 [68%] [-21.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 47 [75%] [18.00dB] [on]
Front Right: Capture 47 [75%] [18.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
I’m new to Linux and quite clueless. What should I do?
