Hi everybody, I hope someone can help me.
I have installed Manjaro Gnome for the first time on a new laptop: a ThinkPad x1 Carbon gen 8.
Everything worked fine apart from the microphone.
I tried to look around for some hint but nothing I tried worked.
Here is the output of a couple of commands that in general al useful for understanding the problem, I hope this can help you in helping me!
Thank you very much in advance!!
[user ~]$ pacmd list-sinks
2 sink(s) available.
index: 0
name: <alsa_output.usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00.analog-stereo>
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9049
volume: front-left: 50217 / 77% / -6,94 dB, front-right: 50217 / 77% / -6,94 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "ThinkPad USB-C Dock Gen2 USB Au"
alsa.long_card_name = "Lenovo ThinkPad USB-C Dock Gen2 USB Au at usb-0000:00:14.0-2.3.3.2, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:2.3.3.2:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.3/1-2.3.3/1-2.3.3.2/1-2.3.3.2:1.0/sound/card1"
udev.id = "usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00"
device.bus = "usb"
device.vendor.id = "17ef"
device.vendor.name = "Lenovo"
device.product.id = "a396"
device.product.name = "ThinkPad USB-C Dock Gen2 USB Audio"
device.serial = "Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000"
device.string = "front:1"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "ThinkPad USB-C Dock Gen2 USB Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output>
* index: 1
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 9039
volume: front-left: 41944 / 64% / -11,63 dB, front-right: 41944 / 64% / -11,63 dB
balance 0,00
volume steps: 65537
muted: no
current latency: 1249,93 ms
max request: 375 KiB
max rewind: 375 KiB
monitor source: 3
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 0
configured latency: 2000,00 ms; range is 0,50 .. 2000,00 ms
card: 1 <alsa_card.pci-0000_00_1f.3>
module: 25
properties:
device.api = "alsa"
alsa.name = "ALC285 Analog"
alsa.id = "ALC285 Analog"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xea23c000 irq 170"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "02c8"
device.product.name = "Comet Lake PCH-LP cAVS"
device.string = "front:0"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.description = "Built-in Audio Analog Stereo"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
[user ~]$
[user ~]$ pacmd list-cards
2 card(s) available.
index: 0
owner module: 7
properties:
alsa.card = "1"
device.bus = "usb"
device.string = "1"
device.description = "ThinkPad USB-C Dock Gen2 USB Audio"
profiles:
input:mono-fallback: Mono Input (priority 1, available: unknown)
input:multichannel-input: Multichannel Input (priority 1, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:mono-fallback: Analog Stereo Output + Mono Input (priority 6501, available: unknown)
output:analog-stereo+input:multichannel-input: Analog Stereo Output + Multichannel Input (priority 6501, available: unknown)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:mono-fallback: Digital Stereo (IEC958) Output + Mono Input (priority 5501, available: unknown)
output:iec958-stereo+input:multichannel-input: Digital Stereo (IEC958) Output + Multichannel Input (priority 5501, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:mono-fallback>
sinks:
alsa_output.usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00.analog-stereo/#0: ThinkPad USB-C Dock Gen2 USB Audio Analog Stereo
sources:
alsa_output.usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00.analog-stereo.monitor/#1: Monitor of ThinkPad USB-C Dock Gen2 USB Audio Analog Stereo
alsa_input.usb-Lenovo_ThinkPad_USB-C_Dock_Gen2_USB_Audio_000000000000-00.mono-fallback/#2: ThinkPad USB-C Dock Gen2 USB Audio Mono
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
properties:
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
index: 1
owner module: 25
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: no)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (priority 1300, available: unknown)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: unknown)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: no)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#3: Monitor of Built-in Audio Analog Stereo
ports:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
properties:
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
[user ~]$
