I have setup Manjaro Linux 21.1.1 on my Ryzen 5 laptop. I have currently tried to tinker around with pulseaudio to figure out the issue, but I still am not able to get my microphone to work. My speakers are working normally but I can’t figure out the issue with my microphone. Any pointers to fix the issue would be really helpful
Generic driver will not work. You will likely need to find the right chipset driver made by realtek…etc if there is one, in AUR repo, and install it manually.
I’d boot into Windows and check under device manager/ sound and see what the chipset is or check your manufacture’s website and then find the correct Linux driver
Data in post #5 shows system has a Realtek ALC236 audio codec
Device is recognised in post #10 system data as Device-3: AMD Family 17h HD Audio
and is using the correct Linux audio driver snd_hda_intel
Kernel v5.13 is no longer supported in Manjaro repositories
I suggest you install kernel v5.15 using Manjaro Settings Manager GUI
( manjaro-settings-manager -m msm_kernel )
OR use these terminal commands to install new kernel and remove old one
sudo mhwd-kernel --install linux515
sudo mhwd-kernel --remove linux513
When you have rebooted to system to load the new kernel, please post more information about ALSA settings for audio device
