When I use zoom based platforms in chromium based browsers(tried brave and chromium), the browser is unable to access the mic(although Ive allowed mic access). It only works on firefox
Audio: Device-1: Intel Broadwell-U Audio driver: snd_hda_intel Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes Sound Server-2: PulseAudio v: 14.2 running: yes
I still am unable to understand why this happens.
Updated system info:
Kernel: 5.14.0-0-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=3b7d0413-1493-41a5-b67f-7bb126c76634 rw apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Hewlett-Packard product: HP Notebook
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 80C2 v: 96.02 serial: <filter> UEFI: Insyde
v: F.02 date: 03/24/2015
ID-1: BAT1 charge: 22.5 Wh (73.3%) condition: 30.7/41.4 Wh (74.0%)
volts: 15.6 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
L2: 3 MiB
bogomips: 17567
Speed: 798 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 798 2: 2354
3: 2195 4: 1527
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
driver: radeon v: kernel alternate: amdgpu bus-ID: 03:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 04f2:b509 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.14.0-0-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma port: 3000 bus-ID: 04:00.0 chip-ID: 14e4:4365
class-ID: 0280
IF: wlp4s0 state: dormant mac: <filter>
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 931.51 GiB used: 27.88 GiB (3.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 105.5 GiB size: 103.71 GiB (98.30%)
used: 27.41 GiB (26.4%) fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 104 MiB (40.6%) fs: vfat dev: /dev/sda2 maj-min: 8:2
Kernel: swappiness: 25 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2 GiB used: 373.3 MiB (18.2%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 45.5 C mobo: N/A gpu: radeon temp: 45.0 C
Processes: 212 Uptime: 3h 46m wakeups: 14 Memory: 3.75 GiB
used: 2.38 GiB (63.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1505 pacman: 1500 lib: 455 flatpak: 5
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
