Microphone not working on Manjaro KDE Plasma (beginner needing guidance)
Hello, I consider myself a beginner in Linux, although I’ve used it in the past on another laptop, but that’s not really relevant. The point is that I’m currently using another, somewhat older device (in my view).
I was on Windows 10, but due to recent events and because I want to learn and improve my skills with operating systems, I returned after a few years to Manjaro KDE Plasma.
The problem is that everything works except my microphone. I got tired of searching for something that would solve the issue in a way I could understand. I don’t want to take a drastic step like going back to Windows 10. Besides that, I genuinely like the platform and want to use it to better understand the Linux experience.
Sorry if the text also sounds confusing, I ask for a bit of patience with me. I’m a bit afraid of being criticized because of my lack of knowledge. If possible, could you help me and guide me in learning and understanding this Linux distribution?
Please forgive me for any mistakes in my English, as I am not a native speaker.
Welcome to the Manjaro community @Linux_Noobr
Regarding your microphone issue, some detailed system information would be helpful. Please read through the following pre-prepared instructions:
As a new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
inxi --filter --verbosity=8
inxi -zv8
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: :point_down:
[MiniHowTo] Present code or command output
  • for example, typing: `code here` will display the text as code here.
What is a Quark?
You should be fine as long as you follow instructions provided by the helpers here, and provide information such as command output or logs if requested. After all, we were all newbies once-upon-a-time.
Although the volunteers are always happy to help, it should also be noted that the Forum Rules - Manjaro specifically include the section Life is a Two-way Street, which includes the following sentences:
That means browsing the forum and using the search feature to see if an issue identical or similar to yours already has a solution. Also, the following 2 wikis are very useful:
Anyway, make sure you provide the inxi -zv8 output and hopefully one of the forum’s audio experts will be able to help you.
Hello, thank you for your response.
I ran the command you requested and here is the output:
 ~  inxi -zv8         ✔
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=ae51146c-5a23-42b4-ba59-415a19063a24 rw rootflags=subvol=@
    quiet splash snd_hda_intel.dmic_detect=0
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Laptop System: Acer product: Aspire E1-431 v: V1.17
    serial: <superuser required>
  Mobo: Acer model: EA40_HC v: Type2 - Board Version
    serial: <superuser required> part-nu: Type1Sku0 uuid: <superuser required>
    Firmware: UEFI-[Legacy] vendor: Insyde v: 1.17 date: 04/25/2012
  System RAM: total: 8 GiB available: 7.59 GiB used: 2.01 GiB (26.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Nanya Technology part-no: NT4GC64B8HG0NS-CG serial: <filter>
  Device-2: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: N/A part-no: SH564128FH8NZPHSCR serial: <filter>
  Info: model: Intel Core i3-3110M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1437 min/max: 1200/2400 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1437 2: 1437 3: 1437 4: 1437 bogomips: 19156
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
    xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 3rd Gen Core processor Graphics
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-7
    process: Intel 22nm built: 2012-13 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
    class-ID: 0300
  Device-2: Sunplus Innovation HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:3 chip-ID: 1bcf:2c18
    class-ID: 0e02
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
  Monitor-1: LVDS-1 model: LG Display 0x02f8 built: 2010 res: mode: 1366x768
    hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2 chroma: red: x: 0.616 y: 0.353
    green: x: 0.333 y: 0.588 blue: x: 0.149 y: 0.102 white: x: 0.314 y: 0.329
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
    drv: crocus x11: drv: crocus
  API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4000 (IVB GT2) driver: mesa intel v: 26.0.2-arch1.1
    device-ID: 8086:0166 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 04:00.2 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp4s0f2 state: down mac: <filter>
  Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
    vendor: Foxconn driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 14e4:4727 class-ID: 0280
  IF-ID-1: wlp9s0b1 state: up mac: <filter>
  IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
  Local Storage: total: 1.13 TiB used: 6.71 GiB (0.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 05A3 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04ABF100
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 3F scheme: MBR
  ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
    used: 6.71 GiB (3.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: ae51146c-5a23-42b4-ba59-415a19063a24
  ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  ID-3: /var/cache raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  ID-4: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
  ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: vfat label: BACKUP
    uuid: 181B-3154
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.1:3 info: Sunplus Innovation HD Webcam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 1bcf:2c18 class-ID: 0e02
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.3:3 info: Silicon Labs USB OPTICAL MOUSE type: mouse
    chip-ID: 10c4:8108 class-ID: 0301
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1253 libs: 342 tools: pamac pm: flatpak pkgs: 0
    1: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://manjaro.grena.ge/stable/$repo/$arch
    4: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    8: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    10: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    11: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    12: https://linorg.usp.br/manjaro/stable/$repo/$arch
    13: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    14: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    15: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    16: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    18: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    19: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    20: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    22: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    23: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    24: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    25: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    26: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    27: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    28: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    29: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    30: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    31: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    32: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    33: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    34: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    35: https://manjaro.nic.cz/stable/$repo/$arch
    36: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    37: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    39: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    40: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    41: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    42: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    44: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    45: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    46: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    47: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    48: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    49: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    51: https://manjaro.mirror.ac.za/stable/$repo/$arch
    52: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    53: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    54: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    55: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    56: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    57: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    58: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    59: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    61: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    62: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    63: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    65: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    66: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    67: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    68: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    69: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    70: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    71: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    72: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    73: https://manjaro.ynh.ovh/stable/$repo/$arch
    74: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    75: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    76: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    77: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    78: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    79: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    80: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    81: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    83: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    84: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    85: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    86: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    87: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    88: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    89: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    90: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    91: https://mirrors2.manjaro.org/stable/$repo/$arch
    92: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    93: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    95: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    96: https://mirror.23m.com/manjaro/stable/$repo/$arch
    97: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    98: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    99: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    100: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    101: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    102: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    103: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    104: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    105: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    106: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    107: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    108: https://mirror.init7.net/manjaro/stable/$repo/$arch
    109: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    110: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    111: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    112: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    113: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    114: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    115: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    116: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    117: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    118: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    119: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    120: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    121: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    122: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    123: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    124: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    125: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 249
  1: cpu: 13.3% command: konsole pid: 2799 mem: 250.2 MiB (3.2%)
  2: cpu: 7.6% command: zsh pid: 2811 mem: 10.4 MiB (0.1%)
  3: cpu: 1.3% command: firefox pid: 1402 mem: 618.5 MiB (7.9%)
  4: cpu: 1.0% command: kwin_wayland pid: 638 mem: 241.2 MiB (3.1%)
  5: cpu: 1.0% command: firefox pid: 1703 mem: 449.1 MiB (5.7%)
  Memory top: 5 of 249
  1: mem: 618.5 MiB (7.9%) command: firefox pid: 1402 cpu: 1.3%
  2: mem: 449.1 MiB (5.7%) command: firefox pid: 1703 cpu: 1.0%
  3: mem: 393.0 MiB (5.0%) command: plasmashell pid: 783 cpu: 0.0%
  4: mem: 294.3 MiB (3.7%) command: firefox pid: 1715 cpu: 0.1%
  5: mem: 250.2 MiB (3.2%) command: konsole pid: 2799 cpu: 13.3%
  Processes: 249 Power: uptime: 2h 40m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 3.02 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Sorry for the long terminal output, I’m not sure if I was supposed to include everything.
Please let me know if you need any additional information.
Also, thank you for your patience — I am still learning Linux and I appreciate the help.
Microphone audio capture is usually not enabled by default, to avoid any audio feedback from speakers.
Audio capture can be enabled and capture level can be adjusted in ALSA mixer controls:
alsamixer --card=0 --view=Capture
Space to toggle CAPTURE on and off
and to increase/decrease level
Hello, thank you for informing me about this factor—I found it interesting. Anyway, I used the alsamixer command and selected my microphone (which I didn’t expect to be recognized by the system). I noticed that Mic Boost and Capture were at maximum, with only Internal Mic Boost set to 00. I tested whether changing it would help and set it to 100, but the problem still persists. I suspect that the system is probably using the internal microphone.
In any case, thank you for guiding me.
By the way, I installed Hardinfo 2 to check the input devices, and my external microphone was listed as “HDA Intel PCH Mic.” I’m not sure if this helps much—it was probably already mentioned in that list of important information about my machine (I say that because I saw something similar, or maybe I’m just overthinking it).
Thank you for your patience, and sorry for being a bit clumsy and for the somewhat confusing text—my English isn’t very good.
If this laptop has a single headset jack (headphone+microphone combined) it would require a splitter cable to use an external microphone
If there are separate headphone and microphone jacks, I suggest check the jack-detection is working for the microphone:
  1. install alsa-tools package:
    pamac install alsa-tools
  2. run the jack sensing tool with microphone disconnected
    sudo hdajacksensetest
  3. connect the microphone and run the command again
If jack-detection is working, test will show present = No when uplugged and present = Yes when plugged-in
If it shows present = No for both tests, jack-detection can be disabled to check if the audio connections from the microphone are working
If it shows present = Yes for both tests, check the jack visually to see if there is any dust or debris inside the jack connection
