My microphone connecting through jack is not detected by Manjaro. I am trying to connect a microphone with my laptop, but the laptop does not recognize it. When I go to setting > sound > output, there was only one option, microphone built-in audio. There was no sound recognize in the system.
I tried switching my microphone from pluging into my laptop directly to plug into my headset jack port. This did not solve the problem. Moreover, the laptop cut the bluetooth headset connection off. I tried to use the built-in microphone from my headset before, but my laptop did not recognize it as a headset. It only allow my headset to connect as a headphone. Once I talked out loud whether with other people around me or testing the headset microphone, the sound connection was cut to silent.
The built-in microphone of my headset works because I tested it with other devices: phone and ipad, but not linux.
I used to connect my wired headset with an extended microphone to the mouth and it worked just fine. I switch to the bluetooth one because it has some superior function(s) over the wired one and also because the wired one is really old and a bit torn.
The bluetooth headset device: Sony WH-1000XM4
The wired headset device: Razor Gaming Headset (from 2015 if I am not mistaken, not the newest one in the market)
The laptop: Acer E5-473G
Here is the result of pacmd list-cards
pacmd list-cards ✔
3 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.card_name = "HDA Intel HDMI"
alsa.long_card_name = "HDA Intel HDMI at 0xc4510000 irq 53"
device.bus_path = "pci-0000:00:03.0"
sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "160c"
device.product.name = "Broadwell-U Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <off>
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "1"
alsa.long_card_name = "HDA Intel PCH at 0xc4514000 irq 51"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
device.bus = "pci"
device.product.id = "9ca0"
device.product.name = "Wildcat Point-LP High Definition Audio Controller"
device.string = "1"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
index: 5
driver: <module-bluez5-device.c>
owner module: 32
properties:
device.description = "WH-1000XM4"
device.string = "94:DB:56:D5:1A:13"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_94_DB_56_D5_1A_13"
bluez.class = "0x240404"
bluez.alias = "WH-1000XM4"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
bluetooth.codec = "sbc"
profiles:
headset_head_unit: Headset Head Unit (HSP) (priority 30, available: no)
a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 40, available: yes)
handsfree_head_unit: Handsfree Head Unit (HFP) (priority 30, available: unknown)
off: Off (priority 0, available: yes)
active profile: <a2dp_sink>
sinks:
bluez_sink.94_DB_56_D5_1A_13.a2dp_sink/#6: WH-1000XM4
sources:
bluez_sink.94_DB_56_D5_1A_13.a2dp_sink.monitor/#9: Monitor of WH-1000XM4
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: yes)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
