L1can
December 5, 2021, 8:11pm
#1
Hi, can someone help me with this problem plis?
I’ve search in many other articles for a solution but nothing work on me.
inxi:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=1ffa5052-01a5-4bd0-b53f-0e9ceec1f4ed rw quiet splash apparmor=1
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 81NB v: Lenovo IdeaPad S340-14API
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad S340-14API
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter>
UEFI: LENOVO v: AMCN26WW(V1.09) date: 11/15/2019
ID-1: BAT1 charge: 50.4 Wh (95.1%) condition: 53.0/52.5 Wh (101.0%)
volts: 12.9 min: 11.3 model: 0x4C 0x47 0x43 0x00 0x32 0x30 0x 0x4C 0x31
0x38 0x4C 0x33 0x50 0x5250
type: Li-ion serial: <filter> status: Charging cycles: 600
Info: Dual Core model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L2: 1024 KiB
bogomips: 20770
Speed: 2312 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz):
1: 2312 2: 2712 3: 1316 4: 1485
disabled, RSB filling
Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-4:2 chip-ID: 13d3:56b2 class-ID: 0e02
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.41.0
5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
chip-ID: 0cf3:e500 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 37.51 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: GPT
ID-1: / raw-size: 126.95 GiB size: 124.4 GiB (97.99%)
used: 37.48 GiB (30.1%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 90.1 C mobo: N/A gpu: amdgpu temp: 90.0 C
Processes: 276 Uptime: 4h 19m wakeups: 5 Memory: 9.66 GiB
used: 8.4 GiB (86.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1175 pacman: 1167 lib: 297 flatpak: 0 snap: 8
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.08
L1can
December 5, 2021, 8:19pm
#3
arecord:
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: ALC257 Analog [ALC257 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
pacmd list-cards
2 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xc07c8000 irq 45"
device.bus_path = "pci-0000:03:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:03:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "15de"
device.product.name = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
device.string = "0"
device.description = "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xc07c0000 irq 46"
device.bus_path = "pci-0000:03:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:03:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller"
device.string = "1"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_03_00.6.analog-stereo/#0: Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo
sources:
alsa_output.pci-0000_03_00.6.analog-stereo.monitor/#0: Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo
alsa_input.pci-0000_03_00.6.analog-stereo/#1: Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
Welcome to the forum!
Please edit your topic title without purposely spelling it wrong to avoid a title that has already been used.
L1can:
many other articles
What articles?
L1can:
nothing work on for me
What didn’t work? What did you try?
L1can:
plis
What?
Please see How to Post
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button–NOT the Quote " button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
Please edit your posts accordingly.
EDIT: I’ve fixed the formatting for you this time since you have not returned in a timely manner.
You should consider updating system BIOS
laptops and netbooks :: ideapad s series netbooks :: s340 14api - Lenovo Support DE
Kernel v5.13 has been marked End Of Life in update announcements for some time and will likely be dropped completely from Manjaro soon
Kernel v5.14.21-2 has been marked End Of Life in Testing branch and will be marked similar when it lands in Stable branch
I suggest you install kernel v5.15 using Manjaro Settings Manager GUI
( manjaro-settings-manager -m msm_kernel
OR use these terminal commands to install new kernel and remove old one
sudo mhwd-kernel --install linux515
sudo mhwd-kernel --remove linux513
If system is using new kernel version and internal microphone is not working as expected, please post more information about ALSA audio devices
sudo alsa-info.sh --upload
