Microphone not available after switching setup
Hey everybody,
i regularly work with my laptop at two different locations (home office, office) with different loudspeakers / microphones. for some time now, i have had the problem that my microphone is no longer recognised when i change location - especially in teams and google meet, i can no longer select a microphone and therefore cannot participate in calls. after a system restart, everything is ok again until i change location again.
Does anyone have any ideas? the micro is listed in the system mixer and also shows a signal when I speak.
i would be grateful for any help - i can work in principle, but the constant restarts are really annoying
Thorsten
sudo inxi --verbosity=8 --filter --width         ✔
[sudo] Passwort für gatt:
  Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=0d218fb4-18ec-4775-b315-f5d84d155a8c rw quiet
    cryptdevice=UUID=93ce3209-9d45-4029-a341-11b51d505acc:luks-93ce3209-9d45-4029-a341-11b51d505acc
    root=/dev/mapper/luks-93ce3209-9d45-4029-a341-11b51d505acc splash
    resume=/dev/mapper/luks-4a65bb64-d328-4642-9981-d37a0cef521d
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Laptop System: LENOVO product: 20XF006GGE v: ThinkPad T14s Gen 2a
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20XF006GGE v: SDK0J40697 WIN serial: <filter>
    part-nu: LENOVO_MT_20XF_BU_Think_FM_ThinkPad T14s Gen 2a
    uuid: 6a109bcc-2c60-11b2-a85c-8c3f94f55343 UEFI: LENOVO v: R1NET56W (1.26)
    date: 02/21/2023
  ID-1: BAT0 charge: 57.0 Wh (100.0%) condition: 57.0/57.0 Wh (99.9%)
    volts: 16.4 min: 15.4 model: LGC 5B10W13976 type: Li-poly serial: <filter>
    status: full cycles: 32
  Device-1: hid-34:88:5d:ec:74:a3-battery model: Keyboard K380 serial: N/A
    charge: N/A status: discharging
  Device-2: hidpp_battery_3 model: Logitech Wireless Mouse MX Master 3
    status: discharging
  System RAM: total: 32 GiB available: 30.19 GiB used: 18.41 GiB (61.0%)
  Device-1: Channel-A DIMM 0 type: LPDDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4266 MT/s volts: min: 0.6 max: 0.6
    width (bits): data: 32 total: 32 manufacturer: Micron Technology
    part-no: MT53E2G32D4NQ-046 serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR4 detail: synchronous unbuffered
  Slot: 1 type: PCIe status: available info: J3600 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 2 type: PCIe status: available info: J3605 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 3 type: PCIe status: available info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:00.0
  Slot: 4 type: PCIe status: available info: J3702, M.2 length: long
  Slot: 5 type: PCIe status: available info: J3703, M.2 length: long
  Slot: 6 type: PCIe status: available info: J4000 length: long volts: 3.3
    bus-ID: 00:00.0
  Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1794 min/max: 400/4507 base/boost: 1900/4450 scaling:
    driver: amd-pstate-epp governor: powersave volts: 1.2 V ext-clock: 100 MHz
    cores: 1: 1794 2: 1794 3: 1794 4: 1794 5: 1794 6: 1794 7: 1794 8: 1794
    9: 1794 10: 1794 11: 1794 12: 1794 13: 1794 14: 1794 15: 1794 16: 1794
    bogomips: 60705
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-4,DP-6,eDP-1
    empty: DP-1, DP-2, DP-7, HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 35.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 13d3:5405
  Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.1.3.4:17
    chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 7680x3240 s-dpi: 96 s-size: 2030x856mm (79.92x33.70")
    s-diag: 2203mm (86.74") monitors: <missing: xrandr>
  Monitor-1: DP-4 model: ASUS VG289 serial: <filter> built: 2022
    res: 3840x2160 dpi: 157 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green:
    x: 0.267 y: 0.620 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
    size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900,
    1280x960, 1280x800, 1280x720, 1440x576, 1024x768, 1440x480, 800x600,
    720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
    unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
    unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 97 6: parse_edid:
    unhandled CEA mode 72
  Monitor-2: DP-6 model: ASUS VG289 serial: <filter> built: 2021
  Monitor-3: eDP-1 model: AU Optronics 0x573d built: 2018 res: 1920x1080
    dpi: 158 gamma: 1.2 chroma: red: x: 0.647 y: 0.329 green: x: 0.302 y: 0.604
    blue: x: 0.153 y: 0.055 white: x: 0.314 y: 0.329
    size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.54 6.6.54-2-MANJARO) device-ID: 1002:1638
    memory: 1000 MiB unified: no
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.4-arch1.0.1
    device-ID: 1002:1638 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: GN Netcom Jabra SPEAK 510 USB driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1.2:14
    chip-ID: 0b0e:0422 class-ID: 0300 serial: <filter>
  Device-5: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
  Device-6: Lenovo ThinkPad USB-C Dock Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-1.2:13 chip-ID: 17ef:30b0 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.1:6
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp6s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wwan0 state: down mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 8087:0029
    class-ID: e001
  Device-1: luks-93ce3209-9d45-4029-a341-11b51d505acc maj-min: 254:0
    type: LUKS dm: dm-0 size: 920.36 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 920.36 GiB
  Device-2: luks-4a65bb64-d328-4642-9981-d37a0cef521d maj-min: 254:1
    type: LUKS dm: dm-1 size: 33.21 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 33.21 GiB
  Local Storage: total: 953.87 GiB used: 178.98 GiB (18.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBQNTY-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 11170101 temp: 30.9 C scheme: GPT
  SMART: yes health: PASSED on: 161d 1h cycles: 15,348
    read-units: 87,557,610 [44.8 TB] written-units: 44,676,434 [22.8 TB]
  ID-1: / raw-size: 920.36 GiB size: 904.84 GiB (98.31%)
    used: 178.97 GiB (19.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-93ce3209-9d45-4029-a341-11b51d505acc label: N/A
    uuid: 0d218fb4-18ec-4775-b315-f5d84d155a8c
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: CB29-D79A
  ID-1: swap-1 type: partition size: 33.21 GiB used: 4 MiB (0.0%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-4a65bb64-d328-4642-9981-d37a0cef521d label: swap
    uuid: d93910d8-3bc2-4a05-a93f-10bd87125297
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 1-2:2 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5405 class-ID: fe01 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-4: 3-1:11 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30af
  Hub-5: 3-1.1:12 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ac
  Device-1: 3-1.1.2:14 info: GN Netcom Jabra SPEAK 510 USB type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
  Hub-6: 3-1.1.3:16 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ae
  Device-1: 3-1.1.3.4:17 info: Microdia USB 2.0 Camera type: video,audio
  Device-2: 3-1.2:13 info: Lenovo ThinkPad USB-C Dock Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:30b0 class-ID: 0300 serial: <filter>
  Device-3: 3-1.3:15 info: Lenovo 40AY type: billboard driver: N/A
    chip-ID: 17ef:30a9 class-ID: 1100 serial: <filter>
  Device-4: 3-3:3 info: Alcor Micro AU9540 Smartcard Reader type: smart card
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 50mA chip-ID: 058f:9540 class-ID: 0b00
  Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 4-1:5 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ab
  Device-1: 4-1.1:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  Hub-9: 4-1.3:7 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30ad
  Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
  Device-2: 5-4:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: 1513 pm: pacman pkgs: 1498 libs: 430 tools: pamac,yay pm: flatpak
    pkgs: 0 pm: snap pkgs: 15
    1: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    4: https://mirror.init7.net/manjaro/stable/$repo/$arch
    5: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    8: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    10: http://manjaro.grena.ge/stable/$repo/$arch
    11: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    12: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    13: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    14: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    15: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    17: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    18: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    19: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    20: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    22: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    23: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    24: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    25: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    26: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    27: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    28: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    29: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    30: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    33: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    34: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    35: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    36: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    37: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    38: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    39: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    40: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    41: https://manjaro.kurdy.org/stable/$repo/$arch
    42: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    43: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    44: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    45: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    46: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    47: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    48: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    49: https://mirrors2.manjaro.org/stable/$repo/$arch
    50: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    51: http://manjaro.mirror.ac.za/stable/$repo/$arch
    52: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    53: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    54: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    55: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    56: https://linorg.usp.br/manjaro/stable/$repo/$arch
    57: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    58: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    59: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    60: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    61: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    62: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    63: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    64: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    65: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    66: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    67: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    68: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    69: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    70: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    71: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    72: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    73: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    74: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    75: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    76: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    77: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    79: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    80: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    81: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    82: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    83: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    84: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    85: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    86: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    87: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    88: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    89: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    91: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    92: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    93: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    94: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    95: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    96: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    97: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    98: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    99: https://mirror.23m.com/manjaro/stable/$repo/$arch
    100: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    101: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    102: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    103: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    104: https://manjaro.ynh.ovh/stable/$repo/$arch
    105: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    106: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    107: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    108: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    109: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    111: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    112: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    113: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    114: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    115: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    116: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    117: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    118: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    119: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    120: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    121: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 502
  1: cpu: 13.9% command: kwin_x11 pid: 1641 mem: 256.3 MiB (0.8%)
  2: cpu: 10.6% command: Xorg pid: 1484 mem: 123.6 MiB (0.3%)
  3: cpu: 5.9% command: brave pid: 2691 mem: 947.6 MiB (3.0%)
  4: cpu: 3.6% command: brave pid: 11900 mem: 649.8 MiB (2.1%)
  5: cpu: 2.8% command: brave pid: 2461 mem: 301.6 MiB (0.9%)
  Memory top: 5 of 502
  1: mem: 947.6 MiB (3.0%) command: brave pid: 2691 cpu: 5.9%
  2: mem: 841.2 MiB (2.7%) command: spectacle pid: 8773 cpu: 0.5%
  3: mem: 649.8 MiB (2.1%) command: brave pid: 11900 cpu: 3.6%
  4: mem: 581.3 MiB (1.8%) command: brave pid: 2408 cpu: 1.5%
  5: mem: 521.9 MiB (1.6%) command: plasmashell pid: 1691 cpu: 0.5%
  Processes: 502 Power: uptime: 12h 59m states: freeze,mem,disk suspend: s2idle
    wakeups: 3 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 12.06 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
It might be possible to get microphone working after changing location, and audio devices, by restarting audio server
systemctl --user restart pulseaudio
Previous topic from May was resolved by seting the Jabra USB speakerphone as the default-source
Jabra 510 microphone not working
To set Jabra microphone as default-source
pactl set-default-source alsa_input.usb-0b0e_Jabra_SPEAK_510_USB_501AA5DC007F022000-00.mono-fallback
If that device is unplugged to change location, system will use another available source as the default-source
I suggest use this command to find the correct name of the other microphone source
pactl list sources short | grep -v monitor
If the other microphone source is the Logitech headset shown in previous topic, and the source name has not changed
pactl set-default-source alsa_input.usb-Logitech_Zone_Vibe_125_2215MH00URA8-00.mono-fallback
OR
Install pulsemixer to change the default-source
Hi nikgnomic,
thank you so much for your support. I finally have the chance to test your approaches after some travels in the last days. Now I face my issue again - and here is what your commands bring:
pactl list sources short | grep -v monitor         ✔
5       alsa_input.usb-0b0e_Jabra_SPEAK_510_USB_501AA5DC007F022000-00.mono-fallback     module-alsa-card.c      s16le 1ch 16000Hz       SUSPENDED
8       alsa_input.pci-0000_06_00.6.HiFi__Mic2__source  module-alsa-card.c      s16le 2ch 44100Hz       SUSPENDED
9       alsa_input.pci-0000_06_00.6.HiFi__Mic1__source  module-alsa-card.c      s32le 2ch 48000Hz       SUSPENDED
after I restarted pulse audio…
After I switched the default, it changes to “Idle” - but still is not selectable in Teams…
pactl set-default-source alsa_input.usb-0b0e_Jabra_SPEAK_510_USB_501AA5DC007F022000-00.mono-fallback                        ✔
    ~  systemctl --user restart pulseaudio         INT ✘
    ~  pactl list sources short | grep -v monitor         ✔
5       alsa_input.usb-0b0e_Jabra_SPEAK_510_USB_501AA5DC007F022000-00.mono-fallback     module-alsa-card.c      s16le 1ch 16000Hz       IDLE
8       alsa_input.pci-0000_06_00.6.HiFi__Mic2__source  module-alsa-card.c      s16le 2ch 44100Hz       IDLE
9       alsa_input.pci-0000_06_00.6.HiFi__Mic1__source  module-alsa-card.c      s32le 2ch 48000Hz       IDLE
Maybe you have some more ideas? Thanks in advance and have a nice eve,
Thorsten
Data in post #4 shows all 3 audio sources are suspended, so system might be suspending audio devices when changing location, or devices might just be suspended when idle and not in use
to check reason for device suspend:
pactl list sources
to de-suspend all sinks and sources if they have were suspended when changing location by suspending/hibernating system
pactl suspend 0
I don’t use MS Teams, but it should have an option to use default device for microphone input (PulseAudio default-source), so the default-source can be configured automatically, or source can be selected in KDE GUI controls
If a named audio device is selected in VOIP settings, the VOIP software might create a direct connection to ALSA device (bypassing PulseAudio) but audio settings are more likely to fail if device is already connected to PulseAudio
to check connection from PulseAudio source to audio applications
pactl list source-outputs
or check audio sources in KDE GUI controls
to check if USB device is set as the default-source
pactl get-default-sink
Thank you, @nikgnomic - I will try again as soon as problem is back (right now all is running). I should have been more precise: the micro seems to be disables (not available) in all applications or browsers at least - I use teams in Browser (tried several) and the problem occurs also for google meet (also browser video calls) and I tried default audio settings as well as specifically selected Jabra Output… It is always the same picture…
Good morning. Here now the output of list sources after location change:
pactl list sources         ✔
Quelle #0
        Status: SUSPENDED
        Beschreibung: Monitor of Family 17h/19h HD Audio Controller Speaker
        Treiber: module-alsa-card.c
        Abtastwert-Angabe: s16le 2ch 48000Hz
        Kanalzuordnung: front-left,front-right
        Besitzer-Modul: 9
        Stumm: nein
        Lautstärke: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
                Verteilung 0,00
        Basis-Lautstärke: 65536 / 100% / 0,00 dB
        Ziel-Monitor: alsa_output.pci-0000_06_00.6.HiFi__Speaker__sink
        Latenz: 0 usec, eingestellt 0 usec
        Flags: DECIBEL_VOLUME LATENCY
        Eigenschaften:
                device.description = "Monitor of Family 17h/19h HD Audio Controller Speaker"
                device.class = "monitor"
                alsa.card = "1"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xfd3c0000 irq 121"
                device.bus_path = "pci-0000:06:00.6"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card1"
                device.bus = "pci"
                device.vendor.id = "1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                device.product.id = "15e3"
                device.product.name = "Family 17h/19h HD Audio Controller"
                device.string = "1"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Formate:
                pcm
Quelle #1
        Status: SUSPENDED
        Beschreibung: Family 17h/19h HD Audio Controller Headphones Stereo Microphone
        Abtastwert-Angabe: s16le 2ch 44100Hz
        Besitzer-Modul: 9
        Stumm: nein
        Lautstärke: front-left: 65540 / 100% / 0,00 dB,   front-right: 65540 / 100% / 0,00 dB
                Verteilung 0,00
        Basis-Lautstärke: 6554 /  10% / -60,00 dB
        Ziel-Monitor: k. A.
        Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
        Eigenschaften:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "ALC257 Analog"
                alsa.id = "ALC257 Analog"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "1"
                device.bus = "pci"
                device.string = "_ucm0003.hw:Generic_1"
                device.buffering.buffer_size = "352768"
                device.buffering.fragment_size = "176384"
                device.access_mode = "mmap+timer"
                device.profile.name = "HiFi: Mic2: source"
                device.profile.description = "Headphones Stereo Microphone"
                alsa.mixer_device = "_ucm0003.hw:Generic_1"
                device.description = "Family 17h/19h HD Audio Controller Headphones Stereo Microphone"
        Ports:
                [In] Mic2: Headphones Stereo Microphone (Typ: Mikro, Priorität: 200, nicht verfügbar)
        Aktiver Port: [In] Mic2
        Formate:
                pcm
Quelle #2
        Status: SUSPENDED
        Beschreibung: Family 17h/19h HD Audio Controller Digital Microphone
        Abtastwert-Angabe: s32le 2ch 48000Hz
        Besitzer-Modul: 9
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: k. A.
        Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY
        Eigenschaften:
                alsa.resolution_bits = "32"
                device.api = "alsa"
                alsa.name = ""
                alsa.id = "DMIC capture dmic-hifi-0"
                alsa.device = "0"
                alsa.card = "3"
                alsa.card_name = "acp"
                alsa.long_card_name = "LENOVO-20XF006GGE-ThinkPadT14sGen2a"
                alsa.driver_name = "snd_acp3x_rn"
                device.bus_path = "pci-0000:06:00.5-platform-acp_pdm_mach.0"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.5/acp_pdm_mach.0/sound/card3"
                device.bus = "pci"
                device.product.id = "15e2"
                device.product.name = "ACP/ACP3X/ACP6x Audio Coprocessor"
                device.string = "_ucm0003.hw:acp"
                device.buffering.buffer_size = "32768"
                device.buffering.fragment_size = "8192"
                device.profile.name = "HiFi: Mic1: source"
                device.profile.description = "Digital Microphone"
                device.description = "Family 17h/19h HD Audio Controller Digital Microphone"
        Ports:
                [In] Mic1: Digital Microphone (Typ: Mikro, Priorität: 100, Verfügbarkeit unbekannt)
        Aktiver Port: [In] Mic1
        Formate:
                pcm
Quelle #3
        Status: SUSPENDED
        Beschreibung: Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 4 Output
        Besitzer-Modul: 7
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.pci-0000_06_00.1.HiFi__HDMI4__sink
        Eigenschaften:
                device.description = "Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 4 Output"
                alsa.card = "0"
                alsa.long_card_name = "HD-Audio Generic at 0xfd3c8000 irq 120"
                device.bus_path = "pci-0000:06:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.1/sound/card0"
                device.bus = "pci"
                device.vendor.id = "1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "1637"
                device.product.name = "Renoir Radeon High Definition Audio Controller"
                device.string = "0"
        Formate:
                pcm
Quelle #4
        Status: SUSPENDED
        Beschreibung: Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 3 Output
        Besitzer-Modul: 7
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.pci-0000_06_00.1.HiFi__HDMI3__sink
        Eigenschaften:
                device.description = "Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 3 Output"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formate:
                pcm
Quelle #5
        Status: SUSPENDED
        Beschreibung: Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 2 Output
        Besitzer-Modul: 7
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.pci-0000_06_00.1.HiFi__HDMI2__sink
        Eigenschaften:
                device.description = "Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 2 Output"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formate:
                pcm
Quelle #6
        Status: SUSPENDED
        Beschreibung: Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 1 Output
        Besitzer-Modul: 7
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.pci-0000_06_00.1.HiFi__HDMI1__sink
        Eigenschaften:
                device.description = "Monitor of Renoir Radeon High Definition Audio Controller HDMI / DisplayPort 1 Output"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formate:
                pcm
Quelle #7
        Status: SUSPENDED
        Name: alsa_output.usb-Lenovo_ThinkPad_USB-C_Dock_Audio_000000000000-00.analog-stereo.monitor
        Beschreibung: Monitor of ThinkPad USB-C Dock Audio Analog Stereo
        Besitzer-Modul: 25
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.usb-Lenovo_ThinkPad_USB-C_Dock_Audio_000000000000-00.analog-stereo
        Eigenschaften:
                device.description = "Monitor of ThinkPad USB-C Dock Audio Analog Stereo"
                alsa.card = "2"
                alsa.card_name = "ThinkPad USB-C Dock Audio"
                alsa.long_card_name = "Lenovo ThinkPad USB-C Dock Audio at usb-0000:06:00.3-1.2, full speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "pci-0000:06:00.3-usb-0:1.2:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-1/3-1.2/3-1.2:1.0/sound/card2"
                udev.id = "usb-Lenovo_ThinkPad_USB-C_Dock_Audio_000000000000-00"
                device.bus = "usb"
                device.vendor.id = "17ef"
                device.vendor.name = "Lenovo"
                device.product.id = "30b0"
                device.product.name = "ThinkPad USB-C Dock Audio"
                device.serial = "Lenovo_ThinkPad_USB-C_Dock_Audio_000000000000"
                device.string = "2"
                device.icon_name = "audio-card-usb"
        Formate:
                pcm
Quelle #8
        Status: SUSPENDED
        Beschreibung: Monitor of Jabra Link 380 Digital Stereo (IEC958)
        Besitzer-Modul: 26
        Stumm: nein
                Verteilung 0,00
        Ziel-Monitor: alsa_output.usb-0b0e_Jabra_Link_380_305075ED437C-00.iec958-stereo
        Eigenschaften:
                device.description = "Monitor of Jabra Link 380 Digital Stereo (IEC958)"
                alsa.card = "4"
                alsa.card_name = "Jabra Link 380"
                alsa.long_card_name = "Jabra Link 380 at usb-0000:06:00.3-1.1.3.4.1, full speed"
                device.bus_path = "pci-0000:06:00.3-usb-0:1.1.3.4.1:1.0"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.4/3-1.1.3.4.1/3-1.1.3.4.1:1.0/sound/card4"
                udev.id = "usb-0b0e_Jabra_Link_380_305075ED437C-00"
                device.bus = "usb"
                device.vendor.id = "0b0e"
                device.vendor.name = "GN Netcom"
                device.product.id = "24c9"
                device.product.name = "Jabra Link 380"
                device.serial = "0b0e_Jabra_Link_380_305075ED437C"
                device.string = "4"
        Formate:
                pcm
Quelle #9
        Status: SUSPENDED
        Beschreibung: Jabra Link 380 Mono
        Abtastwert-Angabe: s16le 1ch 16000Hz
        Kanalzuordnung: mono
        Besitzer-Modul: 26
        Stumm: nein
        Lautstärke: mono: 34181 /  52% / -16,96 dB
                Verteilung 0,00
        Basis-Lautstärke: 46396 /  71% / -9,00 dB
        Ziel-Monitor: k. A.
        Eigenschaften:
                device.api = "alsa"
                alsa.name = "USB Audio"
                alsa.id = "USB Audio"
                alsa.device = "0"
                alsa.card = "4"
                device.bus = "usb"
                device.string = "hw:4"
                device.buffering.buffer_size = "64000"
                device.buffering.fragment_size = "32000"
                device.profile.name = "mono-fallback"
                device.profile.description = "Mono"
                device.description = "Jabra Link 380 Mono"
        Ports:
                analog-input-mic: Mikrofon (Typ: Mikro, Priorität: 8700, Verfügbarkeit unbekannt)
        Aktiver Port: analog-input-mic
        Formate:
                pcm
list source-outputs has no hits - default sink delivers the correct aoudio device…
the suspend 0 command does not work for me…?
pactl suspend 0         ✔
Kein gültiger Befehl angegeben.
Any ideas left?
Thanks in advance - and a great day!
Thorsten
Remove PulseAudio module module-suspend-on-idle temporarily
pactl unload-module module-suspend-on-idle
and check suspend state of audio sources
pacmd dump | grep 'suspend-source alsa_input.usb'
If the response shows USB source is still suspended:
suspend-source alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback ja
Use this command to de-suspend the source
pactl suspend-sink alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback 0
If the response shows USB source is not suspended:
suspend-source alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback nein
and microphone is still not working as expected, install PulseAudio Volume Control
pamac install pavucontrol-qt
Open pavucontrol Configuration tab
pavucontrol --tab=5
pavucontrol-qt --tab=5
Change all card Profiles to Aus (Off)
and then change Profile for Jabra USB headset to Analog Stereo-Ausgabe+Mono-Eingang
(Analog Stereo-Output+Mono-Input)
and finally, check the Eingang (Input Devices) tab to see if USB microphone is working in audio level meters
Moin @nikgnomic
it does not seem to work to de-suspend the Jabra speakers…
1       alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback        module-alsa-card.c      s16le 1ch 16000Hz       SUSPENDED
4       alsa_input.pci-0000_06_00.6.HiFi__Mic2__source  module-alsa-card.c      s16le 2ch 44100Hz       SUSPENDED
5       alsa_input.pci-0000_06_00.6.HiFi__Mic1__source  module-alsa-card.c      s32le 2ch 48000Hz       SUSPENDED
    ~  pactl unload-module module-suspend-on-idle         ✔
    ~  pacmd dump | grep 'suspend-source alsa_input.usb'         ✔
suspend-source alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback no
    ~  pactl suspend-sink alsa_input.usb-0b0e_Jabra_Link_380_305075ED437C-00.mono-fallback 0                                       ✔
Fehlgeschlagen: Entität nicht vorhanden
I really appreciate your help and patience here - thank you so much;-)
Best Thorsten
… and the pavucontrol does not work for me either… ?
pamac install pavucontrol-qt         1 ✘
Vorbereitung...
Eine Authentifizierung ist erforderlich, um Pakete zu installieren, aktualisieren oder zu entfernen
Authenticating as: Dr. Thorsten Gather (gatt)
Password:
Synchronisiere Paketdatenbanken...
Aktualisierung von AUR...
Warnung: plymouth: Lokale Version (24.004.60-6) ist neuer als extra (22.02.122-18)
Abhängigkeiten werden aufgelöst...
Interne Konflikte werden überprüft...
Zu aktualisieren (1):
  archlinux-keyring  20241203-1  (20241015-1)  core   1,2 MB
Wird installiert (1):
  pavucontrol-qt     2.1.0-1                   extra  159,9 KB
Download-Größe gesamt: 1,4 MB
Gesamtgröße installiert: 982,0 KB
Transaktion anwenden ? [j/N] j
Herunterladen von archlinux-keyring (20241203-1) gestartet
Herunterladen von archlinux-keyring (20241203-1) beendet
Überprüfe Schlüsselring...        [1/1]
Integrität wird überprüft...        [1/1]
Paketdateien werden geladen...        [1/1]
Dateikonflikte werden überprüft...        [1/1]
Überprüfe verfügbaren Speicherplatz...        [1/1]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Erneuere archlinux-keyring (20241015-1 -> 20241203-1)...        [1/1]
==> Füge Schlüssel aus archlinux.gpg hinzu...
==> Aktualisiere Trust-Datenbank...
gpg: nächste "Trust-DB"-Pflichtüberprüfung am 2025-01-01
Starte Post-Transaction-Hooks...
Reloading system manager configuration...        [1/3]
Arming ConditionNeedsUpdate...        [2/3]
Refreshing PackageKit...        [3/3]
Herunterladen von pavucontrol-qt (2.1.0-1) gestartet
Herunterladen von pavucontrol-qt (2.1.0-1) beendet
Installiere pavucontrol-qt (2.1.0-1)...        [1/1]
Arming ConditionNeedsUpdate...        [1/3]
Refreshing PackageKit...        [2/3]
Updating the desktop file MIME type cache...        [3/3]
Vorgang erfolgreich abgeschlossen.
    ~  pavucontrol --tab=5         ✔  22s 
zsh: command not found: pavucontrol
Try:
that works - thanks.
If this indeed works, could I suggest you click the [✓] to mark Scotty’s post as the Solution? :wink:
so far this only works to show the control - I have to check the approach next time I switch location now… but I will definitely mark the post afterwards
In the end that seems to work… Since I have the pavucontrol-qt my mic remains available. Thank you guys so much!
