My mic in manjaro kde is picking up audio output from my speaker making it unusable without headphones. It forms a feedback loop with “parec | pacat” manking it louder at every iteration. I don’t know what information to provide. Pls help.
Edit: I’ve come to undersstand the term for it is echo cancellation but don’t know how to impement it.
Paste the output of inxi -Fazy and pa-info
inxi -Fazy
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b27e58e4-ed4d-4f5a-9c12-979d6d24f726 rw apparmor=1
bootsplash.bootfile=/bootsplash-themes/manjaro-glitch/bootsplash
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DY_FX505DY v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505DY v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DY.315 date: 03/09/2020
ID-1: BAT0 charge: 37.4 Wh (100.0%) condition: 37.4/48.0 Wh (77.9%)
volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2651 high: 3263 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2303 2: 2085
3: 2790 4: 3263 5: 2590 6: 3246 7: 2710 8: 2225 bogomips: 33548
disabled, RSB filling
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0380
Device-2: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.10.89-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: e000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3530 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 415.76 GiB (44.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 0J scheme: GPT
ID-1: / raw-size: 58.39 GiB size: 57.35 GiB (98.22%) used: 25.44 GiB (44.4%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 25.6 MiB (10.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 133.01 GiB size: 129.92 GiB (97.68%)
used: 96.18 GiB (74.0%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 47.2 C mobo: 47.0 C
Fan Speeds (RPM): cpu: 3400
GPU: device: amdgpu temp: 42.0 C watts: 10.25 device: amdgpu temp: 47.0 C
Processes: 301 Uptime: 5h 2m wakeups: 2 Memory: 7.52 GiB
used: 2.61 GiB (34.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1655 pacman: 1644 lib: 447 snap: 11
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
pa-info
> pulseaudio_ps_do
dave 2549 0.3 0.2 2221772 17892 ? S<sl 10:35 0:59 /usr/bin/pulseaudio --daemonize=no --log-target=journal
root 8574 0.0 0.0 3256 1568 pts/2 S+ 15:34 0:00 grep pulseaudio
> which pulseaudio
/usr/bin/pulseaudio
> pidof pulseaudio
2549
> pulseaudio --version
pulseaudio 15.0
> pactl info
> pactl list
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
### Allow including a default.pa.d directory, which if present, can be used
### for additional configuration snippets.
.nofail
.include /etc/pulse/default.pa.d
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
### Allow including a system.pa.d directory, which if present, can be used
.nofail
.include /etc/pulse/system.pa.d
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 6 Jan 15 15:19 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116, 5 Jan 15 15:19 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116, 2 Jan 15 10:35 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116, 8 Jan 15 10:27 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 7 Jan 15 10:27 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 4 Jan 15 10:27 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 3 Jan 15 10:27 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 33 Jan 15 10:27 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Jan 15 10:27 /dev/snd/seq
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Jan 15 10:27 .
lrwxrwxrwx 1 root root 12 Jan 15 10:27 pci-0000:04:00.6 -> ../controlC1
drwxr-xr-x 3 root root 240 Jan 15 10:27 ..
lrwxrwxrwx 1 root root 12 Jan 15 10:27 pci-0000:04:00.1 -> ../controlC0
> lsof /dev/snd/*
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pulseaudi 2549 dave mem CHR 116,6 807 /dev/snd/pcmC1D0c
pulseaudi 2549 dave mem CHR 116,5 806 /dev/snd/pcmC1D0p
pulseaudi 2549 dave 16u CHR 116,8 0t0 810 /dev/snd/controlC1
pulseaudi 2549 dave 18u CHR 116,4 0t0 754 /dev/snd/controlC0
pulseaudi 2549 dave 29u CHR 116,8 0t0 810 /dev/snd/controlC1
pulseaudi 2549 dave 36u CHR 116,8 0t0 810 /dev/snd/controlC1
pulseaudi 2549 dave 41u CHR 116,8 0t0 810 /dev/snd/controlC1
pulseaudi 2549 dave 44u CHR 116,5 0t0 806 /dev/snd/pcmC1D0p
pulseaudi 2549 dave 58u CHR 116,6 0t0 807 /dev/snd/pcmC1D0c
> jacks_do
card=0
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
; type=BOOLEAN,access=r-------,values=1
: values=off
card=1
numid=15,iface=CARD,name='Headphone Jack'
: values=off
numid=13,iface=CARD,name='Headset Mic Phantom Jack'
: values=on
numid=14,iface=CARD,name='Internal Mic Phantom Jack'
: values=on
numid=16,iface=CARD,name='Speaker Phantom Jack'
: values=on
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Generic_1
HD-Audio Generic, ALC256 Analog
Default Audio Device
front:CARD=Generic_1,DEV=0
Front output / input
surround21:CARD=Generic_1,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
HD-Audio Generic
USB Stream Output
HD-Audio Generic
USB Stream Output
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.5.1
!!Script ran on: Sat Jan 15 10:04:17 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: TUF Gaming FX505DY_FX505DY
Product Version: 1.0
Firmware Version: FX505DY.315
System SKU:
Board Vendor: ASUSTeK COMPUTER INC.
Board Name: FX505DY
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0010:01/status 15
/sys/bus/acpi/devices/AMDI0030:00/status 15
/sys/bus/acpi/devices/ASUS1000:00/status 15
/sys/bus/acpi/devices/ATK3001:00/status 15
/sys/bus/acpi/devices/ATK4002:00/status 15
/sys/bus/acpi/devices/ELAN1200:00/status 15
/sys/bus/acpi/devices/LNXVIDEO:01/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0A08:00/status 15
/sys/bus/acpi/devices/PNP0C01:00/status 15
/sys/bus/acpi/devices/PNP0C02:01/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 11
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 11
/sys/bus/acpi/devices/PNP0C0F:01/status 11
/sys/bus/acpi/devices/PNP0C0F:02/status 11
/sys/bus/acpi/devices/PNP0C0F:03/status 11
/sys/bus/acpi/devices/PNP0C0F:04/status 11
/sys/bus/acpi/devices/PNP0C0F:05/status 11
/sys/bus/acpi/devices/PNP0C0F:06/status 11
/sys/bus/acpi/devices/PNP0C0F:07/status 11
/sys/bus/acpi/devices/device:15/status 15
/sys/bus/acpi/devices/device:16/status 11
!!Kernel Information
Kernel release: 5.10.89-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.10.89-1-MANJARO
Library version: 1.2.6.1
Utilities version: 1.2.6
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [Generic ]: HDA-Intel - HD-Audio Generic
HD-Audio Generic at 0xfe688000 irq 60
1 [Generic_1 ]: HDA-Intel - HD-Audio Generic
HD-Audio Generic at 0xfe680000 irq 61
!!PCI Soundcards installed in the system
04:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller [1002:15de]
Subsystem: ASUSTeK Computer Inc. Device [1043:17c1]
04:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
|-- controlC0
| |-- dev
| |-- device -> ../../card0
| |-- power
| |-- subsystem -> ../../../../../../../class/sound
| `-- uevent
|-- device -> ../../../0000:04:00.1
|-- hwC0D0
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- driver_pin_configs
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- id
|-- input20
| |-- capabilities
| |-- event13
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- subsystem -> ../../../../../../../class/input
| |-- uevent
| `-- uniq
|-- number
|-- pcmC0D3p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- autosuspend_delay_ms
| |-- control
| |-- runtime_active_time
| |-- runtime_status
| `-- runtime_suspended_time
|-- subsystem -> ../../../../../../class/sound
`-- uevent
!!Card: /sys/class/sound/card1
Tree:
|-- controlC1
| |-- dev
| |-- device -> ../../card1
| |-- power
| `-- uevent
|-- device -> ../../../0000:04:00.6
|-- hwC1D0
| |-- afg
| |-- chip_name
| |-- clear
| |-- dev
| |-- hints
| |-- init_pin_configs
| |-- init_verbs
| |-- mfg
| |-- modelname
| |-- power
| |-- power_off_acct
| |-- power_on_acct
| |-- reconfig
| |-- revision_id
| |-- subsystem_id
| |-- uevent
| |-- user_pin_configs
| |-- vendor_id
| `-- vendor_name
|-- id
|-- input24
| |-- capabilities
| |-- event15
| |-- id
| |-- modalias
| |-- name
| |-- phys
| |-- power
| |-- properties
| |-- uevent
| `-- uniq
|-- number
|-- pcmC1D0c
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- pcmC1D0p
| |-- dev
| |-- pcm_class
| |-- power
| `-- uevent
|-- power
| |-- control
| |-- runtime_status
`-- uevent
!!HDA-Intel Codec information
--startcollapse--
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100700
No Modem Function Group found
Default PCM:
rates [0x70]: 32000 44100 48000
bits [0x2]: 16
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Pincap 0x00000094: OUT Detect HDMI
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=00, enabled=0
Connection: 1
0x02
Node 0x04 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x05 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x40: OUT
Connection: 1
0x04
Node 0x06 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x07 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x08 [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x09 [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x08
Node 0x0a [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0b [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0a
Node 0x0c [Audio Output] wcaps 0x221: Stereo Digital Stripe
Digital:
Node 0x0d [Pin Complex] wcaps 0x400381: Stereo Digital
Pin-ctls: 0x40: OUT
Connection: 1
0x0c
Codec: Realtek ALC256
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0256
Subsystem Id: 0x104317c1
Revision Id: 0x100002
Default PCM:
rates [0x560]: 44100 48000 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=3, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x57 0x57]
Converter: stream=5, channel=0
PCM:
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Device: name="ALC256 Analog", type="Audio", device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x97 0x97]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0x3c 0x3c]
Converter: stream=1, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0d [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00000020: IN
Pin Default 0x90a60130: [Fixed] Mic at Int N/A
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010014: OUT EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x02
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN VREF_HIZ
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Headset Mic Boost Volume", index=0, device=0
Misc = NO_PRESENCE
Pin-ctls: 0x24: IN VREF_80
Node 0x1a [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x00013734: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x02* 0x03
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40679a2d: [N/A] Modem Line at Ext N/A
Conn = Analog, Color = Pink
DefAssociation = 0x2, Sequence = 0xd
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=91
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x03211020: [Jack] HP Out at Ext Left
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x02 0x03*
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 5
0x18 0x19 0x1a 0x1b 0x1d
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x00 0x00]
Connection: 6
0x18 0x19 0x1a 0x1b 0x1d 0x12
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 2
0x12* 0x13
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 0: ALC256 Analog [ALC256 Analog]
Subdevices: 0/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 0/1
!!Amixer output
!!-------Mixer controls for card Generic
Card sysdefault:0 'Generic'/'HD-Audio Generic at 0xfe688000 irq 60'
Mixer name : 'ATI R6xx HDMI'
Components : 'HDA:1002aa01,00aa0100,00100700'
Controls : 8
Simple ctrls : 2
Simple mixer control 'PCM',0
Capabilities: pvolume
Limits: Playback 0 - 255
Mono:
Front Left: Playback 254 [100%] [-0.20dB]
Front Right: Playback 254 [100%] [-0.20dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
!!-------Mixer controls for card Generic_1
Card sysdefault:1 'Generic_1'/'HD-Audio Generic at 0xfe680000 irq 61'
Mixer name : 'Realtek ALC256'
Components : 'HDA:10ec0256,104317c1,00100002'
Controls : 19
Simple ctrls : 10
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [off]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [off]
Front Right: Playback 87 [100%] [0.00dB] [off]
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 60 [95%] [27.75dB] [on]
Front Right: Capture 60 [95%] [27.75dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Headset Mic',0
Capabilities: cswitch cswitch-joined cswitch-exclusive
Capture exclusive group: 0
Capture channels: Mono
Mono: Capture [off]
Simple mixer control 'Headset Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Internal Mic',0
Mono: Capture [on]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
!!Alsactl output
--startcollapse--
state.Generic {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.8 {
iface MIXER
name 'PCM Playback Volume'
value.0 254
value.1 254
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 -20
dbvalue.1 -20
state.Generic_1 {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Auto-Mute Mode'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Capture Source'
value 'Internal Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Headset Mic'
item.1 'Internal Mic'
control.7 {
iface MIXER
name 'Capture Volume'
value.0 60
value.1 60
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 2775
dbvalue.1 2775
control.8 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.9 {
iface MIXER
name 'Headset Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.11 {
iface MIXER
name 'Master Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.12 {
iface MIXER
name 'Master Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.13 {
iface CARD
name 'Headset Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.15 {
iface CARD
name 'Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.16 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.17 {
iface PCM
value.0 3
value.1 4
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.18 {
iface PCM
name 'Capture Channel Map'
value.0 3
value.1 4
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.19 {
iface MIXER
value.0 255
value.1 255
comment {
type INTEGER
count 2
range '0 - 255'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_call
acpi_cpufreq
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
amdgpu
asus_nb_wmi
asus_wireless
asus_wmi
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
ccp
cec
cfg80211
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
edac_mce_amd
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
gpu_sched
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_piix4
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libarc4
libphy
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mousedev
ns
pcspkr
pinctrl_amd
qrtr
r8169
rapl
realtek
rfcomm
rfkill
rng_core
rtw88_8821c
rtw88_8821ce
rtw88_core
rtw88_pci
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_core
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sp5100_tco
sparse_keymap
squashfs
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
uinput
usbhid
uvcvideo
vboxdrv
vboxnetadp
vboxnetflt
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wacom
wmi
wmi_bmof
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x03 0x185600f0
0x05 0x585600f0
0x07 0x585600f0
0x09 0x585600f0
0x0b 0x585600f0
0x0d 0x585600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x90a60130
0x13 0x40000000
0x14 0x90170110
0x18 0x411111f0
0x19 0x411111f0
0x1a 0x411111f0
0x1b 0x411111f0
0x1d 0x40679a2d
0x1e 0x411111f0
0x21 0x03211020
/sys/class/sound/hwC1D0/driver_pin_configs:
0x19 0x04a11120
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
