Yes, I could hear myself using parec | pacat
, the audio was crisp, but it was delayed by about 2-3 seconds.
________________
> pulseaudio_ps_do
sarah 2056 0.8 0.0 3644240 18112 ? S<sl 12:43 0:19 /usr/bin/pulseaudio --daemonize=no --log-target=journal
sarah 14599 1.1 0.6 2934444 206568 ? Sl 13:20 0:00 /usr/bin/kcmshell5 kcm_pulseaudio
sarah 15190 0.0 0.0 3144 796 pts/7 S+ 13:21 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
2056
________________
> pulseaudio --version
pulseaudio 13.99.3
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 34
Server Protocol Version: 34
Is Local: yes
Client Index: 26
Tile Size: 65472
User Name: sarah
Host Name: MidnightStarSign
Server Name: pulseaudio
Server Version: 13.99.3
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_0d_00.4.analog-stereo
Default Source: alsa_input.pci-0000_0d_00.4.analog-stereo
Cookie: eca5:dd3e
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "13.99.3"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="0" name="pci-0000_0b_00.1" card_name="alsa_card.pci-0000_0b_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
module.description = "ALSA Card"
Module #7
Argument: device_id="2" name="usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-02" card_name="alsa_card.usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-02" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #8
Argument: device_id="1" name="pci-0000_0d_00.4" card_name="alsa_card.pci-0000_0d_00.4" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 1
Properties:
Module #9
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #11
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #13
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #14
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #15
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #17
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #24
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #25
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #26
Argument: display=:0 xauthority=/home/sarah/.Xauthority
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #27
Argument: display=:0 xauthority=/home/sarah/.Xauthority session_manager=local/MidnightStarSign:@/tmp/.ICE-unix/1993,unix/MidnightStarSign:/tmp/.ICE-unix/1993
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: SUSPENDED
Description: Starship/Matisse HD Audio Controller Analog Stereo
Driver: module-alsa-card.c
Owner Module: 8
Mute: no
Volume: front-left: 29274 / 45% / -21.00 dB, front-right: 29274 / 45% / -21.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_0d_00.4.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC1220 Analog"
alsa.id = "ALC1220 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfcb00000 irq 136"
device.bus_path = "pci-0000:0d:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0d:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "front:1"
device.buffering.buffer_size = "17664"
device.buffering.fragment_size = "2944"
device.access_mode = "mmap"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Starship/Matisse HD Audio Controller Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-lineout: Line Out (type: Line, priority: 9000, availability group: Legacy 4, available)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 5, available)
Active Port: analog-output-headphones
Formats:
pcm
Source #0
State: SUSPENDED
Description: Monitor of Starship/Matisse HD Audio Controller Analog Stereo
Owner Module: 8
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_0d_00.4.analog-stereo
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Starship/Matisse HD Audio Controller Analog Stereo"
device.class = "monitor"
alsa.card = "1"
device.bus = "pci"
device.string = "1"
Formats:
pcm
Source #1
State: SUSPENDED
Owner Module: 8
Mute: no
Volume: front-left: 42337 / 65% / -11.39 dB, front-right: 42337 / 65% / -11.39 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Monitor of Sink: n/a
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, availability group: Legacy 1, available)
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, availability group: Legacy 2, available)
analog-input-linein: Line In (type: Line, priority: 8100, availability group: Legacy 3, not available)
Active Port: analog-input-rear-mic
Formats:
pcm
Sink Input #31
Driver: protocol-native.c
Owner Module: 14
Client: 9
Sink: 0
Sample Specification: float32le 2ch 48000Hz
Format: pcm, format.sample_format = "\"float32le\"" format.rate = "48000" format.channels = "2" format.channel_map = "\"front-left,front-right\""
Corked: yes
Mute: no
Volume: front-left: 57409 / 88% / -3.45 dB, front-right: 57409 / 88% / -3.45 dB
balance 0.00
Buffer Latency: 208229 usec
Sink Latency: 0 usec
Resample method: speex-float-1
Properties:
media.name = "AudioStream"
application.name = "Firefox"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.process.id = "2778"
application.process.user = "sarah"
application.process.host = "MidnightStarSign"
application.process.binary = "firefox"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "646316c5de21472bbbb570c8c7d19086"
application.process.session_id = "2"
application.icon_name = "firefox"
module-stream-restore.id = "sink-input-by-application-name:Firefox"
Client #0
Driver: module-systemd-login.c
Owner Module: 21
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #2
Owner Module: 14
Properties:
application.name = "Sublime Text"
window.x11.screen = "0"
application.process.id = "2059"
application.process.binary = "sublime_text"
application.icon_name = "sublime-text"
Client #4
Driver: module-x11-xsmp.c
Owner Module: 27
Properties:
application.name = "XSMP Session on KDE as 1015c1ad1941c2000160607068400000019930003"
xsmp.vendor = "KDE"
xsmp.client.id = "1015c1ad1941c2000160607068400000019930003"
Client #5
Owner Module: 14
Properties:
Client #6
Owner Module: 14
Properties:
application.name = "Clementine device finder"
media.role = "music"
application.process.id = "3042"
application.process.binary = "clementine"
application.icon_name = "clementine"
Client #7
Owner Module: 14
Properties:
application.name = "QPulse"
application.process.id = "2001"
application.process.binary = "plasmashell"
Client #8
Owner Module: 14
Properties:
application.name = "Darktable"
application.process.id = "2057"
application.process.binary = "darktable"
application.icon_name = "darktable"
Client #9
Owner Module: 14
Properties:
Client #10
Owner Module: 14
Properties:
application.name = "Brave input"
application.process.id = "5559"
application.process.binary = "brave"
Client #14
Owner Module: 14
Properties:
application.version = "83.0"
Client #15
Owner Module: 14
Properties:
application.name = "WEBRTC VoiceEngine"
application.process.id = "7775"
application.process.binary = "signal-desktop"
application.icon_name = "signal-desktop"
Client #16
Owner Module: 14
Properties:
application.process.id = "7951"
application.process.binary = "Discord"
Client #19
Owner Module: 14
Properties:
application.name = "Clocks"
application.icon_name = "org.gnome.clocks"
application.process.id = "8081"
application.process.binary = "gnome-clocks"
Client #20
Owner Module: 14
Properties:
application.id = "org.gnome.clocks"
Client #21
Owner Module: 14
Properties:
application.process.id = "14599"
application.process.binary = "kcmshell5"
Client #27
Owner Module: 14
Properties:
application.name = "pactl"
application.process.id = "15195"
application.process.binary = "pactl"
application.language = "C"
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xfcca0000 irq 134"
device.bus_path = "pci-0000:0b:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:09:00.0/0000:0a:00.0/0000:0b:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "ab38"
device.product.name = "Navi 10 HDMI Audio"
device.string = "0"
device.description = "Navi 10 HDMI Audio"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
device.product.name = "ASUS VA24E"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4
hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
Card #1
Owner Module: 7
Properties:
alsa.card = "2"
alsa.card_name = "USB 2.0 Camera"
alsa.long_card_name = "Sonix Technology Co., Ltd. USB 2.0 Camera at usb-0000:0d:00.3-2, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:0d:00.3-usb-0:2:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0d:00.3/usb7/7-2/7-2:1.2/sound/card2"
udev.id = "usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-02"
device.bus = "usb"
device.vendor.id = "0c45"
device.vendor.name = "Microdia"
device.product.id = "6367"
device.product.name = "USB 2.0 Camera"
device.serial = "Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001"
device.form_factor = "webcam"
device.string = "2"
device.description = "USB 2.0 Camera"
device.icon_name = "camera-web-usb"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
Active Profile: off
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec)
Properties:
Part of profile(s): input:analog-stereo
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec)
Part of profile(s): input:iec958-stereo
Card #2
Owner Module: 8
Properties:
alsa.card = "1"
device.bus = "pci"
device.string = "1"
device.description = "Starship/Matisse HD Audio Controller"
Profiles:
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: yes)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, available)
Properties:
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, available)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec)
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 2 Nov 22 2020 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 16 Nov 22 2020 /dev/snd/pcmC2D0c
crw-rw----+ 1 root audio 116, 12 Nov 22 2020 /dev/snd/pcmC1D1p
crw-rw----+ 1 root audio 116, 7 Nov 22 2020 /dev/snd/pcmC0D11p
crw-rw----+ 1 root audio 116, 6 Nov 22 2020 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116, 5 Nov 22 2020 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 4 Nov 22 2020 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116, 3 Nov 22 2020 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116, 1 Nov 22 2020 /dev/snd/seq
crw-rw----+ 1 root audio 116, 17 Nov 22 2020 /dev/snd/controlC2
crw-rw----+ 1 root audio 116, 15 Nov 22 2020 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 14 Nov 22 2020 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 13 Nov 22 2020 /dev/snd/pcmC1D2c
crw-rw----+ 1 root audio 116, 9 Nov 22 2020 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 8 Nov 22 2020 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 33 Nov 22 2020 /dev/snd/timer
crw-rw----+ 1 root audio 116, 10 Nov 22 13:20 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116, 11 Nov 22 13:20 /dev/snd/pcmC1D0c
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root 60 Nov 22 2020 .
drwxr-xr-x 4 root root 440 Nov 22 2020 ..
lrwxrwxrwx 1 root root 12 Nov 22 2020 usb-Sonix_Technology_Co.__Ltd._USB_2.0_Camera_SN0001-02 -> ../controlC2
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Nov 22 2020 .
lrwxrwxrwx 1 root root 12 Nov 22 2020 pci-0000:0d:00.3-usb-0:2:1.2 -> ../controlC2
lrwxrwxrwx 1 root root 12 Nov 22 2020 pci-0000:0d:00.4 -> ../controlC1
lrwxrwxrwx 1 root root 12 Nov 22 2020 pci-0000:0b:00.1 -> ../controlC0
________________
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 2056 sarah 16u CHR 116,15 0t0 617 /dev/snd/controlC1
pulseaudi 2056 sarah 18u CHR 116,9 0t0 604 /dev/snd/controlC0
pulseaudi 2056 sarah 24u CHR 116,15 0t0 617 /dev/snd/controlC1
pulseaudi 2056 sarah 30u CHR 116,15 0t0 617 /dev/snd/controlC1
pipewire 4034 sarah 28u CHR 116,1 0t0 535 /dev/snd/seq
pipewire 4034 sarah 29u CHR 116,1 0t0 535 /dev/snd/seq
pipewire- 4040 sarah 25u CHR 116,17 0t0 677 /dev/snd/controlC2
pipewire- 4040 sarah 26u CHR 116,15 0t0 617 /dev/snd/controlC1
pipewire- 4040 sarah 27u CHR 116,9 0t0 604 /dev/snd/controlC0
________________
> jacks_do
card=0
numid=25,iface=CARD,name='HDMI/DP,pcm=10 Jack'
; type=BOOLEAN,access=r-------,values=1
: values=on
numid=31,iface=CARD,name='HDMI/DP,pcm=11 Jack'
: values=off
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=on
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=on
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
card=1
numid=41,iface=CARD,name='Front Headphone Jack'
: values=on
numid=35,iface=CARD,name='Front Mic Jack'
: values=on
numid=37,iface=CARD,name='Line Jack'
: values=off
numid=40,iface=CARD,name='Line Out CLFE Jack'
: values=off
numid=38,iface=CARD,name='Line Out Front Jack'
: values=on
numid=39,iface=CARD,name='Line Out Surround Jack'
: values=off
numid=36,iface=CARD,name='Rear Mic Jack'
: values=on
numid=42,iface=CARD,name='SPDIF Phantom Jack'
: values=on
card=2
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, HDMI 1
HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
HDA ATI HDMI, HDMI 2
HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
HDA ATI HDMI, HDMI 3
HDMI Audio Output
hdmi:CARD=HDMI,DEV=4
HDA ATI HDMI, HDMI 4
HDMI Audio Output
hdmi:CARD=HDMI,DEV=5
HDA ATI HDMI, HDMI 5
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC1220 Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Generic,DEV=0
HD-Audio Generic, ALC1220 Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
usbstream:CARD=Camera
USB 2.0 Camera
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Camera
USB 2.0 Camera, USB Audio
front:CARD=Camera,DEV=0
USB 2.0 Camera
USB Stream Output
________________
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Sun Nov 22 18:21:19 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: System manufacturer
Product Name: System Product Name
Product Version: System Version
Firmware Version: 1407
System SKU: SKU
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: PRIME X570-PRO
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0030:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0A08:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C02:01/status 15
/sys/bus/acpi/devices/PNP0C02:03/status 15
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 11
/sys/bus/acpi/devices/PNP0C0F:01/status 11
/sys/bus/acpi/devices/PNP0C0F:02/status 11
/sys/bus/acpi/devices/PNP0C0F:03/status 11
/sys/bus/acpi/devices/PNP0C0F:04/status 11
/sys/bus/acpi/devices/PNP0C0F:05/status 11
/sys/bus/acpi/devices/PNP0C0F:06/status 11
/sys/bus/acpi/devices/PNP0C0F:07/status 11
!!Kernel Information
Kernel release: 5.9.8-2-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.8-2-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [HDMI ]: HDA-Intel - HDA ATI HDMI
1 [Generic ]: HDA-Intel - HD-Audio Generic
2 [Camera ]: USB-Audio - USB 2.0 Camera
!!PCI Soundcards installed in the system
0b:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
0d:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
Subsystem: ASUSTeK Computer Inc. Device [1043:8733]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Module: snd_usb_audio
autoclock : Y
delayed_register : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
ignore_ctl_error : N
pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
skip_validation : N
use_vmalloc : Y
vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=1, device=0
Control: name="IEC958 Playback Pro Mask", index=1, device=0
Control: name="IEC958 Playback Default", index=1, device=0
Control: name="IEC958 Playback Switch", index=1, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=2, device=0
Control: name="IEC958 Playback Pro Mask", index=2, device=0
Control: name="IEC958 Playback Default", index=2, device=0
Control: name="IEC958 Playback Switch", index=2, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=3, device=0
Control: name="IEC958 Playback Pro Mask", index=3, device=0
Control: name="IEC958 Playback Default", index=3, device=0
Control: name="IEC958 Playback Switch", index=3, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=4, device=0
Control: name="IEC958 Playback Pro Mask", index=4, device=0
Control: name="IEC958 Playback Default", index=4, device=0
Control: name="IEC958 Playback Switch", index=4, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital: Enabled
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=5, device=0
Control: name="IEC958 Playback Pro Mask", index=5, device=0
Control: name="IEC958 Playback Default", index=5, device=0
Control: name="IEC958 Playback Switch", index=5, device=0
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Node 0x0e [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0f [Pin Complex] wcaps 0x400381: Stereo Digital
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=1
Connection: 1
0x0e
Codec: Realtek ALC1220
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec1168
Subsystem Id: 0x10438733
Revision Id: 0x100101
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC1220 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x3b 0x3b]
Converter: stream=5, channel=0
PCM:
rates [0x7e0]: 44100 48000 88200 96000 176400 192000
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC1220 Digital", type="SPDIF", device=1
Digital: Enabled
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x3f 0x3f]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC1220 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 8
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Amp-Out vals: [0x80 0x80]
Pincap 0x00000034: IN OUT Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=06, enabled=1
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=07, enabled=1
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Pin Default 0x40370000: [N/A] CD at Ext N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x20: IN
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In vals: [0x01 0x01]
Pincap 0x00003734: IN OUT Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19040: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=03, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pincap 0x0000373c: IN OUT HP Detect
Pin Default 0x02a19050: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40e7e629: [N/A] Reserved at Ext N/A
Conn = Analog, Color = White
DefAssociation = 0x2, Sequence = 0x9
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x01456130: [Jack] SPDIF Out at Ext Rear
Conn = Optical, Color = Orange
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=127
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17 0x12 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x57 0x57]
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
--endcollapse--
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x0c456367, ctrlif=2, ctlerr=0
Card: Sonix Technology Co., Ltd. USB 2.0 Camera at usb-0000:0d:00.3-2, high speed
Unit: 2
Control: name="Mic Capture Volume", index=0
Info: id=2, control=2, cmask=0x3, channels=2, type="S16"
Volume: min=-24320, max=0, dBmin=-9500, dBmax=0
Unit: 2
Control: name="Mic Capture Switch", index=0
Info: id=2, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
Volume: min=0, max=1, dBmin=0, dBmax=0
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-id:
total 0
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
Subdevices: 1/1
card 2: Camera [USB 2.0 Camera], device 0: USB Audio [USB Audio]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card HDMI
Card hw:0 'HDMI'/'HDA ATI HDMI at 0xfcca0000 irq 134'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100700'
Controls : 42
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!-------Mixer controls for card Generic
Card hw:1 'Generic'/'HD-Audio Generic at 0xfcb00000 irq 136'
Mixer name : 'Realtek ALC1220'
Components : 'HDA:10ec1168,10438733,00100101'
Controls : 47
Simple ctrls : 21
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 59 [68%] [-21.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Center',0
Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Mono: Playback [on]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 63 [100%] [30.00dB] [on]
Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Rear Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
Front Left: 1 [33%] [10.00dB]
Front Right: 1 [33%] [10.00dB]
!!-------Mixer controls for card Camera
Card hw:2 'Camera'/'Sonix Technology Co., Ltd. USB 2.0 Camera at usb-0000:0d:00.3-2, high speed'
Mixer name : 'USB Mixer'
Components : 'USB0c45:6367'
Controls : 4
Simple ctrls : 1
Simple mixer control 'Mic',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 256
Front Left: Capture 0 [0%] [-95.00dB] [off]
Front Right: Capture 128 [50%] [-47.50dB] [off]
!!Alsactl output
--startcollapse--
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value '100008006a100001000000000000000006b3d12441535553205641323445091707000000'
comment {
access 'read volatile'
type BYTES
count 36
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value '100008006a140001000000000000000006b3d12441535553205641323445091707000000'
comment {
type BYTES
count 36
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
comment {
type BYTES
count 36
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Generic {
control.1 {
iface MIXER
name 'Front Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Surround Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.4 {
iface MIXER
name 'Surround Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Center Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
control.6 {
iface MIXER
name 'LFE Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
control.7 {
iface MIXER
name 'Center Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Headphone Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.12 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
name 'Input Source'
value 'Rear Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.20 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Capture Volume'
value.0 63
value.1 63
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.22 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.23 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.24 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.25 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.26 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 1
value.1 1
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 1000
dbvalue.1 1000
control.27 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
comment {
access read
type IEC958
count 1
control.29 {
iface MIXER
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.31 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'Master Playback Volume'
value 59
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -2100
control.34 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Front Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
name 'Rear Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Line Out Front Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'Line Out Surround Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'Line Out CLFE Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.42 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.43 {
iface PCM
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
comment {
access read
type INTEGER
count 6
range '0 - 36'
control.44 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.46 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.47 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.Camera {
control.1 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.2 {
iface MIXER
name 'Mic Capture Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface MIXER
name 'Mic Capture Volume'
value.0 0
value.1 128
comment {
access 'read write'
type INTEGER
count 2
range '0 - 256'
dbmin -9500
dbmax 0
dbvalue.0 -9500
dbvalue.1 -4750
control.4 {
iface CARD
name 'Keep Interface'
value false
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
aesni_intel
agpgart
amdgpu
asus_wmi
battery
blake2b_generic
btrfs
cbc
ccp
cec
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dca
dm_crypt
dm_mod
drm
drm_kms_helper
drm_ttm_helper
drm_vram_helper
edac_mce_amd
eeepc_wmi
encrypted_keys
evdev
fat
fb_sys_fops
ftdi_sio
fuse
ghash_clmulni_intel
glue_helper
gpu_sched
hid
hid_generic
hid_uclogic
hwmon_vid
i2c_algo_bit
i2c_piix4
igb
inet_diag
input_leds
ip_tables
irqbypass
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libcrc32c
loop
mac_hid
mc
mousedev
msr
mxm_wmi
nct6775
nls_cp437
nls_iso8859_1
pcspkr
pinctrl_amd
raid6_pq
rapl
rc_core
rfkill
rng_core
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_rawmidi
snd_seq
snd_seq_device
snd_seq_dummy
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
sp5100_tco
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tcp_diag
tpm
trusted
ttm
uas
udp_diag
uinput
usb_storage
usbhid
uvcvideo
vboxdrv
vboxguest
vboxnetadp
vboxnetflt
vboxsf
vboxvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
xor
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
0x0f 0x585600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x411111f0
0x14 0x01014010
0x15 0x01011012
0x16 0x01016011
0x17 0x40370000
0x18 0x01a19040
0x19 0x02a19050
0x1a 0x0181304f
0x1b 0x02214020
0x1d 0x40e7e629
0x1e 0x01456130
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
