Hello
Basically, all sound is being redirected to my microphone. It also happens when i simply unplug it and mute it on my headphones, turn on music and check the recording in audacity
It also happens on Discord and in live environment, so I guess I haven’t messed anything up in config files
I tried to change loopback mixing
in alsamixer but nothing changed
Muting Capture
and unmuting Capture 1
didn’t help either (it muted my microphone)
I don’t know if it’s going to be helpful, but I’m providing these here:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=637eabac-6629-4b85-a85f-7fa4ef867557 rw apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: H110M-K v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 4210 date: 06/25/2019
RAM: total: 7.72 GiB used: 7.24 GiB (93.8%)
Info: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: DE cache: L2: 6 MiB
bogomips: 24008
Speed: 3393 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3393 2: 3363
3: 3385 4: 3370
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ASUSTeK driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c02
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 2.26 TiB used: 236.61 GiB (10.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: KIOXIA model: EXCERIA SATA SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 15.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
rotation: 7200 rpm serial: <filter> rev: CC26 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GP57EB40 rev: PF00
dev-links: cdrom
ID-1: / raw-size: 120.12 GiB size: 117.68 GiB (97.97%)
used: 83.13 GiB (70.6%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 637eabac-6629-4b85-a85f-7fa4ef867557
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 27.7 MiB (29.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 20D9-6A55
ID-3: /mnt/Win10 raw-size: 287.32 GiB size: 287.32 GiB (100.00%)
used: 153.46 GiB (53.4%) fs: fuseblk dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 50600E50600E3CEA
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: zram size: 8 GiB used: 6.74 GiB (84.3%) priority: -2
dev: /dev/zram0
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: <superuser required>
label: Odzyskiwanie uuid: 2EEED788EED746AD
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-4: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: <superuser required>
label: Dysk 2TB uuid: 66E038ADE0388579
Device-1: 1-3:2 info: Holtek E-Signal LUOM G10 Mechanical Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 04d9:a09f class-ID: 0300
Device-2: 1-4:3 info: China Resource Semico USB Keyboard type: Keyboard
power: 100mA chip-ID: 1a2c:40bc class-ID: 0301
Device-3: 1-8:4 info: MediaTek Slim Portable DVD Writer type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0e8d:1887 class-ID: 0802 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: 27.8 C gpu: nvidia temp: 52 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 272 Uptime: 6h 26m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1430 lib: 401
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
Alsa info script:
!!ALSA Information Script v 0.5.0
!!Script ran on: Thu Jul 8 16:30:40 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: System manufacturer
Product Name: System Product Name
Product Version: System Version
Firmware Version: 4210
System SKU: SKU
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: H110M-K
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/LNXPOWER:08/status 1
/sys/bus/acpi/devices/LNXPOWER:09/status 1
/sys/bus/acpi/devices/LNXPOWER:0a/status 1
/sys/bus/acpi/devices/LNXPOWER:0b/status 1
/sys/bus/acpi/devices/LNXPOWER:0c/status 1
/sys/bus/acpi/devices/LNXPOWER:0d/status 1
/sys/bus/acpi/devices/LNXPOWER:0e/status 1
/sys/bus/acpi/devices/LNXPOWER:0f/status 1
/sys/bus/acpi/devices/LNXPOWER:10/status 1
/sys/bus/acpi/devices/LNXPOWER:11/status 1
/sys/bus/acpi/devices/LNXPOWER:12/status 1
/sys/bus/acpi/devices/LNXPOWER:13/status 1
/sys/bus/acpi/devices/LNXPOWER:14/status 1
/sys/bus/acpi/devices/LNXPOWER:15/status 1
/sys/bus/acpi/devices/LNXPOWER:16/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 15
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:06/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/device:68/status 15
/sys/bus/acpi/devices/device:7a/status 11
!!Kernel Information
Kernel release: 5.10.42-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.42-1-MANJARO
Library version: 1.2.5
Utilities version: 1.2.5
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - No
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xf7220000 irq 128
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xf7080000 irq 17
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
Subsystem: ASUSTeK Computer Inc. Device [1043:86c7]
01:00.1 Audio device [0403]: NVIDIA Corporation GP106 High Definition Audio Controller [10de:10f1] (rev a1)
Subsystem: ASUSTeK Computer Inc. Device [1043:85ed]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
|-- controlC0
| |-- dev
| |-- device -> ../../card0
| |-- power
| |-- subsystem -> ../../../../../../class/sound
| `-- uevent
|-- device -> ../../../0000:00:1f.3
|-- hwC0D0
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- driver_pin_configs
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- id
|-- input15
| |-- capabilities
| |-- event14
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- subsystem -> ../../../../../../class/input
| |-- uevent
| `-- uniq
|-- input16
| |-- capabilities
| |-- event15
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input17
| |-- capabilities
| |-- event16
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input18
| |-- capabilities
| |-- event17
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input19
| |-- capabilities
| |-- event18
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- number
|-- pcmC0D0c
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D0p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D1p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC0D2c
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- autosuspend_delay_ms
| |-- control
| |-- runtime_active_time
| |-- runtime_status
| `-- runtime_suspended_time
|-- subsystem -> ../../../../../class/sound
`-- uevent
!!Card: /sys/class/sound/card1
Tree:
|-- controlC1
| |-- dev
| |-- device -> ../../card1
| |-- power
| |-- subsystem -> ../../../../../../../class/sound
| `-- uevent
|-- device -> ../../../0000:01:00.1
|-- hwC1D0
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- id
|-- input20
| |-- capabilities
| |-- event19
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- subsystem -> ../../../../../../../class/input
| |-- uevent
| `-- uniq
|-- input21
| |-- capabilities
| |-- event20
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input22
| |-- capabilities
| |-- event21
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input23
| |-- capabilities
| |-- event22
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input24
| |-- capabilities
| |-- event23
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input25
| |-- capabilities
| |-- event24
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- input26
| |-- capabilities
| |-- event25
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- number
|-- pcmC1D10p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D11p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D12p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D3p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D7p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D8p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D9p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- control
| |-- runtime_status
`-- uevent
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC887-VD
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0887
Subsystem Id: 0x104386c7
Revision Id: 0x100302
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC887-VD Analog", type="Audio", device=0
Amp-Out caps: ofs=0x40, nsteps=0x40, stepsize=0x03, mute=0
Amp-Out vals: [0x3a 0x3a]
Converter: stream=1, channel=0
PCM:
rates [0x560]: 44100 48000 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Converter: stream=0, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x10, nsteps=0x2e, stepsize=0x03, mute=1
Amp-In vals: [0x2e 0x2e]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC887-VD Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=2, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100711: Stereo Digital
SDI-Select: 0
Digital:
PCM:
formats [0x1]: PCM
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC887-VD Digital", type="SPDIF", device=1
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x90460130: [Fixed] SPDIF Out at Int N/A
Conn = Digital, Color = Unknown
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x40330000: [N/A] CD at Ext N/A
Conn = ATAPI, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Pincap 0x0001003e: IN OUT HP EAPD Detect Trigger
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pincap 0x00000036: IN OUT Detect Trigger
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Control: name="Rear Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00003736: IN OUT Detect Trigger
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19040: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pincap 0x0000373e: IN OUT HP Detect Trigger
Pin Default 0x02a19050: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373e: IN OUT HP EAPD Detect Trigger
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4046c629: [N/A] SPDIF Out at Ext N/A
Conn = Digital, Color = UNKNOWN
DefAssociation = 0x2, Sequence = 0x9
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=24
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 12
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x40 0x40]
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
Codec: Nvidia GPU 84 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0084
Subsystem Id: 0x104385ed
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
*Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x0a* 0x0b 0x0c 0x0d
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 1, ELDV = 1, IA = 0
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=0d, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 0, ELDV = 0, IA = 0
Connection: 4
Node 0x09 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital: Enabled
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0c [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0d [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 7 Jul 8 11:56 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 16 Jul 8 11:56 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 6 Jul 8 11:56 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 15 Jul 8 11:56 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 3 Jul 8 18:19 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 2 Jul 8 12:11 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 4 Jul 8 18:08 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 5 Jul 8 18:08 /dev/snd/pcmC0D2c
crw-rw---- 1 root audio 116, 12 Jul 8 18:08 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 13 Jul 8 18:08 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 14 Jul 8 18:08 /dev/snd/pcmC1D12p
crw-rw---- 1 root audio 116, 8 Jul 8 18:08 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 9 Jul 8 18:28 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 10 Jul 8 18:08 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 11 Jul 8 18:08 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Jul 8 13:03 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jul 8 11:56 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jul 8 11:56 .
drwxr-xr-x 3 root root 400 Jul 8 11:56 ..
lrwxrwxrwx 1 root root 12 Jul 8 11:56 pci-0000:00:1f.3 -> ../controlC0
lrwxrwxrwx 1 root root 12 Jul 8 11:56 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC887-VD Analog [ALC887-VD Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC887-VD Digital [ALC887-VD Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0xf7220000 irq 128'
Mixer name : 'Realtek ALC887-VD'
Components : 'HDA:10ec0887,104386c7,00100302'
Controls : 47
Simple ctrls : 23
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 58 [91%] [-6.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Front Left: Playback 0 [0%] [-64.00dB] [off]
Front Right: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'Center',0
Mono: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 46 [100%] [30.00dB] [on]
Front Right: Capture 46 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Channel Mode',0
Capabilities: enum
Items: '2ch' '4ch' '6ch'
Item0: '2ch'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 0 [0%] [-30.00dB]
Front Right: Capture 0 [0%] [-30.00dB]
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card NVidia
Card sysdefault:1 'NVidia'/'HDA NVidia at 0xf7080000 irq 17'
Mixer name : 'Nvidia GPU 84 HDMI/DP'
Components : 'HDA:10de0084,104385ed,00100100'
Controls : 49
Simple ctrls : 7
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
Simple mixer control 'IEC958',6
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Channel Mode'
value '2ch'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2ch'
item.1 '4ch'
item.2 '6ch'
control.2 {
iface MIXER
name 'Front Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.3 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.4 {
iface MIXER
name 'Surround Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -6400
dbvalue.1 -6400
control.5 {
iface MIXER
name 'Surround Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.6 {
iface MIXER
name 'Center Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -6400
control.7 {
iface MIXER
name 'LFE Playback Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -6400
control.8 {
iface MIXER
name 'Center Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'LFE Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.10 {
iface MIXER
name 'Headphone Playback Volume'
value.0 64
value.1 64
comment {
access 'read write'
type INTEGER
count 2
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.12 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.13 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.14 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.15 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.16 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.17 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.18 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.19 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.20 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.22 {
iface MIXER
name 'Capture Volume'
value.0 46
value.1 46
comment {
access 'read write'
type INTEGER
count 2
range '0 - 46'
dbmin -1600
dbmax 3000
dbvalue.0 3000
dbvalue.1 3000
control.23 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.24 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 46'
dbmin -1600
dbmax 3000
dbvalue.0 -1600
dbvalue.1 -1600
control.25 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.26 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.27 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.29 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.31 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.32 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.34 {
iface MIXER
name 'Master Playback Volume'
value 58
comment {
access 'read write'
type INTEGER
count 1
range '0 - 64'
dbmin -6400
dbmax 0
dbvalue.0 -600
control.35 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface CARD
name 'Front Mic Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'Line Out Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'Front Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.42 {
iface PCM
name 'Playback Channel Map'
value.0 3
value.1 4
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.43 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.44 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.46 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.47 {
iface MIXER
name 'Digital Capture Volume'
value.0 0
value.1 0
comment {
type INTEGER
count 2
range '0 - 120'
tlv '0000000100000008fffff44800000032'
dbmin -3000
dbmax 3000
dbvalue.0 -3000
dbvalue.1 -3000
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value '100009006d2200010002000000000000410ca7c050484c203232315445350a20200907031507500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
type BYTES
count 95
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=12 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
aesni_intel
agpgart
asus_wmi
cdrom
cec
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ee1004
eeepc_wmi
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
i2c_i801
i2c_smbus
intel_cstate
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libphy
lzo_rle
mac_hid
mbcache
mdio_devres
mei
mei_hdcp
mei_me
mousedev
mxm_wmi
nvidia
nvidia_drm
nvidia_modeset
nvidia_uvm
pcspkr
r8169
rapl
realtek
rfkill
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
sr_mod
syscopyarea
sysfillrect
sysimgblt
uinput
usb_storage
usbhid
vboxdrv
vboxnetadp
vboxnetflt
vfat
video
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
zram
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x90460130
0x12 0x40330000
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19040
0x19 0x02a19050
0x1a 0x0181304f
0x1b 0x02214020
0x1c 0x411111f0
0x1d 0x4046c629
0x1e 0x411111f0
0x1f 0x411111f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
0x08 0x585600f0
0x09 0x585600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 0.139049] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.139049] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.139049] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 2.826364] zram: Added device: zram0
[ 2.877159] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 2.882429] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.882443] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.882765] zram0: detected capacity change from 0 to 8589934592
[ 2.912584] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 2.912586] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.912588] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 2.912588] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 2.912589] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x0
[ 2.912590] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 2.912591] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 2.912592] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 2.912593] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 2.925814] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 2.925840] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 2.925864] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 2.925887] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 2.925909] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 2.950927] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[ 2.951037] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
[ 2.951127] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
[ 2.951221] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input23
[ 2.951305] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input24
[ 2.951398] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input25
[ 2.951491] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input26
[ 3.017303] intel_rapl_common: Found RAPL domain package
[ 6.851797] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
[ 8.998909] snd_hda_intel 0000:01:00.1: IRQ timing workaround is activated for card #1. Suggest a bigger bdl_pos_adj.
[ 14.009999] kauditd_printk_skb: 8 callbacks suppressed
[ 924.208397] audit: type=1131 audit(1625739132.749:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2493.270943] snd_hda_intel 0000:00:1f.3: Unstable LPIB (17632 >= 4408); disabling LPIB delay counting
[ 4040.533353] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
