When I use the discord app, my voice volume goes up and down while I’m talking, even with me trying to maintain the same voice volume.
I recorded one gif to show you guys what I’m talking about, but for some reason I can’t include links in the post. The mic test keeps going to low when I’m pronouncing “aaaaaaaaaa” more constant as I can.
I recorded some test audios using Audacity, here my voice volume stayed stable and audible.
I installed* the Discord from official repositories, from snap store and from flat hub (each version at a time and restarting the computer). All had the same symptom (my voice going low and high while I talked).
I tried all recommendations in the Microphone section from Archlinux’s PulseAudio/TroubleShooting wiki page. Unfortunately, unsuccessfully.
Lastly, I opened the web version of Discord in Firefox, (guess what), the input sensitivity worked as expected here.
You guys have any idea of what is causing this?
I use Discord both for gaming and work purposes, it’s an essential tool for me. Any help will be appreciated.
The post is vague because I wasn’t able to include some images and gifs that makes the problem more evident.
@mueen I wasn’t able to get another voice output at constant level through Firefox . I think I got a constant voice level just once and maybe because my record was just too short.
Anyway, I made the following tests:
I made some more tries with Discord web app and ,in all of them, I had this the same problem where my voice keeps going high and low (like in the Discord app);
I defined “pulse” as record device in Audacity’s settings and changed the Audacity from option in the “Recording” of the “PulseAudio Volume Control” to the one the monitors my input device (mic), this enables me to record the PC’s output audio in Audacity.* Then, I used that to record Discord’s “mic test” audio of the native version and the web one. Here is the result* (I suggest checking if your volume is low ).
I uploaded 3 tracks: 1 - mic capture, 2 - mic from discord native app, 3 - mic from discord web app.
I booted in Kubuntu using a Live Media to run Discord in another environment. Here I get the same weird behavior in both native or web version of Discord.
Said that, I think having the same behavior with Discord in another distro (that also has KDE as DE) could mean some bug with the KDE libraries? Or maybe the last releases of Linux kernel is causing these issues with Discord?
* Paste only the url after “…org/”
I will make more tests. I will run Discord on GNOME DE (Pop!OS) to see what happens.
I booted into Pop!OS (GNOME Desktop Environment) and I got the same problem of my voice going up and down using Discord.
I tried others voice apps (Jitsi, Skype and Matrix) and all of them captured my voice normally. So, I think this must be a problem in the Discord application itself.
I will open a ticket on the Discord support and post the outcomes here.
Having a similar issue with Discord on my Garuda Linux install as well, so I’m pretty sure this isn’t a distribution bug. In addition to the Discord mic fluctuation, my microphone just sounded very terrible in general (and it wasn’t the case when I was just using Audacity to test my microphone). However, I have tried Discord on other operating systems such as Windows, and my microphone seemed to work fine there.
I’m awaiting your response from the Discord support ticket.
Hello there, regarding the Discord microphone fluctuation issue, this issue no longer appears when using a separate Discord client for Linux.
Search on pacman for LightCord, which is basically a customizable Discord client that is open-source and has support for BetterDiscord features as well. The issue disappeared after I switched from the default Discord client to LightCord.
Try it out and see if this fixes your issue. If you’re wondering if LightCord is fundamentally different in layout from the default Discord client, no, the layout is entirely the same.
