Hi! I’m having an issue on Firefox since some time. I am not able to receive input from my microphone, even though it asks me permission for it. However, I am able to use my microphone in every other app I have tested, including chromium, obs-studio and cheese. What could this be?
I like firefox better than other browser, it would be nice to not have to reinstall my whole system to use it.
I forgot to provide the output of inxi -Fza
~ >>> inxi -Fza
Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=ad907671-db3c-4d5f-87dc-99bf69229b6d rw quiet
udev.log_priority=3
Desktop: GNOME 3.36.4 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 14-cf0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 84B3 v: KBC Version 74.30 serial: <filter> UEFI: Insyde
v: F.42 date: 06/20/2019
ID-1: BAT0 charge: 36.9 Wh condition: 38.5/38.5 Wh (100%) volts: 13.2/11.6
model: HP Primary type: Li-ion serial: <filter> status: Charging
Topology: Dual Core model: Intel Core i3-7020U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10)
microcode: D6 L2 cache: 3072 KiB
bogomips: 18406
Speed: 821 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 864 2: 900
3: 857 4: 900
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus ID: 1-6:2 chip ID: 05c8:03ba
serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell
driver: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.7.14-1-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtl8723de v: v5.1.1.8_21285.20171026
port: 3000 bus ID: 03:00.0 chip ID: 10ec:d723
Local Storage: total: 931.51 GiB used: 59.00 GiB (6.3%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 29.05 GiB (29.7%) fs: ext4 dev: /dev/sda3
ID-2: /home raw size: 631.01 GiB size: 620.11 GiB (98.27%)
used: 29.94 GiB (4.8%) fs: ext4 dev: /dev/sda4
System Temperatures: cpu: 36.0 C mobo: 34.0 C gpu: amdgpu temp: 31 C
Processes: 258 Uptime: 1d 2h 22m Memory: 3.73 GiB used: 2.12 GiB (56.8%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1359 pacman: 1355
lib: 419 flatpak: 0 snap: 4 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.05
I do not have any idea on how to continue my search, I have reinstalled firefox many times, I have checked the system logs and have not encountered anything useful like missing packages or errors. Firefox just prompts me to use my microphone and then has no access to it, throwing no errors. The errors happened just after a system update, so I think it can be dependency-related but I can’t be sure.
I finally solved it. I did 2 things, and don’t know which fixed it:
I updated my system with today’s update
I removed the ~/.config/pulse
folder, then rebooted my computer (this is more likely to have solved it)
I’ll leave this answer here for if anyone encounters the same problem.
system
Closed
August 25, 2020, 5:09pm
#4
