Hi,
I have a Thinkpad T495 and everything works fine, except the jacks for the headset. I have tried different solutions, like blacklisting kernel modules and hdajackretask settings, but the headset is only detected as output, not as input. The interesting part is, that neither the jack of the laptop itelf, nor the jack of the docking station work.
Here the output of inxi -Fazy
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
root=UUID=421207bf-d97c-4d5c-b2a1-f760834b91fb rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: i3 v: 4.24 with: i3bar tools: avail: i3lock,light-locker vt: 7
dm: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 20NJCTO1WW v: ThinkPad T495
Mobo: LENOVO model: 20NJCTO1WW serial: <superuser required>
part-nu: LENOVO_MT_20NJ_BU_Think_FM_ThinkPad T495 uuid: <superuser required>
Firmware: UEFI vendor: LENOVO v: R12ET49W(1.19 ) date: 01/06/2020
ID-1: BAT0 charge: 51.5 Wh (100%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.7 min: 11.55 model: LGC 02DL007 type: Li-poly serial: <filter>
charging: status: full control: start: 95% end: 100% cycles: 268
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33547
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
svm
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-4 off: eDP-1 empty: DP-1, DP-2,
DP-3, DP-5, HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:15d8 class-ID: 0300
temp: 60.0 C
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2.1:4 chip-ID: 04f2:b681
Display: x11 server: X.Org v: 21.1.18 compositor: Picom v: 12.5 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-4 mapped: DisplayPort-3 pos: primary model: Dell S2721DS
serial: <filter> built: 2021 res: mode: 2560x1440 hz: 60 scale: 100% (1)
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 676mm (26.6")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP note: disabled model: ChiMei InnoLux 0x14f2
built: 2018 res: 2560x1440 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (radeonsi
raven ACO DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:15d8 memory: 1.95 GiB
unified: no
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: TEAC TASCAM US-16x08 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4.1:9 chip-ID: 0644:8047
class-ID: 0103 serial: <filter>
Device-5: Lenovo ThinkPad Dock USB Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-4.4.4:8 chip-ID: 17ef:306f class-ID: 0300
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off with: a2jmidid status: off
tools: cadence,jack_control
Server-2: PipeWire v: 1.4.8 status: off tools: pw-cat,pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pavucontrol
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2
chip-ID: 8087:0025 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 953.87 GiB used: 630.25 GiB (66.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN720
SDAQNTW-1T00-1001 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 10160101 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 630.25 GiB (66.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 62.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 24 GiB note: est. available: 21.41 GiB used: 2.27 GiB (10.6%)
Processes: 282 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 8.55 GiB services: upowerd,xfce4-power-manager
Packages: 1873 pm: pacman pkgs: 1869 libs: 457 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 4 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash
v: 5.3.3 running-in: urxvtd inxi: 3.3.40
and pactl list default sources
Quelle #0
Status: SUSPENDED
Beschreibung: Monitor of Raven/Raven2/Fenghuang HDMI/DP Audio Controller Digital Stereo (HDMI)
Treiber: module-alsa-card.c
Abtastwert-Angabe: s32le 2ch 44100Hz
Kanalzuordnung: front-left,front-right
Besitzer-Modul: 6
Stumm: nein
Lautstärke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
Verteilung 0,00
Basis-Lautstärke: 65536 / 100% / 0,00 dB
Ziel-Monitor: alsa_output.pci-0000_06_00.1.hdmi-stereo
Latenz: 0 usec, eingestellt 0 usec
Flags: DECIBEL_VOLUME LATENCY
Eigenschaften:
device.description = "Monitor of Raven/Raven2/Fenghuang HDMI/DP Audio Controller Digital Stereo (HDMI)"
device.class = "monitor"
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xd05c8000 irq 78"
device.bus_path = "pci-0000:06:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "15de"
device.product.name = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Formate:
pcm
Quelle #1
Status: SUSPENDED
Beschreibung: Monitor of TASCAM US-16x08 Analog Surround 7.1
Abtastwert-Angabe: s24le 8ch 44100Hz
Kanalzuordnung: front-left,front-right,rear-left,rear-right,front-center,lfe,side-left,side-right
Besitzer-Modul: 7
Stumm: nein
Lautstärke: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB, rear-left: 65536 / 100% / 0,00 dB, rear-right: 65536 / 100% / 0,00 dB, front-center: 65536 / 100% / 0,00 dB, lfe: 65536 / 100% / 0,00 dB, side-left: 65536 / 100% / 0,00 dB, side-right: 65536 / 100% / 0,00 dB
Verteilung 0,00
Ziel-Monitor: alsa_output.usb-TASCAM_US-16x08_no_serial_number-00.analog-surround-71
Eigenschaften:
device.description = "Monitor of TASCAM US-16x08 Analog Surround 7.1"
alsa.card = "3"
alsa.card_name = "US-16x08"
alsa.long_card_name = "TASCAM US-16x08 at usb-0000:06:00.3-4.4.1, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:06:00.3-usb-0:4.4.1:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb1/1-4/1-4.4/1-4.4.1/1-4.4.1:1.0/sound/card3"
udev.id = "usb-TASCAM_US-16x08_no_serial_number-00"
device.bus = "usb"
device.vendor.id = "0644"
device.vendor.name = "TEAC Corp."
device.product.id = "8047"
device.product.name = "TASCAM US-16x08"
device.serial = "TASCAM_US-16x08_no_serial_number"
device.string = "3"
device.icon_name = "audio-card-usb"
Formate:
pcm
Quelle #3
Status: SUSPENDED
Beschreibung: ThinkPad Dock USB Audio Analog Stereo
Abtastwert-Angabe: s24le 2ch 44100Hz
Besitzer-Modul: 8
Stumm: nein
Lautstärke: front-left: 65535 / 100% / -0,00 dB, front-right: 65535 / 100% / -0,00 dB
Verteilung 0,00
Basis-Lautstärke: 20724 / 32% / -30,00 dB
Ziel-Monitor: k. A.
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Eigenschaften:
alsa.resolution_bits = "24"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "ThinkPad Dock USB Audio"
alsa.long_card_name = "Generic ThinkPad Dock USB Audio at usb-0000:06:00.3-4.4.4, high speed"
device.bus_path = "pci-0000:06:00.3-usb-0:4.4.4:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb1/1-4/1-4.4/1-4.4.4/1-4.4.4:1.0/sound/card2"
udev.id = "usb-Generic_ThinkPad_Dock_USB_Audio-00"
device.bus = "usb"
device.vendor.id = "17ef"
device.vendor.name = "Lenovo"
device.product.id = "306f"
device.product.name = "ThinkPad Dock USB Audio"
device.serial = "Generic_ThinkPad_Dock_USB_Audio"
device.string = "front:2"
device.buffering.buffer_size = "529200"
device.buffering.fragment_size = "264600"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "ThinkPad Dock USB Audio Analog Stereo"
Ports:
analog-input-mic: Mikrofon (Typ: Mikro, Priorität: 8700, Verfügbarkeit unbekannt)
Aktiver Port: analog-input-mic
Formate:
pcm
Quelle #4
Status: SUSPENDED
Beschreibung: Monitor of Family 17h/19h/1ah HD Audio Controller Analog Stereo
Besitzer-Modul: 9
Stumm: nein
Verteilung 0,00
Ziel-Monitor: alsa_output.pci-0000_06_00.6.analog-stereo
Eigenschaften:
device.description = "Monitor of Family 17h/19h/1ah HD Audio Controller Analog Stereo"
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xd05c0000 irq 79"
device.bus_path = "pci-0000:06:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h/19h/1ah HD Audio Controller"
device.string = "1"
Formate:
pcm
Quelle #5
Status: SUSPENDED
Beschreibung: Family 17h/19h/1ah HD Audio Controller Analog Stereo
Besitzer-Modul: 9
Stumm: nein
Lautstärke: front-left: 20726 / 32% / -30,00 dB, front-right: 20726 / 32% / -30,00 dB
Verteilung 0,00
Basis-Lautstärke: 6554 / 10% / -60,00 dB
Ziel-Monitor: k. A.
Eigenschaften:
alsa.resolution_bits = "32"
device.api = "alsa"
alsa.name = "ALC257 Analog"
alsa.id = "ALC257 Analog"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "front:1"
device.buffering.buffer_size = "1411328"
device.buffering.fragment_size = "705664"
device.description = "Family 17h/19h/1ah HD Audio Controller Analog Stereo"
Ports:
analog-input-internal-mic: Internes Mikrofon (Typ: Mikro, Priorität: 8900, Verfügbarkeit unbekannt)
analog-input-mic: Mikrofon (Typ: Mikro, Priorität: 8700, nicht verfügbar)
Formate:
pcm
Let me know if you need any further information.
Edit
Another weird thing is, that if I choose Microphone (unplugged) in pavucontrol, it still displays the capture of the internal mic. I was able to change this behaviour by using hdajackretask, but then the mic is always shown as plugged and there is no sound captured at all.
