When i plug in the microphone into a motherboard 3.5mm jack or in front, they just dont show, but i do see small sign of life on test sites but it never returns any voice on discord/zoom/slack.
When i plug in usb sound card, sound card shows but it doesnt work at all.
I have tried two kernels, (one older, one newer) and the problem persists. I have tried several commands from similar topics but i didnt want to try everything i see because i didnt want to make things worse.
If i plug in my webcam, that microphone works but picks up voice faintly. (I will plug off web cam when i provide Fazy)
Fazy:
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=9e40c458-fb8c-41c9-8473-df1d639a2bd6 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=e1098956-513c-4552-99e9-3066c75e8288 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B460M-HDV serial: <superuser required>
BIOS: American Megatrends v: P1.60 date: 06/23/2020
Info: model: Intel Pentium Gold G6405 bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3581 high: 4101 min/max: 800/4100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2193 2: 3932 3: 4100
4: 4101 bogomips: 32813
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: Micro-Star MSI driver: radeon v: kernel alternate: amdgpu pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DVI-I-1
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:683f class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa gpu: radeon
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DVI-I-1 mapped: DVI-0 model: Asus VS229 serial: <filter>
built: 2012 res: 1920x1080 hz: 60 dpi: 103 gamma: 1.2
size: 475x267mm (18.7x10.51") diag: 545mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD VERDE (LLVM 13.0.1 DRM 2.50 5.15.41-1-MANJARO)
v: 4.5 Mesa 22.0.4 direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.1:10 chip-ID: 08bb:2902
class-ID: 0300
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
bus-ID: 1-6:5 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
driver: btusb v: 0.8 bus-ID: 1-10.4:9 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.04 TiB used: 1.11 TiB (54.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Blast size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 12.2 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS723020BLA642
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: AA10 scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
used: 98.58 GiB (45.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
ID-3: /var/log raw-size: 214.77 GiB size: 214.77 GiB (100.00%)
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 38.0 C mobo: N/A gpu: radeon temp: 36.0 C
Processes: 236 Uptime: 25m wakeups: 0 Memory: 15.56 GiB
used: 2.02 GiB (13.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1543 pacman: 1528 lib: 475 flatpak: 0
snap: 15 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.16
pa-info
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.27 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'Master Playback Volume'
value 56
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -800
control.30 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.31 {
iface CARD
name 'Front Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.33 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.34 {
iface CARD
name 'Line Out Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.36 {
iface PCM
name 'Playback Channel Map'
value.0 3
value.1 4
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.37 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.38 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.39 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.40 {
iface MIXER
name 'Digital Capture Volume'
value.0 60
value.1 60
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 0
dbvalue.1 0
state.HDMI {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.Device {
control.1 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.2 {
iface PCM
value 0
comment {
access read
type INTEGER
count 1
range '0 - 36'
control.3 {
iface MIXER
name 'Mic Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.4 {
iface MIXER
name 'Mic Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 127'
dbmin 0
dbmax 2381
dbvalue.0 0
control.5 {
iface MIXER
name 'Speaker Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface MIXER
name 'Speaker Playback Volume'
value.0 44
value.1 44
comment {
access 'read write'
type INTEGER
count 2
range '0 - 151'
dbmin -2837
dbmax -6
dbvalue.0 -2013
dbvalue.1 -2013
control.7 {
iface MIXER
name 'Mic Capture Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'Mic Capture Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 16'
dbmin 0
dbmax 2381
dbvalue.0 0
control.9 {
iface MIXER
name 'Auto Gain Control'
value true
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
acpi_tad
aesni_intel
af_alg
algif_hash
algif_skcipher
amdgpu
blake2b_generic
bluetooth
bnep
btbcm
btintel
btrfs
btrtl
btusb
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm_ttm_helper
e1000e
ecdh_generic
ee1004
ff_memless
fuse
ghash_clmulni_intel
gpu_sched
i2c_i801
i2c_smbus
iTCO_vendor_support
iTCO_wdt
intel_cstate
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_tcc_cooling
intel_uncore
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
joydev
kvm
kvm_intel
ledtrig_audio
libcrc32c
loop
mac_hid
mc
mei
mei_hdcp
mei_me
mousedev
ns
ntfs3
parport
parport_pc
pcspkr
ppdev
qrtr
radeon
raid6_pq
rapl
rfcomm
rfkill
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_rawmidi
snd_seq_device
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
squashfs
ttm
uinput
usbhid
vboxdrv
vboxnetadp
vboxnetflt
video
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
xor
xpad
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x40000000
0x12 0x411111f0
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19030
0x19 0x02a19040
0x1a 0x0181303f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4026c629
0x1e 0x411111f0
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x03 0x185600f0
0x05 0x185600f0
0x07 0x185600f0
0x09 0x185600f0
0x0b 0x185600f0
0x0d 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
sudo dmesg | egrep -i ‘(snd|sound|sof)’ :
[ 0.190996] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.255112] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.255113] software IO TLB: mapped [mem 0x0000000098a75000-0x000000009ca75000] (64MB)
[ 0.886550] xor: measuring software checksum speed
[ 2.157304] usb 1-6: Manufacturer: ©Microsoft
[ 2.321205] usb 1-3.1: Product: USB PnP Sound Device
[ 2.341173] input: C-Media Electronics Inc. USB PnP Sound Device as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.3/0003:08BB:2902.0007/input/input12
[ 2.396009] hid-generic 0003:08BB:2902.0007: input,hidraw6: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound Device] on usb-0000:00:14.0-3.1/input3
[ 3.349484] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[ 3.383507] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[ 3.383545] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[ 3.383577] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[ 3.383608] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 3.383641] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 3.383672] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[ 3.406511] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 3.406516] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.406518] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.406520] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.406521] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.406522] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 3.406524] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 3.406525] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 3.479413] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 3.479448] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[ 3.479479] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 3.479508] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 3.479540] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 4.904329] usbcore: registered new interface driver snd-usb-audio
[ 1357.920343] usb 1-3.1: Product: USB PnP Sound Device
[ 1357.935670] input: C-Media Electronics Inc. USB PnP Sound Device as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1:1.3/0003:08BB:2902.0008/input/input25
[ 1357.991623] hid-generic 0003:08BB:2902.0008: input,hidraw6: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound Device] on usb-0000:00:14.0-3.1/input3
Any help?
